[General] 800-150 Latest Exam Cost & Pdf 800-150 Files
104
General 800-150 Latest Exam Cost & Pdf 800-150 Files
Posted at 3/7/2026 13:07:44      View167 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Cisco 800-150 dumps are available on Google Drive shared by Test4Engine: https://drive.google.com/open?id=1zRq4Rph6zz8ZYC_bNqsDhrdzNGHpCHGW
Our company sells three kinds of 800-150 guide torrent online whose contents are definitely same as each other. The PDF format of 800-150 exam torrent is easy to download, prints, and browse learning, which can be printed on paper and can make notes anytime. SOFT/PC test engine of 800-150 Exam applies to Windows system computers. It can simulate the real operation test environment. App/online test engine of the 800-150 guide torrent can be used on all kinds of eletronic devices.
It is convenient for our consumers to check Cisco 800-150 exam questions free of charge before purchasing the Cisco 800-150 practice exam. Cisco is an excellent platform where you get relevant, credible, and unique Cisco 800-150 Exam Dumps designed according to the specified pattern, material, and format as suggested by the Cisco 800-150 exam.
Pdf 800-150 Files, Free 800-150 UpdatesJust like the old saying goes, motivation is what gets you started, and habit is what keeps you going. A good habit, especially a good study habit, will have an inestimable effect in help you gain the success. The 800-150 Study Materials from our company will offer the help for you to develop your good study habits. If you buy and use our study materials, you will cultivate a good habit in study.
Cisco 800-150 Exam Syllabus Topics:
  • Cisco Software: This section of the exam measures the skills of a Network Engineer and discusses Ciscos software systems and licensing. It explains the difference between IOS install and bundle modes and gives an overview of different licensing models. Students learn how to manage Cisco software images, including backing up, transferring, and installing images via FTP, TFTP, or USB. It also covers how to handle configuration files to keep devices running properly and ensure smooth upgrades or replacements.
  • Common Service Tasks and Tools: This section of the exam measures the skills of a Technical Support Engineer and focuses on tasks commonly needed to manage Cisco devices. It explains how devices boot up, introduces common Cisco IOS commands, and identifies tools for file management. It shows how to confirm physical connections, remotely access devices, and connect to the console port. It also covers how to capture the status of a device, recover passwords, and replace devices by using proper tools. Students are also taught how to find serial numbers on Cisco equipment to assist with support and maintenance activities.
  • Cisco Infrastructure and Collaboration Infrastructure: This section of the exam measures the skills of a Collaboration Engineer and focuses on Cisco infrastructure devices, endpoints, and collaboration technologies. It introduces network devices, collaboration endpoints like IP phones and video systems, and explains on-premises collaboration deployments using tools like Cisco Unified Communications Manager. It also covers how video systems integrate into collaboration environments and highlights Ciscos cloud services for enterprise communication, including Webex Meetings, Webex Teams, and hosted collaboration solutions.
Cisco Supporting Cisco Devices for Field Technicians Sample Questions (Q13-Q18):NEW QUESTION # 13
What is the primary advantage of the Cisco Intersight cloud-based approach compared to traditional on- premises management tools?
  • A. It allows management from anywhere without on-premises software
  • B. It requires less local storage
  • C. It offers better integration with non-Cisco products
  • D. It provides faster hardware upgrades
The main advantage ofCisco Intersightis itscloud-based architecture, which allows IT administrators to manage infrastructure from any locationwithout needing to install or maintain traditional on-premises management tools.
This provides:
* Centralized visibility and control over UCS servers and HyperFlex infrastructure
* Remote firmware upgrades and configuration
* Policy-driven automation
Unlike on-premises tools, Intersight eliminates the overhead of maintaining dedicated infrastructure for management.
Reference:Supporting Cisco Devices for Field Technicians (FLDTEC) - Cisco Licensing and Smart Licensing
NEW QUESTION # 14
How must the power to a system with dual power supplies on aCisco Nexus switch be connected?
  • A. Connect the primary power supply to the main source and the secondary to a backup generator.
  • B. Connect each power supply to a separate power source.
  • C. Connect both power supplies to a single power source.
  • D. Connect both power supplies to a power distribution unit with built-in redundancy.
In a Cisco Nexus switch withdual power supplies, the recommended method is toconnect each power supply to a separate power source(Option C). This ensures power redundancy and fault tolerance.
If one power source fails (e.g., due to a power outage or circuit failure), the switch can continue operating uninterrupted using the second power source. Connecting both to a single source (Option D) defeats the purpose of redundancy.
Reference:Supporting Cisco Devices for Field Technicians (FLDTEC) - Cisco Equipment and Related Hardware
NEW QUESTION # 15
What happens to the switch operation when a supervisor module in a Cisco Nexus switch is replaced by two supervisor modules?
  • A. The switch continues to operate without any interruption.
  • B. Only the affected line cards reset.
  • C. All modules in the switch are reset due to a stateless switchover.
  • D. The switch shuts down completely.
In Cisco Nexus switches, when transitioning from a single supervisor module to a dual supervisor configuration, the behavior depends on the redundancy mode configured.
Stateful Switchover (SSO): In configurations supporting SSO, the active and standby supervisors synchronize their state and configuration, allowing for seamless failover without resetting other modules.
Stateless Switchover (Warm Standby): In certain modes, such as the ACI-mode on Cisco Nexus 9508 switches, the standby supervisor does not maintain synchronized state information with the active supervisor. In this scenario, if a switchover occurs (e.g., due to the replacement of the active supervisor), all modules in the switch are reset because the switchover is stateless.
Therefore, when a supervisor module is replaced in a configuration that does not support stateful switchover, all modules in the switch are reset due to the stateless nature of the switchover.
NEW QUESTION # 16
Which function does the Stack Port 1 serve on a Cisco Meraki switch?
  • A. It connects to the Stack Port 2 of the previous switch in a stack configuration.
  • B. It connects to the Stack Port 2 of the next switch in a stack configuration.
  • C. It provides a dedicated uplink to the Meraki cloud for management.
  • D. It serves as a high-speed interconnect for clustered switches.
On Cisco Meraki switches, Stack Port 1 (along with Stack Port 2) is used to form a physical stacking connection between multiple switches. These stack ports are dedicated high-speed interconnects that enable multiple switches to operate as a single logical switch.
The stacking topology depends on the number of switches, but Stack Port 1 serves as one side of this high-speed inter-switch communication channel - not for management or cloud access.
NEW QUESTION # 17
What are the steps to mount a Cisco device in a rack?
  • A. Install mounting brackets.
    Ground the device.
    Mount in rack.
  • B. Install mounting brackets.
    Mount in rack.
    Ground the device.
  • C. Mount in rack.
    Ground the device.
  • D. Ground the device.
    Mount in rack.
The correct sequence for mounting a Cisco device in a rack is:
* Install mounting brackets: Attach the appropriate rack-mount brackets to the sides of the device using the screws provided. This step prepares the device for secure installation in the rack.
* Mount in rack: Carefully place the device into the rack, aligning the brackets with the rack posts, and secure it using the appropriate rack-mount screws.
* Ground the device: After the device is securely mounted, connect the grounding wire to the chassis grounding point and then to the facility ground. This step ensures safety and compliance with electrical standards.
This sequence is recommended to ensure both the physical security of the device and the safety of personnel during installation.
NEW QUESTION # 18
Are you ready to take your career to the next level with the Supporting Cisco Devices for Field Technicians (800-150)? Look no further than Test4Engine for all of your 800-150 exam needs. Our comprehensive and cost-effective solution includes regularly updated Cisco 800-150 Exam Questions, available in a convenient PDF format that can be downloaded on any device, including PC, laptop, mac, tablet, and smartphone.
Pdf 800-150 Files: https://www.test4engine.com/800-150_exam-latest-braindumps.html
