[General] Free PDF 2026 KCNA: Kubernetes and Cloud Native Associate Unparalleled Valid Exa
110
【General】 Free PDF 2026 KCNA: Kubernetes and Cloud Native Associate Unparalleled Valid Exa
Posted at 3/7/2026 15:58:12      View:137 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Linux Foundation KCNA dumps are available on Google Drive shared by Actual4dump: https://drive.google.com/open?id=1QslAKvJ6SRiolQWT8CNBizrrvOAZM1KJ
If you feel that you always suffer from procrastination and cannot make full use of your spare time, maybe our KCNA study materials can help you solve your problem. We are willing to recommend you to try the KCNA practice guide from our company. Our KCNA learning questions are in high quality and efficiency test tools for all people. You can just try our three different versions of our KCNA trainning quiz, you will find that you can study at anytime and anyplace.
The policy of "small profits "adopted by our company has enabled us to win the trust of all of our KCNA customers, because we aim to achieve win-win situation between all of our customers and our company. And that is why even though our company has become the industry leader in this field of KCNA Exam Questions for so many years and our KCNA exam materials have enjoyed such a quick sale all around the world we still keep an affordable price on our KCNA study guide for all of our customers and never want to take advantage of our famous brand.
Latest KCNA Test Camp, KCNA Reliable Guide FilesNo matter how good the product is users will encounter some difficult problems in the process of use. Our KCNA real exam materials are not exceptional also, in order to enjoy the best product experience, as long as the user is in use process found any problem, can timely feedback to us, for the first time you check our KCNA Exam Question performance, professional maintenance staff to help users solve problems. Our KCNA learning reference files have a high efficient product maintenance team, and they can send the KCNA exam questions to you in a few minutes.
Linux Foundation Kubernetes and Cloud Native Associate Sample Questions (Q183-Q188):NEW QUESTION # 183
How many different Kubernetes service types can you define?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
Kubernetes defines four primary Service types, which is why C (4) is correct. The commonly recognized Service spec.type values are:
ClusterIP: The default type. Exposes the Service on an internal virtual IP reachable only within the cluster. This supports typical east-west traffic between workloads.
NodePort: Exposes the Service on a static port on each node. Traffic to <NodeIP>:<NodePort> is forwarded to the Service endpoints. This is often used for simple external access in environments without load balancers, or as a building block for other systems.
LoadBalancer: Integrates with a cloud provider (or load balancer implementation) to provision an external load balancer and route traffic to the Service. This is common in managed Kubernetes.
ExternalName: Maps the Service name to an external DNS name via a CNAME record, allowing in-cluster clients to use a consistent Service DNS name to reach an external dependency.
Some people also talk about "Headless Services," but headless is not a separate type; it's a behavior achieved by setting clusterIP: None. Headless Services still use the Service API object but change DNS and virtual-IP behavior to return endpoint IPs directly rather than a ClusterIP. That's why the canonical count of "Service types" is four.
This question tests understanding of the Service abstraction: Service type controls how a stable service identity is exposed (internal VIP, node port, external LB, or DNS alias), while selectors/endpoints control where traffic goes (the backend Pods). Different environments will favor different types: ClusterIP for internal microservices, LoadBalancer for external exposure in cloud, NodePort for bare-metal or simple access, ExternalName for bridging to outside services.
Therefore, the verified answer is C (4).
NEW QUESTION # 184
You have a Kubernetes cluster with a HorizontalPodAutoscaler (HPA) configured for your application. The HPA is set to scale the application based on CPU utilization. The application suddenly experiences a surge in traffic, causing high CPU usage. How does the HPA respond to this scenario?
  • A. The HPA scales up the application only if CPU utilization exceeds a predefined threshold.
  • B. The HPA only scales down the application when CPU utilization drops below a certain threshold.
  • C. The HPA scales up the application by increasing the resource requests for existing Pods.
  • D. The HPA immediately scales up the application by creating new Pods.
  • E. The HPA scales up the application after a configurable delay to avoid over-provisioning.
The HPA typically has a defined threshold (e.g., 80% CPU utilization) and a scaling policy (e.g., add one Pod if CPU exceeds the threshold). The HPA won't immediately scale up upon a traffic surge; it will wait for the CPU utilization to surpass the specified threshold before triggering the scaling action.
NEW QUESTION # 185
What are the initial namespaces that Kubernetes starts with?
  • A. default, system, kube-public
  • B. default, kube-system, kube-public, kube-node-lease
  • C. kube-default, system, kube-main, kube-primary
  • D. kube-default, kube-system, kube-main, kube-node-lease
Kubernetes creates a set of namespaces by default when a cluster is initialized. The standard initial namespaces are default, kube-system, kube-public, and kube-node-lease, making A correct.
* default is the namespace where resources are created if you don't specify another namespace. Many quick-start examples deploy here, though production environments typically use dedicated namespaces per app/team.
* kube-system contains objects created and managed by Kubernetes system components (control plane add-ons, system Pods, controllers, DNS components, etc.). It's a critical namespace, and access is typically restricted.
* kube-public is readable by all users (including unauthenticated users in some configurations) and is intended for public cluster information, though it's used sparingly in many environments.
* kube-node-lease holds Lease objects used for node heartbeats. This improves scalability by reducing load on etcd compared to older heartbeat mechanisms and helps the control plane track node liveness efficiently.
The incorrect options contain non-standard namespace names like "system," "kube-main," or "kube-primary," and "kube-default" is not a real default namespace. Kubernetes' built-in namespace set is well-documented and consistent with typical cluster bootstraps.
Understanding these namespaces matters operationally: system workloads and controllers often live in kube- system, and many troubleshooting steps involve inspecting Pods and events there. Meanwhile, kube-node- lease is key to node health tracking, and default is the catch-all if you forget to specify -n.
So, the verified answer is A: default, kube-system, kube-public, kube-node-lease.
NEW QUESTION # 186
Which of the following container runtime is planned to be deprecated in Kubernetes 1.20 and high-er?
  • A. None of the options
  • B. podman
  • C. docker
  • D. containerd
  • E. cri-o
https://kubernetes.io/blog/2020/ ... ernetes-and-docker/
NEW QUESTION # 187
Which of the following will view the snapshot of previously terminated ruby container logs from Pod web-1?
  • A. kubectl logs -p -c web-1 ruby
  • B. kubectl logs -p ruby web-1
  • C. kubectl logs -p -c ruby web-1
  • D. kubectl logs -c ruby web-1
To view logs from the previously terminated instance of a container, you use kubectl logs -p. To select a specific container in a multi-container Pod, you use -c <containerName>. Combining both gives the correct command for "previous logs from the ruby container in Pod web-1," which is option A: kubectl logs -p -c ruby web-1.
The -p (or --previous) flag instructs kubectl to fetch logs for the prior container instance. This is most useful when the container has restarted due to a crash (CrashLoopBackOff) or was terminated and restarted. Without -p, kubectl logs shows logs for the currently running container instance (or the most recent if it's completed, depending on state).
Option B is close but wrong for the question: it selects
the ruby container (-c ruby) but does not request the previous instance snapshot, so it returns current logs, not the prior-terminated logs. Option C is missing the -c container selector and is also malformed: kubectl logs -p expects the Pod name (and optionally container); ruby is not a flag positionally correct here. Option D has argument order incorrect and mixes Pod and container names in the wrong places.
Operationally, this is a common Kubernetes troubleshooting workflow: if a container restarts quickly, current logs may be short or empty, and the actionable crash output is in the previous instance logs. Using kubectl logs -p often reveals stack traces, fatal errors, or misconfiguration messages. In multi-container Pods, always pair -p with -c to ensure you're looking at the right container.
Therefore, the verified correct answer is A.
NEW QUESTION # 188
The free demo KCNA practice question is available for instant download. Download the Linux Foundation KCNA exam dumps demo free of cost and explores the top features of Linux Foundation KCNA Exam Questions and if you feel that the Kubernetes and Cloud Native Associate exam questions can be helpful in KCNA exam preparation then take your buying decision.
Latest KCNA Test Camp: https://www.actual4dump.com/Linux-Foundation/KCNA-actualtests-dumps.html
You may be surprised to find that our pass rate for the KCNA learning guide is high as 98% to 100%, I like this, Linux Foundation Valid KCNA Exam Voucher Contact with our customer service staffs at any time, Once you decide to select our Latest KCNA Test Camp - Kubernetes and Cloud Native Associate prep training pdf, we will make every effort to help you pass the exam, Our test online materials for KCNA certifications have 80-95% similarity with the real test questions and answers.
Review the Software License Agreement and click Continue, The Church-Turing KCNA thesis tells us that any programming language that can implement the Lambda calculus or a Turing Machine simulator can implement any algorithm.
Kubernetes and Cloud Native Associate Latest Material Can Help You Save Much Time - Actual4dumpYou may be surprised to find that our pass rate for the KCNA learning guide is high as 98% to 100%, I like this, Contact with our customer service staffs at any time.
Once you decide to select our Kubernetes and Cloud Native Associate prep training pdf, we will make every effort to help you pass the exam, Our test online materials for KCNA certifications have 80-95% similarity with the real test questions and answers.
What's more, part of that Actual4dump KCNA dumps now are free: https://drive.google.com/open?id=1QslAKvJ6SRiolQWT8CNBizrrvOAZM1KJ
