Nutanix - The Best Latest Test NCP-CI-AWS Simulations
Posted at 3/7/2026 17:13:57
View184
Replies0
BONUS!!! Download part of Prep4King NCP-CI-AWS dumps for free: https://drive.google.com/open?id=15DBz6JD4eF6xjLugIfadvXLzn0UoHiyB
In the recent few years, Nutanix NCP-CI-AWS exam certification have caused great impact to many people. But the key question for the future is that how to pass the Nutanix NCP-CI-AWS exam more effectively. The answer of this question is to use Prep4King's Nutanix NCP-CI-AWS Exam Training materials, and with it you can pass your exams. So what are you waiting for? Go to buy Prep4King's Nutanix NCP-CI-AWS exam training materials please, and with it you can get more things what you want.
Nutanix NCP-CI-AWS Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Configuring an NC2 on AWS Environment: This section examines your proficiency in setting up cloud networking and security measures, as well as addressing connectivity issues.
| | Topic 2 | - Deploying an NC2 on AWS Environment: This portion assesses your knowledge of cloud cluster deployment, cloud provider network configuration, and your skills in addressing cluster deployment challenges.
| | Topic 3 | - Managing an NC2 on AWS Environment: This exam component tests your understanding of node and cluster management tasks, along with your ability to oversee cluster and cloud resource health.
| | Topic 4 | - Prepare the AWS cloud environment: This exam segment evaluates your ability to set up the AWS cloud environment, initiate NC2 service subscription, establish implementation criteria, and recognize networking prerequisites.
NCP-CI-AWS Pdf Pass Leader & NCP-CI-AWS Valid Braindumps PdfWe have a team of rich-experienced IT experts who written the valid Nutanix vce braindumps based on the actual questions and checked the updating of NCP-CI-AWS dumps torrent everyday to make sure the success of test preparation. Before you buy our NCP-CI-AWS Exam PDF, you can download the demo of free vce to check the accuracy.
Nutanix Certified Professional - Cloud Integration - AWS Sample Questions (Q39-Q44):NEW QUESTION # 39
An administrator has deployed NC2 on AWS. The cluster deployment completed successfully.
After deployment, the administrator created a subnet in AWS, added it as a network in Prism Element, deployed Prism Central using the newly-configured network, and registered the cloud cluster with it.
The on-premises network and AWS are connected via a Site-to-Site VPN. Cluster nodes, CVM, and Prism Central can communicate with each other, but cannot be accessed from the on-premises network.
What two issues might be the cause of this problem? (Choose two.)
- A. The AWS VPC traffic is blocked by a firewall in the on-premises network.
- B. AWS Direct Connect must be used to establish connection between AWS and on-premises
- C. The AHV firewall is blocking traffic from the on-premises network.
- D. Traffic from the on-premises network is not permitted by VM and Management security groups.
Traffic from the on-premises network is not permitted by VM and Management security groups:
Ensure that the security groups assigned to the VMs and management interfaces in AWS allow inbound traffic from the on-premises network. Without appropriate security group rules, the traffic will be blocked.
The AWS VPC traffic is blocked by a firewall in the on-premises network:
Check if the firewall on the on-premises network is configured to allow traffic from the AWS VPC. Firewalls may have restrictive rules that block incoming traffic, preventing communication.
Refer to AWS documentation on security groups and firewalls and Nutanix documentation on configuring networking for NC2 clusters.
NEW QUESTION # 40
An administrator has deployed an NC2 on AWS cluster that is running mixed workloads. Multiple SQL database are running on the NC2 cluster using a native subnet of 10.78.1.0/24.
The administrator wants to ensure only application servers from source subnet 10.79.1.0/24 that reside outside of the NC2 cluster can access the databases.
Which two actions will help the administrator most securely achieve this? (Choose two.)
To ensure that only application servers from the source subnet 10.79.1.0/24 can access the SQL databases running on the NC2 cluster in the subnet 10.78.1.0/24, the administrator can take the following actions:
Option A: Create a custom Security Group with the following rules:
Key = tag:nutanix:clusters
Key = tag:nutanix:clusters:external
and value = the clusters' UUID
and value = 10.78.1.0/24
Option D: Create a custom Security Group with the following:
Key = nutanix:clusters
Key = nutanix:clusters:external
and value = 10.79.1.0/24
These actions help create security rules that restrict access to the databases only from the specified source subnet, ensuring secure and controlled access.
Nutanix Cloud Clusters on AWS Administration
AWS Security Groups Documentation
NEW QUESTION # 41
An administrator is deploying a new NC2 cluster on AWS and needs to ensure full connectivity is established between the company's on-premises datacenter and the AWS cloud.
Which two AWS offering will satisfy this requirement? (Choose two.)
- A. AWS VPN
- B. ExpressRoute
- C. Dedicated interconnect
- D. Direct Connect
To establish full connectivity between the company's on-premises datacenter and the AWS cloud, the following AWS offerings will satisfy this requirement:
AWS VPN: This service allows you to create a secure connection between your on-premises network or other remote network and your AWS VPC using an IPsec VPN tunnel. It is suitable for low to moderate bandwidth requirements and provides secure, encrypted connections.
Direct Connect: AWS Direct Connect is a dedicated network connection from your premises to AWS. It provides a private, high-bandwidth, low-latency connection which is ideal for high-throughput applications and workloads that need consistent network performance.
AWS VPN Documentation
AWS Direct Connect Documentation
NEW QUESTION # 42
An administrator wants to route the outbound and inbound traffic from the NC2 cluster through a proxy server. Which two statements are correct about using a proxy server? (Choose two.)
- A. A proxy server is only supported with AOS 6.7.1.6 or higher versions and only with user-created VPCs.
- B. NC2 clusters using Flow Virtual Networking do not support a proxy server.
- C. The proxy configuration can be changed while tasks for adding or removing nodes are in progress.
- D. The proxy server must be configured only while creating a cluster because the proxy server settings cannot be configured after the cluster is deployed.
NEW QUESTION # 43
An administrator has noticed the company's NC2 free trial expired 60 days ago.
What should the administrator do to continue using all of the NC2 features on existing clusters?
- A. Contact Nutanix support to redeploy the cluster.
- B. Switch to a paid subscription plan.
- C. Nothing. The clusters will have full feature support.
- D. Contact the AWS cloud vendor.
After the NC2 free trial expires, to continue using all features of NC2 on existing clusters, the administrator needs to switch to a paid subscription plan.
A paid subscription ensures uninterrupted access to the full range of features and support for NC2 clusters.
Without switching to a paid plan, the features might be limited, and support may not be available, impacting the cluster's operations and management.
Refer to the Nutanix billing and subscription documentation for details on switching from a trial to a paid plan and the benefits associated with paid subscriptions.
NEW QUESTION # 44
With the Nutanix Certified Professional - Cloud Integration - AWS (NCP-CI-AWS) web-based practice exam, you get the same features as a NCP-CI-AWS desktop practice test software. It includes real Nutanix NCP-CI-AWS exam questions to help you understand each topic. The web-based NCP-CI-AWS Practice Exam is compatible with every operating system including Mac, Linux, iOS, Windows, and Android. This Nutanix NCP-CI-AWS practice exam works fine on Chrome, Internet Explorer, Microsoft Edge, Opera, etc.
NCP-CI-AWS Pdf Pass Leader: https://www.prep4king.com/NCP-CI-AWS-exam-prep-material.html
- Reliable NCP-CI-AWS Exam Materials ⏬ Original NCP-CI-AWS Questions 🏸 New NCP-CI-AWS Exam Pattern 🍗 Search for [ NCP-CI-AWS ] and obtain a free download on { [url]www.torrentvce.com } 🍏Valid Test NCP-CI-AWS Tutorial[/url]
- NCP-CI-AWS Online Bootcamps 🕢 NCP-CI-AWS Exam Training 👕 Latest Real NCP-CI-AWS Exam 🔥 Search for { NCP-CI-AWS } and easily obtain a free download on ▷ [url]www.pdfvce.com ◁ 🔧Valid Test NCP-CI-AWS Tutorial[/url]
- 2026 Latest Test NCP-CI-AWS Simulations 100% Pass | Trustable Nutanix Certified Professional - Cloud Integration - AWS Pdf Pass Leader Pass for sure 🚻 Search for ⇛ NCP-CI-AWS ⇚ and download it for free immediately on ▷ [url]www.examcollectionpass.com ◁ 💑Reliable NCP-CI-AWS Exam Materials[/url]
- Latest Real NCP-CI-AWS Exam 🕖 Latest Real NCP-CI-AWS Exam 📒 NCP-CI-AWS Dumps Reviews 🐅 The page for free download of ☀ NCP-CI-AWS ️☀️ on ⏩ [url]www.pdfvce.com ⏪ will open immediately 🍠NCP-CI-AWS Latest Real Test[/url]
- Pass Guaranteed Quiz Nutanix - Trustable Latest Test NCP-CI-AWS Simulations 💹 Search for ▛ NCP-CI-AWS ▟ and easily obtain a free download on [url]www.verifieddumps.com 🕌NCP-CI-AWS Sure Pass[/url]
- Get Useful Latest Test NCP-CI-AWS Simulations and Pass Exam in First Attempt 💔 Search for ☀ NCP-CI-AWS ️☀️ and download exam materials for free through [url]www.pdfvce.com 🌅Valid NCP-CI-AWS Test Preparation[/url]
- NCP-CI-AWS Sure Pass 🍴 Valid Test NCP-CI-AWS Tutorial 🎊 NCP-CI-AWS Dumps Reviews 🧕 Search for ▛ NCP-CI-AWS ▟ on [url]www.exam4labs.com immediately to obtain a free download 🔂NCP-CI-AWS Real Braindumps[/url]
- NCP-CI-AWS Exam Dumps Demo 🧏 Latest Real NCP-CI-AWS Exam 👔 Valid Study NCP-CI-AWS Questions 🦏 Search on [url]www.pdfvce.com for ➥ NCP-CI-AWS 🡄 to obtain exam materials for free download 📲Reliable NCP-CI-AWS Exam Materials[/url]
- 2026 Efficient Latest Test NCP-CI-AWS Simulations | NCP-CI-AWS 100% Free Pdf Pass Leader 📖 Search for ➠ NCP-CI-AWS 🠰 and download exam materials for free through ⮆ [url]www.examcollectionpass.com ⮄ 🐋NCP-CI-AWS Latest Exam Answers[/url]
- [url=https://www.avvocatorotalemarti.it/?s=Latest%20Real%20NCP-CI-AWS%20Exam%20%f0%9f%a6%a5%20NCP-CI-AWS%20Sure%20Pass%20%f0%9f%a5%a1%20Valid%20Dumps%20NCP-CI-AWS%20Free%20%f0%9f%8d%9c%20Open%20[%20www.pdfvce.com%20]%20and%20search%20for%20%e2%96%9b%20NCP-CI-AWS%20%e2%96%9f%20to%20download%20exam%20materials%20for%20free%20%f0%9f%8c%83New%20NCP-CI-AWS%20Exam%20Pattern]Latest Real NCP-CI-AWS Exam 🦥 NCP-CI-AWS Sure Pass 🥡 Valid Dumps NCP-CI-AWS Free 🍜 Open [ www.pdfvce.com ] and search for ▛ NCP-CI-AWS ▟ to download exam materials for free 🌃New NCP-CI-AWS Exam Pattern[/url]
- NCP-CI-AWS Exam Dumps Demo 💨 Original NCP-CI-AWS Questions 🛬 NCP-CI-AWS Latest Exam Answers 🍎 Search on ➡ [url]www.easy4engine.com ️⬅️ for ➥ NCP-CI-AWS 🡄 to obtain exam materials for free download 🌷NCP-CI-AWS Upgrade Dumps[/url]
- learn.nolimit.id, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, learn.cnycreativeconcepts.com, www.stes.tyc.edu.tw, estar.jp, sar-solutions.com.mx, Disposable vapes
DOWNLOAD the newest Prep4King NCP-CI-AWS PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=15DBz6JD4eF6xjLugIfadvXLzn0UoHiyB
