[General] Latest AZ-104 Exam Discount - AZ-104 Question Explanations
92
General Latest AZ-104 Exam Discount - AZ-104 Question Explanations
Posted at 3/7/2026 17:58:43      View157 | Replies0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of DumpsKing AZ-104 dumps for free: https://drive.google.com/open?id=1SrquhytSSxZoZgQhsjlHditzqLLWS0Bt
If you are going to take Microsoft AZ-104 certification exam, it is essential to use AZ-104 training materials. If you are looking for reference materials without a clue, stopIf you don't know what materials you should use, you can try DumpsKing Microsoft AZ-104 exam dumps. The hit rate of the dumps is very high, which guarantees you can pass your exam with ease at the first attempt. DumpsKing Microsoft AZ-104 Practice Test dumps can determine accurately the scope of the examination compared with other exam materials, which can help you improve efficiency of study and help you well prepare for AZ-104 exam.
Now you do not need to worry about the relevancy and top standard of DumpsKing Microsoft Azure Administrator (AZ-104) exam questions. These Microsoft AZ-104 dumps are designed and verified by qualified AZ-104 exam trainers. Now you can trust AZ-104 practice questions and start preparation without wasting further time. With the AZ-104 Exam Questions you will get everything that you need to learn, prepare and pass the challenging Microsoft AZ-104 exam with good scores.
100% Pass 2026 Microsoft The Best Latest AZ-104 Exam DiscountFree demo is available for AZ-104 training materials, so that you can have a deeper understanding of what you are going to buy. We also recommend you to have a try. In addition, AZ-104 training materials are compiled by experienced experts, and they are quite familiar with the exam center, and if you choose us, you can know the latest information for the AZ-104 Exam Dumps. We offer you free update for one year after buying AZ-104 exam materials from us, and our system will send the latest version to your email automatically. So you just need to check your email, and change the your learning ways in accordance with new changes.
Microsoft Azure Administrator Sample Questions (Q15-Q20):NEW QUESTION # 15
You have an Azure subscription. The subscription includes a virtual network named VNet1. Currently, VNet1 does not contain any subnets.
You plan to create subnets on VNet1 and to use application security groups to restrict the traffic between the subnets. You need to create the application security groups and to assign them to the subnets.
Which four cmdlets should you run in sequence? To answer, move the appropriate cmdlets from the list of cmdlets to the answer area and arrange them in the correct order.
NEW QUESTION # 16
You have an Azure subscription that contains the virtual machines shown in the following table.
VM1 and VM2 use public IP addresses. From Windows Server 2019 on VM1 and VM2, you allow inbound Remote Desktop connections.
Subnet1 and Subnet2 are in a virtual network named VNET1.
The subscription contains two network security groups (NSGs) named NSG1 and NSG2. NSG1 uses only the default rules.
NSG2 uses the default and the following custom incoming rule:
* Priority: 100
* Name: Rule1
* Port: 3389
* Protocol: TCP
* Source: Any
* Destination: Any
* Action: Allow
NSG1 connects to Subnet1. NSG2 connects to the network interface of VM2.
Box 1: No
The default port for RDP is TCP port 3389. A rule to permit RDP traffic must be created automatically when you create your VM.
Box 2: Yes
NSG2 will allow this.
Box 3: Yes
Note on NSG-Subnet1: Azure routes network traffic between all subnets in a virtual network, by default.
https://docs.microsoft.com/en-us ... hoot-rdp-connection
NEW QUESTION # 17
You have an Azure Active Directory (Azure AD) tenant that contains three global administrators named Admin1, Admin2, and Admin3.
The tenant is associated to an Azure subscription. Access control for the subscription is configured as shown in the Access control exhibit. (Click the Exhibit tab.) You sign in to the Azure portal as Admin1 and configure the tenant as shown in the Tenant exhibit. (Click the Exhibit tab.) For each of the following statements, select Yes if the statement is true. Otherwise, select No.
They are all Global admins so they can all modify user permission. i.e add self as owner etc.
You can be GA in one of the subscription, it doesn't mean that you can create the resources in all subscription.
As a Global Administrator in Azure Active Directory (Azure AD), you might not have access to all subscriptions and management groups in your directory. Azure AD and Azure resources are secured independently from one another. That is, Azure AD role assignments do not grant access to Azure resources, and Azure role assignments do not grant access to Azure AD.
However, if you are a Global Administrator in Azure AD, you can assign yourself access to all Azure subscriptions and management groups in your directory Reference:
https://docs.microsoft.com/en-gb ... access-global-admin
NEW QUESTION # 18
After you answer a question in this section, you will NOT be able to return to it. As a result, these
questions will not appear in the review screen.
You manage a virtual network named VNet1 that is hosted in the West US Azure region.
VNet1 hosts two virtual machines named VM1 and VM2 that run Windows Server.
You need to inspect all the network traffic from VM1 to VM2 for a period of three hours.
Solution: From Azure Monitor, you create a metric on Network In and Network Out.
Does this meet the goal?
  • A. Yes
  • B. No
You should use Azure Network Watcher.
https://docs.microsoft.com/en-us ... monitoring-overview
NEW QUESTION # 19
You have an Azure subscription that contains the resource groups shown in the following table.
You create the following Azure Resource Manager (ARM) template named deploy json.
You deploy the template by running the following cmdlet.
Item-AzSubscriptionDeployment -location -Template file deploy-json For each or the following statements, select Yes il the statement is bue. Otherwise, select No.
NEW QUESTION # 20
In order to make all customers feel comfortable, our company will promise that we will offer the perfect and considerate service for all customers. If you buy the AZ-104 study materials from our company, you will have the right to enjoy the perfect service. We have employed a lot of online workers to help all customers solve their problem. If you have any questions about the AZ-104 Study Materials, do not hesitate and ask us in your anytime, we are glad to answer your questions and help you use our AZ-104 study materials well. We believe our perfect service will make you feel comfortable when you are preparing for your exam.
AZ-104 Question Explanations: https://www.dumpsking.com/AZ-104-testking-dumps.html
Our company gravely declares that you will have the greatest chance to pass the AZ-104 exam after you buy our AZ-104 exam dump, Microsoft Latest AZ-104 Exam Discount i cleared, yessss, i cleared my exam, In the short term, getting a certification may help you out of your career bottleneck and gain new better opportunities (Exam Collection AZ-104 Question Explanations - Microsoft Azure Administrator PDF), Our AZ-104 pass-sure materials: Microsoft Azure Administrator can give you the right answer to help you work out those problems that most of you are trapped into.
In fact, you can find accounts of mentors and advisors in Valid AZ-104 Test Camp virtually every notable individual throughout history, Know what you're getting and avoid those nasty surprises.
Our company gravely declares that you will have the greatest chance to pass the AZ-104 Exam after you buy our AZ-104 exam dump, i cleared, yessss, i cleared my exam.
Pass Guaranteed Quiz 2026 Microsoft AZ-104: Valid Latest Microsoft Azure Administrator Exam DiscountIn the short term, getting a certification may help AZ-104 you out of your career bottleneck and gain new better opportunities (Exam Collection Microsoft Azure Administrator PDF), Our AZ-104 pass-sure materials: Microsoft Azure Administrator can give you the right answer to help you work out those problems that most of you are trapped into.
With regard to the shining points of our AZ-104 latest questions we really have a lot to say, since our AZ-104 testking pdf is compiled by the leading experts who are coming from different countries in the world, our AZ-104 accurate torrent has been proven to be the best study materials for the exam during the nearly 10 years.
P.S. Free & New AZ-104 dumps are available on Google Drive shared by DumpsKing: https://drive.google.com/open?id=1SrquhytSSxZoZgQhsjlHditzqLLWS0Bt
