[General] Trustable Reliable SDS Exam Voucher for Real Exam
102
【General】 Trustable Reliable SDS Exam Voucher for Real Exam
Posted at 3/7/2026 18:09:18      View:123 | Replies:0        Print      Only Author   [Copy Link] 1#
If you want to get a comprehensive idea about our real SDS study materials. It is convenient for you to download the free demo, all you need to do is just to find the “Download for free” item, and you will find there are three kinds of versions of SDS learning guide for you to choose from namely, PDF Version Demo, PC Test Engine and Online Test Engine, you can choose to download any one version of our SDS exam questions as you like.
If you always feel that you can't get a good performance when you come to the exam room. There is Software version of our SDS exam braindumps, it can simulate the real exam environment. If you take good advantage of this SDS practice materials character, you will not feel nervous when you deal with the Real SDS Exam. Furthermore, it can be downloaded to all electronic devices so that you can have a rather modern study experience conveniently. Why not have a try?
Valid SDS Test Topics, Reliable SDS Exam SimulationsWill you feel nervous in facing the real exam? SDS Soft test engine can stimulate the real exam environment, so that you can know what the real exam is like,you’re your nerves will be reduced, at the same time, your confidence will be strengthened. In addition, SDS Soft test engine can install in more than 200 computers, and it supports MS operating system, and it has two modes for practicing. We offer you free demo for SDS Soft test engine, you can have a try before buying, so that you can have a better understanding of what you are going to buy. You can enjoy free update for 365 days, and the update version for SDS exam materials will be sent to you automatically.
DASCA Senior Data Scientist Sample Questions (Q13-Q18):NEW QUESTION # 13
Tar is an example of:
  • A. Archive file format
  • B. Text file format
  • C. ARV file format
  • D. CSV file format
  • E. None of the above
TAR (Tape Archive) is a widely used archive file format in Unix/Linux environments. It is used to combine multiple files into a single archive file (with extension .tar).
Option A: Correct. TAR is specifically designed for archiving.
Option B (CSV): Incorrect. CSV (Comma-Separated Values) is a tabular text data format.
Option C (ARV): Incorrect - no such format.
Option D (Text): Incorrect. Though TAR may contain text files, the TAR format itself is not plain text but an archive format.
Option E: Incorrect since Option A is valid.
Thus, TAR is an Archive file format.
DASCA Data Scientist Knowledge Framework (DSKF) - Data Storage Formats in Data Science & Engineering.
NEW QUESTION # 14
Which of the following is TRUE for data lake?
  • A. The data lake enables organizations to gather, manage, enrich, and analyze many new sources of data, whether structured or unstructured
  • B. The data lake enables organizations to treat data as an organizational asset to be gathered and nurtured versus a cost to be minimized
  • C. The data lake can make both of the Business Intelligence and Data Science environments less agile and more productive
  • D. The data lake can make both of the Business Intelligence and Data Science environments more agile and more productive
Answer: A,B,D
But per MCQ single-choice format # answer: A (though ideally A, B, C are correct).
A data lake is a centralized repository designed to store raw, structured, semi-structured, and unstructured data at scale. It provides:
Agility and productivity (Option A): Data lakes support flexible ingestion and faster access, making BI and data science environments more efficient.
Data integration (Option B): They handle multiple types of data, enabling advanced analytics and machine learning use cases.
Data as an asset (Option C): They shift perspective, treating data as a strategic resource, not just a storage cost.
Option D: Incorrect. Data lakes improve agility, not reduce it.
Option E: Incorrect, since multiple true statements exist.
Thus, the correct choice per DASCA context is Option A (with B and C also being true).
DASCA Data Scientist Knowledge Framework (DSKF) - Data Engineering: Data Lakes vs Warehouses.
NEW QUESTION # 15
Which of the following phases is NOT a Big Data Business Model Maturity Index?
  • A. Business Strategy
  • B. Data Monetization
  • C. Business Optimization
  • D. Business Monitoring
  • E. Business Metamorphosis
The Big Data Business Model Maturity Index (BDBMMI) defines phases organizations pass through in leveraging data strategically:
Business Monitoring (A): Tracking metrics and reporting.
Business Insights (not listed in options but part of the framework).
Business Optimization (B): Using analytics to improve efficiency.
Data Monetization (D): Creating new revenue streams with data.
Business Metamorphosis (E): Transforming the business model through data.
Business Strategy (Option C): While strategy is essential, it is not one of the defined phases of BDBMMI.
Thus, the correct answer is Option C (Business Strategy).
DASCA Data Scientist Knowledge Framework (DSKF) - Big Data Business Model Maturity Index (BDBMMI).
NEW QUESTION # 16
Which of the following is used to summarize a dataset by showing the median, quantiles, and min/max values for each of the variables?
  • A. Bar Charts
  • B. Scatter Chart
  • C. Pie Charts
  • D. Histogram
  • E. Box Plots
Answer: E
A Box Plot (also called Whisker Plot) is a visualization tool used to summarize data distribution using five- number summary:
Minimum,
First quartile (Q1),
Median (Q2),
Third quartile (Q3),
Maximum.
It also highlights outliers explicitly.
Option A (Box Plots): Correct.
Option B (Pie Charts): Show proportions, not distribution.
Option C (Histogram): Shows frequency distribution but not quartiles/median.
Option D (Scatter Chart): Used for relationships between two variables, not summary statistics.
Option E (Bar Charts): Compare categories, not statistical spread.
Thus, the correct answer is Option A (Box Plots).
DASCA Data Scientist Knowledge Framework (DSKF) - Data Visualization Tools: Box Plots and Statistical Summaries.
NEW QUESTION # 17
Which of the following is NOT a main data container in Python?
  • A. Lists
  • B. Tuples
  • C. Dict
  • D. LinkedList
Python's built-in data containers are widely used in data science and programming:
Lists (Option A): Ordered, mutable sequences.
Tuples (Option B): Ordered, immutable sequences.
Dict (Option D): Dictionaries, key-value data structures implemented using hash tables.
LinkedList (Option C): Python does not provide a native linked list as a built-in container. While linked lists can be implemented manually or through external libraries (e.g., collections.deque for efficient appends
/pops), they are not part of Python's main native containers.
Thus, the correct answer is Option C (LinkedList).
DASCA Data Scientist Knowledge Framework (DSKF) - Programming for Data Science: Python Data Structures.
NEW QUESTION # 18
One can instantly download actual SDS exam questions after buying them from us. Free demos and up to 1 year of free updates are also available at Exams4Collection. Buy Senior Data Scientist (SDS) practice material now and earn the Senior Data Scientist (SDS) certification exam of your dreams with us!
Valid SDS Test Topics: https://www.exams4collection.com/SDS-latest-braindumps.html
With our SDS practice torrent for 20 to 30 hours, we can claim that you are ready to take part in your SDS exam and will achieve your expected scores, DASCA Reliable SDS Exam Voucher Professional team with specialized experts, We have professional Valid SDS Test Topics - Senior Data Scientist dumps torrent and Valid SDS Test Topics - Senior Data Scientist latest dumps for you, which ensure you get a high score in test, DASCA Reliable SDS Exam Voucher We are the leading company in this field.
Our products mainly include the following major features, Other Ways to Work with Variables, With our SDS practice torrent for 20 to 30 hours, we can claim that you are ready to take part in your SDS exam and will achieve your expected scores.
Reliable SDS Exam Voucher | High Hit-Rate Senior Data Scientist 100% Free Valid Test TopicsProfessional team with specialized experts, We have professional SDS Senior Data Scientist dumps torrent and Senior Data Scientist latest dumps for you, which ensure you get a high score in test.
We are the leading company in this field, We have professional experts editing SDS exam vce guide once the real exam questions changes.
