Microsoft MO-210 Online Practice Test
Posted at 3/7/2026 19:21:58
P.S. Free 2026 Microsoft MO-210 dumps are available on Google Drive shared by ActualVCE: https://drive.google.com/open?id=1rYUDTCWI1SyJjE2qk5bE4TegxZeEW09A
The ActualVCE Microsoft Excel (Microsoft 365 Apps) (MO-210) PDF dumps file is a collection of real, valid, and updated MO-210 practice questions that are also easy to install and use. The MO-210 PDF dumps file can be installed on a desktop computer, laptop, and even on your smartphone devices. Just download ActualVCE Microsoft Excel (Microsoft 365 Apps) in MO-210 PDF Questions on your desired device and start Microsoft MO-210 exam dumps preparation today.
ActualVCE is one of the trusted and reliable platforms that is committed to offering quick MO-210 exam preparation. To achieve this objective ActualVCE is offering valid, updated, and Real MO-210 Exam Questions. These ActualVCE Microsoft Excel (Microsoft 365 Apps) (MO-210) exam dumps will provide you with everything that you need to prepare and pass the final MO-210 exam with flying colors.
Updated Microsoft MO-210 Exam Questions in PDF Format for Quick PreparationThere are many benefits after you pass the MO-210 certification such as you can enter in the big company and double your wage. Our MO-210 study materials boost high passing rate and hit rate so that you needn’t worry that you can’t pass the test too much. We provide free tryout before the purchase to let you decide whether it is valuable or not by yourself. To further understand the merits and features of our MO-210 Practice Engine, you should try it first!
Microsoft Excel (Microsoft 365 Apps) Sample Questions (Q15-Q20):NEW QUESTION # 15
Instructions
Exam Environment
Exam Interface and Controls
The exam panel provides access to the project task(s). Each project has an associated file in which you will perform the project tasks.
Project 1
Overview:
Video Games
You are tracking video game popularity by compiling a workbook to document your findings.
Task 4:
Convert the table on the Recent Releases worksheet to a cell range.
Here are the complete solutions below.
Step 1: Select the Table
* Navigate to theRecent Releasesworksheet.
* Clickanywhereinside the data table (for example, click on the text "A Little to the Left").
* Note:You do not need to highlight the whole table; just clicking one cell inside it is enough to activate the hidden menu.
Step 2: Go to the "Table Design" Tab
* Look at the Ribbon at the very top of the Excel window.
* Because you clicked inside the table, a new tab calledTable Design(or sometimes justDesign) will appear on the far right side of the Ribbon.
* Click on theTable Designtab.
Step 3: Click "Convert to Range"
* In theTable Designtoolbar, look for theToolsgroup (usually on the left side).
* Click the button labeledConvert to Range.
Visual Reference:
Step 4: Confirm the Action
* A confirmation dialog box will pop up asking:"Do you want to convert the table to a normal range?"
* ClickYes.
Result:The table functionality (like the little filter arrows next to the headers) will disappear, but the cell colors and data will remain exactly where they are. The data is now a standard "Range."
NEW QUESTION # 16
Instructions
Exam Environment
Project 1
Overview:
Video Games
Task 5:
Insert a Footer that displays today's date on the right and then return to Normal view.
Project 1: Video Games - Task 5 Solution
Task:Insert a Footer that displays today's date on the right and then return to Normal view.
Step 1: Open the Header & Footer View
* Go to theInserttab on the Ribbon.
* Look for theTextgroup (usually near the right side).
* Click on theHeader & Footerbutton.
* Note:This will automatically switch your screen to " age Layout" view, and you will see the header area at the top of the page.
Visual Reference Look for this icon in the Insert tab) [ Header & Footer ] Step 2: Navigate to the Footer
* You are currently in the Header. You need to go to theFooter.
* On theHeader & Footertab (which appears in the Ribbon when you are in this mode), click the button labeledGo to Footer.
* Alternative:You can simply scroll down to the bottom of the page until you see the footer boxes
"Click to add footer".
Visual Reference Button in the Navigation group) [ Go to Footer ]
Step 3: Select the Right Section
* The footer is divided into three boxes: Left, Center, and Right.
* Click inside theRightbox.
Visual Reference:[ Left Box ] [ Center Box ] [ *Click Here (Right Box)* ] Step 4: Insert the Current Date
* With your cursor flashing in the right footer box, look at theHeader & Footertab in the Ribbon.
* In theHeader & Footer Elementsgroup, click theCurrent Datebutton.
* You will see the code &[Date] appear in the box. This is correct; it will turn into the actual date once you click away.
Visual Reference Icon looks like a small calendar) [ Current Date ] -> Displays as &[Date] Step 5: Return to Normal View
* Clickanywhere inside the worksheet cells(outside the footer area) to apply the change.
* Go to theViewtab on the Ribbon.
* In theWorkbook Viewsgroup (far left), click onNormal.
Visual Reference View Tab > Workbook Views) [ Normal ]
Result:You have successfully added the date to the footer. In "Normal" view, you won't see the footer anymore, but it is there and will appear when printed.
NEW QUESTION # 17
Instructions
Exam Environment
Overview:
Guitar Stores
You and a partner own several Guitar Stores. You are analyzing your revenue from the past two quarters.
Task 2:
Without using the New Sheet button, move the pie chart on the Qtr 2 worksheet to its own chart sheet named Qtr 2 Chart.
See the solution in Explanation below.
To move the pie chart to its own dedicated chart sheet without using the "New Sheet" button, follow these steps:
Step 1: Select the Pie Chart
Click anywhere on the Pie Chart located on the Qtr 2 worksheet. This action will activate the contextual chart tabs on the Ribbon.
Step 2: Open the Move Chart Dialog
Once the chart is selected, look at the top of your Excel window:
Go to the Chart Design tab (this tab only appears when a chart is selected).
On the far right of the Ribbon, in the Location group, click the Move Chart button.
Step 3: Configure the New Chart Sheet
A Move Chart dialog box will appear. To move the chart to its own sheet:
Select the New sheet: radio button.
In the text box next to "New sheet:", delete the default text and type Qtr 2 Chart.
Click OK.
Result
Excel will create a new sheet tab at the bottom of your workbook named Qtr 2 Chart that contains only the pie chart, scaled to fill the entire page.
NEW QUESTION # 18
Instructions
Exam Environment
Overview:
Jelly Beans
A shop you manage sells gourmet jelly beans. You are tracking the amount of jelly beans sold each quarter and summarizing the information in aworkbook.
Task 4:
Filter the Profits worksheet to display only flavors with Total Profit that are Above Average.
To filter theProfitsworksheet to display only the flavors with aTotal Profitthat isAbove Average, follow these steps:
Step 1: Access the Profits Worksheet
* Click on theProfitsworksheet tab at the bottom of the Excel window.
Step 2: Apply the Above Average Filter
* Look at theTotal Profitheader (CellG3). If you don't see a small drop-down arrow next to it, go to the Datatab and clickFilter.
* Click theFilter Drop-down Arrowin theTotal Profitheader cell.
* Hover your mouse overNumber Filtersin the menu that appears.
* From the side menu, selectAbove Average.
Step 3: Verify the Results
* Excel will automatically calculate the average of all values in the "Total Profit" column and hide any rows that fall below that number.
* You will notice the row numbers on the left are now blue, indicating a filter is active.
NEW QUESTION # 19
Instructions
Exam Environment
Overview:
Motorhome Rentals
Your company rents motorhomes. The motorhomes rent year-around at different prices. You are preparing pricing worksheets to be shared with others.
Task 3:
Set cells A1:F11 so they will be the only cells that print.
To ensure that only a specific range of cells is printed, you need to define aPrint Area. This prevents Excel from printing empty pages or extra data outside of your selection.
Step-by-Step Solution
* Select the range:Use your mouse to click on cellA1and drag your cursor down to cellF11to highlight the entire area.
* Navigate to Page Layout:Click on thePage Layouttab in the top Ribbon.
* Set the Print Area:
* Locate thePage Setupgroup.
* Click on thePrint Areabutton.
* From the drop-down menu, selectSet Print Area.
Once this is set, Excel will only print the content within A1:F11, even if there is data elsewhere on the sheet.
NEW QUESTION # 20
All the ActualVCE Microsoft MO-210 practice questions are real and based on actual Microsoft Excel (Microsoft 365 Apps) (MO-210) exam topics. The web-based Microsoft Excel (Microsoft 365 Apps) (MO-210) practice test is compatible with all operating systems like Mac, IOS, Android, and Windows. Because of its browser-based Microsoft Excel (Microsoft 365 Apps) (MO-210) practice exam, it requires no installation to proceed further. Similarly, Chrome, IE, Firefox, Opera, Safari, and all the major browsers support the Microsoft Excel (Microsoft 365 Apps) (MO-210) practice test.
100% MO-210 Exam Coverage: https://www.actualvce.com/Microsoft/MO-210-valid-vce-dumps.html
Consider sitting for an 100% MO-210 Exam Coverage - Microsoft Excel (Microsoft 365 Apps) and discovering that the practice materials you've been using are incorrect and useless, Microsoft MO-210 Latest Material At the same time, you can switch to suit your learning style at any time, Our MO-210 guide torrent can help you to save your valuable time and let you have enough time to do other things you want to do, Microsoft MO-210 Latest Material The PC version provides simulative exam system which is also effective and you can operate by computer and it also gains much popularity among customers.
This is rather like the situation with pointers MO-210 before garbage collectors became available, We also tend to avoid high-tech stocks, Consider sitting for an Microsoft Excel (Microsoft 365 Apps) and MO-210 Latest Material discovering that the practice materials you've been using are incorrect and useless.
Beware! Get Real Microsoft MO-210 Dumps for Easy Exam PrepAt the same time, you can switch to suit your learning style at any time, Our MO-210 Guide Torrent can help you to save your valuable time and let you have enough time to do other things you want to do.
The PC version provides simulative exam system MO-210 Latest Material which is also effective and you can operate by computer and it also gains much popularity among customers, Thousands of candidates have passed the exam with our MO-210 training materials effortlessly.
- Vce MO-210 File 🌻 Intereactive MO-210 Testing Engine 👽 MO-210 Exam Training 🟪 Open website ➤ [url]www.pdfdumps.com ⮘ and search for ⇛ MO-210 ⇚ for free download 🧇MO-210 Exam Training[/url]
- Valid MO-210 Braindumps 🚆 MO-210 PDF VCE 🧵 Reliable MO-210 Exam Cram 🧚 Open ⏩ [url]www.pdfvce.com ⏪ and search for ➡ MO-210 ️⬅️ to download exam materials for free ⬆MO-210 Exam Training[/url]
- Real MO-210 PDF Questions [2026]-The Greatest Shortcut Towards Success 🙁 Search for { MO-210 } and download exam materials for free through ( [url]www.easy4engine.com ) ⚜MO-210 Questions Pdf[/url]
- Microsoft MO-210 Exam | MO-210 Latest Material - Sample Download Free of 100% MO-210 Exam Coverage ⏫ Go to website ➤ [url]www.pdfvce.com ⮘ open and search for ( MO-210 ) to download for free 🐩MO-210 Vce Torrent[/url]
- MO-210 Discount 🦆 Reliable MO-210 Exam Cram 📴 Vce MO-210 File 😐 Search for ➥ MO-210 🡄 and download it for free immediately on ➽ [url]www.examcollectionpass.com 🢪 🍴MO-210 Exam Training[/url]
- Microsoft MO-210 PDF Questions Format 🗾 Open ➽ [url]www.pdfvce.com 🢪 enter ✔ MO-210 ️✔️ and obtain a free download ⚽MO-210 Certified[/url]
- MO-210 Questions Pdf 🍡 MO-210 Questions Pdf 🙆 Study MO-210 Tool 🏵 Enter ☀ [url]www.vce4dumps.com ️☀️ and search for ⏩ MO-210 ⏪ to download for free 🏜MO-210 PDF VCE[/url]
- Microsoft MO-210 Exam | MO-210 Latest Material - Sample Download Free of 100% MO-210 Exam Coverage ⚜ Search for 「 MO-210 」 and download exam materials for free through ▶ [url]www.pdfvce.com ◀ 🥠Vce MO-210 File[/url]
- Quiz Microsoft - High-quality MO-210 - Microsoft Excel (Microsoft 365 Apps) Latest Material 👖 Simply search for “ MO-210 ” for free download on ⮆ [url]www.vceengine.com ⮄ 🏊Sample MO-210 Test Online[/url]
- Quiz Microsoft - High-quality MO-210 - Microsoft Excel (Microsoft 365 Apps) Latest Material ▶ Search for ( MO-210 ) and download it for free immediately on ➽ [url]www.pdfvce.com 🢪 🔭MO-210 Discount[/url]
- Microsoft MO-210 Exam | MO-210 Latest Material - Sample Download Free of 100% MO-210 Exam Coverage 🔀 Open “ [url]www.practicevce.com ” enter ▶ MO-210 ◀ and obtain a free download 🧝MO-210 Certification Book Torrent[/url]
- students.wesleyprimrose.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
What's more, part of that ActualVCE MO-210 dumps now are free: https://drive.google.com/open?id=1rYUDTCWI1SyJjE2qk5bE4TegxZeEW09A
