[General] Salesforce Mule-101 Valid Exam Sample, Latest Mule-101 Exam Duration
106
General Salesforce Mule-101 Valid Exam Sample, Latest Mule-101 Exam Duration
Posted at 3/8/2026 00:51:23      View139 | Replies0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Actualtests4sure Mule-101 dumps for free: https://drive.google.com/open?id=16WnImFDsMKcK1ARxbHgzPtXHvnUMxmt5
Our Mule-101 exam preparation materials have a higher pass rate than products in the same industry. If you want to pass Mule-101 certification, then it is necessary to choose a product with a high pass rate. Our Mule-101 study materials guarantee the pass rate from professional knowledge, services, and flexible plan settings. The 99% pass rate is the proud result of our Mule-101 Study Materials. I believe that pass rate is also a big criterion for your choice of products, because your ultimate goal is to obtain Mule-101 certification.
Salesforce Mule-101 Exam Syllabus Topics:
  • Recognize and interpret essential integration concepts and terminology: This domain focuses on foundational concepts including cloud service models, infrastructure types, networking protocols, data formats, security principles, and API classifications.
  • Recognize common integration problems, use cases, and technical solutions: This domain examines integration scenarios, compares legacy and modern approaches, and guides selection of appropriate integration technologies for business problems.
  • Explain the common technical complexities and patterns in integration development: This domain explores interaction patterns, composition patterns, API specifications, observability approaches, and deployment
  • application architecture comparisons.
  • Describe the components and benefits of Anypoint Platform for system integration: This domain covers Anypoint Platform's integration components, connectors, runtime
  • control planes, deployment options, and reusable Exchange assets.
Latest Mule-101 Exam Duration, Mule-101 Reliable Test PdfTry to have a positive mindset, keep your mind focused on what you have to do. Self- discipline is important if you want to become successful. Learn to reject temptations. As old saying goes, no pains no gains. Learning our Mule-101 study materials will help you calm down. What you have learned will finally pay off. It is never too late to learn. You still have the chance to obtain the Mule-101 certificate. What is more, many people have harvest happiness and success after passing the Mule-101 exam. Then you are available for various high salary jobs.
Salesforce Certified MuleSoft Integration Foundations Sample Questions (Q12-Q17):NEW QUESTION # 12
A MuleSoft developer must implement an API as a Mule application, run the application locally, and execute unit tests against the running application.
  • A. API Designer
  • B. Anypoint CLI
  • C. API Manager
  • D. Anypoint Studio
Anypoint Studio: This is the desktop Integrated Development Environment (IDE) for MuleSoft.
Capabilities:
Implement: It provides the graphical interface to drag-and-drop connectors and configure flows.
Run Locally: It includes an embedded Mule Runtime engine, allowing developers to run and debug apps on their own machines.
Execute Unit Tests: It has MUnit fully integrated, allowing developers to run tests and see coverage reports directly in the IDE.
Why others are incorrect:
API Designer: Web-based tool for designing specs (RAML), not implementing logic or running local runtimes.
Anypoint CLI: Command-line tool for platform operations, not development/testing.
NEW QUESTION # 13
Which productivity advantage does Anypoint Platform have to both implement and manage an API?
  • A. Automatic API governance
  • B. Automatic API semantic versioning
  • C. Automatic API proxy generation
  • D. Automatic API specification generation
Automatic API Proxy Generation: When managing an API in API Manager, Anypoint Platform allows you to automatically generate and deploy an API Proxy application to CloudHub.
Functionality: This proxy sits in front of your backend implementation (or a non-Mule API) and enforces policies (like rate limiting or security) without requiring you to write code for the proxy manually. This significantly speeds up the process of securing and managing APIs compared to building custom gateway solutions.
NEW QUESTION # 14
According to MuleSoft's IT delivery and operating model, which approach can an organization adopt in order to reduce the frequency of IT project delivery failures?
  • A. Stop scope creep by centralizing requirements-gathering
  • B. Prevent technology sprawl by reducing production of API assets
  • C. Adopt an enterprise data model
  • D. Decouple central IT projects from the innovation that happens within each line of business
The Problem (IT Delivery Gap): Traditional IT operating models often treat IT as a centralized factory, which becomes a bottleneck. The business demands change faster than Central IT can deliver, leading to project failures or delays.
The Solution (Decoupling): MuleSoft advocates for a new operating model (C4E) where Central IT produces reusable assets (System APIs) and then "gets out of the way." Innovation at the Edge: By decoupling core IT from the Line of Business (LOB), the LOB developers can self-serve those assets to build their own Process and Experience APIs. This allows innovation to happen in parallel across the organization, rather than waiting in a single queue, thus reducing failure rates associated with bottlenecks. 1111
NEW QUESTION # 15
A developer is examining the responses from a RESTful web service that is compliant with the Hypertext Transfer Protocol (HTTP/1.1) as defined by the Internet Engineering Task Force (IETF). 13 (The question asks to identify the code class for success)
  • A. 5xx
  • B. 3xx
  • C. 4xx
  • D. 2xx
HTTP Status Codes: Understanding these is fundamental to MuleSoft integration.
2xx (Success - Answer B): The request was received, understood, and accepted. (e.g., 200 OK, 201 Created, 202 Accepted).
3xx (Redirection): Further action needs to be taken to complete the request (e.g., 301 Moved Permanently).
4xx (Client Error): The request contains bad syntax or cannot be fulfilled (e.g., 400 Bad Request, 401 Unauthorized, 404 Not Found).
5xx (Server Error): The server failed to fulfill an apparently valid request (e.g., 500 Internal Server Error, 502 Bad Gateway).
Context: When a Mule flow makes an HTTP Request, it checks these status codes to determine if the On Error scope should be triggered. By default, 4xx and 5xx trigger errors; 2xx indicates success.
NEW QUESTION # 16
According to the Internet Engineering Task Force (IETF), which supporting protocol does File Transfer Protocol (FTP) use for reliable communication?
  • A. Secure Sockets Layer (SSL)
  • B. Transmission Control Protocol (TCP)
  • C. Lightweight Directory Access Protocol (LDAP)
  • D. Hypertext Transfer Protocol (HTTP)
TCP (Transmission Control Protocol): FTP is an application-layer protocol that relies on TCP at the transport layer to ensure reliable, ordered, and error-checked delivery of a stream of bytes12.
Mechanism: FTP establishes two TCP connections: one for control (commands) and one for data transfer.
UDP: Is unreliable (best effort).
HTTP: Is an alternative application protocol, not the transport layer for FTP.
LDAP: Is for directories.
NEW QUESTION # 17
The Salesforce Mule-101 Dumps PDF File material is printable, enabling your off-screen study. This format is portable and easily usable on smart devices including laptops, tablets, and smartphones. Salesforce Mule-101 dumps team of professionals keeps an eye on content of the Salesforce Mule-101 Exam and updates its product accordingly. Our pdf is a very handy format for casual and quick preparation of the Salesforce certification exam.
Latest Mule-101 Exam Duration: https://www.actualtests4sure.com/Mule-101-test-questions.html
DOWNLOAD the newest Actualtests4sure Mule-101 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=16WnImFDsMKcK1ARxbHgzPtXHvnUMxmt5
