SDS最新試題 & SDS認證
106
SDS最新試題 & SDS認證
Posted at 3/8/2026 01:16:29      View:100 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. KaoGuTi在Google Drive上分享了免費的、最新的SDS考試題庫:https://drive.google.com/open?id=1v4XOVmXffZm_xMslhpPlUEQQXiISf5Ku
希望成為擁有SDS認證的IT專業人士嗎?想減少獲得SDS認證的成本嗎?想通過所有的DASCA認證嗎?如果“是”,KaoGuTi是考生最明智的選擇,為您提供涵蓋最新認證考試問題的最佳題庫學習資料。SDS題庫可以在您考前模擬真實的考試環境,也是最有效的考古題。利用DASCA的SDS考古題,您將達到你的目的,得到最佳的效果,給您帶來無限大的利益,在您以后的IT行業道路上可以走的更遠。
SDS 認證是 DASCA 認證體系中增長最快的領域,也是一個國際性的廠商中比較難的認證考試。不過不用擔心,KaoGuTi 就是一個能使 SDS 認證考試的通過率提高的一個網站,我們的 DASCA SDS 考題指南由我們的專業團隊破解SDS 考試系統數據包,經過資深IT認證講師和技術專家精心編輯整理。包括了當前 SDS 考試所有單選題、複選題、實作題、拖拉題等題型。可以幫助考生順利通過考試。
最有效的SDS最新試題,免費下載SDS考試題庫幫助妳通過SDS考試選擇使用KaoGuTi提供的產品,你踏上了IT行業巔峰的第一步,離你的夢想更近了一步。KaoGuTi為你提供的測試資料不僅能幫你通過DASCA SDS認證考試和鞏固你的專業知識,而且還能給你你提供一年的免費更新服務。
最新的 DASCA Data Scientist SDS 免費考試真題 (Q44-Q49):問題 #44
The Big Data Vision Workshop process is ideal for organizations who:
  • A. Have a desire to leverage the Big Data Vision Workshop to identify where and how to leverage data and analytics to power their business models
  • B. All of the above
  • C. Both A and B
  • D. Have a desire to leverage Big Data to transform their business but do not know where and how to start
  • E. Have a wealth of data that they do not know how to monetize
答案:B
解題說明:
The Big Data Vision Workshop is an early-phase framework designed to help organizations shape their data- driven transformation journey. It is particularly beneficial when:
Option A: Organizations want to leverage big data but lack clarity on where to start.
Option B: Organizations already have large volumes of data but struggle to derive monetization strategies from it.
Option C: Organizations want to identify use cases where data and analytics can enhance or even redefine their business models.
Since all three statements apply, the correct answer is Option E (All of the above).
DASCA Data Scientist Knowledge Framework (DSKF) - Business Applications of Data Science: Big Data Vision Workshop.
問題 #45
Which of the following is an example of NLP?
  • A. Using Twitter to assess public sentiment
  • B. Finding which text documents are about similar topics
  • C. All of the above
  • D. Both A and C
  • E. Flagging e-mails as spam
答案:C
解題說明:
Natural Language Processing (NLP) is the field of machine learning that deals with human language understanding and generation. Applications include:
Option A (Spam detection): NLP techniques classify emails based on text patterns and context.
Option B (Sentiment analysis on Twitter): NLP models analyze textual data to extract emotions, opinions, and trends.
Option C (Topic modeling): NLP clustering and probabilistic models (e.g., LDA) classify documents by semantic similarity.
Since all are valid NLP applications, the correct answer is Option E (All of the above).
DASCA Data Scientist Knowledge Framework (DSKF) - Applications of Machine Learning: NLP in Real- World Use Cases.
問題 #46
What is Scrumban?
  • A. It combines the principles of Scrum and Kanban into a pull-based system
  • B. It is Kanban
  • C. It combines the principles of Scrum and Kanban into a push-based system
  • D. It is Scrum
答案:A
解題說明:
Scrumban is a hybrid Agile methodology that merges Scrum and Kanban to take advantage of the strengths of both.
From Scrum, Scrumban adopts structured sprint planning, roles, and iterative review cycles.
From Kanban, it borrows the visual board system, continuous workflow management, and the pull-based approach, where tasks are pulled into the workflow only when capacity is available.
The pull-based system ensures that teams do not overload themselves and helps manage work-in-progress (WIP) effectively. This makes Scrumban particularly suitable for projects with frequent changes, ongoing maintenance tasks, or teams transitioning from Scrum to Kanban.
Thus, the correct answer is Option C.
DASCA Data Scientist Knowledge Framework (DSKF) - Agile Project Management Techniques for Data Science.
問題 #47
Which of the following is True about Time Series Analysis?
  • A. Identifying interesting patterns in a corpus of time series data that is too large for a human to comb through
  • C. Predicting when/whether an event will occur, such as a failure of the machine generating the data
  • D. Both A and B
  • E. Projecting the value of the time series at future points in time, such as a stock whose price we want to predict
答案:B
解題說明:
Time Series Analysis (TSA) is the process of analyzing data collected sequentially over time to extract meaningful insights.Applications include:
Option A: Correct. Event prediction (e.g., failure detection in IoT or predictive maintenance).
Option B: Correct. Forecasting future values (e.g., stock price, sales forecasting).
Option C: Correct. Pattern discovery in large-scale time series datasets using clustering, anomaly detection, or seasonality detection.
Since all three are true, the best answer is Option E (All of the above).
DASCA Data Scientist Knowledge Framework (DSKF) - Analytics and Machine Learning: Time Series Analysis and Forecasting.
問題 #48
Which of the following is an SLAs specification in case of Internet Service Provider (ISP)?
  • A. Turnaround Time (TAT)
  • B. Mean Time Between Failures (MTBF)
  • C. Mean Time To Recovery (MTTR)
  • D. All of the above
答案:D
解題說明:
Service Level Agreements (SLAs) define performance commitments between service providers (like ISPs) and customers. Key SLA metrics include:
MTBF (Option A): Measures reliability by defining the expected average time between service failures.
MTTR (Option B): Measures availability by defining how quickly service can be restored after a failure.
TAT (Option C): Measures responsiveness in resolving customer requests or incidents.
All three are standard SLA performance specifications. Hence, the correct answer is Option D (All of the above).
DASCA Data Scientist Knowledge Framework (DSKF) - Data Engineering and IT Practices: SLAs and Performance Metrics.
問題 #49
你是否正在為通過DASCA SDS認證考試而奮鬥?想早點實現通過DASCA SDS認證考試的目標嗎?你可以選擇我們的KaoGuTi為你提供的培訓資料。如果你選擇了KaoGuTi,通過DASCA SDS認證考試不再是一個夢想。
SDS認證: https://www.kaoguti.com/SDS_exam-pdf.html
我們KaoGuTi DASCA的SDS考試的做法是最徹底的,以及最準確及時的最新的實踐檢驗,你會發現目前市場上的唯一可以有讓你第一次嘗試通過困難的信心,DASCA SDS最新試題 線上測試引擎:支持Windows / Mac / Android / iOS, 等系統,也就是適用於任何電子產品,你可以通過免費下載我們的KaoGuTi提供的部分關於DASCA SDS考題及答案作為嘗試來確定我們的可靠性,相信你會很滿意的,現在,購買DASCA SDS題庫之后,您的郵箱會收到我們的郵件,您可以及時下載您購買的SDS題庫并訪問,這樣可以全面地了解詳細的考試試題以及答案,KaoGuTi SDS認證不僅為你提供優秀的資料,而且還為你提供優質的服務。
這樣,他就有充分的時間作案,原來北柯鎮是謝家的附屬勢力,每年都會向謝家繳納壹定的稅賦,我們KaoGuTi DASCA的SDS考試的做法是最徹底的,以及最準確及時的最新的實踐檢驗,你會發現目前市場上的唯一可以有讓你第一次嘗試通過困難的信心。
無與倫比的SDS最新試題擁有模擬真實考試環境與場境的軟件VCE版本&最好的SDS認證線上測試引擎:支持Windows / Mac / Android / iOS, 等系統,也就是適用於任何電子產品,你可以通過免費下載我們的KaoGuTi提供的部分關於DASCA SDS考題及答案作為嘗試來確定我們的可靠性,相信你會很滿意的。
現在,購買DASCA SDS題庫之后,您的郵箱會收到我們的郵件,您可以及時下載您購買的SDS題庫并訪問,這樣可以全面地了解詳細的考試試題以及答案,KaoGuTi不僅為你提供優秀的資料,而且還為你提供優質的服務。
順便提一下,可以從雲存儲中下載KaoGuTi SDS考試題庫的完整版:https://drive.google.com/open?id=1v4XOVmXffZm_xMslhpPlUEQQXiISf5Ku
