Cert NCP-DB-6.10 Exam | NCP-DB-6.10 Valid Exam Format
Posted at 3/8/2026 01:21:10
View222
Replies1
TestKingFree is a leading platform that has been helping the Nutanix NCP-DB-6.10 exam candidates for many years. Over this long time period, countless Nutanix NCP-DB-6.10 exam candidates have passed their dream Nutanix Certified Professional - Database Automation (NCP-DB) v6.10 (NCP-DB-6.10) certification and they all got help from valid, updated, and Real NCP-DB-6.10 Exam Questions. So you can also trust the top standard of Nutanix NCP-DB-6.10 exam dumps and start NCP-DB-6.10 practice questions preparation without wasting further time.
The pass rate of the NCP-DB-6.10 training materials is 99%, we pass guarantee, and if you cant pass, money guarantee for your failure, that is money will return to your account. You just need to send the participation and the failure scanned, money will be returned. We can ensure that your money will be returned, either the certification or the money back. Besides the NCP-DB-6.10 Training Materials include the question and answers with high-quality, you will get enough practice.
2026 Efficient 100% Free NCP-DB-6.10 C 100% Free Cert Exam | NCP-DB-6.10 Valid Exam FormatWe are concerted company offering tailored services which include not only the newest and various versions of NCP-DB-6.10 practice materials, but offer one-year free updates services with patient staff offering help 24/7. So there is considerate and concerted cooperation for your purchasing experience accompanied with patient staff with amity. Their enrichment is dependable and reliable. You can find NCP-DB-6.10 practice materials on our official website we will deal with everything once your place your order.
Nutanix Certified Professional - Database Automation (NCP-DB) v6.10 Sample Questions (Q112-Q117):NEW QUESTION # 112
An administrator needs to restore a database provisioned on Storage Spaces. The virtual disks are shared with multiple databases.
Which restore method is supported?
- A. Copy-based restore via NDB GUI
- B. Disk-based restore via NDB CLI
- C. Disk-based restore via NDB GUI
- D. Copy-based restore via NDB CLI
For restoring a database provisioned on Storage Spaces, especially when virtual disks are shared among multiple databases, the supported method is a copy-based restore via the NDB GUI. This method allows for a precise and controlled restoration process suitable for shared storage environments.
NEW QUESTION # 113
What is the first step to install NDB on a Nutanix AHV cluster?
- A. Open Prism Central and enable the NDB VM in the settings menu.
- B. NDB is offered as a SaaS service and doesn't require any installations.
- C. Run LCM update to get the latest version of NDB.
- D. Download the QCOW2 image file of NDB and upload it to Prism Element.
To install NDB on a Nutanix AHV cluster, you need to download the QCOW2 image file of NDB from the Nutanix Support Portal and upload it to Prism Element. This image file contains the NDB software and the CentOS operating system. After uploading the image, you need to create a VM from the image and configure the network settings. Then, you need to register the NDB VM with Prism Central and enable the NDB service in the settings menu.
NEW QUESTION # 114
An administrator configures VM Host Affinity for database server VMs on a Nutanix AHV-powered cluster, intending to optimize HA by ensuring that VMs are placed on separate hosts. After a host failure, the administrator notices that database VMs are clustered on a single remaining host, risking another outage.
How could the administrator avoid this scenario in future host failures?
- A. Set anti-affinity rules to spread VMs across multiple nodes dynamically.
- B. Assign additional backup VMs within the same host to maintain service.
- C. Configure automatic host failover in Prism Central.
- D. Increase the number of affinity zones within the cluster
Configuring VM Host Affinity in a Nutanix AHV-powered cluster ensures that VMs are placed on specific hosts to optimize performance or HA. However, after a host failure, if database VMs cluster on a single remaining host, it indicates that the affinity rules alone are insufficient to maintain high availability (HA) during failover scenarios. To prevent this, the administrator should configure anti- affinity rules, which dynamically ensure that VMs (e.g., database server VMs) are spread across multiple hosts. Anti-affinity rules override default VM placement behavior during failover, reducing the risk of a single point of failure by keeping VMs separated even after a host outage.
NEW QUESTION # 115
What is the minimum frequency in minutes configurable for NDB Log Catch-up operation?
The minimum frequency configurable for the NDB Log Catch-up operation is 15 minutes. This setting determines how frequently the log catch-up process runs, which is crucial for maintaining data integrity and ensuring up-to-date database states.
NEW QUESTION # 116
An administrator needs to add a stretched VLAN across two clusters in NDB Which two prerequisites should be met prior to completing this action? (Choose two.)
- A. Nutanix Cluster Management must be enabled.
- B. VLAN must be static.
- C. Both clusters must be registered in NDB.
- D. VLAN must be IPAM.
A stretched VLAN is a virtual network that spans across multiple Nutanix clusters and allows the communication between VMs on different clusters using the same subnet. A stretched VLAN can be used to provide high availability and load balancing for NDB components, such as HAProxy VMs, that require a virtual IP address (VIP) to be accessible from any cluster. To add a stretched VLAN across two clusters in NDB, the administrator needs to meet two prerequisites: the VLAN must be static and both clusters must be registered in NDB. A static VLAN is a VLAN that is manually created and configured by the administrator, as opposed to an IPAM VLAN that is automatically created and managed by NDB. A static VLAN can be added to a stretched VLAN in NDB, while an IPAM VLAN cannot. Both clusters must be registered in NDB before adding a stretched VLAN, as NDB needs to have the information and access to the clusters and their networks. The administrator can register the clusters in NDB using the Prism Element details, agent network configuration, and storage container information. The other option, Nutanix Cluster Management, is not a prerequisite for adding a stretched VLAN in NDB. Nutanix Cluster Management is a feature that allows the administrator to manage multiple Nutanix clusters from a single NDB UI, such as creating or deleting clusters, adding or removing nodes, or performing cluster operations. Nutanix Cluster Management is not required for adding a stretched VLAN, as the VLANs are created and configured in Prism Element, not in NDB.
NEW QUESTION # 117
As our Nutanix Certified Professional - Database Automation (NCP-DB) v6.10 study questions can bring more professional quality service for the user. Our NCP-DB-6.10 study materials can give the user confidence and strongly rely on feeling, lets the user in the reference appendix not alone on the road, because we are to accompany the examinee on NCP-DB-6.10 Exam, candidates need to not only learning content of teaching, but also share his arduous difficult helper, so believe us, we are so professional company. Now, you can free download the demo of our NCP-DB-6.10 test guide to understand in more details.
NCP-DB-6.10 Valid Exam Format: https://www.testkingfree.com/Nutanix/NCP-DB-6.10-practice-exam-dumps.html
Nutanix Cert NCP-DB-6.10 Exam The software version: many people are used to studying on computers, Besides the NCP-DB-6.10 training materials include the question and answers with high-quality, you will get enough practice, You can get high Nutanix Certified Professional (NCP) NCP-DB-6.10 passing score by preparing learning materials with one or two days and this is the only shortest way to help you NCP-DB-6.10 pass exam, We promise that our price of NCP-DB-6.10 latest dumps: Nutanix Certified Professional - Database Automation (NCP-DB) v6.10 is reasonable.
Better Superfetch performance, External Style NCP-DB-6.10 Sheets, The software version: many people are used to studying on computers,Besides the NCP-DB-6.10 Training Materials include the question and answers with high-quality, you will get enough practice.
Cert NCP-DB-6.10 Exam | Pass-Sure NCP-DB-6.10: Nutanix Certified Professional - Database Automation (NCP-DB) v6.10 100% PassYou can get high Nutanix Certified Professional (NCP) NCP-DB-6.10 passing score by preparing learning materials with one or two days and this is the only shortest way to help you NCP-DB-6.10 pass exam.
We promise that our price of NCP-DB-6.10 latest dumps: Nutanix Certified Professional - Database Automation (NCP-DB) v6.10 is reasonable, You may previously think preparing for the NCP-DB-6.10 practice exam will be full of agony; actually, you can abandon the time-consuming thought from now on.
- 100% Pass Nutanix - Unparalleled NCP-DB-6.10 - Cert Nutanix Certified Professional - Database Automation (NCP-DB) v6.10 Exam 🔤 Search for ▷ NCP-DB-6.10 ◁ and obtain a free download on ➡ [url]www.examcollectionpass.com ️⬅️ 🎽NCP-DB-6.10 Practice Exams Free[/url]
- Study NCP-DB-6.10 Center 🥍 NCP-DB-6.10 Valid Exam Test 💓 Flexible NCP-DB-6.10 Learning Mode 🏜 Immediately open [url]www.pdfvce.com and search for NCP-DB-6.10 to obtain a free download 🚈Exam NCP-DB-6.10 Voucher[/url]
- NCP-DB-6.10 Test Sample Online 👠 NCP-DB-6.10 Study Material 🍩 NCP-DB-6.10 Test Sample Online 🐪 Search for ▛ NCP-DB-6.10 ▟ and download it for free immediately on ⮆ [url]www.testkingpass.com ⮄ ❓NCP-DB-6.10 Reliable Test Experience[/url]
- Cert NCP-DB-6.10 Exam - Quiz NCP-DB-6.10 Nutanix Certified Professional - Database Automation (NCP-DB) v6.10 First-grade Valid Exam Format 🔢 Copy URL [ [url]www.pdfvce.com ] open and search for ➤ NCP-DB-6.10 ⮘ to download for free 🔟Flexible NCP-DB-6.10 Learning Mode[/url]
- Certification NCP-DB-6.10 Test Answers 🥵 NCP-DB-6.10 Exam Success 🆑 Exam NCP-DB-6.10 Papers 💠 Search for NCP-DB-6.10 and download it for free immediately on ▷ [url]www.troytecdumps.com ◁ 🦥NCP-DB-6.10 Reliable Test Experience[/url]
- Download Real Nutanix NCP-DB-6.10 Exam Questions And Start Your Preparation Journey 🏂 Open ⇛ [url]www.pdfvce.com ⇚ enter ➤ NCP-DB-6.10 ⮘ and obtain a free download 🌑Certification NCP-DB-6.10 Test Answers[/url]
- Flexible NCP-DB-6.10 Learning Mode 🛒 NCP-DB-6.10 Certification Book Torrent 🤬 Certification NCP-DB-6.10 Test Answers 🚮 Enter [url]www.pdfdumps.com and search for ➥ NCP-DB-6.10 🡄 to download for free 😑Certification NCP-DB-6.10 Test Answers[/url]
- [url=http://www.cardinalep.com/?s=What%20are%20the%20Benefits%20of%20Preparing%20with%20the%20Pdfvce%20Nutanix%20NCP-DB-6.10%20Exam%20Dumps? 🧃 Enter www.pdfvce.com and search for ⏩ NCP-DB-6.10 ⏪ to download for free 🐝Exam NCP-DB-6.10 Papers]What are the Benefits of Preparing with the Pdfvce Nutanix NCP-DB-6.10 Exam Dumps? 🧃 Enter www.pdfvce.com and search for ⏩ NCP-DB-6.10 ⏪ to download for free 🐝Exam NCP-DB-6.10 Papers[/url]
- What are the Benefits of Preparing with the [url]www.exam4labs.com Nutanix NCP-DB-6.10 Exam Dumps? 🎃 Search for ▷ NCP-DB-6.10 ◁ and easily obtain a free download on ➽ www.exam4labs.com 🢪 🧓Valid Test NCP-DB-6.10 Test[/url]
- Download Real Nutanix NCP-DB-6.10 Exam Questions And Start Your Preparation Journey 📔 Search for ▷ NCP-DB-6.10 ◁ and easily obtain a free download on { [url]www.pdfvce.com } 🦄NCP-DB-6.10 Exam Preparation[/url]
- Latest NCP-DB-6.10 Exam Test 📢 NCP-DB-6.10 Testdump 🚐 Valid NCP-DB-6.10 Exam Answers 🤍 Search on [url]www.exam4labs.com for ⇛ NCP-DB-6.10 ⇚ to obtain exam materials for free download 🧰Exam NCP-DB-6.10 Overview[/url]
- ghrcn.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, academy.aladaboi.com, www.stes.tyc.edu.tw, mawada.om, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
