[General] Study 156-587 Plan Exam Pass at Your First Attempt | 156-587: Check Point Certif
91
General Study 156-587 Plan Exam Pass at Your First Attempt | 156-587: Check Point Certif
Posted at 3/8/2026 03:33:01      View183 | Replies0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of DumpStillValid 156-587 dumps from Cloud Storage: https://drive.google.com/open?id=1s8tkku0cd-TjH43jp9ce6FC0aqtjBKxn
Our 156-587 exam torrent is highly regarded in the market of this field and come with high recommendation. Choosing our 156-587 exam guide will be a very promising start for you to begin your exam preparation because our 156-587 practice materials with high repute. We remunerate exam candidates who fail the 156-587 Exam Torrent after choosing our 156-587 study tools, which kind of situation is rare but we still support your dream and help you avoid any kind of loss. Just try it do it, and we will be your strong backup.
CheckPoint 156-587 Exam Syllabus Topics:
  • Advanced Identity Awareness Troubleshooting: This section of the exam measures the skills of heck Point Security Consultants and focuses on troubleshooting identity awareness systems.
  • Advanced Access Control Troubleshooting: This section of the exam measures the skills of Check Point System Administrators in demonstrating expertise in troubleshooting access control mechanisms. It involves understanding user permissions and resolving authentication issues.
  • Advanced Client-to-Site VPN Troubleshooting: This section of the exam measures the skills of CheckPoint System Administrators and focuses on troubleshooting client-to-site VPN issues.
  • Advanced Troubleshooting with Logs and Events: This section of the exam measures the skills of  Check Point Security Administrators and covers the analysis of logs and events for troubleshooting. Candidates will learn how to interpret log data to identify issues and security threats effectively.
Real Study 156-587 Plan - Pass 156-587 ExamThe CheckPoint 156-587 pdf questions learning material provided to the customers from DumpStillValid is in three different formats. The first format is PDF format which is printable and portable. It means it can be accessed from tablets, laptops, and smartphones to prepare for the CheckPoint 156-587 Exam. The CheckPoint 156-587 PDF format can be used offline, and candidates can even prepare for it in the classroom or library by printing questions or on their smart devices.
CheckPoint Check Point Certified Troubleshooting Expert - R81.20 Sample Questions (Q108-Q113):NEW QUESTION # 108
Which of the following commands can be used to see the list of processes monitored by the Watch Dog process?
  • A. fw ctl get str watchdog
  • B. cpwd_admin list
  • C. cpstat fw -f watchdog
  • D. ps -ef | grep watchd
To see the list of processes monitored by the WatchDog process (CPWD), you use the cpwd_admin list command.
* Option A (cpstat fw -f watchdog): Shows firewall status and statistics for the "fw" context, not necessarily the list of monitored processes.
* Option B (fw ctl get str watchdog): Not a valid parameter for retrieving the list of monitored processes; "fw ctl" deals with kernel parameters.
* Option C (cpwd_admin list): Correct command that lists all processes monitored by CPWD, their status, and how many times they have been restarted.
* Option D (ps -ef | grep watchd): This will list any running process that matches the string "watchd" but will not specifically detail which processes are being monitored by CPWD.
Therefore, the best answer is cpwd_admin list.
Check Point Troubleshooting References
* sk97638: Explains Check Point WatchDog (CPWD) usage and the cpwd_admin utility.
* R81.20 CLI Reference Guide: Describes common troubleshooting commands including cpwd_admin list.
* Check Point Gaia Administration Guide: Provides instructions for monitoring system processes and verifying CPWD.
NEW QUESTION # 109
You are using the identity Collector with identity Awareness in large environment. Users report that they cannot access resources on Internet You identify that the traffic is matching the cleanup rule Instead of the proper rule with Access Roles using the IDC How can you check if IDC is working?
  • A. pdp debug set IDP all
  • B. pdp connections idc
  • C. ad query I debug on
  • D. pep debug idc on
NEW QUESTION # 110
In some scenarios it is very helpful to use advanced Linux commands for troubleshooting purposes. Which command displays information about resource utilization for running processes and shows additional information for core utilization and memory?
  • A. cptop
  • B. top
  • C. vmstat
  • D. mpstat
The top command is a Linux command that displays information about resource utilization for running processes and shows additional information for core utilization and memory. The top command provides a dynamic real-time view of the system, showing the processes that are consuming the most CPU, memory, and other resources. The top command also shows the total number of processes, the system load average, the uptime, and the CPU usage by user, system, and idle. The top command can be customized by using various options and interactive commands to change the display, sort the processes, filter the output, and kill processes.
The other commands are incorrect because:
B : vmstat is a Linux command that displays information about the virtual memory, CPU, disk, and system activity. It does not show information about individual processes or core utilization.
C : cptop is a Check Point command that displays information about the firewall kernel activity, such as the number of connections, packets, drops, and rejects. It does not show information about other processes or memory usage.
D : mpstat is a Linux command that displays information about the CPU utilization by each processor or core. It does not show information about processes or memory usage.
top(1) - Linux manual page
vmstat(8) - Linux manual page
cptop - Check Point Software
mpstat(1) - Linux manual page
NEW QUESTION # 111
What is the name of the VPN kernel process?
  • A. VPND
  • B. CVPND
  • C. FWK
  • D. VPNK
NEW QUESTION # 112
What command is usually used for general firewall kernel debugging and what is the size of the buffer that is automatically enabled when using the command?
  • A. fw ctl zdebug, buffer size is 32768 KB
  • B. fw ctl debug, buffer size is 1024 KB
  • C. fw ctl kdebug, buffer size is 32000 KB
  • D. fw ctl zdebug, buffer size is 1 MB
NEW QUESTION # 113
What is more difficult is not only passing the CheckPoint 156-587 Certification Exam, but the acute anxiety and the excessive burden also make the candidate nervous to qualify for the Check Point Certified Troubleshooting Expert - R81.20 certification. If you are going through the same tough challenge, do not worry because CheckPoint is here to assist you.
Real 156-587 Exam Questions: https://www.dumpstillvalid.com/156-587-prep4sure-review.html
BONUS!!! Download part of DumpStillValid 156-587 dumps for free: https://drive.google.com/open?id=1s8tkku0cd-TjH43jp9ce6FC0aqtjBKxn
