[General] Online HPE0-S59 Tests & Training HPE0-S59 Solutions
46
General Online HPE0-S59 Tests & Training HPE0-S59 Solutions
Posted at 3/8/2026 04:00:48      View168 | Replies0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of UpdateDumps HPE0-S59 dumps from Cloud Storage: https://drive.google.com/open?id=16XuXgGEcXoTUK40rhuh1FpS8iQjRz1Uf
HP HPE0-S59 certification exam is very important for every IT person. With this certification you will not be eliminated, and you will be a raise. Some people say that to pass the HP HPE0-S59 exam certification is tantamount to success. Yes, this is true. You get what you want is one of the manifestations of success. UpdateDumps of HP HPE0-S59 Exam Materials is the source of your success. With this training materials, you will speed up the pace of success, and you will be more confident.
HP HPE0-S59 Exam is a multiple-choice exam that consists of 60 questions. Candidates are given 90 minutes to complete the exam. HPE0-S59 exam is available in English and Japanese languages. The passing score for the exam is 65%, and the exam fee is $200. Candidates can take the exam at Pearson VUE testing centers worldwide.
Training HP HPE0-S59 Solutions - Updated HPE0-S59 DemoIn order to cater to different kinds of needs of candidates, we offer three versions for HPE0-S59 training materials for you to select. Each version has its own advantage, and you can choose the most suitable one in accordance with your own needs. HPE0-S59 PDF version is printable, and you can print it into paper if you like. HPE0-S59 Soft test engine can stimulate the real exam environment, so that you can build up your confidence for the exam. HPE0-S59 Online test engine is convenient and easy to learn, and it supports offline proactive. You can also have a review of what you have learned through HPE0-S59 Online test engine.
HPE Compute Solutions Sample Questions (Q91-Q96):NEW QUESTION # 91
Your customer plans to use HPE Primera to boot HPE Synergy compute nodes. They currently have two HPE Virtual Connect SE 100Gb F32 Module for Synergy modules installed in the frame. The customer wants to use FC as a storage access protocol What must be done to complete this task?
  • A. FC connectivity on the modules should be enabled through the service console by disabling FCoE.
  • B. Add FC upgrade licenses in HPE OneView that will enable FC connectivity for the modules
  • C. Enter both modules into a maintenance mode, then enable FC connectivity through CLI
  • D. Enable FC primary and secondary boot on the modules through the HPE OneView interface
To use FC (Fibre Channel) as a storage access protocol with HPE Primera to boot HPE Synergy compute nodes, you must add FC upgrade licenses in HPE OneView. These licenses enable FC connectivity for the HPE Virtual Connect SE 100Gb F32 Modules, allowing the compute nodes to connect to the FC storage.
NEW QUESTION # 92
Your customer reports that they cannot deploy HPE Synergy compute nodes using HPE OneView for VMware vCenter Server (HPE OV4VC).
What should you check during troubleshooting process?
  • A. If an compute nodes are added to the vCenter Server
  • B. If vCenter Server is licensed in the HPE Oneview interface
  • C. If the HPE Oneview instance Is integrated with HPE OV4VC.
  • D. If HPE OneView credentials are added in vCenter Server
When troubleshooting the deployment of HPE Synergy compute nodes using HPE OneView for VMware vCenter Server (HPE OV4VC), it's essential to verify that HPE OneView credentials are correctly added in the vCenter Server. Proper integration and authentication are necessary for HPE OV4VC to communicate and manage the compute nodes effectively.
NEW QUESTION # 93
Your customer changed the storage pool state from managed to discovered.
What is the impact of that change?
  • A. All volumes from that pool will be removed from HPE OneView.
  • B. Storage pool parameters cannot be modified using HPE OneView.
  • C. Volume provisioning will be disabled for that storage pool.
  • D. This storage pool can be deleted using HPE OneView interface.
NEW QUESTION # 94
Your customer has an HPE Synergy frame equipped with a D3940 Storage Module. Each of the compute nodes has the appropriate storage controller installed and two 12Gb SAS switches installed in the first fabric.
The customer reports that the compute nodes cannot access the storage module.
What will you verify first when troubleshooting this problem?
  • A. If the D3940 storage module is properly licensed through the HPE OneView interface.
  • B. If there is at least one iSCSI network configured that will provide access to the module.
  • C. If the SAS logical interconnect is a part of the logical enclosure and has a healthy state.
  • D. If the D3940 module is imported in a managed state that allows volume provisioning.
NEW QUESTION # 95
What is important to consider when setting up RAID configurations in an HPE server?
  • A. The visual arrangement of RAID arrays
  • B. The color scheme of RAID controllers
  • C. Matching RAID controllers with server brands
  • D. The RAID level's suitability for the data requirement
NEW QUESTION # 96
It is known to us that the 21st century is an information era of rapid development. Now the people who have the opportunity to gain the newest information, who can top win profit maximization. In a similar way, people who want to pass HPE0-S59 exam also need to have a good command of the newest information about the coming exam. However, it is not easy for a lot of people to learn more about the information about the study materials. Luckily, the HPE0-S59 Study Materials from our company will help all people to have a good command of the newest information.
Training HPE0-S59 Solutions: https://www.updatedumps.com/HP/HPE0-S59-updated-exam-dumps.html
BONUS!!! Download part of UpdateDumps HPE0-S59 dumps for free: https://drive.google.com/open?id=16XuXgGEcXoTUK40rhuh1FpS8iQjRz1Uf
