[General] 100% Pass 2026 Newest JN0-650: Questions Enterprise Routing and Switching, Profe
98
General 100% Pass 2026 Newest JN0-650: Questions Enterprise Routing and Switching, Profe
Posted at 3/8/2026 05:45:46      View136 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free & New JN0-650 dumps are available on Google Drive shared by ActualCollection: https://drive.google.com/open?id=1bl1scWCQMXywk3sTFjgMe9jiAMZp1fCy
JN0-650 exam training allows you to pass exams in the shortest possible time. If you do not have enough time, our study material is really a good choice. In the process of your learning, our study materials can also improve your efficiency. If you don't have enough time to learn, JN0-650 test guide will make the best use of your spare time, and the scattered time will add up. It is also very important to achieve the highest efficiency for each piece of debris. The professional tailored by JN0-650 learning question must be very suitable for you. You will have a deeper understanding of the process. Efficient use of all the time, believe me, you will realize your dreams.
Our JN0-650 practice exam is specially designed for those people who have not any time to attend the class and prepare Juniper exam tests with less energy. You will understand each point of questions and answers with the help of our JN0-650 Exam Review. And our exam pass guide will cover the points and difficulties of the JN0-650 real exam, getting certification are just a piece of cake.
Free 1 year Juniper JN0-650 Dumps Updates: a Full Refund Guarantee By ActualCollectionIn recent years, some changes are taking place in this line about the new points are being constantly tested in the Enterprise Routing and Switching, Professional (JNCIP-ENT) real exam. So our experts highlight the new type of JN0-650 questions and add updates into the practice materials, and look for shifts closely when they take place. As to the rapid changes happened in this JN0-650 Exam, experts will fix them and we assure your JN0-650 exam simulation you are looking at now are the newest version. And we only sell the latest JN0-650 exam questions and answers.
Juniper Enterprise Routing and Switching, Professional (JNCIP-ENT) Sample Questions (Q12-Q17):NEW QUESTION # 12
You are deploying IP phones in your enterprise networks. When plugged in, the IP phones must be automatically provided with the correct VLAN ID needed for sending voice traffic to the EX Series switches.
In this scenario, which two solutions are required to accomplish this task? (Choose two.)
  • A. Use LLDP on appropriate interfaces.
  • B. Create two VLANs and assign them as VLAN members to the appropriate access interfaces.
  • C. Enable the voice VLAN feature with the appropriate access interfaces and VLAN ID for voice traffic.
  • D. Enable LLDP-MED on appropriate access interfaces.
NEW QUESTION # 13
Exhibit.
You have determined that traffic in your network is being routed through your route reflector instead of using the optimal path. Referring to the exhibit, what are two configuration changes on the route reflector that would solve the problem? (Choose two.)
  • A. set policy-options policy-statement NHS term 10 from route-type external
  • B. set protocols bgp group int-group import NHS
  • C. delete protocols bgp group int-group export IfJHS
  • D. set policy-options policy-statement NHS term 10 from route-type internal
The exhibit shows a BGP Route Reflector (RR) configuration where an export policy named NHS (Next-Hop Self) is applied to the internal BGP group int-group. The policy NHS sets the next-hop self attribute for BGP routes.
* The Problem (Traffic Tromboning): In a standard BGP Route Reflector design, the RR should reflect routes without modifying the BGP next-hop attribute. By applying a next-hop self policy on the export to clients, the RR tells all its clients that it is the exit point for those routes. Consequently, all data plane traffic is sent to the RR first before being forwarded to the actual destination, rather than following the optimal direct path between clients. This is known as "traffic tromboning" or suboptimal routing.
* The Solution (Option C): The most direct way to fix this is to delete the export policy that is forcing the next-hop to be the RR. By deleting protocols bgp group int-group export NHS, the RR will resume standard behavior and reflect the original next-hop received from the route source, allowing clients to route traffic directly to the correct destination.
* The Refined Solution (Option D): If you must keep the NHS policy (perhaps for routes learned from external peers), you should ensure it only applies to those specific routes. By adding from route-type internal to the policy term and then potentially changing the logic (or simply narrowing the scope), you can prevent the RR from incorrectly applying next-hop self to internal routes that it is merely reflecting.
In the context of this specific problem, Option D combined with a change in the policy's action or scope helps ensure reflected internal routes maintain their original, optimal next-hops.
* Option A is incorrect because setting next-hop self for external routes is common practice, but it doesn't solve the problem of internal reflected routes being diverted to the RR.
* Option B is incorrect because applying this as an import policy would change how the RR itself sees the routes, but it wouldn't fix the attributes being sent out to the clients in the reflection process.
NEW QUESTION # 14
Exhibit:
There is a functioning OSPFv3 neighborship between Router-1 and Router-2 over the ge-0/0/1 link. However, the 172.100.100.0/24 and 172.101.101.100/24 routes are not being shared through OSPFv3. Referring to the configuration shown in the exhibit, which two actions must you take to solve the problem? (Choose two.)
  • A. Add interface ge-0/0/2 under OSPFv3 for both routers.
  • B. Add interface ge-0/0/1 under the IPv4 unicast realm for both routers.
  • C. Add the IPv6 family protocol under ge-0/0/2 for both routers.
  • D. Add the lo0 interface under OSPFv3 for both routers.
NEW QUESTION # 15
Referring to the exhibit, anycast RP is implemented to ensure multicast service availability. The source is currently sending multicast traffic using group 239.1.1.1 and R3 is receiving PIM register messages, but R2 does not have active source information.
In this scenario, what are two methods to receive the active source information on R2? (Choose two.)
  • A. Configure an RP set in PIM on R1, allowing R1 to forward PIM register messages to R2 and R3 in the set.
  • B. Configure an MSDP protocol between R2 and R3.
  • C. Configure an RP set in PIM on R2 and R3, allowing the RPs to forward PIM register messages to the other RPs in the set.
  • D. Configure an MSDP protocol between R1 and R2.
NEW QUESTION # 16
Your network has Junos Fusion configured with MX960 routers as aggregation devices (AD) and QFX5100 switches as satellite devices (SD).
Which two statements are correct in this scenario? (Choose two.)
  • A. SDs are added to the AD by configuring the cascade port on the AD.
  • B. The AD runs the Junos software for all its connected SDs.
  • C. All SDs connected to a single AD must use the same software version.
  • D. The Fusion extended ports are configured on the SDs.
NEW QUESTION # 17
No doubt the Juniper JN0-650 certification exam is one of the most difficult ActualCollection certification exams in the modern ActualCollection world. This JN0-650 exam always gives a tough time to their candidates. The ActualCollection understands this challenge and offers real, valid, and top-notch Juniper JN0-650 Exam Dumps in three different formats. All these three JN0-650 exam questions formats are easy to use and compatible with all devices, operating systems, and web browsers.
JN0-650 New Study Guide: https://www.actualcollection.com/JN0-650-exam-questions.html
Juniper Questions JN0-650 Exam People should have the right to choose freely rather than just have one choice, Juniper Questions JN0-650 Exam You will find everything you need to overcome the difficulties in the actual test, Juniper Questions JN0-650 Exam In fact, the overload of learning seems not to be a good method, once you are weary of such a studying mode, it's difficult for you to regain interests and energy, We will give you the best service and suggestion on the JN0-650 study material.
These variables can help change and adapt the music so it is synchronized to the events that unfold for the player, We have been providing updated and real JN0-650 Mock Test preparation material.
For Quick Exam preparation download, the Juniper JN0-650 Exam dumpsPeople should have the right to choose freely rather than JN0-650 just have one choice, You will find everything you need to overcome the difficulties in the actual test.
In fact, the overload of learning seems not to be a good Questions JN0-650 Exam method, once you are weary of such a studying mode, it's difficult for you to regain interests and energy.
We will give you the best service and suggestion on the JN0-650 study material, With instant access to download JN0-650 exam dumps right after purchase.
