[General] Explore ExamDiscuss's Top Three Formats for CompTIA 220-1202 Exam
115
【General】 Explore ExamDiscuss's Top Three Formats for CompTIA 220-1202 Exam
Posted at 3/8/2026 07:11:19      View:101 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 CompTIA 220-1202 dumps are available on Google Drive shared by ExamDiscuss: https://drive.google.com/open?id=1L1arOoU_9cQ2rQw5UL-H9-YaesL7ekC9
CompTIA 220-1202 certification can guarantee you have good job prospects, because CompTIA certification 220-1202 exam is a difficult test of IT knowledge, passing CompTIA Certification 220-1202 Exam proves that your IT expertise a strong and you can be qualified for a good job.
There is an irreplaceable trend that an increasingly amount of clients are picking up 220-1202 study materials from tremendous practice materials in the market. There are unconquerable obstacles ahead of us if you get help from our 220-1202 Exam Questions. So many exam candidates feel privileged to have our 220-1202 practice braindumps. And our website is truly very famous for the hot hit in the market and easy to be found on the internet.
The Best 220-1202 – 100% Free Reliable Test Online | 220-1202 Unlimited Exam PracticeIn this hustling society, our 220-1202 study guide is highly beneficial existence which can not only help you master effective knowledge but pass the 220-1202 exam effectively. They have a prominent role to improve your soft-power of personal capacity and boost your confidence of conquering the exam with efficiency. As there are all keypoints in the 220-1202 Practice Engine, it is easy to master and it also helps avoid a waste of time for selecting main content.
CompTIA A+ Certification Exam: Core 2 Sample Questions (Q127-Q132):NEW QUESTION # 127
A technician needs to provide remote support for a legacy Linux-based operating system from their Windows laptop. The solution needs to allow the technician to see what the user is doing and provide the ability to interact with the user's session. Which of the following remote access technologies would support the use case?
  • A. VNC
  • B. VPN
  • C. SSH
  • D. RDP
The correct answer isVNC (Virtual Network Computing). VNC is a graphical desktop-sharing system that uses the Remote Frame Buffer protocol (RFB) to remotely control another computer. It is platform- independent and widely supported on Linux, which makes it ideal for providinginteractive remote support for a Linux-based operating system. It allows the technician not only to view the remote desktop session but also tocontrol it, fulfilling the need to see and interact with the user's session.
* A. VPN(Virtual Private Network) creates a secure tunnel to a network but doesnot provide desktop sharing or session controlby itself.
* C. SSH(Secure Shell) provides secure command-line access to Unix/Linux systems but does not offer graphical desktop interaction, which is a requirement in this case.
* D. RDP(Remote Desktop Protocol) is primarily a Microsoft protocol, and although it can be made to work on Linux, it isnot natively supported on legacy Linux systems, and thusless suitablethan VNC in this scenario.
CompTIA A+ 220-1102 Core 2 Objective Reference:
Objective 1.8 - Given a scenario, use features and tools of the operating system.
Under this objective, candidates are expected to be familiar with remote access technologies, includingRDP, SSH, and VNC, and understand their appropriate uses and limitations on different platforms such as Windows and Linux.
NEW QUESTION # 128
A company's IT policy requires the protection of sensitive data on employee laptops, especially those taken off premises. Recently, data theft on these devices has become a concern. Which of the following security measures should the company implement to safeguard the laptops?
  • A. VPN access
  • B. Biometric authentication
  • C. Full disk encryption
  • D. Intrusion detection software
Full disk encryption protects all data on a laptop by making the contents unreadable without proper authentication, preventing data theft even if the device is lost or stolen.
NEW QUESTION # 129
A technician needs to prevent accidental access to Wi-Fi networks available in a shared office space. The BYOD and company-owned devices already have Wi-Fi settings configured via MDM solutions. Which of the following settings should the technician change?
  • A. SSID configuration
  • B. Content filtering configuration
  • C. Port forwarding/mapping
  • D. IP filtering configuration
The correct answer is B. SSID configuration, because controlling SSID visibility and behavior directly affects which wireless networks devices can see and attempt to join. In shared office environments, multiple Wi-Fi networks may be present, increasing the risk of users accidentally connecting to the wrong network.
According to the Quentin Docter - CompTIA A+ Complete Study Guide, SSIDs define how wireless networks are advertised and discovered. By modifying SSID settings-such as disabling broadcast or restricting auto-join behavior-technicians can prevent devices from attempting to connect to unauthorized or unintended networks.
The Travis Everett & Andrew Hutz - All-in-One Exam Guide explains that MDM solutions often preconfigure approved wireless profiles. Adjusting SSID configuration ensures devices only recognize and connect to sanctioned networks, reducing accidental associations and security risks.
The Mike Meyers / Mark Soper Lab Manual clarifies that IP filtering, content filtering, and port forwarding are network traffic control mechanisms. They do not prevent a device from seeing or attempting to connect to nearby Wi-Fi networks.
Because the goal is to prevent accidental Wi-Fi access, not filter traffic after connection, modifying SSID configuration is the correct and most effective solution.
NEW QUESTION # 130
A user logs in to a computer each morning and tries to print a daily report, but it will not print. The help desk resolves the issue each day temporarily. To fix this permanently, which of the following should the technician do? (Select two)
  • A. Start the print spooler service
  • B. Set the print spooler log-on to the user's account
  • C. Start the printer extensions and notifications service
  • D. Set the print spooler to have no dependencies
  • E. Set the print spooler to Automatic
  • F. Set the print spooler recovery to take no action
Answer: A,E
The recurring print issue suggests theprint spooler service is not set to start automatically, causing it to stop between sessions. Ensuring it is set tostart automaticallyand manuallystarting the servicewill resolve the issue.
FromMark Soper - Mike Meyers' Lab Manual:
"The print spooler is essential for print services. If it isn't configured to start automatically, users may experience recurring failures."
"Manually starting the service or setting it to 'Automatic' in the Services panel resolves persistent print availability problems."
NEW QUESTION # 131
A user reports that their internally hosted CRM application splash screen attempts to load, pauses for a few seconds, and then disappears. A technician installs the application software on their computer and is able to recreate the issue. When checking the application logs, the technician sees the following:
Windows could not start the CRM Service on Local Computer 10169. The
service did not start due to a log-on failure.
Which of the following would most likely cause this issue?
  • A. The LDAP service account used by the service is disabled.
  • B. The computer does not meet minimum hardware specifications.
  • C. VLAN settings are blocking communication to the hosted application.
  • D. The user typed their account password incorrectly.
  • E. The bandwidth available is insufficient to run the application.
The log entry indicates the CRM service cannot start due to a log-on failure, which most commonly occurs when the service account used to run the application (often an LDAP/domain service account) is disabled or has incorrect credentials. This prevents the required background service from starting and causes the application to close immediately.
NEW QUESTION # 132
Whether you are good at learning or not, passing the exam can be a very simple and enjoyable matter together with our 220-1202 practice engine. As a professional multinational company, we fully take into account the needs of each user when developing our 220-1202 Exam Braindumps. For example, in order to make every customer can purchase at ease, our 220-1202 preparation quiz will provide users with three different versions for free trial, corresponding to the three official versions.
220-1202 Unlimited Exam Practice: https://www.examdiscuss.com/CompTIA/exam/220-1202/
Whereas the other two CompTIA A+ Certification Exam: Core 2 (220-1202) exam questions formats are concerned both are the easy-to-use and compatible mock 220-1202 exam that will give you a real-time environment for quick CompTIA Exams preparation, We provide our time-saved, high efficient 220-1202 actual exam containing both functions into one, Our 220-1202 exam question can be obtained within 5 minutes after your purchase and full of high quality points for your references, and also remedy your previous faults and wrong thinking of knowledge needed in this exam.
Stanley E Fawcett is the Donald L, If you don't have enough, 220-1202 New Learning Materials the Music app will let you know and offer a Buy Points button that you can click to purchase more points.
Whereas the other two CompTIA A+ Certification Exam: Core 2 (220-1202) exam questions formats are concerned both are the easy-to-use and compatible mock 220-1202 exam that will give you a real-time environment for quick CompTIA Exams preparation.
Attain 100% Success with CompTIA 220-1202 Exam Questions on Your First AttemptWe provide our time-saved, high efficient 220-1202 actual exam containing both functions into one, Our 220-1202 exam question can be obtained within 5 minutesafter your purchase and full of high quality points for 220-1202 your references, and also remedy your previous faults and wrong thinking of knowledge needed in this exam.
And with our 220-1202 practice engine, your dream will come true, As 220-1202 exam questions with high prestige and esteem in the market, we hold sturdy faith for you.
