Latest Test Mule-Dev-202 Simulations | Practice Mule-Dev-202 Exam Fee
104
Posted at 3/8/2026 08:44:55      View:86 | Replies:0        Print      Only Author   [Copy Link] 1#
As the leader in this career, we always adhere to the principle of “mutual development and benefit”, and we believe our Mule-Dev-202 practice materials can give you a timely and effective helping hand whenever you need in the process of learning. With our Mule-Dev-202 exam questions for 20 to 30 hours, you will find that you can pass the exam with confidence. Tens of thousands of our customers have tested that our pass rate of the Mule-Dev-202 study braindumps is high as 98% to 100%, which is unmatched on the market!
This is a desktop-based Mule-Dev-202 practice exam software that doesn't require an internet connection except for license validation during purchase. The software provides Salesforce Certified MuleSoft Hyperautomation Developer (Mule-Dev-202) practice exams that are customizable, helping students prepare for the actual Mule-Dev-202 Exam. The team updates the Salesforce Mule-Dev-202 tests regularly and is available 24/7 to address any issues. Assessment records are saved for easy tracking. Windows computers support the desktop Salesforce Mule-Dev-202 practice exam software.
Top Latest Test Mule-Dev-202 Simulations 100% Pass | Valid Practice Mule-Dev-202 Exam Fee: Salesforce Certified MuleSoft Hyperautomation DeveloperThe Salesforce Mule-Dev-202 exam practice questions are being offered in three different formats. These formats are Salesforce Mule-Dev-202 web-based practice test software, desktop practice test software, and PDF dumps files. All these three Salesforce Mule-Dev-202 exam questions format are important and play a crucial role in your Salesforce Certified MuleSoft Hyperautomation Developer (Mule-Dev-202) exam preparation. With the Salesforce Mule-Dev-202 exam questions you will get updated and error-free Salesforce Certified MuleSoft Hyperautomation Developer (Mule-Dev-202) exam questions all the time. In this way, you cannot miss a single Mule-Dev-202 exam question without an answer.
Salesforce Certified MuleSoft Hyperautomation Developer Sample Questions (Q14-Q19):NEW QUESTION # 14
A Salesforce flow needs to connect to external APIs provided by Northern Trail Outfitters (NTO) and AnyAirlines to retrieve data.
Which three steps should be taken to connect to the external APIs? (Choose three.)
  • A. Create External Services in Salesforce for NTO and AnyAirlines.
  • B. Create Named Credentials in Salesforce for NTO and AnyAirlines.
  • C. Use an Action element to call and consume the appropriate API in the Salesforce flow.
  • D. Create Named Credentials in Anypoint for NTO and AnyAirlines.
  • E. Use a Virtual service to call and consume the appropriate API in the Salesforce flow.
Answer: A,B,C
To connect a Salesforce flow to external APIs, follow these steps:
Create Named Credentials in Salesforce:
Named Credentials in Salesforce simplify the authentication process by storing the URL and authentication details needed to call the external service. Set up Named Credentials for both NTO and AnyAirlines APIs.
Navigate to Salesforce Setup > Named Credentials > New Named Credential.
Enter the details for NTO API, including the endpoint URL and authentication settings.
Repeat the process for the AnyAirlines API.
Create External Services in Salesforce:
External Services allow you to register the external APIs with Salesforce so that they can be invoked from a flow.
Navigate to Salesforce Setup > External Services > New External Service.
Use the OpenAPI/Swagger or RAML specification files provided by NTO and AnyAirlines to register their APIs.
This step involves importing the API specifications and configuring the services, which will be used in the flow.
Use an Action Element in Salesforce Flow:
Within Salesforce Flow, use the Action element to call the external services that were registered.
This involves adding an Action to your flow and selecting the appropriate External Service action that corresponds to the API method you want to invoke.
Salesforce External Services Documentation
Salesforce Named Credentials Documentation
NEW QUESTION # 15
Which type of integration project should be implemented with MuleSoft Composer?
  • A. Batch processing of larger-than-memory files with conditional logic within the batch steps
  • B. Automating Ul interactions using image recognition
  • C. Long runningworkflows that require manual steps and approvals byusers
  • D. Data transformation from a source system to a target system by a non-technical user
MuleSoft Composer is designed for business users to create integrations without deep technical knowledge. It is ideal for scenarios that involve:
Data Transformation and Integration:
Non-technical users can easily connect different systems, automate data transfers, and transform data from one system to another using a no-code interface.
MuleSoft Composer provides pre-built connectors and an intuitive interface to set up these integrations.
Simplified Automation:
The platform is optimized for creating straightforward, rule-based automations where complex coding is not required.
Therefore, automating data transformation tasks by a non-technical user fits perfectly with MuleSoft Composer's capabilities.
MuleSoft Composer Documentation
NEW QUESTION # 16
AnyAirlines is developing an RPA process to extract information from a legacy system. To capture the manual workflow, they leverage RPA Recorder.
Which two best practices should they be aware of when working with the autogenerated workflow code?
(Choose two.)
  • A. All autocaptured information is for documentation purposes only.
  • B. The autogenerated workflows may contain sensitive information that must be removed.
  • C. All keystrokes and mouse clicks in the autogenerated code must be disabled before deploying to production.
  • D. Some autogenerated code must be replaced with more robust or specialized action steps.
When developing an RPA process using RPA Recorder, it is essential to be mindful of the following best practices concerning the autogenerated workflow code:
Replace Autogenerated Code:
Robustness: Some of the autogenerated code may not be optimized for robustness or specific use cases. It is often necessary to review and replace parts of the autogenerated workflow with more robust or specialized action steps to ensure reliability and accuracy.
Specialization: Customizing the workflow to fit the specific requirements of the process can improve performance and handle exceptions better.
Remove Sensitive Information:
Sensitive Data: Autogenerated workflows might capture sensitive information such as usernames, passwords, or other confidential data. It is crucial to identify and remove or mask this information before deploying the RPA process to production to maintain security and compliance.
Compliance: Ensuring that sensitive information is handled appropriately helps in adhering to data protection regulations and organizational policies.
MuleSoft RPA Documentation
NEW QUESTION # 17
An AnyAirlines employee regularly performs a manual process to extract customer and flight information from multiple legacy systems. AnyAirlines recently purchased MuleSoft automation and wants to automate this process using MuleSoft RPA.
During an evaluation of the candidate RPA process, which two key qualifiers should be considered? (Choose two.)
  • A. Is the process data-driven?
  • B. Is the process risky?
  • C. Is the process rule-based?
  • D. Is the process speed-sensitive?
When evaluating a candidate process for RPA automation using MuleSoft RPA, consider the following key qualifiers:
Is the Process Rule-Based?:
RPA is well-suited for processes that follow clear, predefined rules. If the process involves repetitive tasks with defined rules and decision points, it is a good candidate for RPA automation.
Rule-based processes can be accurately automated by RPA bots without the need for complex decision- making.
Is the Process Data-Driven?:
Data-driven processes involve manipulating, transferring, and extracting data, making them ideal for RPA automation.
If the manual process involves working with structured data (e.g., extracting customer and flight information), it is a good fit for RPA, as bots can efficiently handle data operations.
Other considerations like risk and speed sensitivity are also important but focusing on rule-based and data- driven aspects ensures that the process is structured and systematic, making it easier to automate reliably.
RPA Best Practices
NEW QUESTION # 18
Which component of Anypoint Platform is responsible for enforcing API policies?
  • A. API Gateway
  • B. API Runtime
  • C. API Analytics
  • D. API Manager
The component of Anypoint Platform responsible for enforcing API policies is the API Gateway:
API Gateway:
The API Gateway is a runtime component that enforces policies applied to APIs. It acts as an intermediary that manages API traffic, security, and performance by applying the policies configured in API Manager.
Policies such as rate limiting, security, transformation, and monitoring are enforced at the API Gateway to ensure that APIs are accessed securely and efficiently.
Anypoint Platform API Gateway Documentation
NEW QUESTION # 19
Desktop-based practice exam software Mule-Dev-202 is the first format that Prep4sureGuide provides to its customers. It helps track the progress of the candidate from beginning to end and provides a progress report that is easily accessible. This Salesforce Mule-Dev-202 Practice Questions is customizable and mimics the real exam, with the same format, and is easy to use on Windows-based computers. The product support staff is available to assist with any issues that may arise.
Practice Mule-Dev-202 Exam Fee: https://www.prep4sureguide.com/Mule-Dev-202-prep4sure-exam-guide.html
Everyone in our company work hard to improve Mule-Dev-202 exam torrent questions to save more cherish time for our users and help them pass the Mule-Dev-202 test as soon as possible, and our company strictly follows the rule of private policy by using most international credit cards as the online payment method of Mule-Dev-202 test guide, which can avoid the fraud transaction and guarantee the safety for our users, And we make synchronization with offical Mule-Dev-202 to make sure our Mule-Dev-202 certification data is the newest.
Navigate the Pinterest Website, Each social media site offers these conversations in its own way, using content as the currency of communications exchange, Everyone in our company work hard to improve Mule-Dev-202 exam torrent questions to save more cherish time for our users and help them pass the Mule-Dev-202 test as soon as possible, and our company strictly follows the rule of private policy by using most international credit cards as the online payment method of Mule-Dev-202 test guide, which can avoid the fraud transaction and guarantee the safety for our users.
Salesforce Latest Test Mule-Dev-202 Simulations - First-Grade Practice Mule-Dev-202 Exam Fee and Pass-Sure Mock Salesforce Certified MuleSoft Hyperautomation Developer ExamsAnd we make synchronization with offical Mule-Dev-202 to make sure our Mule-Dev-202 certification data is the newest, We will offer you the best preparation materials regarding Mule-Dev-202 training practice.
However, that is not certain and sure enough Mule-Dev-202 to successfully pass this exam, We make sure you to get a 100% pass for the test.
