[General] Microsoft MB-230 Practice Exams for Thorough Preparation (Desktop & Web-Base
76
General Microsoft MB-230 Practice Exams for Thorough Preparation (Desktop & Web-Base
Posted at 3/8/2026 11:56:27      View163 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Microsoft MB-230 dumps are available on Google Drive shared by DumpsReview: https://drive.google.com/open?id=1xs13ZO2ZhPxlM8TuI3dNAYv0v4NFdr7-
According to the survey, the candidates most want to take Microsoft MB-230 test in the current IT certification exams. Of course, the Microsoft MB-230 certification is a very important exam which has been certified. In addition, the exam qualification can prove that you have high skills. However, like all the exams, Microsoft MB-230 test is also very difficult. To pass the exam is difficult but DumpsReview can help you to get Microsoft MB-230 certification.
How much MB-230: Microsoft Dynamics 365 Customer Service Exam CostThe price of the MB-230: Microsoft Dynamics 365 Customer Service exam is $165 USD, for more information related to exam price please visit to Microsoft Training website as prices of Microsoft exams fees get varied country wise.
Exam MB-230 Topic | MB-230 Braindump PdfThe web-based Microsoft MB-230 practice exam does not require special plugins and creates a MB-230 testing atmosphere that removes candidates exam anxiety. "DumpsReview" web-based Microsoft Dynamics 365 Customer Service Functional Consultant (MB-230) practice test tracks your progress and helps you overcome mistakes. Our Microsoft MB-230 practice exam software displays results at the end of each attempt.
Career Path After Acing Microsoft MB-230 ExamThe Microsoft MB-230 exam leads to the associate-level certification. This certificate is all you need to be successful in your field. After earning it, you will be able to apply for several job roles, which also offer a good salary. To be precise, these are the positions you can pursue after getting certified:
  • Microsoft Dynamics Consultant;
  • Microsoft Dynamics CRM Architect;
  • Microsoft Architect;
  • Dynamics Ax Developer;
  • Dynamics Ax Solution Architect.
Interestingly, all the above-mentioned job titles are paid between $24,807 and $99,751 per year.
Microsoft Dynamics 365 Customer Service Functional Consultant Sample Questions (Q11-Q16):NEW QUESTION # 11
You need to build a personal dashboard that displays the following charts and views:
Charts:
* Number of cases by owner and priority
* Products with most cases opened
* Display the number of cases opened in a seven-day period
* Display the number of escalated cases
A picture containing application Description automatically generated
https://docs.microsoft.com/en-us ... ashboard-and-charts
NEW QUESTION # 12
A company uses Dynamics 365 Customer Service. The company installs Dynamics 365 Customer Service Insights.
The company wants to use dashboards to report phone calls and emails to monitor the productivity of representatives.
You need to perform the configuration.
Which configuration should you use? To answer, select the appropriate configurations in the answer area.
Box 1: Go to the Dynamics 365 Customer Service URL and choose the Dynamics 365 Customer Service Insights dashboard.
Customer Service Insights is now embedded in Dynamics 365 Customer Service. After it is enabled, this experience allows you to start seeing historical analytics directly within the Customer Service environment.
Several reports and dashboards can be viewed by your management team.
Box 2: Channel
https://docs.microsoft.com/en-us ... r-service-analytics
NEW QUESTION # 13
A company has satellite offices that service local areas.
Each office must have full control over its own resources.
You need to configure the organizational units to reflect the satellite office structure.
Which entities should you use to relate to the organizational units? To answer, select the appropriate options in the answer area.
NEW QUESTION # 14
You need to create an entitlement template. In System Settings, you navigate to Service Management.
Graphical user interface, text, application Description automatically generated
https://docs.microsoft.com/en-us ... itlements-templates
NEW QUESTION # 15
You are configuring a business process flow for a case entity.
All cases must be flagged for review.
You need to complete configuration of the business process flow.
Solution: Set the input parameter type as Option set for the action.
Does the solution meet the goal?
  • A. No
  • B. Yes
Section: Topic 1, Perform Configuration
NEW QUESTION # 16
Exam MB-230 Topic: https://www.dumpsreview.com/MB-230-exam-dumps-review.html
BONUS!!! Download part of DumpsReview MB-230 dumps for free: https://drive.google.com/open?id=1xs13ZO2ZhPxlM8TuI3dNAYv0v4NFdr7-
