[General] Microsoft MB-820 Dumps PDF- Easiest Preparation Method [2026]
79
General Microsoft MB-820 Dumps PDF- Easiest Preparation Method [2026]
Posted at 3/8/2026 12:54:08      View156 | Replies0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of PassSureExam MB-820 dumps for free: https://drive.google.com/open?id=1ua36JaJk5ktqkFEFVVlzt3iaUrxySMkr
Our Microsoft Dynamics 365 Business Central Developer Web-Based Practice Exam is compatible with all major browsers, including Chrome, Internet Explorer, Firefox, Opera, and Safari. No specific plugins are required to take this Microsoft Dynamics 365 Business Central Developer practice test. It mimics a real MB-820 test atmosphere, giving you a true exam experience. This Microsoft Dynamics 365 Business Central Developer (MB-820) practice exam helps you become acquainted with the exam format and enhances your test-taking abilities.
Our company boosts top-ranking expert team, professional personnel and specialized online customer service personnel. Our experts refer to the popular trend among the industry and the real exam papers and they research and produce the detailed information about the MB-820 exam dump. They constantly use their industry experiences to provide the precise logic verification. The MB-820 prep material is compiled with the highest standard of technology accuracy and developed by the certified experts and the published authors only. The test bank is finished by the senior lecturers and products experts. The MB-820 Exam Dump includes the latest MB-820 PDF test questions and practice test software which can help you to pass the test smoothly. The test questions cover the practical questions in the test Microsoft certification and these possible questions help you explore varied types of questions which may appear in the test and the approaches you should adapt to answer the questions.
Reliable MB-820 Test Price - MB-820 Latest Test PreparationMB-820 exam training allows you to pass exams in the shortest possible time. If you do not have enough time, our study material is really a good choice. In the process of your learning, our study materials can also improve your efficiency. If you don't have enough time to learn, MB-820 test guide will make the best use of your spare time, and the scattered time will add up. The service of MB-820 Test Guide is very prominent. It always considers the needs of customers in the development process. There are three versions of our MB-820 learning question, PDF, PC and APP. Each version has its own advantages. You can choose according to your needs.
Microsoft Dynamics 365 Business Central Developer Sample Questions (Q27-Q32):NEW QUESTION # 27
You need to parse the API JSON response and retrieve each order no. in the response body.
How should you complete the code segment? To answer select the appropriate options in the answer area.
Code Segment Analysis:
* The AL code is trying to read JSON data from a response and process it to extract subcontracting order numbers. It uses JsonToken, JsonObject, and JsonArray to work with the JSON data.
* JToken.ReadFrom(Data): This line reads the incoming JSON data and converts it into a token. It processes the full JSON body so you can start working with it.
* JToken.SelectToken("results"): This line selects the part of the JSON containing the results array.
The key "results" is where the JSON response data is expected to be found.
* JsonArray: Once the results are extracted, they are stored as an array, and each element in the array (which is expected to contain subcontracting order numbers) is processed.
* SubcontractingOrderNo: The extracted order_no from the JSON is stored in this variable.
Breakdown of Steps:
* JToken.ReadFrom(Data): This step reads the entire JSON response.
* JToken.SelectToken("results"): This step selects the results array from the JSON response.
* JArray.AsArray(): This step converts the selected results token into a JSON array that can be iterated over.
* GetValueAsText(JToken, 'order_no'): This step retrieves the order_no from each element in the array.
Correct Code Completion:
* JToken.ReadFrom(Data): This is the correct method to read the incoming JSON response, as it will convert the string into a JsonToken that can be further processed.
* JToken.SelectToken("results"): This is the correct method to extract the results array from the token.
This method looks for the key "results" in the JSON and retrieves the relevant array.
Final Code Segment:
al
Copy code
procedure ReadJsonData(Data: text)
var
JToken: JsonToken;
JObject: JsonObject;
JArray: JsonArray;
SubcontractingOrderNo: Code[20];
begin
if Data = '' then
exit;
JToken := JToken.ReadFrom(Data); // Step 1: Read the JSON response data.
JToken := JToken.SelectToken('results'); // Step 2: Select the "results" array.
JArray := JToken.AsArray(); // Convert the token into a JSON array.
foreach JToken in JArray do begin
SubcontractingOrderNo := GetValueAsText(JToken, 'order_no'); // Retrieve the order number.
end;
end;
* JToken.ReadFrom(Data): This reads the raw JSON data string and converts it into a JSON token that can be processed.
* JToken.SelectToken("results"): This extracts the results array from the JSON data.
* JArray.AsArray(): Converts the token into an array so we can iterate over it.
* GetValueAsText(JToken, 'order_no'): Extracts the order_no value from each item in the array.
NEW QUESTION # 28
You develop a test application.
You must meet the following requirements:
* Roll back changes to a test method after run time.
* Run an approve action on a test page named TestPageA.
You need to implement the given requirements on the test codeunit
Which actions should you perform? To answer, select the appropriate options in the answer area NOTE: Each correct selection is worth one point.
To roll back changes to a test method after run time, you should:
* Set the TransactionModel attribute to AutoRollback.
To run an approve action on a test page named TestPageA, you should:
* Configure TestPageA.Approve.Invoke().
In Business Central's testing framework, the TransactionModel attribute can be set to AutoRollback. This ensures that any changes made during the test are rolled back after the test is complete, leaving the database in its original state.
For running an action on a test page, you would use the 'Invoke' method on the action you wish to perform. In this case, to run an approve action on TestPageA, you would use TestPageA.Approve.Invoke() within your test codeunit. This simulates the user action of approving something on the page.
These actions ensure that the testing environment is properly set up to test specific functionalities without persisting test data and to invoke actions as part of the test scenarios.
NEW QUESTION # 29
You need to configure telemetry for the SaaS tenant and test whether the ingested signals are displayed.
1 - Create an Azure Application Insights instance by using...
2 - Select the environment in the Admin Center...
3 - Select the Application Insights instance, select Logs...
Topic 1, Contoso, Ltd.
Overview
Contoso, Ltd. Is a sales company in the manufacturing industry. It has subsidiaries in multiple countries/regions, each with its own localization. The subsidiaries must be data-independent from each other. Contoso. Ltd. uses an external business partner to manage the subcontracting of some manufacturing items. Contoso. Ltd. has different sectors with data security between sectors required.
Contoso, Ltd. uses Business Central online as the main ERP for financial. sales, purchase, warehouse, and manufacturing processes. It has employees that use the Business Central web application and external applications. The company has a custom external mobile app under development The IT department and its partners installed custom extensions to satisfy the company's requirements where the functionality is not available natively.
Contoso. Ltd. interacts with external services provided by customers and partners. Different applications interact with SOAP and OData endpoints exposed from Business Central.
An external business partner of Contoso, Ltd exposed a REST API for receiving details about new subcontracting orders and for sending the planned release date of each subcontracting order received.
Contoso. Ltd. has not activated the monitoring of the tenant and has no internal telemetry for its apps.
Custom reporting must be created to meet the requirements of the different departments.
Contoso, Ltd. has the following tenant management considerations:
IT department
* The IT department requires the ability to monitor the tenant to prevent performance problems and detect possible anomalies.
* The IT department plans to use Azure Application Insights and Log Analytics to inspect the ingested telemetry signals.
* All tenant upgrades are automatically handled by Microsoft. The IT department does not check for update availability or for tenant-related notifications.
* The IT department has not configured the receipt of tenant-related notifications from the Business Central admin center.
External business partner
* The external business partner must add custom telemetry to an application created for Contoso. Ltd. to monitor a business process.
* Custom telemetry signals for the application must be visible only on the partner's telemetry.
SOAP
* Contoso, Ltd. plans to dismiss using the SOAP protocol for integrations.
* Contoso, Ltd. must be able to detect if external applications are using its Business Central SOAP endpoints.
Issue
The Business Central tenant is upgraded by Microsoft to a new major version during the night.
Users report that one of the Contoso. ltd. extensions disappeared from the tenant The IT department confirms that the extension is still published.
Contoso. Ltd. plans to create a custom mobile application that has the following requirements:
* The app must be used by employees to check item details from the ERP in real time and to report issues that occur during the manufacturing process.
* An AL extension must be created for handling archived issues.
* Business Central development guidelines must be followed when implementing modules.
* A module must be implemented for the reporting and tracking of issues information. You plan to call this module Issue Management The module must expose a method nan Postlude.
* Code modifications will be required over time.
* The Issue Management process must be split into two extensions:
o ISSUE BASE: main extension
o ISSUE EXT: second extension with dependency from ISSUE BASE
* In the version 1.0.0.0 of the ISSUE BASE extension, you plan to create an Issue table that contains a global Decimal variable named Issue Total.
* In the version 1.0.0.0 of the ISSUE BASE extension, you plan to define a table named Issue Category with a Description field defined as follows:
field (2; Description; Text[SG])
DataClassificstion * CustoaerContent;
* The Issue table defined in ISSUE BASE extension contains a Clone procedure defined as follows:
procedure Corte () begin end;
* In the ISSUE EXT extension, you create a table extension object of the Issue table.
* The table extension object of the Issue table must access the Issue Total: Decimal variable.
After weeks of usage, you discover that you must remove the Description field and the Clone procedure because they are no longer required.
In a new version of the ISSUE BASE extension, you create a new Issue Type table. You must move data row by row from a previously obsolete Issue Category table to the new Issue Type table. Because a large amount of data must be moved, you must write an Upgrade codeunit by using the DataTransfer object.
The IT department creates a custom API for exposing the custom Issue table. The API provides an action for copying an issue to a new table. The action is defined as follows:
(Service Enabled]
procedure Copy (vary action Context: WebServiceActionContext)
begin
end;
Contoso, Ltd. must create an API in Business Central to expose item details to the mobile application.
* The API must have the lowest possible impact on the production environment when used during working hours.
* The API must only support Get operations.
A user of the ISSUE BASE extension in Business Central reports a problem.
To debug the problem, snapshot debugging with the following configuration was activated:
You discover that the debugging is not triggering.
Contoso, Ltd. must connect Business Central to the external API provided by the business partner. This will be used for the partner to send the details of new subcontracting orders to fulfill the sales demand, and for receiving the planned release date of each order sent. The integration requirements are as follows:
* The business partner will provide a REST API secured with basic authentication. Credentials to access the API will be shared with Contoso, ltd.
* The API for sending subcontracting orders must be called by sending an authenticated POST request to the given endpoint.
* The API for retrieving the order no. and planned release date of each subcontracting order responds with the following JSON:
Each order no. must be retrieved.
NEW QUESTION # 30
You need to create the Install codeunit that is requited in the extension used for installing or updating the Housekeeping app.
Which data type or declaration should you use? To answer, select the appropriate options in the answer area.
NOTE; Each correct selection is worth one point.
For the Install codeunit required for the extension used for installing or updating the Housekeeping app, you should use the following data type and declaration:
* Data type for information: ModuleInfo
* Start of the declaration of the method or procedure to perform the tasks: local procedure In AL language, which is used for developing extensions in Business Central, an Install codeunit is a special type of codeunit that is used to handle installation or upgrade logic for an extension.
* ModuleInfo is a data type that contains information about the current extension, such as its version. It is typically used within the OnInstallAppPerCompany or OnUpgradePerCompany triggers of an Install codeunit to determine if the app is being installed for the first time or upgraded.
* A local procedure within an Install codeunit is a method that is only accessible within the codeunit itself. It is not visible to other objects or extensions. This is suitable for tasks that are internal to the installation process and should not be exposed globally.
These selections align with the requirements of handling installation and update procedures in a controlled and encapsulated manner within Business Central extensions.
Topic 1, Case Study Alpine Ski House
Alpine Ski House is a company that owns and operates hotels, restaurants, and stores. Currently, the company uses the following software and interlace:
* Property management software (PMS) to manage hotel rooms
* On-premises accounting software to generate sales invoices and create purchase orders
* An API that allows restaurants and stores to obtain necessary information Restaurants and stores use standalone software for point of sale (POS) devices. Each day, the POS terminals generate a text file of sales data and save the files in a serval folder. An account assistant must manually import the files to the current software tables to be processed by the system.
The general manager receives several reports monthly from department managers. The reports take too much time to prepare.
The company is moving from a different system to Business Central online to manage the whole company.
The company plans to increase efficiency in every department by using APIs to obtain or share information between the different systems.
Each department involved in purchasing must be able to make purchase requests automatically and easily.
The departments do not need access to the full ERP management system.
Alpine Ski House requires the development of several extensions for the planned improvements. Business Central design patterns must be used to develop all extensions.
Alpine Ski House must develop the following pages:
* Pages that provide multiple configurations in a multistep dialog, like a wizard, to provide required information when the extensions are first installed
* Department-specific Role Center pages to show relevant information and pages with additional information The IT department plans to use Power 61 to analyze departmental information. The database must be configured to provide optimal performance.
The housekeeping department requires the following to increase efficiency and help avoid data entry errors:
* A Housekeeping Role Center to minimize navigation to relevant areas In Business Central online and to show relevant information in it
* Pages to embed into a new Room page to show additional information about the Room entity
* A table named Room Incident for the housekeeping team to enter room issue information
* A Housekeeping canvas app that connects to an extension
The department requires the development of an extension with a new API page named RoomsAPI.
* The housekeeping team will use RoomsAPI to publish room details, update when work is complete, or provide repair notifications from the canvas app.
* This custom API page must expose a custom table named Rooms and have an ID 50000. The table must be able to update from the PMS. The PMS team must know the end to connect to the custom API.
* A developer provides the following details for the API page:
APIPublisher = 'alpine';
APIGroup - 'integration';
APIVersion - 'v2.6';
fntityName # 'room';
EntitySetName = 'rooms';
* The extension must be published in Business Central online and include a list page named Room List that includes all hotel rooms.
* Installation or updates to this extension must meet the following requirements:
o Some web services must be published automatically.
o The version of the specified application's metadata must be obtained in AL language.
o The code required to perform tasks cannot be accessible from other parts of the application.
The Room Incident table information must include the following fields:
* Incident entry: An incremental number
* Room No.: A room from the Room table
* Incident Date: The work date
o The table definition in the Room Incident table must autofill the Incident Date when the housekeeping team inserts a new record, o The value for Incident Date must be the work date configured in the Business Central online client.
* Status: Includes the following options lo identify the status of the incident:
o Open: When the Room Incident is created
o In Progress: When someone starts repair work
o Closed: When the incident is solved
* Incident Closing Date: Auto-updating field (when the status passes to Closed, the field will update with the work date)
* Incident Description: Text
* Image. Media data type
o The stored picture must be downloadable from a menu action.
o A Room Incident page must be developed to contain the download action.
To increase efficiency, the new system must manage the generated data from the restaurants and stores directly by using the API on the POS terminals.
* The company requires a code unit called from a job queue to read the information from the POS terminal APIs.
* The POS terminal information must be stored in a table named POS Information, have an ID 50100. and be editable on a page.
* The account manager requires an option on the menu of the page to run the process manually.
To analyze the information received from the POS terminals, the company requires:
* A custom API named ticketAPI to export the information to Power BI
* Use of the Read Scale-Out feature to improve database performance
The purchasing department requites a new entity in Business Central online to log non-conformities of goods received from vendors. The entity must be set up as follows:
* The non-conformity entity must have two tables:
o a header with common information
o one or more lines with the detailed received items that are non-conforming
* The entity requires a page named Non-conformity and a subpage named Non-Conformity Lines to store the information.
When a purchase order with incorrect quantity 01 quality issues is received, the entity must create a non- conformity document in the system. The following information must be nick the document:
* Non-conformity Number: must use the No. Series table from Business Central online to manage this field and use these features:
o Alphanumeric values
o Number format that includes "NO and the year as part of the number: for example, NC24-001
* Non-conformity Date: stores only the creation date
* Vendor No.: stores the number of the vendor that sent the items; only vendors from the company must be included
* Owner: code of an employee defined in the company
* Receipt No.: must meet the following conditions:
o Be an existing receipt No.
o Be received from the vendor indicated in the Vendor No. field
* Comments: can include comments with rich text and pictures to illustrate quality problems
* Status: includes nonconformity statuses, such as:
o Open
o Notified
o Closed
* Lines must contain the following details:
o Item No.: item received (for existing inventory items only)
o Description: item description
0 Quantity: non-conforming quantity
0 Non-conformity Type:
# Quality
# Quantity
# Delivery date
The serial numbers of the non-conformities and the period in which they can be created must be in a configuration table and its corresponding page to allow them to be modified for the users.
NEW QUESTION # 31
You need to create the access modifier for IssueTotal.
Which variable declaration should you use?
  • A. Protected vat IssueTotal: Decimal
  • B. Local var IssueTotal: Decimal
  • C. Public var IssueTotal: Decimal
  • D. Var IssueTotal; Decimal
  • E. Internal var IssueTotal: Decimal
Answer: E
In Business Central development using AL (the language for Business Central extensions), the use of access modifiers defines how variables and procedures are accessed within and outside of an object or codeunit.
* Access Modifiers in AL:
* Public: A public variable can be accessed from any object or codeunit within the same module or extension.
* Protected: This restricts access to the current object and objects that inherit from the current object. However, in AL (at least in versions used for Business Central), the Protected access modifier is used with methods but not variables.
* Internal: This modifier restricts the visibility to the current extension. This means that variables or methods declared as internal can only be accessed from within the same extension. This is appropriate when you want to provide functionality that is shared within the extension but not exposed externally.
* Local: This restricts the variable or method to the current object or method where it is declared. It cannot be accessed from anywhere else, even within the same extension.
* Scenario Justification:
* In the scenario for Contoso, Ltd., IssueTotal is a global variable in the ISSUE BASE extension, and the ISSUE EXT extension needs to access it. Therefore, the variable cannot be declared as Local, because this would restrict access to just the current object (or method).
* Using Public would expose the variable outside of the extension, which is unnecessary because you only want other parts of the extension (specifically the ISSUE EXT extension) to have access.
* The best choice in this case is Internal because it restricts access to the variable to within the same extension, which includes the base extension and any dependent extensions like ISSUE EXT. It strikes the right balance between visibility and encapsulation.
Microsoft Dynamics 365 Business Central Developer References:
* Access Modifiers in AL: Microsoft's documentation on AL provides the details on access modifiers, where it is specified that internal variables can be accessed within the extension, and the public variable is accessible across all extensions#source: Microsoft Learn on AL Programming#.
* Best Practices for AL Development: Business Central development best practices suggest keeping variables internal unless they need to be accessed outside of the current extension#source: Microsoft Learn on AL development guidelines#.
Topic 1, Contoso, Ltd. Contoso, Ltd. Is a sales company in the
IT department
SOAP
Issue
(Service Enabled]
begin
end;
NEW QUESTION # 32
We will provide you with comprehensive study experience by give you MB-820 free study material & Microsoft exam prep torrent. The questions & answers from the Microsoft practice torrent are all valid and accurate, made by the efforts of a professional IT team. The authority and validity of Microsoft MB-820 training practice are the guarantee for all the IT candidates. We arrange our experts to check the update every day. Once there is any new technology about MB-820 Exam Dumps, we will add the latest questions into the MB-820 study pdf, and remove the useless study material out, thus to ensure the MB-820 exam torrent you get is the best valid and latest. So 100% pass is our guarantee.
Reliable MB-820 Test Price: https://www.passsureexam.com/MB-820-pass4sure-exam-dumps.html
The MB-820 exam torrent can prove your ability to let more big company to attention you, Compared with other exam trainings which are engaged in the question making, our MB-820 exam guide materials do outweigh all others concerning this aspect, To get the Microsoft Dynamics 365 Business Central Developer MB-820 practice test, find a reliable source that provides the MB-820 exam dumps to their clients, Microsoft MB-820 Exam Discount Opportunities are everywhere.
Drag the proxy to the right of the smoothed head if you like, Exam Preparation Tasks, The MB-820 Exam Torrent can prove your ability to let more big company to attention you.
Compared with other exam trainings which are engaged in the question making, our MB-820 exam guide materials do outweigh all others concerning this aspect, To get the Microsoft Dynamics 365 Business Central Developer MB-820 practice test, find a reliable source that provides the MB-820 exam dumps to their clients.
Get The Actual Microsoft MB-820 Exam Questions In PDFOpportunities are everywhere, We work MB-820 to install a strong willingness to learn while enhancing your knowledge.
2026 Latest PassSureExam MB-820 PDF Dumps and MB-820 Exam Engine Free Share: https://drive.google.com/open?id=1ua36JaJk5ktqkFEFVVlzt3iaUrxySMkr
