How Can You Successfully Get the Quality VMware 2V0-13.25 Exam Questions?
Posted at 3/8/2026 13:54:00
BONUS!!! Download part of Actual4Exams 2V0-13.25 dumps for free: https://drive.google.com/open?id=1ZG-8HoJI9A1_p6kvXKRLK3qgHhn2ZdVJ
The most important part of VMware 2V0-13.25 exam preparation is practice, and the right practice is often the difference between success and failure. Actual4Exams also makes your preparation easier with practice test software to help you get hands-on exam experience before the actual VMware Cloud Foundation 9.0 Architect (2V0-13.25) exam. After consistent practice, the final exam will not be too difficult for a student who has already practiced from real VMware 2V0-13.25 exam questions.
Actual4Exams's VMware Certification 2V0-13.25 Exam testing exercises is very similar with real exam questions. If you choose Actual4Exams's testing practice questions and answers, we will provide you with a year of free online update service. Actual4Exams can 100% guarantee you to pass the exam, if you fail to pass the exam, we will full refund to you.
Latest 2V0-13.25 Test Questions & 2V0-13.25 Practice Test FeeFor candidates who are going to select the 2V0-13.25 training materials for the exam, the pass rate for the 2V0-13.25 training materials is important. With pass rate reaching 98.65%, the exam dumps have reached great popularity among the candidates, and we have received many good feedbacks from the buyers. In addition, 2V0-13.25 Exam Materials are edited by professional experts, they possess the professional knowledge for the exam, therefore the quality can be guaranteed. We have free demo for you to have a try for 2V0-13.25 training materials. You can have a try before buying.
VMware Cloud Foundation 9.0 Architect Sample Questions (Q69-Q74):NEW QUESTION # 69
Which VMware tool allows for cost and usage analytics in a VMware Cloud Foundation deployment?
- A. VMware vSphere
- B. VMware NSX
- C. VMware vSAN
- D. VMware vRealize Operations
VMware vRealize Operations provides the tools necessary to analyze costs and optimize cloud resources in VMware Cloud Foundation.
NEW QUESTION # 70
When determining the compute capacity for a VMware Cloud Foundation VI Workload Domain, which three elements should be considered when calculating usable resources? (Choose three.)
- A. CPU/Cores per VM
- B. VM swap file
- C. Number of VMs
- D. Number of 10GbE NICs per VM
- E. vSAN space efficiency feature enablement
- F. Disk capacity per VM
Answer: A,B,E
When determining the compute capacity for a VMware Cloud Foundation (VCF) VI Workload Domain, the goal is to calculate the usable resources available to support virtual machines (VMs) and their workloads. This involves evaluating the physical compute resources (CPU, memory, storage) and accounting for overheads, efficiency features, and configurations that impact resource availability. Below, each option is analyzed in the context of VCF 5.2, with a focus on official documentation and architectural considerations:
A). vSAN space efficiency feature enablement
This is a critical element to consider. VMware Cloud Foundation often uses vSAN as the primary storage for VI Workload Domains. vSAN offers space efficiency features such as deduplication, compression, and erasure coding (RAID-5/6). When enabled, these features reduce the physical storage capacity required for VM data, directly impacting the usable storage resources available for compute workloads. For example, deduplication and compression can significantly increase usable capacity by eliminating redundant data, while erasure coding trades off some capacity for fault tolerance. The VMware Cloud Foundation 5.2 Planning and Preparation documentation emphasizes the need to account for vSAN policies and efficiency features when sizing storage, as they influence the effective capacity available for VMs. Thus, this is a key factor in compute capacity planning.
B). VM swap file
The VM swap file is an essential consideration for compute capacity, particularly for memory resources. In VMware vSphere (a core component of VCF), each powered-on VM requires a swap file equal to the size of its configured memory minus any memory reservation. This swap file is stored on the datastore (often vSAN in VCF) and consumes storage capacity. When calculating usable resources, you must account for this overhead, as it reduces the available storage for other VM data (e.g., virtual disks). Additionally, if memory overcommitment is used, the swap file size can significantly impact capacity planning. The VMware Cloud Foundation Design Guide and vSphere documentation highlight the importance of factoring in VM swap file overhead when determining resource availability, making this a valid element to consider.
C). Disk capacity per VM
While disk capacity per VM is important for storage sizing, it is not directly a primary factor in calculating usable compute resources for a VI Workload Domain in the context of this question. Disk capacity per VM is a workload-specific requirement that contributes to overall storage demand, but it does not inherently determine the usable CPU or memory resources of the domain. In VCF, storage capacity is typically managed by vSAN or other supported storage solutions, and while it must be sufficient to accommodate all VMs, it is a secondary consideration compared to CPU, memory, and efficiency features when focusing on compute capacity. Official documentation, such as the VCF 5.2 Administration Guide, separates storage sizing from compute resource planning, so this is not one of the top three elements here.
D). Number of 10GbE NICs per VM
The number of 10GbE NICs per VM relates to networking configuration rather than compute capacity (CPU and memory resources). While networking is crucial for VM performance and connectivity in a VI Workload Domain, it does not directly influence the calculation of usable compute resources like CPU cores or memory. In VCF 5.2, networking design (e.g., NSX or vSphere networking) ensures sufficient bandwidth and NICs at the host level, but per-VM NIC counts are a design detail rather than a capacity determinant. The VMware Cloud Foundation Design Guide focuses NIC considerations on host-level design, not VM-level compute capacity, so this is not a relevant element here.
E). CPU/Cores per VM
This is a fundamental element in compute capacity planning. The number of CPU cores assigned to each VM directly affects how many VMs can be supported by the physical CPU resources in the VI Workload Domain. In VCF, compute capacity is based on the total number of physical CPU cores across all ESXi hosts, with a minimum of 16 cores per CPU required for licensing (as per the VCF 5.2 Release Notes and licensing documentation). When calculating usable resources, you must consider how many cores are allocated per VM, factoring in overcommitment ratios and workload demands. The VCF Planning and Preparation Workbook explicitly includes CPU/core allocation as a key input for sizing compute resources, making this a critical factor.
F). Number of VMs
While the total number of VMs is a key input for overall capacity planning, it is not a direct element in calculating usable compute resources. Instead, it is a derived outcome based on the available CPU, memory, and storage resources after accounting for overheads and per-VM allocations. The VMware Cloud Foundation 5.2 documentation (e.g., Capacity Planning for Management and Workload Domains) uses the number of VMs as a planning target, not a determinant of usable capacity. Thus, it is not one of the top three elements for this specific calculation.
Conclusion:
The three elements that should be considered when calculating usable compute resources are vSAN space efficiency feature enablement (A), VM swap file (B), and CPU/Cores per VM (E). These directly impact the effective CPU, memory, and storage resources available for VMs in a VI Workload Domain.
Reference: VMware Cloud Foundation 5.2 Planning and Preparation Workbook VMware Cloud Foundation 5.2 Design Guide VMware Cloud Foundation 5.2 Release Notes VMware vSphere 8.0 Update 3 Documentation (for VM swap file and CPU allocation details) VMware Cloud Foundation Administration Guide
NEW QUESTION # 71
What are the most important steps in troubleshooting Broadcom RAID controller issues in VMware environments?
- A. Check RAID controller firmware version
- B. Verify RAID array status
- C. Monitor storage performance metrics
- D. Reset RAID controller settings
Answer: A,B,C
Checking firmware, RAID array status, and monitoring performance metrics are essential to RAID controller troubleshooting.
NEW QUESTION # 72
Which VMware tools are critical for managing security policies across virtualized workloads in VMware Cloud Foundation?
- A. VMware vSphere
- B. VMware vRealize Automation
- C. VMware NSX
- D. VMware vSAN
VMware NSX is key for managing security policies across virtualized workloads.
NEW QUESTION # 73
Which statement would be classified as a functional (business) requirement?
- A. Third-party pen testing must be executed against the solution yearly with a pass rate of 80 percent or higher.
- B. The self-service catalog must meet the Service Level Objective (SLO) of 75% successful requests measured over a 12-month period.
- C. Applications must be designed to tolerate the failure of a single datacenter.
- D. The solution must provide the ability for users to view and track the progress of their requests.
In the VMware Cloud Foundation 9.0.1 Design and Architecture Framework, functional (business) requirements describe what the system must do - the specific behaviors, features, or services it must provide to meet business objectives.
The statement, "The solution must provide the ability for users to view and track the progress of their requests," defines a business-driven functionality - the need for request visibility in the service catalog, directly impacting user experience and service operations.
By contrast:
Option B defines a Service Level Objective (SLO), categorized as a non-functional (performance) requirement.
Option C pertains to availability and resilience, a non-functional reliability requirement.
Option D is a security and compliance requirement, also non-functional.
Therefore, option A is the only one describing a functional capability - the system feature enabling users to monitor their service request lifecycle.
References (VMware Cloud Foundation documents):
VMware Cloud Foundation 9.0.1 Design Guide - "Functional vs. Non-Functional Requirements Classification." VMware Cloud Foundation 9.0.2 Architecture Guide - "Mapping Business Functional Requirements to Service Capabilities."
NEW QUESTION # 74
Actual4Exams guarantee the best valid and high quality VMware study guide which you won’t find any better one available. 2V0-13.25 training pdf will be the right study reference if you want to be 100% sure pass and get satisfying results. From our 2V0-13.25 free demo which allows you free download, you can see the validity of the questions and format of the 2V0-13.25 actual test. In addition, the price of the 2V0-13.25 dumps pdf is reasonable and affordable for all of you.
Latest 2V0-13.25 Test Questions: https://www.actual4exams.com/2V0-13.25-valid-dump.html
The number of questions of the 2V0-13.25 study materials you have done has a great influence on your passing rate, VMware 2V0-13.25 Valid Dumps Questions We will satisfy your aspiring goals, As long as you spend less time on the game and spend more time on learning, the 2V0-13.25 study materials can reduce your pressure so that users can feel relaxed and confident during the preparation and certification process, VMware 2V0-13.25 Valid Dumps Questions Most of our specialized educational staff is required to have more than 10 years’ relating industry experience.
Course participants should have basic IT or 2V0-13.25 cybersecurity experience, It was an afternoon Sunday Funday, as Jes Feuer, Preston's mom, remembers it, The number of questions of the 2V0-13.25 Study Materials you have done has a great influence on your passing rate.
Free PDF 2026 Pass-Sure VMware 2V0-13.25 Valid Dumps QuestionsWe will satisfy your aspiring goals, As long as you spend less time on the game and spend more time on learning, the 2V0-13.25 study materials can reduce your pressure so that 2V0-13.25 Valid Dumps Questions users can feel relaxed and confident during the preparation and certification process.
Most of our specialized educational staff is required 2V0-13.25 Valid Dumps Questions to have more than 10 years’ relating industry experience, These examination guides are set up by the specialists who will give all Latest 2V0-13.25 Test Questions of you the fundamental and pragmatic learning and certainties which are refreshed every day.
- 2V0-13.25 Valid Dumps Files ⏮ Valid 2V0-13.25 Exam Materials 🍡 2V0-13.25 Exam Passing Score 🗯 Search on ➤ [url]www.vce4dumps.com ⮘ for ☀ 2V0-13.25 ️☀️ to obtain exam materials for free download 🤮Demo 2V0-13.25 Test[/url]
- Test 2V0-13.25 Passing Score 📬 Valid 2V0-13.25 Exam Forum ✌ Test 2V0-13.25 Passing Score 🚞 Open ⇛ [url]www.pdfvce.com ⇚ and search for ▷ 2V0-13.25 ◁ to download exam materials for free 🧏Latest 2V0-13.25 Test Materials[/url]
- 2V0-13.25 Latest Exam 🕎 Valid 2V0-13.25 Exam Materials 🎳 2V0-13.25 Latest Braindumps Ppt 💃 Search for 【 2V0-13.25 】 on ▶ [url]www.prep4sures.top ◀ immediately to obtain a free download ♣Reliable 2V0-13.25 Exam Simulations[/url]
- Real VMware 2V0-13.25 Dumps Attempt the Exam in the Optimal Way 🎏 Copy URL ➥ [url]www.pdfvce.com 🡄 open and search for ➤ 2V0-13.25 ⮘ to download for free 🪒Valid 2V0-13.25 Exam Materials[/url]
- 2V0-13.25 Latest Braindumps Ppt 🤶 2V0-13.25 Latest Study Questions ☝ Valid 2V0-13.25 Exam Forum 🔖 The page for free download of ⮆ 2V0-13.25 ⮄ on [ [url]www.pdfdumps.com ] will open immediately 🏰2V0-13.25 Passleader Review[/url]
- VMware 2V0-13.25 Exam | 2V0-13.25 Valid Dumps Questions - Useful Tips - Questions for your 2V0-13.25 Learning 😃 Simply search for ➽ 2V0-13.25 🢪 for free download on ▶ [url]www.pdfvce.com ◀ 🃏2V0-13.25 Latest Study Questions[/url]
- 2V0-13.25 Latest Exam 🍖 2V0-13.25 Latest Exam 🦕 Demo 2V0-13.25 Test 💎 Download ⏩ 2V0-13.25 ⏪ for free by simply searching on ➡ [url]www.verifieddumps.com ️⬅️ 🧽Demo 2V0-13.25 Test[/url]
- New Release 2V0-13.25 Questions - VMware 2V0-13.25 Exam Dumps 🥉 Download ⇛ 2V0-13.25 ⇚ for free by simply entering ⇛ [url]www.pdfvce.com ⇚ website 🥓2V0-13.25 Latest Study Questions[/url]
- Demo 2V0-13.25 Test 💒 2V0-13.25 Latest Study Questions 🎻 2V0-13.25 Latest Exam Camp 🧩 Open ➠ [url]www.pdfdumps.com 🠰 and search for ➠ 2V0-13.25 🠰 to download exam materials for free 🔣Latest 2V0-13.25 Test Materials[/url]
- 2V0-13.25 Valid Dumps Files 🙄 Latest 2V0-13.25 Test Materials 💜 Valid 2V0-13.25 Exam Camp Pdf ✡ Open “ [url]www.pdfvce.com ” and search for { 2V0-13.25 } to download exam materials for free 💃New 2V0-13.25 Exam Objectives[/url]
- VMware 2V0-13.25 Preparation Materials Available In Different Formats 🅰 Search for [ 2V0-13.25 ] and download it for free immediately on { [url]www.prepawaypdf.com } 🍳Demo 2V0-13.25 Test[/url]
- www.stes.tyc.edu.tw, conceptplusacademy.com, class.dtechnologys.com, teachsmart.asia, smartkidscampus.com, www.stes.tyc.edu.tw, animfx.co.in, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
What's more, part of that Actual4Exams 2V0-13.25 dumps now are free: https://drive.google.com/open?id=1ZG-8HoJI9A1_p6kvXKRLK3qgHhn2ZdVJ
