[Hardware] Useful Mule-Dev-201 - Salesforce Certified MuleSoft Developer Pass Rate
77
【Hardware】 Useful Mule-Dev-201 - Salesforce Certified MuleSoft Developer Pass Rate
Posted at 3/8/2026 17:03:26      View:82 | Replies:0        Print      Only Author   [Copy Link] 1#
Salesforce certification Mule-Dev-201 exam has become a very popular test in the IT industry, but in order to pass the exam you need to spend a lot of time and effort to master relevant IT professional knowledge. In such a time is so precious society, time is money. Prep4sureGuide provide a training scheme for Salesforce Certification Mule-Dev-201 Exam, which only needs 20 hours to complete and can help you well consolidate the related IT professional knowledge to let you have a good preparation for your first time to participate in Salesforce certification Mule-Dev-201 exam.
There is a group of experts in our company which is especially in charge of compiling our Mule-Dev-201 exam engine. There is no doubt that we will never miss any key points in our Mule-Dev-201 training materials. As it has been proven by our customers that with the help of our Mule-Dev-201 Test Prep you can pass the exam as well as getting the related Mule-Dev-201 certification only after 20 to 30 hours' preparation, which means you can only spend the minimum of time and efforts to get the maximum rewards.
100% Pass Rate Mule-Dev-201 Pass Rate - 100% Pass Mule-Dev-201 ExamFirmly believe in an idea, the Mule-Dev-201 exam questions are as long as the user to follow our steps, follow our curriculum requirements, users can be good to achieve their goals, to obtain the Mule-Dev-201 qualification certificate of the target. Before you make your decision to buy our Mule-Dev-201 learning guide, you can free download the demos to check the quality and validity. Then you can know the Mule-Dev-201 training materials more deeply.
Salesforce Certified MuleSoft Developer Sample Questions (Q135-Q140):NEW QUESTION # 135
Which of the following is invalid type of event processor which can be used as a router ?
  • A. Pick First
  • B. Choice
  • C. First Successful
  • D. Round Robin
Pick First is not valid type. Rest all are valid type of event processor.
Choice : https://docs.mulesoft.com/mule-runtime/4.3/choice-router-concept Round Robin : https://docs.mulesoft.com/mule-runtime/4.3/round-robin First Successful : https://docs.mulesoft.com/mule-runtime/4.3/first-successful
NEW QUESTION # 136
A Batch Job scope has five batch steps. An event processor throws an error in the second batch step because theinput data is incomplete. What is the default behavior of the batch job after the error is thrown?
  • A. Error is ignored
  • B. Batch is retried
  • C. All processing of the batch job stops.
  • D. Event processing continues to the next batch step.
In case ofan error , batch job completes in flight steps and stops further processing.
MuleSoft Doc Ref : Handling Errors During Batch Job | MuleSoft Documentation The default is all processing will stop but we can change it by Max Failed Record field.
General -> Max Failed Records: Mule has three options for handling a record-level error: Finish processing, Continue processing and Continue processing until the batch job accumulates a maximum number of failed records. This behavior can be controlled by Max Failed Records.
The default value is Zero which corresponds to Finish processing.
The value -1, corresponds to Continue processing.
The value +ve integer, corresponds to Continue processing until the batch job accumulates a maximum number of failed records
NEW QUESTION # 137
Refer to the exhibits.
Larger image
Larger image
Larger image
The Mule application configures and uses two HTTP Listener global configuration elements.
Mule application is run in Anypoint Studio.
If the mule application starts correctly, what URI and port numbers can receive web client requests? If the mule applications fails to start , what is the reason for the failure?
  • A. The mule applicationstart successfullyWeb client requests can only be received at URI on port 2222 but not on port 3333
  • B. The mule application start successfullyWeb client requests can be received at URI on port 2222 and on port 3333.
  • C. The mule application fails to startThere is URL path conflict because both HTTP Listeners are configured with same path
  • D. The mule application fails to start because of the port binding conflict as HTTP request also use same port i.e. 3333
In this case both the flows can start without any error and requests can be received on both ports. Flow names
httpListener1 can call other flow using HTTP request without any issues.
Hence correct answer is
Lets check why other options are incorrect
1) The mule application fails to start. There isURL path conflict because both HTTP Listeners are configured with same path ---- This is incorrect as port value is different in both listeners
2) The mule application start successfully. Web client requests can only be received at URI on port 2222 but not on port 3333 --- This is incorrect as there is no reason for not receiving requests on port 3333
3) The mule application fails to start because of the port binding conflict as HTTP request also use same port i.
e. 3333 --- Port binding conflict will nothappen in this case. It would have if both listener configurations would have been on same port . But that is not the case here.
Mule Ref Doc : HTTPListener Reference - Mule 4 | MuleSoft Documentation
NEW QUESTION # 138
Refer to the exhibits. A database Address table contains a ZIPCODE column and an increasing ID column.
The Address table currently contains tour (4) records. The On Table Row Database listener is configured with its watermark set to the Address table's ZIPCODE column and then the Mule application is run in Anypoint Studio tor the first time, and the On Table Row Database listener polls the Address table.
Anew row is added to the database with 1D=5 and ZIPCODE-90006, and then the On Table Row Database listener polls the database again.
Alter the next execution of the On Table Row Database listener polling, what database rows have beenprocessed by the Mule flow since the Mule application was started?
  • A. ID ZIPCODE1 900012 900053 900094 900015 90006
  • B. ID ZIPCODE1 900012 900053 900095 90006
  • C. ID ZIPCODE1 900012 900053 90009
  • D. ID ZIPCODE1 900012 900053 900094 90001
NEW QUESTION # 139
Which one of them is NOT a flow in Mule?
  • A. async sub flow
  • B. async flow
  • C. sync flow
  • D. subflow
Correct answer is async sub flow. Rest are valid flows in Mule.
Sub flow is always synchronous.
NEW QUESTION # 140
The passing rate of our Mule-Dev-201 study materials is 99% and the hit rate is also high. Our study materials are selected strictly based on the real Mule-Dev-201 exam. Our expert team guarantees that each answer and question is useful and valuable. We also update frequently to guarantee that the client can get more learning Mule-Dev-201 resources and follow the trend of the times. So if you use our study materials you will pass the test with high success probability.
Exam Mule-Dev-201 Forum: https://www.prep4sureguide.com/Mule-Dev-201-prep4sure-exam-guide.html
Salesforce Mule-Dev-201 Pass Rate You just need to spend 20 to 30 hours on study, and then you can take your exam, In a sense, our Mule-Dev-201 real exam dumps equal a mobile learning device, Should your requirement, Prep4sureGuide find an efficient method to help all candidates to pass Mule-Dev-201 exam, Salesforce Mule-Dev-201 Pass Rate In the 21st century, the rate of unemployment is increasing greatly, Salesforce Mule-Dev-201 Pass Rate It’s our motto to timely deliver an excellent product in an affordable price.
Modifying one will most likely affect another, but you still Mule-Dev-201 have to arrange a balanced combination that will suit both your application/deployment and your infrastructure.
But what if you've got a friend who uses Spotify but not Facebook, You just need to spend 20 to 30 hours on study, and then you can take your exam, In a sense, our Mule-Dev-201 Real Exam dumps equal a mobile learning device.
Pass Guaranteed Quiz 2026 High-quality Salesforce Mule-Dev-201 Pass RateShould your requirement, Prep4sureGuide find an efficient method to help all candidates to pass Mule-Dev-201 exam, In the 21st century, the rate of unemployment is increasing greatly.
