[General] Valid Salesforce-MuleSoft-Developer-I Test Duration | Exam Salesforce-MuleSoft-D
55
General Valid Salesforce-MuleSoft-Developer-I Test Duration | Exam Salesforce-MuleSoft-D
Posted at 3/8/2026 17:23:54      View161 | Replies0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of It-Tests Salesforce-MuleSoft-Developer-I dumps from Cloud Storage: https://drive.google.com/open?id=1_mTV4U177lG2cQdY82TPFjoBrBgYOiL6
It's not easy for most people to get the Salesforce-MuleSoft-Developer-I guide torrent, but I believe that you can easily and efficiently obtain qualification Salesforce-MuleSoft-Developer-I certificates as long as you choose our products. After you choose our study materials, you can master the examination point from the Salesforce-MuleSoft-Developer-I Guide question. Then, you will have enough confidence to pass your exam. As for the safe environment and effective product, why dont you have a try for our Salesforce-MuleSoft-Developer-I question torrent, never let you down!
Salesforce Salesforce-MuleSoft-Developer-I exam is a Technical Specialist exam. Salesforce Salesforce-MuleSoft-Developer-I exam can help and promote IT staff have a good career. With a good career, and of course you can create a steady stream of corporate and national interests, so as to promote the development of the national economy. If all of the IT staff can do like this the state will become stronger. It-Tests Salesforce Salesforce-MuleSoft-Developer-I Exam Training materials can help IT personnel to achieve this purpose. We guarantee you 100% to pass the exam. Make the tough decision to choose our It-Tests Salesforce Salesforce-MuleSoft-Developer-I exam training materials please.
Salesforce Salesforce-MuleSoft-Developer-I Dumps - Well Renowned Way Of Instant SuccessWe are famous for our company made these Salesforce-MuleSoft-Developer-I exam questions with accountability. We understand you can have more chances getting higher salary or acceptance instead of preparing for the Salesforce-MuleSoft-Developer-I exam. Our Salesforce-MuleSoft-Developer-I practice materials are made by our responsible company which means you can gain many other benefits as well. We offer free demos of our Salesforce-MuleSoft-Developer-I learning guide for your reference, and send you the new updates if our experts make them freely.
Salesforce Salesforce-MuleSoft-Developer-I Exam Syllabus Topics:
  • Structuring Mule Applications: Structuring Mule applications covers parameterizing an application and defining and reusing global configurations. It includes breaking an application into multiple flows using private flows, subflows, and the Flow Reference component.
  • Transforming Data with DataWeave: It involves writing DataWeave scripts and using DataWeave functions. This topic also includes defining and using DataWeave variables, functions, and modules, and applying correct syntax.
  • Accessing and Modifying Mule Events: It describes the Mule event data structure. Moreover, the topic focuses on usage of transformers and enriching Mule events.
  • Designing APIs: Designing APIs involves describing the lifecycle of the modern API and using RAML to define various aspects of an API. It includes identifying when to use query parameters vs URI parameters, and defining API parameters.
Topic 5
  • Debugging and Troubleshooting Mule Applications: Using breakpoints to inspect a Mule event during runtime, installing missing Maven dependencies, and reading and deciphering Mule log error messages are sub-topics of this topic.
Topic 6
  • Handling Errors: Handling errors includes describing default error handling in Mule applications and defining custom global default error handlers. It involves comparing On Error Continue and On Error Propagate scopes, creating error handlers for a flow, using the Try scope, and mapping errors to custom application errors.
Topic 7
  • Building API Implementation Interfaces: This topic involves manually creating a RESTful interface for a Mule application and generating a REST Connector from a RAML specification. It also includes describing the features and benefits of APIkit.
Topic 8
  • Deploying and Managing APIs and Integrations: It includes packaging Mule applications for deployment and deploying them to CloudHub. This topic also involves using CloudHub properties, creating and deploying API proxies, connecting an API implementation to API Manager, and applying policies to secure an API.
Salesforce Certified MuleSoft Developer (Mule-Dev-201) Sample Questions (Q63-Q68):NEW QUESTION # 63
What is output of Dataweave flatten function?
  • A. Object
  • B. Array
  • C. LInkedHashMap
  • D. Map
Correct answer isArray.
Flatten turns a set of subarrays (such as [ [1,2,3], [4,5,[6]], [], [null] ]) into a single, flattened array (such as [
1, 2, 3, 4, 5, [6], null ]).
This example defines three arrays of numbers, creates another array containing those three arrays, and then uses the flatten function to convert the array of arrays into a single array with all values.
Source
%dw 2.0
output application/json
var array1 = [1,2,3]
var array2 = [4,5,6]
var array3 = [7,8,9]
var arrayOfArrays = [array1, array2, array3]
flatten(arrayOfArrays)
Output
[ 1,2,3,4,5,6,7,8,9 ]
NEW QUESTION # 64
The error occurs when a project is run in Anypoint Studio. The project, which has a dependency that is not in the MuleSoft Maven repository, was created and successfully run on a different computer.
What is the next step to fix the error to get the project to run successfully?
  • A. Install the dependency to thecomputer's local Maven repository
  • B. Add the dependency to the MULE_HOME/bin folder
  • C. Edit the dependency in the Mule project's pom.xml file
  • D. Deploy the dependency to MuleSoft's Maven repository
As dependency is not present in Mulesoft Maven repository, we need to install the dependency on computer's local Maven repository.
https://docs.mulesoft.com/mule-runtime/4.3/maven-reference
NEW QUESTION # 65
Refer to the exhibits.
A Mule application is being developed to process web client POSTrequests with payloads containing order information including the user name and purchased items The Shipping connector returns a shipping address for the input payloads user name The Shipping connector's Shipping Address operation is configured with a target named shippingAddress.
The Set Payload transformer needs to set an item key equal to the items value from the original received payload and a shippinglnfo key equal to the the ShippingAddress operation's response What is a straightforward way to property configure the Set Payload transformer with the required data?
  • A.
  • B.
  • C.
  • D.
NEW QUESTION # 66
Each route in the Scatter-Gather sets the payload to the number shown in the label. Whatresponse is returned to a web client request to the HTTP Listener?
  • A.
  • B.
  • C.
  • D.
Correct answer is as below.After all processing routes have finished execution, the Scatter-Gathercomponent creates a new Mule event that combines all resulting Mule events from each route, and then passes the new Mule event to the next component in the flow.
"0": {
"attributes": ...,
"payload": "100"
"1": {
"attributes": ...,
"payload": "200"
Bottom of Form
NEW QUESTION # 67
A Mule application contains two HTTP Listeners, each configured for different API endpoints: http://acme.com/apis/orders and http: //acme .com/a pis/customers.
What base path value should be set in an HTT? Listener config element so that it can be used to configure both HTTP Listeners?
  • A. /apis/orders|customers
  • B. /apis/?
  • C. /apis/
  • D. /apis/*
Option 2 is the correct answer as /api/* accespts everything starting with /api/
NEW QUESTION # 68
Thus, it leads to making your practice quite convenient. Salesforce Salesforce-MuleSoft-Developer-I desktop software functions on Windows-based computers and works without a functional internet connection. Salesforce Salesforce-MuleSoft-Developer-I Exam Questions always provide ease to their consumers. therefore, the committed team is present around the clock to fix any problem.
Exam Salesforce-MuleSoft-Developer-I Prep: https://www.it-tests.com/Salesforce-MuleSoft-Developer-I.html
BONUS!!! Download part of It-Tests Salesforce-MuleSoft-Developer-I dumps for free: https://drive.google.com/open?id=1_mTV4U177lG2cQdY82TPFjoBrBgYOiL6
