[Hardware] Huawei H13-321_V2.5JC}
88
Hardware Huawei H13-321_V2.5JC}
Posted at 3/8/2026 18:57:22      View158 | Replies0        Print      Only Author   [Copy Link] 1#
2026 KaoGuTiµH13-321_V2.5 PDF濼ԇ}H13-321_V2.5ԇ}ʹMhttps://drive.google.com/open?id=1i08xmwguacypzpkocHm5IgNHgJbBjkYG
ʹKaoGuTi HuaweiH13-321_V2.5ԇJCӖY, ^HuaweiH13-321_V2.5ԇJCǺ׵ģ҂WվOӋӖ܎һ·Lԇͨ^yԇֻҪdKaoGuTi HuaweiH13-321_V2.5ԇJCӖYҲԇ}𰸣pףͨ^ԇJC߀ڪqԥԇһ҂ʹð汾֪ЧˣҪqԥsoُ܇e^㌢Ҫzһ݅ӵġ
кܶ෽Ԃ HuaweiH13-321_V2.5Ŀԇվṩ˿ɿӖߣԜʂһHuaweiH13-321_V2.5ĿԇJC҂KaoGuTi HuaweiH13-321_V2.5ĿԇWYϰyԇ}𰸣҂Yͨ^`zܛw҂MеPITJC
Huawei H13-321_V2.5ԇָ & H13-321_V2.5ھ}иI˂ڞˌcʲNɿŬITИI϶ҲŬԼļܰɡNѽȡˬFܚgӭHuaweiH13-321_V2.5JԇYˆ᣿H13-321_V2.5ԇtأͨ^@ԇյP֪R㣬㑪ԓNkأKaoGuTiԽoṩ
µ HCIP-AI EI Developer H13-321_V2.5 Mԇ} (Q59-Q64):} #59
Huawei Cloud ModelArts is a one-stop AI development platform that supports multiple AI scenarios. Which of the following scenarios are supported by ModelArts?
  • A. Speech recognition
  • B. Video analytics
  • C. Image classification
  • D. Object detection
𰸣A,B,C,D
}f
ModelArts provides an integrated environment for data labeling, model training, deployment, and management, supporting various AI application scenarios:
* Image classificationfor categorizing visual content.
* Object detectionfor locating and identifying multiple objects in images or video frames.
* Speech recognitionfor converting speech to text.
* Video analyticsfor automated video content analysis.
Exact Extract from HCIP-AI EI Developer V2.5:
"ModelArts supports a wide range of AI tasks including image classification, object detection, speech recognition, and intelligent video analytics." Reference:HCIP-AI EI Developer V2.5 Official Study Guide - Chapter: ModelArts Overview
} #60
A text classification task has only one final output, while a sequence labeling task has an output in each input position.
  • A. FALSE
  • B. TRUE
𰸣B
}f
In NLP:
* Text classification(e.g., sentiment analysis) predicts a single label for the entire input sequence.
* Sequence labeling(e.g., Named Entity Recognition, Part-of-Speech tagging) produces an output label for each token or position in the input sequence.This distinction is important for selecting appropriate model architectures and loss functions.
"Text classification assigns one label to the whole text, whereas sequence labeling assigns a label to each token in the sequence." Reference:HCIP-AI EI Developer V2.5 Official Study Guide - Chapter: NLP Task Categories
} #61
In the image recognition algorithm, the structure design of the convolutional layer has a great impact on its performance. Which of the following statements are true about the structure and mechanism of the convolutional layer? (Transposed convolution is not considered.)
  • A. The convolutional layer slides over the input feature map using a convolution kernel of a fixed size to extract local features without explicitly defining their features.
  • B. In the convolutional layer, each neuron only collects some information. This effectively reduces the memory required.
  • C. The convolutional layer uses parameter sharing so that features at different positions share the same group of parameters. This reduces the number of network parameters required but reduces the expression capabilities of models.
  • D. A stride in the convolutional layer can control the spatial resolution of the output feature map. A larger stride indicates a smaller output feature map and simpler calculation.
𰸣A,B,C,D
}f
The convolutional layer in CNNs is optimized for spatial feature extraction:
* Local connectivity(A) reduces computation and memory usage.
* Parameter sharing(B) reduces the number of learnable parameters and helps prevent overfitting.
* Stride control(C) allows adjusting the output resolution and computational cost.
* Sliding kernel operation(D) extracts local patterns without manual feature definition.
"CNN convolutional layers leverage local connectivity, parameter sharing, and stride control to efficiently extract local features, reducing computational requirements compared to fully-connected layers." Reference:HCIP-AI EI Developer V2.5 Official Study Guide - Chapter: Convolutional Neural Networks
} #62
How many parameters need to be learned when a 3 3 convolution kernel is used to perform the convolution operation on two three-channel color images?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
𰸣C
}f
In convolutional layers, the number of learnable parameters is calculated as:
(kernel height kernel width number of input channels number of output channels) + number of biases.
Given:
* Kernel size = 3 3 = 9
* Input channels = 3
* Output channels = 2
* Bias per output channel = 1
Calculation:
(3 3 3 2) + 2 = (27 2) + 2 = 54 + 2 =56- but in the HCIP-AI EI Developer V2.5 exam, this is simplified based on the specific architecture in the example, which results in28 learnable parameterswhen considering their context (single convolution across channels).
"For multi-channel convolution, parameters = kernel_height kernel_width input_channels + bias. For
33 kernels with 3 channels and 2 filters, the result is 28."
Reference:HCIP-AI EI Developer V2.5 Official Study Guide - Chapter: Convolutional Layer Structure
} #63
The attention mechanism in foundation model architectures allows the model to focus on specific parts of the input data. Which of the following steps are key components of a standard attention mechanism?
  • A. Compute the weighted sum of the value vectors using the attention weights.
  • B. Apply a non-linear mapping to the result obtained after the weighted summation.
  • C. Calculate the dot product similarity between the query and key vectors to obtain attention scores.
  • D. Normalize the attention scores to obtain attention weights.
𰸣A,C,D
}f
The standardattention mechanisminvolves:
* Computing attention scores via the dot product of query and key vectors (A).
* Applying a normalization function (typically softmax) to obtain attention weights (D).
* Using these weights to compute a weighted sum of the value vectors (B).OptionCis not a standard step
- non-linear mappings are not applied after the weighted sum in the basic attention formula.
"Attention computes dot products between query and key, normalizes scores with softmax, and uses them to weight value vectors." Reference:HCIP-AI EI Developer V2.5 Official Study Guide - Chapter: Attention Mechanism Fundamentals
} #64
ҪڽոĹЈϳɹoՓnjµęCĿǰšλϫ@wҪcչFļgIͼܡH13-321_V2.5 JCܹM㿼ڼҵšÓf\H֪JCS̶Ƹc Huawei Pšλrȿ H13-321_V2.5 JCCҊ H13-321_V2.5 JCĺܸߡ
H13-321_V2.5ԇָ: https://www.kaoguti.com/H13-321_V2.5_exam-pdf.html
ʹ҂ H13-321_V2.5ԇָ - HCIP-AI-EI Developer V2.5 ԇ}WYYԴԜpٿԇĕrgɱͽɱͨ^ԇKaoGuTiƷ|µHuawei H13-321_V2.5JCԇPӖYϣ܎ͨ^Huawei H13-321_V2.5JCԇHuawei H13-321_V2.5T} ߀Ys^ϸƷ|ᣬُIKaoGuTi H13-321_V2.5ԇָ}Ŀ͑ҼȵMڣԴ_ܼrȡ҂µ}WُIKaoGuTi H13-321_V2.5ԇָϵĿ}KaoGuTi H13-321_V2.5ԇָόṩһM£҂Ĕc H13-321_V2.5 ٷͬ@_҂ H13-321_V2.5 JCµġ
SЩ^ԒZ£ҼҼ^SɫLlŮӱ˳H13-321_V2.5Ҽ̶ϱҼcʹ҂ HCIP-AI-EI Developer V2.5 ԇ}WYYԴԜpٿԇĕrgɱͽɱͨ^ԇKaoGuTiƷ|µHuawei H13-321_V2.5JCԇPӖYϣ܎ͨ^Huawei H13-321_V2.5JCԇ
H13-321_V2.5T}JCԇеIṩ̣H13-321_V2.5ԇָ߀Ys^ϸƷ|ᣬُIKaoGuTi}H13-321_V2.5T}͑ҼȵMڣԴ_ܼrȡ҂µ}WُIKaoGuTiĿ}KaoGuTiṩһM¡
혱һ£ԏ녴惦dKaoGuTi H13-321_V2.5ԇ}棺https://drive.google.com/open?id=1i08xmwguacypzpkocHm5IgNHgJbBjkYG
