[General] 300-425 Reliable Exam Questions, Valid 300-425 Test Guide
101
【General】 300-425 Reliable Exam Questions, Valid 300-425 Test Guide
Posted at 3/8/2026 19:49:42      View:120 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free & New 300-425 dumps are available on Google Drive shared by Lead2Passed: https://drive.google.com/open?id=1SzPDVfrwK3Z7hjSeR0EHSJ3FhPUHeaZz
The more you can clear your doubts, the more easily you can pass the Designing Cisco Enterprise Wireless Networks (300-425) exam. Lead2Passed 300-425 practice test works amazingly to help you understand the 300-425 exam pattern and how you can attempt the real Cisco Exam Questions. It is just like the final 300-425 exam pattern and you can change its settings. When you take Lead2Passed Cisco 300-425 Practice Exams, you can know whether you are ready for the finals or not. It shows you the real picture of your hard work and how easy it will be to clear the 300-425 exam if you are ready for it.
After a series of investigations and studies, we found that those students who wish to pass the 300-425 exam through their own in-depth study of the textbooks are often slack in their learning. Some students may even feel headaches when they read the content that difficult to understand in the textbooks. Our 300-425 Study Materials are excellent examination review products composed by senior industry experts that focuses on researching the mock examination products which simulate the real 300-425 test environment. And you will be more confident to pass the 300-425 exam.
Valid 300-425 Test Guide - Exam 300-425 SuccessThe clients only need 20-30 hours to learn the 300-425 exam questions and prepare for the test. Many people may complain that we have to prepare for the test but on the other side they have to spend most of their time on their most important things such as their jobs, learning and families. But if you buy our 300-425 Study Guide you can both do your most important thing well and pass the 300-425 test easily because the preparation for the test costs you little time and energy.
To become certified, candidates must pass the Cisco 300-425 exam, along with two other exams - the Cisco 350-401 and the Cisco 300-420. Designing Cisco Enterprise Wireless Networks certification is valid for three years and requires candidates to renew their certification by passing a recertification exam. Designing Cisco Enterprise Wireless Networks certification is highly valued in the industry and recognized globally, making it an essential credential for network engineers and IT professionals who specialize in wireless network design. With the growing demand for wireless networks in the enterprise, the Cisco 300-425 Certification is an excellent way for professionals to showcase their expertise and advance their careers.
Cisco 300-425 exam is a certification exam that focuses on designing wireless networks for enterprise-level organizations. 300-425 exam is specifically designed for IT professionals who are responsible for designing and implementing wireless networks within their organization. 300-425 exam focuses on topics such as wireless LAN (WLAN) design, site surveys, network infrastructure, and security.
Cisco Designing Cisco Enterprise Wireless Networks Sample Questions (Q338-Q343):NEW QUESTION # 338
A company wants to replace its existing PBX system with a new VoIP System that will include wireless IP phones. The CIO has concerns about whether the company's existing wireless network can support the new system. Which tool in Cisco Prime can help ensure that the current network will support the new phone system?
  • A. Voice Readiness
  • B. Site Calibration
  • C. Location Readiness
  • D. Map Editor
NEW QUESTION # 339
A wireless engineer is hired to design a network for a technology company. The company campus has four buildings and a warehouse with access points that provide full wireless coverage as well as a pair of WLCs located in the core of the network. Which type of wireless architecture is being used?
  • A. autonomous deployment
  • B. centralized deployment
  • C. distributed deployment
  • D. unified deployment
The wireless architecture described is a centralized deployment. This is characterized by access points distributed across multiple buildings and managed centrally by Wireless LAN Controllers (WLCs).
Centralized deployments are common in larger environments like a technology company campus because they allow for centralized management, scalability, and advanced features such as load balancing and fault tolerance.
* CCNP Enterprise Wireless Design ENWLSD 300-425 and Implementation ENWLSI 300-430 Official Cert Guide Premium Edition and Practice Tests
NEW QUESTION # 340
An engineer must optimize client roaming after noticing that clients in the environment are not roaming as expected. Upon reviewing an over- the-air packet capture, the engineer sees that the AP is sending a BSS Transition Management query to the client, which causes it to roam.
The disassociation imminent feature is not enabled on the WLAN. What is the cause of the issue?
  • A. Fast Transition is disabled.
  • B. Optimized roaming is enabled.
  • C. Low RSSI check is enabled.
  • D. Band Select is enabled.
Optimized roaming is a feature that helps manage the client's roaming behavior by disassociating clients with a signal strength below a predefined threshold. This feature is designed to prevent clients from sticking to an AP with poor connectivity, which can lead to suboptimal performance. If the BSS Transition Management query is causing the client to roam and the disassociation imminent feature is not enabled, it indicates that optimized roaming is likely enabled, prompting the client to seek a better AP connection.
NEW QUESTION # 341
Based on a wireless network design, an engineer configured a primary and secondary controller for their APs. A power interruption caused the primary Cisco WLC to go down, and, as expected, all APs joined the secondary controller. When the primary controller came back up, all the APs remained joined to the secondary controller. Which approach must the engineer take for the APs to move back to the primary?
  • A. Set AP Fail over Priority to Critical globally.
  • B. Set AP Fallback to Enabled on the primary controller.
  • C. Set AP Fallback to Enabled on the secondary controller.
  • D. Set AP Fail over Priority to 4 on each AP.
NEW QUESTION # 342
An engineer is designing a new wireless network. The network needs to meet these requirements:
Which design approach should be taken?
  • A. 5 GHz frequency band without channel bonding, to support 20 MHz channels
  • B. 5 GHz frequency band with channel bonding, to support 80 MHz channels.
  • C. 5 GHz frequency band with channel bonding, to support 40 MHz channels
  • D. 2.4 GHz frequency band without channel bonding, to support 20 MHz channels
https://www.cisco.com/c/en/us/su ... 08184-config-802-11
NEW QUESTION # 343
Our after sales services are also considerate. If you get any questions with our 300-425 guide question, all helps are available upon request. Once you place your order this time, you will enjoy and experience comfortable and convenient services immediately. Besides, we do not break promise that once you fail the 300-425 Exam, we will make up to you and relieve you of any loss. Providing with related documents, and we will give your money back. We have been always trying to figure out how to provide warranty service if customers have questions with our 300-425 real materials.
Valid 300-425 Test Guide: https://www.lead2passed.com/Cisco/300-425-practice-exam-dumps.html
P.S. Free 2026 Cisco 300-425 dumps are available on Google Drive shared by Lead2Passed: https://drive.google.com/open?id=1SzPDVfrwK3Z7hjSeR0EHSJ3FhPUHeaZz
