[Hardware] AZ-800 Reliable Test Price & AZ-800 Valid Exam Discount
96
Hardware AZ-800 Reliable Test Price & AZ-800 Valid Exam Discount
Posted at 3/8/2026 20:57:58      View168 | Replies0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of ITPassLeader AZ-800 dumps for free: https://drive.google.com/open?id=1lfqvvx-4eUffwLIO9uFmkrGSrm6sn8bt
Don't be trapped by one exam and give up the whole Microsoft certification. If you have no confidence in passing exam, ITPassLeader releases the latest and valid AZ-800 guide torrent files which is useful for you to get through your exam certainly. The earlier you pass exams and get certification with our AZ-800 Latest Braindumps, the earlier you get further promotion and better benefits. Sometimes opportunity knocks but once. Timing is everything.
Every person in IT industry should not just complacent with own life. Now the competitive pressures in various industries are self-evident, and the IT industry is no exception. So if you have a goal, then come true it courageously. Pass the Microsoft AZ-800 Exam is a competition. If you passed the exam, then you will have a brighter future. ITPassLeader can provide you with the true and accurate training materials to help you pass the exam. And then you can achieve your ideal.
Desktop Microsoft AZ-800 Practice Test Software By ITPassLeaderOur AZ-800 exam torrent offers you free demo to try before buying. You will get your downing link and password after the payment, and you can download AZ-800 exam dumps right now. If you have any questions, you can directly contact us through online live chat or you can notify us through email, we will give you reply as soon as we can. In addition, we provide you free update for one year after purchasing the AZ-800 Exam Dumps.
Microsoft Administering Windows Server Hybrid Core Infrastructure Sample Questions (Q161-Q166):NEW QUESTION # 161
You need to ensure that data availability on SSPace1 meets the technical requirements.
What is the maximum number of physical disks that can fail on each disk? To answer, select the appropriate options in the answer area.
NEW QUESTION # 162
Your network contains an Active Directory Domain Services (AD DS) forest. The forest contains two domains named contoso.com and east.contoso.com. Contoso.com contains two users named CONTOSO
User1 and EASTUser2.
You need to ensure that the users can perform the following tasks:
* User1 must deploy an additional domain controller to eastcontoso.com.
* User2 must deploy a new domain controller that will host a domain named west.contoso.com.
The solution must follow the principle of least privilege.
To which group should you add each user? To answer, select the appropriate options in the answer area.
The Administering Windows Server Hybrid Core Infrastructure guidance for AD DS promotion and forest operations states that adding a new domain controller to an existing domain requires credentials that "are a member of Domain Admins in the target domain (or equivalent delegated rights)." This is the minimum built-in role permitted to run AD DS installation and write to the domain's configuration containers for DC promotion. Therefore, to add an additional DC in east.contoso.com, the least-privilege group for User1 is EASTDomain Admins.
For creating a new domain (child domain or new tree) in an existing forest, the exam materials specify that this is a forest-wide operation handled by the Domain Naming Master and requires enterprise-level permissions: "to create or remove domains in a forest, you must use an account that is a member of the Enterprise Admins group." Domain Admins in a single domain are insufficient because the task modifies forest-level naming contexts. Thus, to deploy the first DC for west.contoso.com, the least-privilege role that satisfies the requirement for User2 is CONTOSOEnterprise Admins.
These selections follow the principle of least privilege: User1 is scoped to the child domain's administration only, while User2 receives the forest-level rights necessary to add a new domain.
NEW QUESTION # 163
You have a disaggregated cluster deployment. The deployment contains a scale-out file server (SOFS) cluster that runs Windows Server and a compute duster that has the Hyper-V role enabled.
You need to implement Storage Quality of Service (QoS). The solution must ensure that you can control the bandwidth usage between the SOFS cluster and the Hyper-V cluster.
Which cmdlet should you run on each cluster? To answer, drag the appropriate cmdlets to the correct clusters.
Each cmdlet may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
In a disaggregated deployment (separate Hyper-V compute cluster and Scale-Out File Server storage cluster), Storage Quality of Service (Storage QoS) is implemented with centralized policies that are defined on the SOFS and applied to VM virtual disks from the Hyper-V side. The Administering Windows Server Hybrid Core Infrastructure materials describe centralized Storage QoS as follows: "In a SOFS-based deployment, you create Storage QoS policies on the Scale-Out File Server. Policies define minimum and maximum IOPS
/throughput and are stored on the cluster so they can be referenced by any VM using CSV shares exposed by the SOFS." The guide further states: "To apply a Storage QoS policy to a virtual hard disk, use the Hyper-V cmdlet to set the VHD attachment and reference the policy by name or ID. The policy then governs I/O for that disk regardless of which Hyper-V host the VM runs on." Accordingly, on the SOFS cluster, you run New-StorageQosPolicy to create the centralized policy (for example, with MinimumIops, MaximumIops, or bandwidth constraints). On the Hyper-V cluster, you attach or update the VM disk to consume that policy using Set-VMHardDiskDrive (for example, -QoSPolicyID or - QoSPolicyName). The Set-VMSan cmdlet pertains to Hyper-V Virtual SAN configuration and is not used for Storage QoS. This pattern ensures you can control and cap bandwidth usage between the SOFS storage and the Hyper-V compute clusters while maintaining consistent, cluster-wide enforcement.
NEW QUESTION # 164
SIMULATION
Task 3
You need to run a container that uses the mcr.microsoft.com/windows/servercore/iis image on SRV1. Pott 60 on the container must be published to port 5001 on SRV1 and the container must run in the background.
See the solution of this Task below
To run a container on SRV1 using the mcr.microsoft.com/windows/servercore/iis image, publish port 60 on the container to port 5001 on SRV1, and ensure it runs in the background, you can follow these steps:
Step 1: Pull the IIS Image First, pull the IIS image from the Microsoft Container Registry:
docker pull mcr.microsoft.com/windows/servercore/iis
Step 2: Run the Container Next, run the container with the required port mapping and ensure it runs in the background using the -d flag:
docker run -d -p 5001:60 --name iis_container mcr.microsoft.com/windows/servercore/iis This command will start a container named iis_container using the IIS image, map port 60 inside the container to port 5001 on SRV1, and run the container in detached mode.
Step 3: Verify the Container is Running To verify that the container is running and the port is published, use the following command:
docker ps
This will list all running containers and show the port mappings.
Step 4: Access the IIS Server You can now access the IIS server running in the container by navigating to http://<SRV1_IP>:5001 in a web browser, where <SRV1_IP> is the IP address of SRV1.
Note: Ensure that Docker is installed on SRV1 and that the port 5001 is open on the firewall to allow incoming connections1.
By following these steps, you should be able to run the IIS container on SRV1 with the specified port mapping and have it running in the background.
NEW QUESTION # 165
Your network contains an Active Directory Domain Services (AD DS) domain named contoso.com.
You need to identify which server is the PDC emulator for the domain.
Solution: From Active Directory Domains and Trusts, you right-click Active Directory Domains and Trusts in the console tree, and then select Operations Master.
Does this meet the goal?
  • A. Yes
  • B. No
NEW QUESTION # 166
You can get the downloading link and password within ten minutes after payment. Administering Windows Server Hybrid Core Infrastructure AZ-800 exam dumps contain both questions and answers, and its convenient for you to check your answers. Administering Windows Server Hybrid Core Infrastructure AZ-800 training materials are high-quality and high accuracy, since we are strict with the quality and the answers. We ensure you that AZ-800 Exam Dumps are available, and the effectiveness can be also guarantees.
AZ-800 Valid Exam Discount: https://www.itpassleader.com/Microsoft/AZ-800-dumps-pass-exam.html
Our AZ-800 latest dumps can help you by offering high quality and accuracy message for you, We provide tens of thousands of AZ-800 Valid Exam Discount exam questions for all candidates, Now, I think you should begin to prepare for the AZ-800 Valid Exam Discount - Administering Windows Server Hybrid Core Infrastructure exam test, Microsoft AZ-800 Reliable Test Price Prepare for your Blockchain examination with our training course, Microsoft AZ-800 Reliable Test Price We are all well aware that a major problem in the industry is that there is a lack of quality study materials.
Role-Based Awareness and Training, We are also taught that neurons hold all the information in the brain, Our AZ-800 Latest Dumps can help you by offering high quality and accuracy message for you.
AZ-800 Reliable Test Price - AZ-800: Administering Windows Server Hybrid Core Infrastructure First-grade Reliable Test PriceWe provide tens of thousands of Windows Server exam questions for all candidates, AZ-800 New Braindumps Now, I think you should begin to prepare for the Administering Windows Server Hybrid Core Infrastructure exam test, Prepare for your Blockchain examination with our training course.
We are all well aware that a major problem AZ-800 in the industry is that there is a lack of quality study materials.
