[General] Free PDF Quiz 2026 Microsoft AZ-120–High Pass-Rate New Braindumps Ebook
97
【General】 Free PDF Quiz 2026 Microsoft AZ-120–High Pass-Rate New Braindumps Ebook
Posted at 3/9/2026 00:47:38      View:169 | Replies:0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest BraindumpsIT AZ-120 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1CRF6pchc-Fv66rUlWqB0LVKTjiwWDMS1
The exam requires an enormous amount of effort and determination and dedication to get to the end goal. BraindumpsIT is one of the most reliable platforms that offer an accurate, reliable, and straightforward Microsoft AZ-120 dumps to ensure the success of students on the initial try. BraindumpsIT offers the complete package that includes all exam dumps conforming to the syllabus for passing the Planning and Administering Microsoft Azure for SAP Workloads (AZ-120) exam certificate in the first try.
Download the free AZ-120 demo of whatever product you want and check its quality and relevance by comparing it with other available study contents within your access. BraindumpsIT’s study guides and AZ-120 Dump will prove their worth and excellence. Check also the feedback of our clients to know how our products proved helpful in passing the exam.
AZ-120 Online Tests & Real AZ-120 Testing EnvironmentConstantly updated multiple mock exams with a great number of questions that will help you in better self-assessment. Memorize all your previous Planning and Administering Microsoft Azure for SAP Workloads (AZ-120) exam questions attempts and display all the changes in your results at the end of each Microsoft AZ-120 Practice Exam attempt. Users will be able to customize the AZ-120 practice test software by time or question types. Supported on all Windows-based PCs.
Microsoft Planning and Administering Microsoft Azure for SAP Workloads Sample Questions (Q126-Q131):NEW QUESTION # 126
You migrate SAP ERP Central Component (SAP ECC) production and non-production landscapes to Azure.
You are licensed for SAP Landscape Management (LaMa).
You need to refresh from the production landscape to the non-production landscape.
Step 1: From the Azure portal, create a service principal
The Azure connector can use a Service Principal to authorize against Microsoft Azure. Follow these steps to create a Service Principal for SAP Landscape Management (LaMa).
Step 2: Add permissions to the service principal
The Service Principal does not have permissions to access your Azure resources by default. You need to give the Service Principal permissions to access them.
Step 3: From the Cloud Managers tab in LaMa, add an adapter
Create a new connector in SAP LaMa
Open the SAP LaMa website and navigate to Infrastructure. Go to tab Cloud Managers and click on Add.
Select the Microsoft Azure Cloud Adapter
Step 4: Install and configure LaMA on an SAP NetWeater instance
Provision a new adaptive SAP system
You can manually deploy a new virtual machine or use one of the Azure templates in the quickstart repository.
It contains templates for SAP NetWeaver ASCS, SAP NetWeaver application servers, and the database. You can also use these templates to provision new hosts as part of a system copy/clone etc.
Note: To support customers on their journey into a cloud model (hybrid or entirely public cloud), SAP and Microsoft partnered to create an adapter that integrates the SAP management capabilities of LaMa with the IaaS advantages of Microsoft Azure.
https://docs.microsoft.com/en-us ... p/lama-installation
https://docs.microsoft.com/en-us ... p-remote-management
NEW QUESTION # 127
For each of the following statements, select yes if the statement is true. Otherwise, select No.
NEW QUESTION # 128
You plan to migrate an SAP ERP Central Component (SAP ECC) production system to Azure.
You are reviewing the SAP EarlyWatch Alert report for the system.
You need to recommend sizes for the Azure virtual machines that will host the system.
Which two sections of the report should you review? Each correct answer presents a complete solution.
  • A. Hardware Configuration under Landscape
  • B. Patch Levels under SAP Software Configuration
  • C. Data Volume Management
  • D. Database and ABAP Load Optimization
  • E. Hardware Capacity
Answer: A,E
https://wiki.scn.sap.com/wiki/di ... acity+Checks+in+EWA
NEW QUESTION # 129
This question requires that you evaluate the underlined text to determine if it is correct.
You have an SAP environment on Azure that uses Microsoft SQL server as the RDBMS.
You plan to migrate to an SAP HANA database.
To calculate the amount of memory and disk space required for the database, you can use SAP Quick Sizer.
Instructions: Review the underlined text, If the makes the stamen correct, select ''No change is needed. " if the statement is incorrect select the answer choice that makes the statement correct.
  • A. No change is needed.
  • B. Azure Migrate
  • C. SQL Server Management Studio (SSMS)
  • D. /SDF/HDB_SIZING
NEW QUESTION # 130
You have an SAP landscape on Azure that contains the virtual machines shown in the following table.
You need to ensure that the Application Server role is available if a single Azure datacenter fails.
What should you include in the solution?
  • A. Azure Application Gateway v2
  • B. Azure Load Balancer Standard
  • C. Azure Private Link
  • D. a local network gateway
NEW QUESTION # 131
On the other hand, those who do not score well can again try reading all the Planning and Administering Microsoft Azure for SAP Workloads (AZ-120) dumps questions and then give the AZ-120 exam. This will help them polish their skills and clear all their doubts. Also, you must note down your Planning and Administering Microsoft Azure for SAP Workloads (AZ-120) practice test score every time you try the Microsoft Exam Questions. It will help you keep a record of your study and how well you are doing in them.
AZ-120 Online Tests: https://www.braindumpsit.com/AZ-120_real-exam.html
Microsoft New AZ-120 Braindumps Ebook By doing this they can gain several personal and professional benefits, As for the contents of the AZ-120 exam guide dumps, all the questions are refined from the original resource, checked and verified under several process by the professional experts who has rich hands-on experience, Microsoft New AZ-120 Braindumps Ebook Unprecedented severe competition makes college students and job seekers fell insecure for their future.
Each mixed set is different and each provides AZ-120 Online Tests a well-rounded approach to creative training, challenging you to solve problems using multiple mediums, Pixel is a more New AZ-120 Braindumps Ebook generic term because it specifies the smallest picture element" in an image.
Authoritative New AZ-120 Braindumps Ebook bring you Practical AZ-120 Online Tests for Microsoft Planning and Administering Microsoft Azure for SAP WorkloadsBy doing this they can gain several personal and professional benefits, As for the contents of the AZ-120 Exam Guide dumps, all the questionsare refined from the original resource, checked AZ-120 and verified under several process by the professional experts who has rich hands-on experience.
Unprecedented severe competition makes college students Certification AZ-120 Questions and job seekers fell insecure for their future, The science and technology are very developed now, If you don't have enough time to learn, AZ-120 test guide will make the best use of your spare time, and the scattered time will add up.
What's more, part of that BraindumpsIT AZ-120 dumps now are free: https://drive.google.com/open?id=1CRF6pchc-Fv66rUlWqB0LVKTjiwWDMS1
