NGFW-Engineer Simulated Test - Reliable NGFW-Engineer Exam Simulator
115
Posted at 3/9/2026 02:24:44      View:82 | Replies:0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest ExamDiscuss NGFW-Engineer PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1hweVVcoYYeRRbhIg6KNk8wU4jqIDqA7g
Our experts composed the contents according to the syllabus and the trend being relentless and continuously updating in recent years. We are sufficiently definite of the accuracy and authority of our NGFW-Engineer practice materials. They also simplify the difficulties in the contents with necessary explanations for you to notice. To make the best NGFW-Engineer study engine, they must be fully aware of exactly what information they need to gather into our NGFW-Engineer guide exam.
Palo Alto Networks NGFW-Engineer Exam Syllabus Topics:
  • PAN-OS Networking Configuration: This section of the exam measures the skills of Network Engineers in configuring networking components within PAN-OS. It covers interface setup across Layer 2, Layer 3, virtual wire, tunnel interfaces, and aggregate Ethernet configurations. Additionally, it includes zone creation, high availability configurations (active
  • active and active
  • passive), routing protocols, and GlobalProtect setup for portals, gateways, authentication, and tunneling. The section also addresses IPSec, quantum-resistant cryptography, and GRE tunnels.
  • PAN-OS Device Setting Configuration: This section evaluates the expertise of System Administrators in configuring device settings on PAN-OS. It includes implementing authentication roles and profiles, and configuring virtual systems with interfaces, zones, routers, and inter-VSYS security. Logging mechanisms such as Strata Logging Service and log forwarding are covered alongside software updates and certificate management for PKI integration and decryption. The section also focuses on configuring Cloud Identity Engine User-ID features and web proxy settings.
  • Integration and Automation: This section measures the skills of Automation Engineers in deploying and managing Palo Alto Networks NGFWs across various environments. It includes the installation of PA-Series, VM-Series, CN-Series, and Cloud NGFWs. The use of APIs for automation, integration with third-party services like Kubernetes and Terraform, centralized management with Panorama templates and device groups, as well as building custom dashboards and reports in Application Command Center (ACC) are key topics.
NGFW-Engineer Pass-Sure Materials - NGFW-Engineer Quiz Bootcamp & NGFW-Engineer Test QuizExamDiscuss is the leading position in this field and famous for high pass rate of the NGFW-Engineer learning guide. If you are headache about your qualification exams, our NGFW-Engineer learning guide materials will be a great savior for you. Now it is your opportunity that we provide the best valid and professional NGFW-Engineer Study Guide materials which have 100% pass rate. If you really want to clear exam and gain success one time, choosing us will be the wise thing for you. If you hesitate about us please pay attention on below about our satisfying service and high-quality NGFW-Engineer guide torrent.
Palo Alto Networks Next-Generation Firewall Engineer Sample Questions (Q61-Q66):NEW QUESTION # 61
In an active/active high availability (HA) configuration with two PA-Series firewalls, how do the firewalls use the HA3 interface?
  • A. To exchange hellos, heartbeats, HA state information, and management plane synchronization for routing and User-ID information
  • B. To forward packets to the HA peer during session setup and asymmetric traffic flow
  • C. To synchronize sessions, forwarding tables, IPSec security associations, and ARP tables between firewalls in an HA pair
  • D. To perform session cache synchronization among all HA peers having the same cluster ID
The HA3 interface, a Layer 2 link using MAC-in-MAC encapsulation, enables packet forwarding between active/active firewalls to handle asymmetric routing and ensure proper session setup when traffic arrives at the non-owner peer.
NEW QUESTION # 62
An administrator is troubleshooting a newly configured site-to-site VPN between a PAN-OS firewall and a third-party policy-based VPN gateway. The tunnel allows traffic between the first pair of configured subnets, but traffic to a newly added remote subnet is failing. The administrator has confirmed that routing and Security policies are correct.
What is the most likely cause of this issue?
  • A. The tunnel's maximum transmission unit (MTU) size must be increased to accommodate the new traffic.
  • B. The Security policy for the new subnet must be placed above the existing VPN policy.
  • C. The new local and remote subnets are missing from the Proxy ID configuration.
  • D. A static route for the new subnet pointing to the tunnel interface is missing.
With a policy-based VPN, Phase 2 traffic selectors must explicitly include each permitted local and remote subnet pair. If the new subnet pair was added in routing and policy but not added to the Proxy ID configuration, the peer will not negotiate selectors for that traffic, so the new subnet traffic fails while the original subnet continues to work.
NEW QUESTION # 63
In an authentication sequence, what happens if the "Continue on client cert failure" option is enabled?
  • A. The firewall will deny access if the client certificate is invalid.
  • B. The firewall will log the failure and terminate the session.
  • C. The firewall will skip client certificate authentication and proceed to the next authentication profile in the sequence.
  • D. The firewall will prompt the user to provide a valid client certificate.
NEW QUESTION # 64
After enabling multiple security profiles such as IPS, antivirus, and URL filtering on an NGFW, users report degraded network performance.
Which factor is MOST likely causing the issue?
  • A. Incorrect DNS configuration
  • B. Asymmetric routing
  • C. VLAN misconfiguration
  • D. Excessive CPU utilization due to deep inspection
Deep packet inspection and threat analysis consume significant system resources.
Improper tuning or undersized hardware can lead to performance degradation.
NEW QUESTION # 65
Which two statements apply to configuring required security rules when setting up an IPSec tunnel between a Palo Alto Networks firewall and a third- party gateway? (Choose two.)
  • A. The IKE negotiation and IPSec/ESP packets are denied by default via the interzone default deny policy.
  • B. For incoming and outgoing traffic through the tunnel, creating separate rules for each direction is optional.
  • C. The IKE negotiation and IPSec/ESP packets are allowed by default via the intrazone default allow policy.
  • D. For incoming and outgoing traffic through the tunnel, separate rules must be created for each direction.
Separate rules must be created for each direction: Palo Alto Networks firewalls enforce security policies based on traffic direction. To allow bidirectional communication through the IPSec tunnel, two separate rules are required - one for incoming and one for outgoing traffic.
IKE negotiation and IPSec/ESP packets are denied by default: Palo Alto Networks firewalls use an interzone default deny policy, meaning that unless an explicit policy allows IKE (UDP
500/4500) and ESP (protocol 50) traffic, the firewall will block these packets, preventing tunnel establishment. Therefore, administrators must create explicit rules permitting IKE and IPSec/ESP traffic to the firewall's external interface.
NEW QUESTION # 66
For candidates who are going to buy the NGFW-Engineer training materials online, they have the concern of the safety of the website. Our NGFW-Engineer training materials will offer you a clean and safe online shopping environment, since we have professional technicians to examine the website and products at times. In addition, NGFW-Engineer Training Materials have 98.75% pass rate, and you can pass the exam. We also pass guarantee and money back guarantee if you fail to pass the exam.
Reliable NGFW-Engineer Exam Simulator: https://www.examdiscuss.com/Palo-Alto-Networks/exam/NGFW-Engineer/
BTW, DOWNLOAD part of ExamDiscuss NGFW-Engineer dumps from Cloud Storage: https://drive.google.com/open?id=1hweVVcoYYeRRbhIg6KNk8wU4jqIDqA7g
