[Hardware] 100% Pass 2026 Fortinet NSE5_FNC_AD_7.6: Test Fortinet NSE 5 - FortiNAC-F 7.6 Ad
54
Hardware 100% Pass 2026 Fortinet NSE5_FNC_AD_7.6: Test Fortinet NSE 5 - FortiNAC-F 7.6 Ad
Posted at 3/9/2026 02:32:27      View174 | Replies0        Print      Only Author   [Copy Link] 1#
If you want to pass a high percentage of the Fortinet NSE5_FNC_AD_7.6 Exam, you should consider studying for the actual exam. These practice tests are designed to help you prepare for the exam and ensure you know the syllabus content. It will also help you improve your time management skills, as these tests are designed like an actual exam. Moreover, they will help you learn to answer all questions in the time allowed.
Fortinet NSE5_FNC_AD_7.6 Exam Syllabus Topics:
  • Network Visibility and Monitoring: This domain covers managing guest and contractor access, utilizing logging options for tracking network events, configuring device profiling for automatic device identification and classification, and troubleshooting network device connection issues.
  • Concepts and Initial Configuration: This domain covers organizing infrastructure devices within FortiNAC-F and understanding isolation networks for quarantining non-compliant devices. It includes using the configuration wizard for initial system setup and deployment.
  • Deployment and Provisioning: This domain focuses on configuring security automation for automatic event responses, implementing access control policies, setting up high availability for system redundancy, and creating security policies to enforce network security requirements.
  • Integration: This domain addresses connecting FortiNAC-F with other systems using Syslog and SNMP traps, managing multiple instances through FortiNAC-F Manager, and integrating Mobile Device Management for extending access control to mobile devices.
Latest NSE5_FNC_AD_7.6 Practice Questions - Exam NSE5_FNC_AD_7.6 Revision PlanAs practice makes perfect, we offer three different formats of NSE5_FNC_AD_7.6 exam study material to practice and prepare for the NSE5_FNC_AD_7.6 exam. Our Fortinet NSE5_FNC_AD_7.6 practice test simulates the real Fortinet NSE 5 - FortiNAC-F 7.6 Administrator (NSE5_FNC_AD_7.6) exam and helps applicants kill exam anxiety. These NSE5_FNC_AD_7.6 practice exams provide candidates with an accurate assessment of their readiness for the NSE5_FNC_AD_7.6 test.
Fortinet NSE 5 - FortiNAC-F 7.6 Administrator Sample Questions (Q32-Q37):NEW QUESTION # 32
While deploying FortiNAC-F devices in a 1+1 HA configuration, the administrator has chosen to use the shared IP address option.
Which condition must be met for this type of deployment?
  • A. The primary and secondary administrative interfaces are on the same subnet.
  • B. The isolation network type is layer 3.
  • C. There is a direct cable link between FortiNAC-F devices.
  • D. The isolation network type is Layer 2.
In a 1+1 High Availability (HA) deployment, FortiNAC-F supports two primary methods for management access: individual IP addresses or a Shared IP Address (also known as a Virtual IP or VIP). The Shared IP option is part of a Layer 2 HA design, which simplifies administration by providing a single URL or IP that always points to whichever appliance is currently in the "Active" or "In Control" state.
For a Shared IP configuration to function correctly, the Primary and Secondary administrative interfaces (port1) must be on the same subnet. This requirement exists because the Shared IP is a logical address that is dynamically assigned to the physical interface of the active unit. Since only one unit can own the IP at a time, both units must reside on the same broadcast domain (Layer 2) to ensure that ARP requests for the Shared IP are correctly answered and that the gateway remains reachable regardless of which unit is active. If the appliances were on different subnets (a Layer 3 HA design), a shared IP could not be used because it cannot "float" across different network segments; instead, administrators would need to manage each unit via its unique physical IP or use a FortiNAC Manager.
"For L2 HA configurations, click the Use Shared IP Address checkbox and enter the Shared IP Address information... If your Primary and Secondary Servers are not in the same subnet, do not use a shared IP address. The shared IP address moves between appliances during a failover and recovery and requires both units to reside on the same network." - FortiNAC-F High Availability Reference Manual: Shared IP Configuration.
NEW QUESTION # 33
An administrator has configured the DHCP scope for a registration isolation network, but the isolation process isn't working.
What is the problem with the configuration?
  • A. The domain name server designation is incorrect.
  • B. The lease pool does not contain a complete subnet.
  • C. The gateway defined for the scope is incorrect.
  • D. The label uses a system-reserved value.
In a FortiNAC-F deployment, the configuration of the DHCP scope for isolation networks (Registration, Remediation, etc.) must perfectly align with the underlying network infrastructure to ensure that isolated hosts can communicate with the FortiNAC appliance. In the provided exhibits, there is a clear discrepancy between the DHCP configuration and the Network Topology.
As shown in the "Network Topology" exhibit, the Registration Network resides on a router interface (or sub-interface) with the IP address 192.168.180.1. This address represents the default gateway for any host placed into the Registration VLAN. However, the "DHCP configuration" exhibit shows the scope "REG-ScopeOne" configured with a Gateway of 10.0.1.254. This 10.0.1.254 address belongs to the management/service network (port2 of FortiNAC), not the registration subnet. If a host in the Registration VLAN receives this incorrect gateway via DHCP, it will attempt to send all off-link traffic to an unreachable IP, preventing it from loading the Captive Portal or communicating with the FortiNAC server.
According to the FortiNAC-F Configuration Wizard Reference, when defining a Layer 3 network scope, the "Gateway" field must contain the IP address of the router interface that acts as the gateway for that specific isolation VLAN. The FortiNAC appliance itself usually sits on a different subnet, and traffic is directed to it via the router's DHCP Relay (IP Helper) and DNS redirection.
"When configuring scopes for a Layer 3 network, the Gateway value must be the IP address of the router interface for that subnet. This allows the host to reach its local gateway to route traffic. If the gateway is misconfigured, the host will be unable to reach the FortiNAC eth1/port2 interface for registration... Ensure the Gateway matches the network topology for the isolation VLAN." - FortiNAC-F Configuration Wizard Reference Manual: DHCP Scopes.
NEW QUESTION # 34
An administrator wants to use FortiNAC-F to automatically provision printers throughout their organization. Each building uses its own local VLAN for printers.
Which FortiNAC-F feature would allow this to be accomplished with a single network access policy?
  • A. Device profiling rules
  • B. Dynamic host groups
  • C. Preferred VLAN designations
  • D. Logical networks
The FortiNAC-F Logical Network feature is specifically designed to provide an abstraction layer between high-level security policies and the underlying physical network infrastructure. In large-scale deployments where different physical locations (like Building 1, 2, and 3 in the exhibit) use different local VLAN IDs for the same type of device (e.g., VLAN 10, 20, and 30 for printers), managing separate policies for each building would create significant administrative overhead.
By using a Logical Network, an administrator can create a single entity-for example, a logical network named "rinters"-and use it as the "Access Value" in a single Network Access Policy. The mapping of this logical label to a specific physical VLAN occurs at the Model Configuration level for each network device. When a printer connects to a switch in Building 1, FortiNAC-F evaluates the policy, identifies that the printer should be in the "rinters" logical network, and checks the Model Configuration for that specific switch to see which VLAN ID is mapped to that label (VLAN 10). If the same printer moves to Building 3, the same single policy applies, but FortiNAC-F provisions it to VLAN 30 based on the local mapping for that building's switch.
This architectural approach ensures that policies remain consistent and easy to manage regardless of the complexity or variations in the local network topology.
"Logical Networks provide a way to define a network access requirement once and apply it across many different network devices that may use different VLAN IDs for that access... Each managed device can use different VLAN IDs for the same Logical Network label. You can define the Logical Networks based on requirements and then associate the network to a VLAN ID when the managed device is configured in the Model Configuration." - FortiNAC-F IoT Deployment Guide: Define the Logical Networks.
NEW QUESTION # 35
A network administrator is troubleshooting a network access issue for a specific host. The administrator suspects the host is being assigned a different network access policy than expected.
Where would the administrator look to identify which network access policy, if any, is being applied to a particular host?
  • A. The Policy Details view for the host
  • B. The Connections view
  • C. The Policy Logs view
  • D. The Port Properties view of the hosts port
When troubleshooting network access in FortiNAC-F, it is often necessary to verify exactly why a host has been granted a specific level of access. Since FortiNAC-F evaluates policies from the top down and assigns access based on the first match, an administrator needs a clear way to see the results of this evaluation for a specific live endpoint.
The Policy Details (C) view is the designated tool for this purpose. By navigating to the Hosts > Hosts (or Adapter View) in the Administration UI, an administrator can search for the specific MAC address or IP of the host in question. Right-clicking on the host record reveals a context menu from which Policy Details can be selected. This view provides a real-time "look" into the policy engine's decision for that specific host, showing the Network Access Policy that was matched, the User/Host Profile that triggered the match, and the resulting Network Access Configuration (VLAN/ACL) currently applied.
While Policy Logs (A) provide a historical record of all policy transitions across the system, they are often too high-volume to efficiently find a single host's current state. The Connections view (B) shows the physical port and basic status but lacks the granular policy logic breakdown. The Port Properties (D) view shows the configuration of the switch interface itself, which is only one component of the final access determination.
"To identify which policy is currently applied to a specific endpoint, use the Policy Details view. Navigate to Hosts > Hosts, select the host, right-click and choose Policy Details. This window displays the specific Network Access Policy, User/Host Profile, and Network Access Configuration currently in effect for that host record." - FortiNAC-F Administration Guide: Policy Details and Troubleshooting.
NEW QUESTION # 36
What will happen to the host of a guest user created from this template if the time of connection is 8:00 PM?
  • A. The host will be marked as a rogue device.
  • B. The host will be administratively disabled.
  • C. The host will be marked as non-authenticated.
  • D. The host will be marked as at-risk.
In FortiNAC-F, the Guest & Contractor Template is a configuration object that defines the parameters for accounts created by sponsors or through self-registration. One of the critical security controls within this template is the Login Availability setting. This setting restricts the specific days and times during which a guest or contractor is permitted to authenticate and access the network.
As shown in the exhibit, the "StandardGuest" template has Login Availability set to "Specify Time", with a schedule defined as Mon-Fri, 6:00 AM to 7:00 PM. If a guest user attempts to connect or authenticate at 8:00 PM, which is outside of the permitted window, FortiNAC-F's policy engine will automatically deny the authentication request. When an authentication attempt is denied due to schedule restrictions, the system does not move the host into the "Authenticated" or "Registered" state required for production access. Instead, the host is marked as non-authenticated in the adapter or host view.
This behavior ensures that even if a guest possesses valid credentials, their access is strictly bound by the organizational policy for visitor hours. The host will typically remain in its current isolation or registration VLAN, and the user will see a message on the captive portal indicating that their account is not currently authorized for login. It is important to distinguish this from "at-risk" (C), which relates to security scan failures, or "rogue" (B), which typically refers to unknown devices that have not yet been associated with a valid account or profiling rule.
"Login Availability defines the timeframe during which the guest or contractor account is valid for network access. This schedule is enforced at the time of authentication. If a user attempts to log in outside of the designated window, the authentication is rejected by the system. Consequently, the host record will reflect a non-authenticated status, and the device will remain restricted to the isolation or registration network until a valid login window is reached." - FortiNAC-F Administration Guide: Guest and Contractor Templates Section.
NEW QUESTION # 37
To some extent, to pass the NSE5_FNC_AD_7.6 exam means that you can get a good job. The NSE5_FNC_AD_7.6 exam materials you master will be applied to your job. The possibility to enter in big and famous companies is also raised because they need outstanding talents to serve for them. Our NSE5_FNC_AD_7.6 Test Prep is compiled elaborately and will help the client a lot. Our product is of high quality and the passing rate and the hit rate are both high.
Latest NSE5_FNC_AD_7.6 Practice Questions: https://www.torrentexam.com/NSE5_FNC_AD_7.6-exam-latest-torrent.html
