[General] 確保通過的CWNA-109題庫分享&認證考試負責人材料和可信賴的CWNA-109測試
30
【General】 確保通過的CWNA-109題庫分享&認證考試負責人材料和可信賴的CWNA-109測試
Posted at 3/9/2026 11:36:55      View:97 | Replies:0        Print      Only Author   [Copy Link] 1#
BONUS!!! 免費下載Testpdf CWNA-109考試題庫的完整版:https://drive.google.com/open?id=1dj_b8nHTJGLd2P6F2swvocmQ7R1HUnOW
CWNP CWNA-109認證證書可以加強你的就業前景,可以開發很多好的就業機會。Testpdf是一個很適合參加CWNP CWNA-109認證考試考生的網站,不僅能為考生提供CWNP CWNA-109認證考試相關的所有資訊,而且還為你提供一次不錯的學習機會。Testpdf能夠幫你簡單地通過CWNP CWNA-109認證考試。
Testpdf為你提供真實的環境中找的真正的CWNP的CWNA-109考試的準備過程,如果你是初學者或是想提高你的專業技能,Testpdf CWNP的CWNA-109考古題將提供你,一步步讓你靠近你的願望,你有任何關於考試的考題及答案的問題,我們將第一時間幫助你解決,在一年之內,我們將提供免費更新。
CWNA-109測試 & CWNA-109題庫Testpdf為CWNP CWNA-109 認證考試準備的培訓包括CWNP CWNA-109認證考試的模擬測試題和當前的考試真題。在互聯網上你也可以看到幾個也提供相關的培訓的網站,但是你比較之後,你就會發現Testpdf的關於CWNP CWNA-109 認證考試的培訓比較有針對性,不僅品質是最高的,而且內容是最全面的。
最新的 CWNA Certification CWNA-109 免費考試真題 (Q123-Q128):問題 #123
A WLAN transmitter that emits a 50 mW signal is connected to a cable with 3 dB loss. If the cable is connected to an antenna with 9dBi gain, what is the EIRP at the antenna element?
  • A. 10 dBm
  • B. 23 dBm
  • C. 26 dBm
  • D. 13 dBm
答案:B
解題說明:
To calculate the EIRP at the antenna element, we need to add the transmitter output power, subtract the cable loss, and add the antenna gain. All these values need to be converted to dBm first, if they are not already given in that unit. In this case, we have:
Transmitter output power = 50 mW = 10 log (50) dBm = 16.99 dBm Cable loss = 3 dB Antenna gain = 9 dBi EIRP = Transmitter output power - Cable loss + Antenna gain EIRP = 16.99 - 3 + 9 EIRP = 22.99 dBm Rounding up to the nearest integer, we get 23 dBm as the EIRP at the antenna element12. References: CWNA-109 Study Guide, Chapter 2: Radio Frequency Fundamentals, page
92; CWNA-109Study Guide, Chapter 2: Radio Frequency Fundamentals, page 88.
問題 #124
When compared with legacy Power Save mode, how does VHT TXOP power save improve battery life for devices on a WLAN?
  • A. VHT TXOP power save uses the partial AID in the preamble to allow clients to identify frames targeted for them.
  • B. Legacy Power Save mode was removed in the 802.11ac amendment.
  • C. VHT TXOP power save allows stations to enter sleep mode and legacy Power Save does not.
  • D. VHT TXOP power save allows the WLAN transceiver to disable more components when in a low power state.
答案:D
解題說明:
VHT TXOP (Very High Throughput Transmit Opportunity) power save is a feature introduced with the
802.11ac amendment, which is designed to improve the power efficiency of devices connected to a WLAN.
This feature enhances battery life in several ways, compared to the legacy Power Save mode:
* Enhanced Power Saving: VHT TXOP power save allows devices to disable more components of the WLAN transceiver when they are in a low power state. This reduces the power consumption during periods when the device is not actively transmitting or receiving data.
* Intelligent Wake-Up Mechanisms: It employs more sophisticated mechanisms for devices to determine when they need to wake up and listen to the channel, further reducing unnecessary power usage.
* Optimized Operation: This power save mode is optimized for the high-throughput environment of
802.11ac networks, allowing devices to efficiently manage power while maintaining high performance.
Legacy Power Save mode, introduced in earlier versions of the 802.11 standards, does not provide the same level of component disablement or the intelligent wake-up mechanisms found in VHT TXOP power save, making option B the correct answer.
IEEE 802.11ac-2013 Amendment: Enhancements for Very High Throughput for Operation in Bands below 6 GHz.
CWNA Certified Wireless Network Administrator Official Study Guide: Exam CWNA-109, by David D.
Coleman and David A. Westcott.
問題 #125
Option 43 must be configured to allow access points to locate controllers. In what network service should this option be configured?
  • A. DNS
  • B. RADIUS
  • C. DHCP
  • D. LDAP
答案:C
解題說明:
DHCP (Dynamic Host Configuration Protocol) is the network service where option 43 must be configured to allow access points to locate controllers. DHCP is a protocol that allows a device to obtain an IP address and other network configuration parameters from a server. In a wireless controller scenario, the access points can use DHCP to request an IP address from a DHCP server, which can also provide the IP address or hostname of the wireless controller as an option in the DHCP response. Option 43 is a vendor-specific option that can be used to encode custom information for different types of devices. For example, Cisco access points can use option 43 to receive the IP address of the wireless controller from the DHCP server, while Aruba access points can use option 43 to receive the hostname of the wireless controller from the DHCP server. This way, the access points can discover the wireless controller and establish a connection with it. References: 1, Chapter 8, page 309; 2, Section 5.2
問題 #126
XYZ Company has decided to install an 802.11 WLAN system that will support 1083 wireless users, but they are concerned about network security. XYZ is interested in deploying standardized security features. In addition to WPA2-Enterprise with PEAP and role-based access control, XYZ would like to support management frame protection as well as a fast secure roaming protocol for future mobile handsets.
As XYZ Company selects a product to deploy, what two IEEE amendments, which are included in
802.11-2016, and 802.11-2020 should be supported to provide the management frame protection and fast secure roaming security features?
  • A. 802.11r and 802.11w
  • B. 802.11k and 802.11v
  • C. 802.11j and 802.11z
  • D. 802.11j and 802.11k
答案:A
解題說明:
The two IEEE amendments that should be supported to provide the management frame protection and fast secure roaming security features are 802.11r and 802.11w12.
* 802.11r (Fast BSS Transition): This amendment to the IEEE 802.11 standard permits continuous connectivity aboard wireless devices in motion, with fast and secure client transitions from one Basic Service Set to another1.
* 802.11w (Management Frame Protection): This amendment increases the security of its management frames2.
問題 #127
You have implemented an 802.11ax WLAN for a customer. All APs are four stream HE APs. The customer states that it is essential that most of the clients can use the OFDMA modulation scheme. What do you tell the customer?
  • A. If the devices support 802.11ac, they can be updated to support OFDMA through driver upgrades
  • B. OFDMA is an optional feature of 802.11ax and most APs don't even support it
  • C. The clients that must support OFDMA must also be upgraded to 802.11ax
  • D. All 5 GHz PHYs use OFDM modulation, so you will achieve OFDMA everywhere in 5 GHz
答案:C
解題說明:
OFDMA is a new modulation scheme introduced in 802.11ax that allows multiple users to share the same channel by dividing it into smaller subchannels called resource units (RUs). This improves the efficiency and capacity of the WLAN by reducing contention and overhead. However, to use OFDMA, both the AP and the client must support 802.11ax and negotiate the parameters of the subchannel allocation. Therefore, the customer needs to upgrade the clients that require OFDMA to 802.11ax devices12.
The other options are not correct because they do not reflect the reality of OFDMA. Option B is incorrect because OFDMA is a mandatory feature of 802.11ax for both downlink and uplink transmissions, and all
802.11ax APs must support it1. Option C is incorrect because OFDM and OFDMA are different modulation schemes, and OFDM does not allow multiple users to share the same channel. Option D is incorrect because
802.11ac devices cannot support OFDMA through driver upgrades, as they lack the hardware and firmware capabilities to do so2.: 1: CWNA-109 Official Study Guide, page 144 2: OFDMA
問題 #128
Testpdf的CWNA-109資料的命中率高達100%。它可以保證每個使用過它的人都順利通過考試。當然,這也並不是說你就完全不用努力了。你需要做的就是,認真學習這個資料裏出現的所有問題。只有這樣,在考試的時候你才可以輕鬆應對。怎麼樣?Testpdf的資料可以讓你在準備考試時節省很多的時間。它是你通過CWNA-109考試的保障。想要這個資料嗎?那就快點擊Testpdf的網站來購買吧。另外,你也可以在購買之前先試用一下資料的樣本。这样你就可以亲自确定资料的质量如何了。
CWNA-109測試: https://www.testpdf.net/CWNA-109.html
當你選擇了Testpdf你就會真正知道你已經為通過CWNP CWNA-109認證考試做好了準備,他們不斷利用自己的IT知識和豐富的經驗來研究CWNP CWNA-109 認證考試的往年的考題而推出了CWNP CWNA-109 認證考試的考試練習題和答案,CWNA-109評估考試是基於網絡的考試,以更低的成本為您提供在參加CWNA-109考試前檢查您的技能的能力,如果你正在準備CWNA-109 考試,為CWNA Certification認證做最後衝刺,又苦於沒有絕對權威的考試真題模擬, Testpdf希望能助你成功,很多人之所以練習CWNA-109問題集的效率不高,就是在CWNA-109問題集練習上存在各種誤區,大家都知道,Testpdf CWNP的CWNA-109考試培訓資料的知名度非常高,在全球範圍類也是赫赫有名的,為什麼會產生這麼大的連鎖反映呢,因為Testpdf CWNP的CWNA-109考試培訓資料確實很適用,而且真的可以幫助我們取得優異的成績。
清壹色全是為葉玄叫好的,秦川的身上的佛光寶氣更加濃郁了,當你選擇了Testpdf你就會真正知道你已經為通過CWNP CWNA-109認證考試做好了準備,他們不斷利用自己的IT知識和豐富的經驗來研究CWNP CWNA-109 認證考試的往年的考題而推出了CWNP CWNA-109 認證考試的考試練習題和答案。
優秀的CWNP CWNA-109題庫分享是行業領先材料&高品質的CWNA-109:CWNP Wireless Network Administrator (CWNA)CWNA-109評估考試是基於網絡的考試,以更低的成本為您提供在參加CWNA-109考試前檢查您的技能的能力,如果你正在準備CWNA-109 考試,為CWNA Certification認證做最後衝刺,又苦於沒有絕對權威的考試真題模擬, Testpdf希望能助你成功!
很多人之所以練習CWNA-109問題集的效率不高,就是在CWNA-109問題集練習上存在各種誤區。
從Google Drive中免費下載最新的Testpdf CWNA-109 PDF版考試題庫:https://drive.google.com/open?id=1dj_b8nHTJGLd2P6F2swvocmQ7R1HUnOW
