[General] U4GM Guide ARC Raiders Dam Controlled Access Zone Steps
24
General U4GM Guide ARC Raiders Dam Controlled Access Zone Steps
Posted at 3/9/2026 15:46:44      View142 | Replies0        Print      Only Author   [Copy Link] 1#
Most squads run past the Controlled Access Zone on Dam Battlegrounds the first time they see it. Then they hear what drops in there and come sprinting back. It sits in that awkward strip between the Breach and the generators, and it's built like a stack of problems: wet lower levels, ladders that leave you exposed, and catwalks that turn every footstep into a warning bell. If you're planning to push it, sort your loadout first and know what you're chasingpeople who've been farming ARC Raiders Items will tell you the difference between "nice loot" and "we should've extracted five minutes ago" is usually just preparation.
Your first job is getting power back online. That means finding a Fuel Cell somewhere down low, usually near old machines, pallets, or those half-hidden storage corners everyone forgets to check. The moment you grab it, you'll feel the penaltyyour movement's worse, your turns are slower, and suddenly you're the most valuable target in the room. Don't do the heroic solo carry. Have one player clear ahead, one watch the back, and one ready to trade if a patrol or another squad walks in. Slot the cell into the receptacle and you'll hear the place wake up, which is great, because it also tells everyone nearby you're committing.
Next is the heavy security door with four indicator lights. It looks simple until you realise what it's asking: four hidden buttons, pressed at the same time. One is normally close to the door, so someone always finds that and thinks they're done. The other three can be on pipe runs, around corners on the upper walkways, or inside rooms that only opened after power came back. You need comms, full stop. Do a quick callout like "ready on three," then count it clean. If one person is late, even by a beat, it won't take. And yes, you'll have to reset and do the run again, which is exactly when teams get jumped.
Once you're through, there's a control panel that's basically dead weight until you repair it. Most runs ask for 12 Metal Parts and an Industrial Battery, and scavenging those inside the zone is a trap. You'll burn time opening crates while footsteps stack up behind you. Bring the materials in your packs and treat the repair like a pit stop: drop, craft, move. When the final chamber opens, don't linger. Split roles fastone player grabs weapon cases, one checks containers for blueprints and components, one watches the entry. Also pick your exit before you even touch the first Fuel Cell, because the route you used to enter often becomes the route other squads use to intercept.
The Controlled Access Zone isn't hard because the steps are complicated; it's hard because it makes you stay loud and busy for too long. You'll feel that pressure the second the vault opens, like the whole map just tilted toward you. If you're missing a material or you keep failing the button timing, it can be smarter to back out and reset the plan rather than forcing it and donating gear. And if you're trying to gear up for repeated runsammo, consumables, or that one piece you keep losingsome players top off their setups through U4GM so they can jump back in without spending all night rebuilding their stash.
