[General] NCP-MCA Frenquent Update - NCP-MCA Latest Material
24
General NCP-MCA Frenquent Update - NCP-MCA Latest Material
Posted at 3/10/2026 11:56:47      View177 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free & New NCP-MCA dumps are available on Google Drive shared by TestKingIT: https://drive.google.com/open?id=1bucQdjEYsKsywIgj45Oxh45yI5xF0i3q
Why we are so popular in the market and trusted by tens of thousands of our clients all over the world? The answer lies in the fact that every worker of our company is dedicated to perfecting our NCP-MCA exam guide. The professional experts of our company are responsible for designing every NCP-MCAquestion and answer. No one can know the NCP-MCA study materials more than them. In such a way, they offer the perfect NCP-MCA exam materials not only on the content but also on the displays.
By earning the NCP-MCA certification, IT professionals can demonstrate their expertise in managing and automating multicloud environments using Nutanix technology. Nutanix Certified Professional - Multicloud Automation (NCP-MCA 6.10) certification is recognized by employers around the world and can help IT professionals advance their careers and increase their earning potential.
The NCP-MCA certification exam is a challenging test that requires candidates to demonstrate their knowledge and skills in a variety of different areas. However, Nutanix provides a range of resources to help candidates prepare for the exam, including online training courses, practice exams, and study guides. Candidates who are interested in earning this certification should take advantage of these resources to ensure they are fully prepared for the exam.
The NCP-MCA Certification Exam is a challenging exam that requires a solid understanding of multicloud automation concepts, tools, and technologies. It covers topics such as workflow automation, infrastructure as code, and scripting languages like Python and PowerShell. NCP-MCA exam is designed to test an individual's ability to automate and orchestrate complex multicloud environments using Nutanix solutions. The NCP-MCA certification exam is an excellent way to validate your skills and knowledge in multicloud automation.
Nutanix NCP-MCA Practice Test - The Secret To Overcome Exam AnxietyThis offline software works only on Windows computers and laptops. TestKingIT also offers up to 1 year of free updates, if for instance, the sections of real Nutanix Certified Professional - Multicloud Automation (NCP-MCA 6.10) examination changes after your purchase of the NCP-MCA practice test material. So just download actual NCP-MCA Exam Questions and start your journey today. It ensures that you would qualify for the Nutanix NCP-MCA certification exam on the maiden strive with brilliant grades.
Nutanix Certified Professional - Multicloud Automation (NCP-MCA 6.10) Sample Questions (Q69-Q74):NEW QUESTION # 69
Refer to exhibits.
The variable VM_NAME is giving a warning that indicates that the variable is not found. When checking the Service tab, the variable is found to match the VM_NAME field entry as shown in the exhibit below:
What is causing this warning message?
  • A. User modifiable variable for VM_NAME is not allowed
  • B. VM_NAME variable must be defined under Application Profile
  • C. Service Name matches the variable name
  • D. @@{calm_time}@@ output is longer than allowed for a Service Name
https://portal.nutanix.com/page/ ... ons-Guide-v3_6_2:nu
NEW QUESTION # 70
What is a Category?
  • A. A grouping of entities into a key value pair
  • B. A grouping of clusters into a key value pair
  • C. A grouping of VMs into a key value pair
  • D. A grouping of hosts into a key value pair
A Category in Nutanix is a grouping of entities (such as VMs, hosts, clusters, etc.) into a key-value pair. Categories are used to organize and manage resources more effectively by tagging them with meaningful identifiers.
Nutanix documentation on Categories.
Nutanix Best Practices for Using Categories.
NEW QUESTION # 71
When using Prism Central Disaster Recovery in an Organization, which statement is true for Playbooks on a recovered Prism Central?
  • A. No changes need to be made to credentials in enabled Playbooks; they will continue to work successfully.
  • B. Credentials should be re-entered into enabled Playbooks since a credential provider is used.
  • C. No changes need to be made to credentials in enabled Playbooks since a credential provider is used.
  • D. Credentials should be re-entered into enabled Playbooks so they will continue to work successfully.
In Nutanix Prism Central Disaster Recovery, when a Prism Central instance fails over to a recovered site, several automation components-including Playbooks-must be revalidated. Nutanix documentation clearly states:
* Playbooks store encrypted credentials locally in the Prism Central database.
* When Prism Central is recovered on a DR site, the credential encryption keys donottransfer.
* As a result,any credentials previously stored in Playbooks become invalidand must be manually re- entered.
This requirement ensures that the scripts, tasks, remediation sequences, and integrations invoked by the Playbook can authenticate properly after recovery.
Therefore:
* Playbookscannot automatically use previously stored credentialsafter a DR failover.
* Administrators mustre-enter all credentialsin enabled Playbooks so the automation continues functioning.
Hence, OptionCis correct.
Options A and D are incorrect because Playbooks donotautomatically retain functional credentials after DR recovery.
Option B is incorrect because the presence or absence of a credential provider does not change the need to re- enter credentials.
NEW QUESTION # 72
An administrator has a vendor-provided script that must be run at 9 am every Saturday on a Linux application VM.
The administrator currently has a playbook that has a Time trigger and a VM SSH action to execute the script.
However, the administrator has received a request to have the output of the script emailed to the application team when it is executed.
What is the easiest way to satisfy this request?
  • A. Add an Email action to the end of the existing playbook and use the {{action[index] .stdout}} parameter in the Message field.
  • B. Add an Email action to the end of the existing playbook and use the {{action [index].response_body}} parameter in the Message field.
  • C. Modify the script to include a function to format the output of the script and email the output to the desired address.
  • D. Direct the output of the script to a file and use the Send Email with Payload action at the end of your existing playbook.
The easiest way to satisfy the request is to add an Email action to the end of the existing playbook and use the {{action[index] .stdout}} parameter in the Message field. This way, the administrator does not need to modify the script or create a file to store the output. The {{action[index] .stdout}} parameter will capture the standard output of the previous action, which is the VM SSH action that executes the script. The Email action will then send the output as the message body to the specified recipients. References: You can find more information about this topic in the following sources:
* Nutanix Certified Professional - Multicloud Automation (NCP-MCA) Exam Blueprint Guide, Section 3 - Validate Blueprints, Runbooks, Playbooks, and Automation Settings, page 10
* Nutanix Multicloud Automation Administration (NMCAA), Module 4 - X-Play, Lesson 2 - Playbooks, page 4-11
NEW QUESTION # 73
Which two entities can Categories be assigned to? (Choose two.)
  • A. Groups
  • B. Hosts
  • C. VMs
  • D. Users
In Nutanix, Categories can be assigned to various entities to help organize and manage resources. The two entities that can be assigned categories are:
* Hosts: Categories can be used to tag and manage hosts within the infrastructure.
* VMs: Categories can also be assigned to virtual machines, allowing for better organization and management based on specific attributes or requirements.
* Nutanix documentation on Category Management.
* Nutanix Best Practices for Using Categories.
NEW QUESTION # 74
We offer you free update for one year after purchasing, that is to say, in the following year, you will get the updated version for NCP-MCA learning materials for free. And our system will immediately send the latest version to your email address automatically once they update. Whats more, the NCP-MCA Learning Materials are high quality, and it will ensure you to pass the exam successfully. Pass guarantee and money back guarantee if you cant pass the exam.
NCP-MCA Latest Material: https://www.testkingit.com/Nutanix/latest-NCP-MCA-exam-dumps.html
BTW, DOWNLOAD part of TestKingIT NCP-MCA dumps from Cloud Storage: https://drive.google.com/open?id=1bucQdjEYsKsywIgj45Oxh45yI5xF0i3q
