PEGACPDC25V1 Valid Test Pdf, PEGACPDC25V1 Reliable Test Review
26
Posted at 3/10/2026 14:23:27      View138 | Replies0        Print      Only Author   [Copy Link] 1#
What's more, part of that ExamDumpsVCE PEGACPDC25V1 dumps now are free: https://drive.google.com/open?id=1Tg-waRRffMZTip8mCIn1Rq7BHefR4N3j
Here I would like to explain the core value of ExamDumpsVCE exam dumps. ExamDumpsVCE Practice PEGACPDC25V1 Test dumps guarantee 100% passing rate. ExamDumpsVCE real questions and answers are compiled by lots of Pegasystems experts with abundant experiences. So it has very high value. The dumps not only can be used to prepare for Pegasystems certification exam, also can be used as a tool to develop your skills. In addition, if you want to know more knowledge about your exam, ExamDumpsVCE exam dumps can satisfy your demands.
Pegasystems PEGACPDC25V1 Exam Syllabus Topics:
  • Customer Engagement Optimization: Addresses change management, revision management, GenAI brand voice, and action update processes.
  • Next-Best-Action concepts: Covers one-to-one engagement fundamentals, contact center optimization, always-on outbound strategies, and next-best-action optimization.
  • Decision strategies: Focuses on building decision strategies with business logic to power the decisioning engine.
  • Actions and treatments: Focuses on defining and managing customer actions for web and outbound channels.
Topic 5
  • Channels: Covers implementing real-time containers, offer emails, and third-party integrations for multi-channel delivery.
100% Pass Perfect PEGACPDC25V1 - Certified Pega Decisioning Consultant 25 Valid Test PdfThere is no doubt that advanced technologies are playing an important role in boosting the growth of Pegasystems companies. This is the reason why the employees have now started upgrading their skillset with the Certified Pega Decisioning Consultant 25 (PEGACPDC25V1) certification exam because they want to work with those latest applications and save their jobs. They attempt the PEGACPDC25V1 exam to validate their skills and try to get their dream job.
Pegasystems Certified Pega Decisioning Consultant 25 Sample Questions (Q101-Q106):NEW QUESTION # 101
U+ Bank uses a scorecard rule in a decision strategy to compute the mortgage limit for a customer. U+ Bank updated their scorecard to include a new property in the calculation: customer income.
What changes do you need to make in the decision strategy for the updated scorecard to take effect?
  • A. The score calculation is independent of the strategy and no change is required.
  • B. Add a new Group By component for the mortgage limit calculation.
  • C. A new proposition filter needs to be configured in the strategy to filter on customer income.
  • D. Remap the scorecard property in the decision strategy for the change to take effect.
The score calculation is independent of the strategy and no change is required. When you use a scorecard component in a decision strategy, you only need to specify the name of the scorecard rule and the output property that will store the score value. The scorecard rule itself defines how the score is calculated based on the input properties and factors. Therefore, if you update the scorecard rule to include a new property in the calculation, you do not need to make any changes in the decision strategy for the updated scorecard to take effect. Verified Reference: [Pega Academy - Decisioning Consultant - Using scorecards]
NEW QUESTION # 102
You are a decisioning architect on a next-best-action project and are responsible for designing and implementing decision strategies. Select each component on the leftand drag it to the correct requirement on the right.
NEW QUESTION # 103
NEW QUESTION # 104
MyCo, a telecom company, uses Pega Customer Decision Hub to present offers to qualified customers. The business recently decided to send offer messages through the email channel. The Design department has designed an email treatment which includes dynamic placeholders.
As a deaccessioning architect, what do you use in order to test the visualization and the rendering of the email content, including replacing of the placeholders with customer information?
  • A. A seed list from the Test email tab
  • B. Schedule an outbound run with a limited number of customers
  • C. Preview section from the email content editor
  • D. A list of customer email addresses from the Test email tab
To test the visualization and the rendering of the email content, including replacing of the placeholders with customer information, you use a seed list from the Test email tab. A seed list is a predefined set of customers that you can use to test your email treatments before sending them to your target audience. You can select one or more customers from the seed list and send them a test email with your treatment. You can then verify how the email looks in their inbox and how the placeholders are replaced with their actual values. Verified References: [Pega Academy - Decisioning Consultant - Testing email treatments]
NEW QUESTION # 105
1yCo, a telecom company, wants to start promoting data plan offers through SMS to qualified customers. The marketing team needs to ensure that the outbound run always uses the latest customer information.
What do you configure to implement this requirement?
  • A. Trigger an external Extract-Transform-Load (ETL) process.
  • B. Select the Refresh the audience checkbox.
  • C. Run the starting population segment daily.
  • D. Select a different audience sample with a similar profile.
To implement this requirement, you need to select the Refresh the audience checkbox in the outbound run configuration. This option allows you to refresh the audience data before each run by executing a data flow that reads from your customer data source and updates your customer data set. This way, you can ensure that the outbound run always uses the latest customer information available in your system. Verified Reference: Pega Academy - Decisioning Consultant - Configuring outbound runs
NEW QUESTION # 106
What kind of services on the PEGACPDC25V1 training engine can be considered professional, you will have your own judgment. We will give you the most professional answers on the PEGACPDC25V1 practice engine in the first time. But I would like to say that our PEGACPDC25V1 Study Materials must be the most professional of the PEGACPDC25V1 exam simulation you have used. Our experts who compiled them are working on the subject for years.
PEGACPDC25V1 Reliable Test Review: https://www.examdumpsvce.com/PEGACPDC25V1-valid-exam-dumps.html
P.S. Free 2026 Pegasystems PEGACPDC25V1 dumps are available on Google Drive shared by ExamDumpsVCE: https://drive.google.com/open?id=1Tg-waRRffMZTip8mCIn1Rq7BHefR4N3j
