BootcampPDF JS-Dev-101 Test Questions Prioritize Your Study Time
Posted at 3/11/2026 02:03:22
View150
Replies0
2026 Latest BootcampPDF JS-Dev-101 PDF Dumps and JS-Dev-101 Exam Engine Free Share: https://drive.google.com/open?id=1kY3DrGPDBbzDJjlDTF6Rpc47lLJ00Pmm
Passing the Salesforce Certified JavaScript Developer - Multiple Choice exam at first attempt is a goal that many candidates strive for. However, some of them think that good Salesforce JS-Dev-101 study material is not important, but this is not true. The right JS-Dev-101 preparation material is crucial for success in the exam. And applicants who dont find updated JS-Dev-101 prep material ultimately fail in the real examination and waste money. That's why BootcampPDF offers actual JS-Dev-101 exam questions to help candidates pass the exam and save their resources.
Probably youve never imagined that preparing for your upcoming JS-Dev-101 exam could be so easy. The good news is that JS-Dev-101 test dumps have made it so! The brilliant JS-Dev-101 test dumps are the product created by those professionals who have extensive experience of designing exam study materials. These professionals have deep exposure of the test candidates problems and requirements hence our JS-Dev-101 Test Dumps cater to your need beyond your expectations.
Salesforce JS-Dev-101 Actual Exam Questions Free Updates By BootcampPDFBootcampPDF is the website that provides all candidates with IT certification exam dumps and can help all candidates pass their exam with ease. BootcampPDF IT expert edits all-time exam materials together on the basis of flexibly using the experiences of forefathers, thereby writing the best Salesforce JS-Dev-101 Certification Training dumps. The exam dumps include all questions that can appear in the real exam. So it can guarantee you must pass your exam at the first time.
Salesforce Certified JavaScript Developer - Multiple Choice Sample Questions (Q33-Q38):NEW QUESTION # 33
A developer is wondering whether to use, Promise.then or Promise.catch, especially when a Promise throws an error?
Which two promises are rejected?
Which 2 are correct?
- A. Promise.reject('cool error here').catch(error => console.error(error));
- B. Promise.reject('cool errorhere').then(error => console.error(error));
- C. New Promise(() => (throw 'cool error here'}).then(null, error => console.error(error)));
- D. New Promise((resolve, reject) => (throw 'cool error here'}).catch(error =>console.error(error)) ;
NEW QUESTION # 34
Refer to the code below:
flag();
function flag() {
console.log('flag');
const anotherFlag = () => {
console.log('another flag');
anotherFlag();
What is result of the code block?
- A. The console logs 'flag' and then an error is thrown.
- B. The console logs 'flag' and 'another flag'.
- C. The console logs only 'flag'.
- D. An error is thrown.
Comprehensive and Detailed Explanation From Exact Extract JavaScript Knowledge:
Key points:
Function declarations are hoisted (their definitions are available before the line where they appear).
Function expressions assigned to const or let are not hoisted as callable functions, but here anotherFlag is only used after it is defined.
Step-by-step:
flag(); at the top:
flag is a function declaration defined later; due to hoisting, it is available.
It logs 'flag'.
The declaration:
function flag() {
is already in effect (hoisted before execution).
const anotherFlag = () => { console.log('another flag'); } defines anotherFlag as an arrow function.
anotherFlag(); is called after its definition; this is valid and logs 'another flag'.
No errors occur. The console output is:
flag
another flag
So option D is correct.
Concepts: function hoisting, difference between function declarations and function expressions, execution order.
NEW QUESTION # 35
Refer to the following code:
Let sampleText = 'The quick brown fox jumps';
A developer needs to determine if a certainsubstring is part of a string.
Which three expressions return true for the given substring ?
Choose 3 answers
- A. sampleText.includes('fox');
- B. sampleText.includes(' fox ');
- C. sampleText.includes(' quick ') !== -1;
- D. sampleText.includes(' Fox ', 3)
- E. sampleText.includes(' quick ', 4);
Answer: B,C,E
NEW QUESTION # 36
Which option is true about the strict mode in imported modules?
- A. A developer can only reference notStrict() functions from the imported module.
- B. Imported modules are in strict mode whether you declare them as such or not.
- C. Add the statement use non-strict; before any other statements in the module to enable notstrict mode.
- D. Add the statement use strict = false; before any other statements in the module to enable notstrict mode.
Comprehensive and Detailed Explanation From Exact Extract JavaScript knowledge:
In JavaScript, ES modules (files imported using import / export) have special semantics:
All code inside a module is automatically executed in strict mode.
This is specified by the ECMAScript standard and does not require the explicit "use strict"; directive.
Effects:
You do not need to write "use strict"; at the top of a module file.
You cannot turn strict mode off for module code.
All module top-level code is treated as strict.
Now evaluate each option:
Option A:
There is no use non-strict; directive in JavaScript.
The only directive recognized by engines is "use strict";.
You cannot explicitly enable a "non-strict" mode with such a string.
Option B:
This matches the language specification.
ES modules are always in strict mode, automatically.
This is true.
Option C:
use strict = false; is not a directive; it is parsed as a normal expression, and does not affect strict mode.
There is no supported way to disable strict mode in modules.
Option D:
There is no special notStrict() restriction in modules.
Functions exported/imported in modules are simply subject to strict mode rules like the rest of the module's code.
Therefore, the only correct statement is:
Study Guide / Concept Reference (no links):
ES modules (import / export)
Automatic strict mode in modules
"use strict"; directive for scripts vs modules
Inability to disable strict mode in ES module code
________________________________________
NEW QUESTION # 37
A developer wants to use a module called DatePrettyPrint.
This module exports one default function called printDate().
How can the developer import and use printDate()?
- A. import DatePrettyPrint from '/path/DatePrettyPrint.js';
DatePrettyPrint.printDate(); - B. import DatePrettyPrint() from '/path/DatePrettyPrint.js';
printDate(); - C. import printDate from '/path/DatePrettyPrint.js';
printDate(); - D. import printDate from '/path/DatePrettyPrint.js';
Comprehensive and Detailed Explanation From Exact Extract JavaScript Knowledge ES Modules follow these rules:
Default exports are imported using:
import anyName from 'module'
The name chosen in the import does NOT need to match the exported name.
If a module exports:
export default function printDate() {}
then consuming code should import the function directly:
To execute it:
printDate();
Option analysis:
A incorrect:
import DatePrettyPrint() is invalid syntax.
Also calling printDate() without importing it is incorrect.
B incorrect:
A default export imported as DatePrettyPrint gives the function itself, not an object containing methods.
You cannot call DatePrettyPrint.printDate().
C incorrect:
Imports printDate but then calls DatePrettyPrint.printDate(), which does not exist.
D correct:
Correct import of a default-exported function.
Correct direct invocation.
JavaScript Knowledge Reference (text-only)
Default export imported without braces.
Importing default functions gives a callable function, not an object.
Correct syntax: import identifier from "module".
NEW QUESTION # 38
To pass the JS-Dev-101 exam, you must put in a lot of time studying, practicing, and working hard. You will need real Salesforce JS-Dev-101 Questions and the necessary understanding of the exam's format to pass the JS-Dev-101 test. Without preparing with actual Salesforce Certified JavaScript Developer - Multiple Choice (JS-Dev-101) questions, applicants find it difficult to get the knowledge essential to pass the Salesforce certification exam in a short time.
Valid Exam JS-Dev-101 Preparation: https://www.bootcamppdf.com/JS-Dev-101_exam-dumps.html
Once we successfully develop the new version of the JS-Dev-101 test guide, the system will automatically send you an email that includes the updated version, No doubt the BootcampPDF is one of the leading and reliable platforms that has been helping JS-Dev-101 exam candidates in their preparation, Salesforce JS-Dev-101 braindumps is the best way to prepare your exam in just 1 day, Why buy BootcampPDF Valid Exam JS-Dev-101 Preparation Salesforce Valid Exam JS-Dev-101 Preparation Training Material The training material for all certifications that BootcampPDF Valid Exam JS-Dev-101 Preparation offers is the best in the market, it gives you real exam questions along with regular updates.
Freelance negotiation grid It takes time and effort to find and develop relationships Valid Exam JS-Dev-101 Preparation with good clients, This approach differs from that of a symphony orchestra, in which many musicians may play the same first violin or cello part.
Free PDF Quiz Authoritative Salesforce - Pass4sure JS-Dev-101 Dumps PdfOnce we successfully develop the new version of the JS-Dev-101 Test Guide, the system will automatically send you an email that includes the updated version, No doubt the BootcampPDF is one of the leading and reliable platforms that has been helping JS-Dev-101 exam candidates in their preparation.
Salesforce JS-Dev-101 braindumps is the best way to prepare your exam in just 1 day, Why buy BootcampPDF Salesforce Training Material The training material for all certifications that BootcampPDF JS-Dev-101 offers is the best in the market, it gives you real exam questions along with regular updates.
More detailed information is under below.
- JS-Dev-101 Pdf Free 🐾 Exam Sample JS-Dev-101 Online 📮 JS-Dev-101 Latest Test Report 🦡 Immediately open [url]www.prepawayete.com and search for JS-Dev-101 to obtain a free download ⚽JS-Dev-101 Paper[/url]
- Real JS-Dev-101 Questions 🚂 JS-Dev-101 New Braindumps Pdf 👫 JS-Dev-101 Latest Test Report 👯 ➽ [url]www.pdfvce.com 🢪 is best website to obtain { JS-Dev-101 } for free download 🦮JS-Dev-101 Real Questions[/url]
- JS-Dev-101 Latest Version 😄 Valid JS-Dev-101 Dumps Demo 🚥 Valid JS-Dev-101 Dumps Demo 🤓 ➠ [url]www.troytecdumps.com 🠰 is best website to obtain JS-Dev-101 for free download 🏑
ractice JS-Dev-101 Exams[/url] - Quiz 2026 JS-Dev-101: Accurate Pass4sure Salesforce Certified JavaScript Developer - Multiple Choice Dumps Pdf 💯 Search for ➠ JS-Dev-101 🠰 and download it for free immediately on ▛ [url]www.pdfvce.com ▟ 🈵JS-Dev-101 Valid Exam Voucher[/url]
- JS-Dev-101 Exam Study Solutions 🥒 JS-Dev-101 Excellect Pass Rate 🏭 JS-Dev-101 Real Questions 📖 Immediately open ➡ [url]www.troytecdumps.com ️⬅️ and search for [ JS-Dev-101 ] to obtain a free download 🍥JS-Dev-101 Exam Study Solutions[/url]
- Valid JS-Dev-101 Dumps Demo 🦊 Valid JS-Dev-101 Dumps Demo 🔤 JS-Dev-101 Latest Version 🌏 Enter ➡ [url]www.pdfvce.com ️⬅️ and search for ⇛ JS-Dev-101 ⇚ to download for free 👆JS-Dev-101 Paper[/url]
- Quiz 2026 JS-Dev-101: Accurate Pass4sure Salesforce Certified JavaScript Developer - Multiple Choice Dumps Pdf 🧭 Open website ⏩ [url]www.examcollectionpass.com ⏪ and search for ▶ JS-Dev-101 ◀ for free download ⛑JS-Dev-101 Valid Exam Answers[/url]
- Latest Pass4sure JS-Dev-101 Dumps Pdf offer you accurate Valid Exam Preparation | Salesforce Salesforce Certified JavaScript Developer - Multiple Choice 🏛 Immediately open ▷ [url]www.pdfvce.com ◁ and search for ➥ JS-Dev-101 🡄 to obtain a free download ⭕JS-Dev-101 Valid Exam Voucher[/url]
- Quiz 2026 JS-Dev-101: Accurate Pass4sure Salesforce Certified JavaScript Developer - Multiple Choice Dumps Pdf 🧁 Search for ➥ JS-Dev-101 🡄 and download it for free on [ [url]www.exam4labs.com ] website 🔉Real JS-Dev-101 Questions[/url]
- [url=http://clarkeequineservices.co.uk/?s=Latest%20JS-Dev-101%20Exam%20Labs%20%f0%9f%8c%91%20Guide%20JS-Dev-101%20Torrent%20%f0%9f%90%89%20Free%20JS-Dev-101%20Sample%20%f0%9f%8c%92%20Search%20for%20%e2%96%9b%20JS-Dev-101%20%e2%96%9f%20and%20easily%20obtain%20a%20free%20download%20on%20[%20www.pdfvce.com%20]%20%f0%9f%90%a3JS-Dev-101%20Real%20Questions]Latest JS-Dev-101 Exam Labs 🌑 Guide JS-Dev-101 Torrent 🐉 Free JS-Dev-101 Sample 🌒 Search for ▛ JS-Dev-101 ▟ and easily obtain a free download on [ www.pdfvce.com ] 🐣JS-Dev-101 Real Questions[/url]
- HotPass4sure JS-Dev-101 Dumps Pdf - Leader in Qualification Exams - Updated Salesforce Salesforce Certified JavaScript Developer - Multiple Choice 🌍 Search for ▷ JS-Dev-101 ◁ and obtain a free download on ⏩ [url]www.practicevce.com ⏪ 🦲JS-Dev-101 New Real Test[/url]
- lms.itacademypro.com, www.stes.tyc.edu.tw, academy.sarkarijournal.com, www.stes.tyc.edu.tw, telegra.ph, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, writeablog.net, www.stes.tyc.edu.tw, Disposable vapes
What's more, part of that BootcampPDF JS-Dev-101 dumps now are free: https://drive.google.com/open?id=1kY3DrGPDBbzDJjlDTF6Rpc47lLJ00Pmm
