Customized JN0-364 Lab Simulation - New JN0-364 Test Pass4sure
Posted at 3/11/2026 06:10:43
View156
Replies0
Many people think that passing some difficult Juniper certification exams needs to be proficient in much of JN0-364 expertise and only these Juniper personnels who grasp the comprehensive knowledge would be able to enroll in the exam. In fact, there are many ways to help you make up for your lack of knowledge, and pass the JN0-364 Certification exams in the same. Perhaps you would spend less time and effort than the people who grasp fairly comprehensive expertise. The saying goes, all roads lead to Rome.
We have gained high appraisal for the high quality JN0-364 guide question and considerate serves. All content is well approved by experts who are arduous and hardworking to offer help. They eliminate banal knowledge and exam questions out of our JN0-364 real materials and add new and essential parts into them. And they also fully analyzed your needs of JN0-364 exam dumps all the time. Our after sales services are also considerate. If you get any questions with our JN0-364 guide question, all helps are available upon request. Once you place your order this time, you will enjoy and experience comfortable and convenient services immediately. Besides, we do not break promise that once you fail the JN0-364 Exam, we will make up to you and relieve you of any loss. Providing with related documents, and we will give your money back. We have been always trying to figure out how to provide warranty service if customers have questions with our JN0-364 real materials. So all operations are conducted to help you pass the exam with efficiency.
New Juniper JN0-364 Test Pass4sure | Valid JN0-364 Test SyllabusDo you want to find a high efficiency way to prepare for JN0-364 exam test?As we all know, high efficiency will produce unbelievable benefits. With our Juniper JN0-364 study pdf, you can make full use of your spare time. If you are tired of screen reading, you can print JN0-364 Pdf Dumps into papers. You take your spare time to prepare and study. You will get your JN0-364 exam certification with less time investment. Come on, everyone, Choose JN0-364 test dumps, you will succeed.
Juniper Service Provider Routing and Switching, Specialist (JNCIS-SP) Sample Questions (Q55-Q60):NEW QUESTION # 55
You are designing a high availability solution for a Juniper router with dual Routing Engines (RE). You want to ensure that the routing protocol state is preserved during an RE switchover. You have already enabled graceful Routing Engine switchover (GRES) and you want to avoid relying on helper routers to maintain the routing protocol state. In this scenario, which feature would accomplish this behavior?
- A. non-stop active bridging
- B. bidirectional forwarding detection
- C. non-stop active routing
- D. graceful restart
When designing High Availability (HA) for Juniper Service Provider routers, understanding the interaction between the control plane and data plane is vital. The user has already enabledGraceful Routing Engine Switchover (GRES), which synchronizes the interface and kernel state between the primary and backup Routing Engines (REs). However, GRES by itself does not preserve the routing protocol state (like OSPF adjacencies or BGP sessions).
To achieve the preservation of the routing protocol state without relying on external "helper" routers, you must implementNon-Stop Active Routing (NSR). According to Juniper Networks documentation, NSR uses the infrastructure provided by GRES to also synchronize the routing protocol process (rpd) information.
Under NSR, the backup RE maintains a "hot" standby state of all routing protocols. If the primary RE fails, the backup RE takes over immediately. Because it already possesses the full routing table and peer session states, the peering neighbors are unaware that a switchover occurred. No protocol adjacency resets occur, and traffic continues to flow uninterrupted.
It is crucial to differentiate NSR fromGraceful Restart (Option C). While Graceful Restart also aims to maintain traffic flow during a switchover, itdoesrequire help from neighboring routers (known as "helper mode"). If the neighbors do not support or are not configured for Graceful Restart, the sessions will drop.
Since the user explicitly stated they want to "avoid relying on helper routers," Graceful Restart is not the correct solution.
Non-stop Active Bridging (Option A)provides a similar "hitless" failover but specifically for Layer 2 environments (STP/VLANs) rather than Layer 3 routing protocols.BFD (Option B)is a failure detection protocol used to speed up convergence but does not preserve state during an RE failover; in fact, without NSR, BFD would likely trigger a faster teardown of the session during a switchover. Therefore,NSRis the only feature that meets the requirement for independent control-plane preservation.
NEW QUESTION # 56
In an OSPF network, what is a purpose of a designated router?
- A. to reduce OSPF traffic on the OSPF segment
- B. to assign an OSPF router ID to all routers in the OSPF segment
- C. to forward traffic within the configured subnet
- D. to flood routes to all other OSPF devices in the entire domain
On multi-access network segments, such asEthernet, OSPF could potentially face a scalability issue. If every router on a segment formed a full adjacency with every other router, the number of adjacencies would follow the formula $n(n-1)/2$. In a segment with 10 routers, this would result in 45 adjacencies, each generating redundant flooding of Link-State Advertisements (LSAs) and excessive Hello traffic.
To solve this, OSPF elects aDesignated Router (DR)and aBackup Designated Router (BDR). According to Juniper Networks documentation, the primary purpose of the DR is to act as a central point of contact for the segment, therebyreducing OSPF traffic (Option C).
Instead of every router syncing with every other router, they all form aFull adjacencyonly with the DR and BDR. When a router (a DR-Other) has an update, it sends it to the multicast address224.0.0.6(All DR Routers). The DR then acknowledges the update and floods it to all other routers on the segment using the multicast address224.0.0.5(All OSPF Routers). This "hub-and-spoke" signaling model within the local segment significantly minimizes the bandwidth consumed by protocol overhead and reduces the CPU load on the participating routers.
It is important to note that the DR's scope is limited to the local segment; it does not "assign IDs" (Option A) nor does it flood routes to the "entire domain" (Option D), as that is the responsibility of individual routers within their respective areas.
NEW QUESTION # 57
Exhibit:
You have configured an MPLS LSP to 192.168.100.3. However, the LSP is in the down state. Referring to the exhibit, which two actions would solve this problem? (Choose two.)
- A. Issue the set interfaces lo0 family mpls command on router R1 and commit.
- B. Issue the set routing-options rib inet.3 static route 192.168.100.1 command and commit.
- C. Issue the set protocols mpls label-switched-path to-r3 no-cspf command and commit.
- D. Issue the set protocols ospf traffic-engineering command and commit.
In a Juniper Networks environment, establishing a functionalMultiprotocol Label Switching (MPLS)Label- Switched Path (LSP) requires synchronized control plane operations. According to Juniper technical documentation, the most common reason for an LSP to remain in the "Down" state at the ingress router is a failure of theConstrained Shortest Path First (CSPF)algorithm during the path computation phase.
The provided exhibit for routerR1reveals a critical error in the show mpls lsp detail output: "CSPF: could not determine self". This specific error indicates that the CSPF process is unable to find its own local router ID within theTraffic Engineering Database (TED). For CSPF to build a valid TED, the underlying Interior Gateway Protocol (IGP), such as OSPF, must be configured to flood opaque link-state advertisements (Type
10 LSAs) that carry traffic engineering attributes. As seen in the OSPF configuration, traffic engineering is not enabled. Therefore, issuing theset protocols ospf traffic-engineeringcommand (Option D) will allow R1 to populate the TED with its own local information and that of its neighbors, enabling CSPF to calculate a valid path.
Alternatively, an administrator can choose to bypass the requirement for a TED entirely by disabling CSPF on the specific LSP. By issuing theset protocols mpls label-switched-path to-r3 no-cspfcommand (Option B), the router will stop attempting to perform a constrained path calculation. Instead, the signaling protocol (RSVP) will rely on the standardinet.0routing table to determine the hop-by-hop path to the egress destination (192.168.100.3), allowing the LSP to establish without traffic engineering constraints.
Regarding the other options, whilefamily mplsis required on all transit interfaces, the ingress loopback interface (lo0) generally does not require it for standard LSP signaling unless it's used as a transit hop.
Furthermore, adding a static route toinet.3(Option A) is used for next-hop resolution of BGP routes over LSPs but does not assist in the signaling or establishment of the LSP itself.
NEW QUESTION # 58
Which IS-IS adjacency state indicates that hello packets have been exchanged but the adjacency is not yet fully established?
- A. up
- B. two-way
- C. initializing
- D. loading
In theIS-IS (Intermediate System to Intermediate System)protocol, the process of forming an adjacency between two neighbors follows a specific sequence of states. While OSPF uses states like "Init," "Two-Way," and "Full," IS-IS uses a slightly different nomenclature within its state machine.
According to Juniper Networks technical documentation, when a router first sends anIS-IS Hello (IIH) PDU and receives one back from a neighbor, but has not yet confirmed that the neighbor "sees" it back, the adjacency enters theInitializingstate. Specifically, on a point-to-point link, the state transitions fromDownto Initializingas soon as the first PDU is received. On a broadcast network (like Ethernet), the Initializing state indicates that the local router has received a Hello PDU from the neighbor, but the local router's own System ID is not yet listed in the neighbor's list of "seen" neighbors (the neighbor's Hello PDU does not yet contain the local router's MAC address).
The adjacency only moves to theUpstate (Option C) once bi-directional communication is confirmed- meaning both routers have seen each other's System IDs in the incoming Hello PDUs.
* Loading (Option A):This is an OSPF state, not an IS-IS state. In IS-IS, database synchronization happens after the adjacency is Up.
* Two-Way (Option D):While functionally similar to the state IS-IS is achieving, "Two-Way" is the specific terminology for OSPF. In IS-IS, the intermediate step between knowing a neighbor exists and having a fully functional adjacency is strictly calledInitializing.
NEW QUESTION # 59
During OSPF neighbor establishment, which packet type is used to describe the contents of the link-state database?
- A. Link-State PDU (LSP)
- B. Link-State Request (LSR)
- C. Database Description (DBD)
- D. Hello packet
In theOSPF (Open Shortest Path First)protocol, ensuring that all routers within an area have a synchronized Link-State Database (LSDB)is fundamental to building a consistent loop-free topology. During the adjacency formation process-specifically when transitioning from theExStartstate to theExchangestate- routers must determine what information they are missing from their neighbors without sending the entire database at once, which would be highly inefficient.
TheDatabase Description (DBD)packet, also known as a DDP, is the mechanism used for this summary exchange. According to Juniper Networks technical documentation, the DBD packet does not contain full Link-State Advertisements (LSAs). Instead, it contains only theLSA headers, which include the LSA type, the ID of the advertising router, and the sequence number.
By exchanging these headers, a Juniper router can compare the neighbor's database summary against its own local LSDB. If the router identifies a header in the DBD packet that represents a newer or missing entry, it records that LSA in its "Link-State Request List." This collaborative "handshake" ensures that only the necessary, updated information is requested in the subsequentLink-State Request (LSR)phase. It is important to distinguish this from theLink-State PDU (LSP)mentioned in Option D, which is actually the term used in the IS-IS protocol, not OSPF. In OSPF, the functional unit is the LSA, and the transport vehicle for the initial summary is the DBD packet. This methodical synchronization is what allows OSPF to scale effectively in large service provider environments.
NEW QUESTION # 60
Are you feeling anxious about taking the Service Provider Routing and Switching, Specialist (JNCIS-SP) (JN0-364) exam? Our customizable practice test questions will help you overcome your anxiety and prepare for the actual exam. With each attempt, you will receive a score report that will help you identify and correct your mistakes before your final attempt. Our web-based practice exam creates a similar situation to the JN0-364 Real Exam Questions, making it easier for you to pass. Purchase our Service Provider Routing and Switching, Specialist (JNCIS-SP) (JN0-364) practice test material today and say goodbye to exam anxiety!
New JN0-364 Test Pass4sure: https://www.actualvce.com/Juniper/JN0-364-valid-vce-dumps.html
By paying close attention to every single detail that matters the most, you will be able to find the best and reliable Juniper JN0-364 pdf dumps for the preparation of JNCIS-SP exam, The Juniper JNCIS-SP JN0-364 practice test content is very easy and simple to understand, For getting a command on the real Juniper JN0-364 exam format, you can try our JN0-364 exam testing engine and solve as many JN0-364 practice questions and answers as you can, Juniper Customized JN0-364 Lab Simulation It can be printed on the papers which are convenient for you to take notes and learn at any time and place.
Mentoring is one of the most powerful tools at their JN0-364 disposal, The adjective the description) is the value, By paying close attention to every single detail that matters the most, you will be able to find the best and reliable Juniper JN0-364 Pdf Dumps for the preparation of JNCIS-SP exam.
Juniper Customized JN0-364 Lab Simulation: Service Provider Routing and Switching, Specialist (JNCIS-SP) - ActualVCE Sample Download FreeThe Juniper JNCIS-SP JN0-364 practice test content is very easy and simple to understand, For getting a command on the real Juniper JN0-364 exam format, you can try our JN0-364 exam testing engine and solve as many JN0-364 practice questions and answers as you can.
It can be printed on the papers which are convenient for you to take notes and learn at any time and place, JN0-364 exam preparation product is the best product that leads you to get 100% result.
- Valid Test JN0-364 Experience 📢 JN0-364 Valid Dump 🐍 JN0-364 Reliable Test Questions 💑 Download ☀ JN0-364 ️☀️ for free by simply entering ➥ [url]www.troytecdumps.com 🡄 website 😥JN0-364 Reliable Dumps Files[/url]
- Trustable JN0-364 learning materials - JN0-364 preparation exam - Pdfvce 🏀 Open [url]www.pdfvce.com enter ➤ JN0-364 ⮘ and obtain a free download 🕝JN0-364 Valid Test Topics[/url]
- Valid Test JN0-364 Experience ☮ JN0-364 Reliable Exam Preparation 🍝 New JN0-364 Learning Materials ❇ Download ✔ JN0-364 ️✔️ for free by simply searching on { [url]www.dumpsquestion.com } 🆘JN0-364 Latest Test Vce[/url]
- JN0-364 Actual Test Answers 💒 JN0-364 Related Certifications 🚠 JN0-364 Authorized Pdf 👞 Search for ▛ JN0-364 ▟ and download exam materials for free through [url]www.pdfvce.com ✴JN0-364 Downloadable PDF[/url]
- 2026 100% Free JN0-364 CValid 100% Free Customized Lab Simulation | New JN0-364 Test Pass4sure 🏗 Search for JN0-364 and easily obtain a free download on ▛ [url]www.dumpsmaterials.com ▟ 🤰JN0-364 Related Certifications[/url]
- Free JN0-364 Practice 🌺 JN0-364 Latest Real Test 🗨 Free JN0-364 Practice 🤗 Copy URL ⮆ [url]www.pdfvce.com ⮄ open and search for ➥ JN0-364 🡄 to download for free 🧂Free JN0-364 Practice[/url]
- 100% Pass 2026 Juniper JN0-364: Service Provider Routing and Switching, Specialist (JNCIS-SP) Newest Customized Lab Simulation 🤔 Simply search for ⏩ JN0-364 ⏪ for free download on ⇛ [url]www.prep4away.com ⇚ 🚦JN0-364 Authorized Pdf[/url]
- Don't Miss Golden Opportunity C Download Juniper JN0-364 Dumps Now at Affordable Rates 🧨 Enter ▷ [url]www.pdfvce.com ◁ and search for ⇛ JN0-364 ⇚ to download for free ▶JN0-364 Valid Test Topics[/url]
- Trustable JN0-364 learning materials - JN0-364 preparation exam - [url]www.prepawayexam.com 😊 Download ➠ JN0-364 🠰 for free by simply entering ▶ www.prepawayexam.com ◀ website 🥩New JN0-364 Learning Materials[/url]
- JN0-364 Latest Test Vce 💗 JN0-364 Training Materials 🍠 JN0-364 Exam Guide ⛴ Search for JN0-364 on ➠ [url]www.pdfvce.com 🠰 immediately to obtain a free download 🌳JN0-364 Related Certifications[/url]
- Unlimited JN0-364 Exam Practice 🙀 Study JN0-364 Plan 🍥 Unlimited JN0-364 Exam Practice 🥍 Go to website [url]www.validtorrent.com open and search for ➠ JN0-364 🠰 to download for free 🍰JN0-364 Valid Test Topics[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.4shared.com, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, learn.csisafety.com.au, graphiskill.com, Disposable vapes
