PEGACPSA25V1 Exam Questions: Complete Guide to Passing the Pega System Architect
711
Posted at 3 day before      View:19 | Replies:0        Print      Only Author   [Copy Link] 1#
If you are planning to take the PEGACPSA25V1 Certified Pega System Architect 25 exam, choosing the right preparation materials can make a significant difference in your success. The most updated PEGACPSA25V1 Practice Test Questions from PassQuestion are specifically designed to mirror the real exam format and align with the latest syllabus. These high-quality practice questions not only help you understand the structure of the exam but also allow you to identify key knowledge areas, improve problem-solving skills, and build confidence. By practicing with verified and accurate PEGACPSA25V1 exam questions, you can avoid outdated content and focus your efforts on mastering the topics that truly matter for passing the exam efficiently.
What Is the PEGACPSA25V1 Certified Pega System Architect 25 Certification?
The Certified Pega System Architect '25 certification is an entry-level credential tailored for developers and technical professionals who want to gain a strong foundation in building applications using the Pega Platform. This certification validates your ability to design case workflows, manage data, configure user interfaces, and apply core development principles within Pega.
As the first step in the Pega System Architect certification path, it establishes a baseline of knowledge required for more advanced certifications. Earning this credential demonstrates your readiness to contribute to real-world Pega projects and enhances your credibility in the rapidly growing low-code development ecosystem.
Complete PEGACPSA25V1 Exam Overview
Before starting your preparation, it is essential to understand the structure and requirements of the exam:
  • Exam Code: PEGACPSA25V1
  • Total Questions: 60 multiple-choice questions
  • Exam Duration: 90 minutes
  • Passing Score: 65%
  • Prerequisites: Basic understanding of Pega System Architect concepts
This exam is designed to evaluate both your theoretical knowledge and your practical ability to apply Pega development concepts in real scenarios.
In-Depth Breakdown of PEGACPSA25V1 Exam Topics and Their Weighting
Understanding the exam domains is essential for effective preparation. Below is a detailed breakdown of the topics and their weight:
1. Case Management (25%)
This is the most heavily weighted section and focuses on designing and managing case workflows:
  • Design case lifecycle stages and statuses
  • Configure SLAs, urgency, goals, and deadlines
  • Route assignments using business logic
  • Implement approval processes and authority matrices
  • Automate workflows using conditions and decision rules
  • Manage child cases and optional actions
Mastering case management is crucial as it forms the backbone of Pega application development.
2. Data and Integration (20%)
This section tests your ability to handle and manipulate data:
  • Understand and configure the data model
  • Create data objects, relationships, and records
  • Implement data validation and transformations
  • Access and refresh data in case of processing
  • Simulate and persist application data
Focus on real-world data scenarios to strengthen this area.
3. Application Development (15%)
This domain evaluates your knowledge of building scalable applications:
  • Use Center-out architecture and Situational Layer Cake
  • Manage rules, rulesets, and inheritance
  • Work with Agile Workbench and development tools
  • Debug and maintain applications
Understanding Pega's architecture principles is key to success here.
4. User Experience (10%)
This section focuses on designing intuitive interfaces:
  • Configure UI views, templates, and forms
  • Customize layouts and dynamic field behavior
  • Understand channels, portals, and personas
5. Security (10%)
Security is a fundamental part of application development:
  • Understand authentication vs. authorization
  • Implement role-based access control (RBAC)
  • Manage operators, access groups, and roles
6. Pega GenAI (10%)
A modern and increasingly important domain:
  • Use Pega GenAI Knowledge Buddy and Blueprint
  • Leverage Autopilot for faster development
  • Integrate AI capabilities using Connect Rules
  • Implement AI-powered coaching and agents
This section highlights the increasing significance of AI in enterprise applications.
7. DevOps (5%)
Covers continuous integration and deployment practices:
  • Understand CI/CD in Pega
  • Identify testing strategies for deployment success
8. Insights (5%)
Focuses on analytics and reporting:
  • Create Insights using Explore Data
  • Understand dashboards and reporting structures
Proven Study Strategies to Pass the PEGACPSA25V1 Exam Faster and More Efficiently
To achieve success, follow these practical and effective preparation tips:
1. Start with a Clear Understanding of the Exam Blueprint
Before diving into preparation, carefully review the exam objectives and topic weightings. This helps you allocate your study time efficiently, ensuring that you focus more on high-value sections like Case Management and Data & Integration while still covering all domains.
2. Use High-Quality Practice Tests to Reinforce Learning
Incorporate reliable practice questions, such as those from PassQuestion, into your study routine. These tests simulate real exam scenarios, enabling you to assess your readiness, identify areas for improvement, and enhance your accuracy through repeated practice.
3. Combine Theory with Hands-On Practice on the Pega Platform
Reading alone is not enough—apply what you learn in a practical environment. Build sample applications, configure workflows, and experiment with UI and data features in Pega. This hands-on experience will significantly improve your understanding of real-world use cases.
4. Simulate Real Exam Conditions to Improve Time Management
Practice answering questions within the actual exam time limit (90 minutes). This will help you develop a sense of pacing, reduce exam-day stress, and ensure that you can complete all questions without rushing.
5. Review Mistakes and Continuously Improve
After each practice test, spend time analyzing your incorrect answers. Understand where you went wrong and revisit those topics. Continuous improvement is key to strengthening your weak areas.
Final Thoughts: Achieve PEGACPSA25V1 Certification and Start Your Pega Career Journey
The PEGACPSA25V1 Certified Pega System Architect 25 exam is an excellent starting point for anyone pursuing a career in Pega development. With a strong understanding of core concepts and the help of PassQuestion's updated practice test questions, you can significantly improve your chances of passing on the first attempt. Stay consistent, practice regularly, and focus on real-world application skills—success will follow.
