[General] Patek Philippe Annual Calendar Watch 5396R-016
32
General Patek Philippe Annual Calendar Watch 5396R-016
Posted at 4/14/2026 20:26:23      View166 | Replies1        Print      Only Author   [Copy Link] 1#
Patek Philippe Annual Calendar Watch 5396R-016, Sand Beige Dial
This watch is a refined interpretation from the Calatrava annual calendar functionality, commemorating the 30th wedding anniversary of Patek Philippe's trademarked invention. high quality fake watches
Within 1996, Patek Philippe released one of the most practical complications within modern watchmaking: the yearly calendar. Originally used in the actual 5035 model, it instantly distinguishes between 30-day as well as 31-day months, requiring just a manual adjustment once a year in late February. Positioned between the " simplicity" of a full calendar and the complexity of a everlasting calendar, the annual calendar quickly became one of Patek Philippe's most successful problems, currently used in 24 timepieces across the Nautilus, Aquanaut, along with other complicated collections. Thirty years later on, to celebrate this invention, Patek Philippe presents a new edition of one of its the majority of classic annual calendar watches-the 5396R-016-in rose gold with a lustrous sand beige sunburst switch.
Launched 5 years ago, the 5396 model includes a vertically symmetrical display, mixing windows with traditional subdials: the day of the week and also month are displayed inside two windows at twelve o'clock, while the date is actually displayed in a sub-dial in 6 o'clock, which additionally integrates a 24-hour indication and moon phase screen. replica swiss watches
This particular timepiece faithfully continues the particular series' signature minimalist ratios of the past two decades. The actual fully polished 38. 5 mm x 11. 25 mm rose gold case comes after the classic Patek Philippe Calatrava 96, with smooth outlines and a slim bezel encircling the dial. Small realignment buttons at 2, four, 8, and 10 o'clock on the side of the case adjust typically the date and moon stage display; the movement will be clearly visible through the sky-blue crystal case back. Waterproof to 30 meters.
This new timepiece comes with a sunburst dial in a soft finish, complemented by faceted rose gold applied hour indicators and faceted dauphine fingers, along with a slender central secs hand. A snail-patterned sub-dial at 6 o'clock shows the 24-hour time and celestial satellite phase, its subtle consistency enhancing legibility. replica Patek Philippe Grand Complications
The watch is usually powered by the 26-330 H QA LU 24 automated movement, a modern evolution in the movement previously used in this product. Introduced around 2019, this particular movement replaced the previous 324 S QA LU twenty four and introduced several technical upgrades. The new movement incorporates a stop-seconds function for accurate time setting; a more effective unidirectional winding system; along with a redesigned 21K gold main rotor for improved power transfer efficiency. Composed of 339 parts, the movement is definitely 5. 8 mm thicker and vibrates at twenty-eight, 800 vibrations per hour. This utilizes a Patek Philippe Gyromax® balance wheel along with Spiromax® silicon hairspring. The particular moon phase display needs a one-day adjustment every 122 years. Through the sapphire crystal case back, the motion is engraved with the Patek Philippe Seal, a guarantee associated with its precise timekeeping in addition to exquisite finishing.
The new Patek Philippe Yearly Calendar watch 5396R-016 includes a lustrous dark chestnut brownish alligator leather strap along with contrasting beige stitching and also a rose gold double-folding clasp.
De Bethune DB25 DB25Vxs Silver Moon
Greubel Forsey Tourbillon 24 Secondes Architecture GFO1h Final
Technical Specifications - Patek Philippe Annual Calendar Watch 5396R-016
Situation: 38. 5 mm throughout diameter x 11. twenty five mm in thickness - 18 CARAT rose gold - fully refined - sapphire crystal cup front and back : water-resistant to 30 yards
Dial: Sunburst dial in a beige complete - rose gold applied complex dome hour markers ~ rose gold dauphine hands, core seconds hand - bi-week/month display window at 10 o'clock - date show window at 6 o'clock - 24-hour indicator as well as moon phase display from 6 o'clock
Movement: Caliber 26-330 S QA LU 24 , automatic winding - 33. 3 mm in size x 5. 8 mm in thickness - 339 components - Gyromax balance steering wheel - Spiromax hairspring : stop seconds function ~ unidirectional winding system , 21K gold central one - Frequency: 28, eight hundred vibrations per hour - Reserve of power: 35-45 hours - Patek Philippe Seal
Strap: Dark chestnut dark brown alligator leather strap together with beige stitching - Rose gold colored folding clasp
Reference Number: 5396R-016
Posted at 4/20/2026 04:17:29        Only Author  2#
The viewpoints in the article have been very insightful, and Ive learned a great deal. Free Latest CISA guide files exam resourcesyour gateway to promotions and higher pay!
