[General] Pdf Amazon SAA-C03 Dumps | SAA-C03 Real Question
26
General Pdf Amazon SAA-C03 Dumps | SAA-C03 Real Question
Posted at 4/19/2026 11:34:48      View154 | Replies0        Print      Only Author   [Copy Link] 1#
2026 Latest PassLeaderVCE SAA-C03 PDF Dumps and SAA-C03 Exam Engine Free Share: https://drive.google.com/open?id=1mA0WPen9ywQMD90qXo16bouUJEKftmT8
The PassLeaderVCE is a reliable and trusted platform that is committed to making the AWS Certified Solutions Architect - Associate (SAA-C03) exam preparation instant, simple and successful. To do this the PassLeaderVCE is offering top-rated and real AWS Certified Solutions Architect - Associate (SAA-C03) exam questions with high-in-demand features. These features are inclusively designed to ace the Amazon SAA-C03 exam preparation.
I would like to bring to you kind attention that our latest Amazon SAA-C03 study guide is produced. These exam materials are high passing rate. We are sure that SAA-C03 study guide will be the best assist for your coming exam. We guarantee "No Pass Full Refund". If you feel depressed about your past failure and eager to look for Valid SAA-C03 Study Guide, I advise you to reply to our exam materials as 100% passing without any doubt. Thousands of candidates' choice for our SAA-C03 study guide will be your wise decision.
SAA-C03 Real Question - SAA-C03 Exam EngineAll of these advantages, you can avail of after passing the SAA-C03 exam. You must find the best resource to prepare for the Amazon SAA-C03 test if you want to pass the Amazon SAA-C03 Certification Exam. Without proper Amazon SAA-C03 exam preparation, getting success in the Amazon SAA-C03 exam is impossible.
Amazon SAA-C03 (Amazon AWS Certified Solutions Architect - Associate) Certification Exam is designed for individuals who want to validate their skills and knowledge in designing and deploying scalable, highly available, and fault-tolerant systems on the Amazon Web Services (AWS) platform. AWS Certified Solutions Architect - Associate certification exam is ideal for professionals who are looking to enhance their career prospects in cloud computing, particularly in the AWS ecosystem. The SAA-C03 Certification Exam is the latest version of the AWS Solutions Architect - Associate certification and is updated to reflect the latest AWS services and trends in cloud computing.
Amazon AWS Certified Solutions Architect - Associate Sample Questions (Q532-Q537):NEW QUESTION # 532
A company has deployed a server less application that invokes an AWS Lambda function when new documents are uploaded to an Amazon S3 bucket The application uses the Lambda function to process the documents After a recent marketing campaign the company noticed that the application did not process many of The documents What should a solutions architect do to improve the architecture of this application?
  • A. Deploy an additional Lambda function Load balance the processing of the documents across the two Lambda functions
  • B. Configure an S3 bucket replication policy Stage the documents m the S3 bucket for later processing
  • C. Set the Lambda function's runtime timeout value to 15 minutes
  • D. Create an Amazon Simple Queue Service (Amazon SOS) queue Send the requests to the queue Configure the queue as an event source for Lambda.
To improve the architecture of this application, the best solution would be to use Amazon Simple Queue Service (Amazon SQS) to buffer the requests and decouple the S3 bucket from the Lambda function. This will ensure that the documents are not lost and can be processed at a later time if the Lambda function is not available. This will ensure that the documents are not lost and can be processed at a later time if the Lambda function is not available. By using Amazon SQS, the architecture is decoupled and the Lambda function can process the documents in a scalable and fault-tolerant manner
NEW QUESTION # 533
A company wants to send data from its on-premises systems to Amazon S3 buckets. The company created the S3 buckets in three different accounts. The company must send the data privately without traveling across the internet. The company has no existing dedicated connectivity to AWS.
Which combination of steps should a solutions architect take to meet these requirements? (Select TWO.)
  • A. Establish a networking account in the AWS Cloud. Create a private VPC in the networking account. Set up an AWS Direct Connect connection with a private VIF between the on-premises environment and the private VPC.
  • B. Establish a networking account in the AWS Cloud. Create a private VPC in the networking account. Peer VPCs from the accounts that host the S3 buckets with the VPC in the network account.
  • C. Create an Amazon S3 interface endpoint in the networking account.
  • D. Establish a networking account in the AWS Cloud. Create a private VPC in the networking account. Set up an AWS Direct Connect connection with a public VIF between the on-premises environment and the private VPC.
  • E. Create an Amazon S3 gateway endpoint in the networking account.
Comprehensive and Detailed Explanation From Exact Extract of Amazon Web Services (AWS) Architect documents:
To send data privately from on-premises to S3 buckets across multiple AWS accounts:
A: Using AWS Direct Connect with a private virtual interface (VIF) enables private connectivity from on-premises into the VPC.
E: After establishing the central VPC in a networking account, use VPC peering to allow access to S3 buckets across multiple AWS accounts.
"Direct Connect private virtual interface (VIF) allows private IP connectivity to VPC resources."
"VPC Peering enables routing of traffic between VPCs using private IP addresses."
- AWS Direct Connect Documentation
- VPC Peering Guide
Why not others:
B: Public VIF sends traffic over public AWS services-not fully private.
C: Interface endpoint is useful within a single account/VPC context.
D: Gateway endpoint doesn't solve inter-account routing.
Private Connectivity using Direct Connect
VPC Peering Overview
NEW QUESTION # 534
[Design Secure Architectures]
A company wants lo build a web application on AWS. Client access requests to the website are not predictable and can be idle for a long time. Only customers who have paid a subscription fee can have the ability to sign in and use the web application.
Which combination of steps will meet these requirements MOST cost-effectively? (Select THREE.)
  • A. Create an Amazon Cognito identity pool to authenticate users.
  • B. Use AWS Amplify to serve the frontend web content with HTML. CSS, and JS. Use an integrated Amazon CloudFront configuration.
  • C. Create an Amazon Cogmto user pool to authenticate users
  • D. Use Amazon S3 static web hosting with PHP. CSS. and JS. Use Amazon CloudFront to serve the frontend web content.
  • E. Create an AWS Lambda function to retrieve user information from Amazon DynamoDB. Create an Amazon API Gateway endpoint to accept RESTful APIs. Send the API calls to the Lambda function.
  • F. Create an Amazon Elastic Container Service (Amazon ECS) service behind an Application Load Balancer to retrieve user information from Amazon RDS. Create an Amazon API Gateway endpoint to accept RESTful APIs. Send the API calls to the Lambda function.
Answer: B,C,E
https://docs.aws.amazon.com/Amaz ... WebsiteHosting.html
NEW QUESTION # 535
A company has a three-tier web application that is deployed on AWS. The web servers are deployed in a public subnet in a VPC. The application servers and database servers are deployed in private subnets in the same VPC. The company has deployed a third-party virtual firewall appliance from AWS Marketplace in an inspection VPC. The appliance is configured with an IP interface that can accept IP packets.
A solutions architect needs to Integrate the web application with the appliance to inspect all traffic to the application before the traffic teaches the web server. Which solution will moot these requirements with the LEAST operational overhead?
  • A. Create a Network Load Balancer the public subnet of the application's VPC to route the traffic lo the appliance for packet inspection
  • B. Create an Application Load Balancer in the public subnet of the application's VPC to route the traffic to the appliance for packet inspection
  • C. Deploy a transit gateway m the inspection VPC Configure route tables to route the incoming pockets through the transit gateway
  • D. Deploy a Gateway Load Balancer in the inspection VPC Create a Gateway Load Balancer endpoint to receive the incoming packets and forward the packets to the appliance
https://aws.amazon.com/blogs/net ... ection-using-aws-ga
NEW QUESTION # 536
A company has deployed a Java Spring Boot application as a pod that runs on Amazon Elastic Kubernetes Service (Amazon EKS) in private subnets. The application needs to write data to an Amazon DynamoDB table. A solutions architect must ensure that the application can interact with the DynamoDB table without exposing traffic to the internet.
Which combination of steps should the solutions architect take to accomplish this goal? (Choose two.)
  • A. Attach an IAM user that has sufficient privileges to the EKS pod.
  • B. Attach an IAM role that has sufficient privileges to the EKS pod.
  • C. Allow outbound connectivity to the DynamoDB table through the private subnets' network ACLs.
  • D. Create a VPC endpoint for DynamoDB.
  • E. Embed the access keys in the Java Spring Boot code.
https://docs.aws.amazon.com/amaz ... oints-dynamodb.html
https://aws.amazon.com/about-aws ... iam-permissions-to-
NEW QUESTION # 537
The pass rate is 98% for SAA-C03 exam bootcamp, if you choose us, we can ensure you that you can pass the exam just one time. In addition, we offer you free demo to have a try before buying, so that you can know what the complete version is like. In order to strengthen your confidence for SAA-C03 training materials, we are pass guarantee and money back guarantee, and we will refund your money if you fail to pass the exam. We have a professional service team and they have the professional knowledge for SAA-C03 Exam Bootcamp, if you have any questions, you can contact with them.
SAA-C03 Real Question: https://www.passleadervce.com/AWS-Certified-Solutions-Architect/reliable-SAA-C03-exam-learning-guide.html
What's more, part of that PassLeaderVCE SAA-C03 dumps now are free: https://drive.google.com/open?id=1mA0WPen9ywQMD90qXo16bouUJEKftmT8
