[Hardware] 2026 Fortinet Updated Valid FCSS_SDW_AR-7.4 Test Blueprint
34
Hardware 2026 Fortinet Updated Valid FCSS_SDW_AR-7.4 Test Blueprint
Posted at 4/19/2026 12:20:25      View136 | Replies0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of TestBraindump FCSS_SDW_AR-7.4 dumps from Cloud Storage: https://drive.google.com/open?id=1rLFG9zAUm5AerhtQBi_YQGrh-kIHuvmh
Some people prefer books, some check videos, and some hire online tutors, to clear the FCSS_SDW_AR-7.4 exam. It all depends on you what you like the most. If you learn better by books, go for it but if you are busy, and don't have much time to consult a list of books for studying, its better to get the most probable FCSS - SD-WAN 7.4 Architect (FCSS_SDW_AR-7.4) exam questions. We are sure that you will learn well and can crack Fortinet FCSS_SDW_AR-7.4 exam easily.
To contribute the long-term of cooperation with our customers, we offer great discount for purchasing our FCSS_SDW_AR-7.4 exam pdf. Comparing to other dumps vendors, the price of our FCSS_SDW_AR-7.4 questions and answers is reasonable for every candidate. You will grasp the overall knowledge points of FCSS_SDW_AR-7.4 Actual Test with our pass guide and the accuracy of our FCSS_SDW_AR-7.4 exam answers will enable you spend less time and effort.
Professional Valid FCSS_SDW_AR-7.4 Test Blueprint | FCSS_SDW_AR-7.4 100% Free Reliable Exam SimsPracticing with Fortinet FCSS_SDW_AR-7.4 Exam questions will help you to become an expert, Fortinet FCSS_SDW_AR-7.4 and acquire the Fortinet FCSS_SDW_AR-7.4 Certification. Fortinet FCSS_SDW_AR-7.4 Exam Questions allow you to verify your skills as a professional, prepared by Fortinet FCSS_SDW_AR-7.4. You have to pass the FCSS - SD-WAN 7.4 Architect FCSS_SDW_AR-7.4 exam to achieve the Fortinet FCSS_SDW_AR-7.4 certification on the first attempt, which is organized by Fortinet.
Fortinet FCSS_SDW_AR-7.4 Exam Syllabus Topics:
  • SD-WAN Configuration: This section of the exam measures the skills of network engineers and covers configuring a basic SD-WAN setup. Candidates are expected to demonstrate their ability to define SD-WAN members and zones effectively, ensuring foundational network segmentation and management.
  • SD-WAN Troubleshooting: This part assesses the troubleshooting skills of network support specialists. Candidates should be able to diagnose and resolve issues related to SD-WAN rules, session behaviors, routing inconsistencies, and ADVPN connectivity problems to maintain seamless network operations.
  • Centralized Management: This domain evaluates network administrators competence in deploying and managing SD-WAN configurations centrally using FortiManager. It includes tasks such as implementing branch configurations and utilizing overlay templates to streamline network management.
  • Advanced IPsec: Intended for security engineers, this section covers the deployment of advanced IPsec topologies for SD-WAN, including hub-and-spoke models, ADVPN configurations, and complex multi-hub or multi-region deployments. Candidates need to demonstrate expertise in securing wide-area networks using IPsec technologies.
Topic 5
  • Rules and Routing: Targeted at network engineers, this section assesses the ability to configure SD-WAN rules and routing policies. Candidates will be tested on managing traffic flow and prioritization across the SD-WAN infrastructure.
Fortinet FCSS - SD-WAN 7.4 Architect Sample Questions (Q45-Q50):NEW QUESTION # 45
Which SD-WAN rule and interface uses FortiGate to steer the traffic from the LAN subnet 10.0.1.0/24 to the corporate server 10.2.5.254?
  • A. SD-WAN service rule 4 and port1 or port2.
  • B. SD-WAN service rule 3 and interface HUB1-VPN2.
  • C. SD-WAN service rule 4 and interface port2.
  • D. SD-WAN service rule 3 and interface HUB1-VPN3.
Traffic steering in Fortinet SD-WAN is based on defined rules and the corresponding outgoing interfaces. The exhibit (not shown here) would indicate that the traffic from the LAN subnet 10.0.1.0/24 to the server
10.2.5.254 is matched by SD-WAN rule 3 and sent out via the HUB1-VPN3 interface.
[FCSS_SDW_AR-7.4 1-0.docx Q2]
FortiOS 7.4 SD-WAN Concept Guide - Rule Matching
NEW QUESTION # 46
You have configured the performance SLA with the probe mode as Prefer Passive.
What are two observable impacts of this configuration? (Choose two.)
  • A. During passive monitoring, the SLA performance rule cannot detect dead members.
  • B. FortiGate can offload the traffic that is subject to passive monitoring to hardware.
  • C. FortiGate passively monitors the member if ICMP traffic is passing through the member.
  • D. FortiGate passively monitors the member if TCP traffic is passing through the member.
  • E. After FortiGate switches to active mode, the SLA performance rule falls back to passive monitoring after 3 minutes.
FortiGate passively monitors the member if TCP traffic is passing through the member With Prefer Passive mode, FortiGate inspects existing traffic (like TCP flows) to measure performance metrics without generating its own probes.
FortiGate passively monitors the member if ICMP traffic is passing through the member Similarly, when ICMP flows exist, FortiGate uses them for SLA checks.
NEW QUESTION # 47
Which statement best describe the role of the ADVPN device in handling traffic?
  • A. This is a spoke. The kernel received a shortcut request and forwards the query to another spoke.
  • B. This is a spoke that has received a shortcut query from another spoke and has forwarded the response to its hub.
  • C. This is a hub that has received a query from a spoke and has forwarded it to another spoke.
  • D. This is a hub in a dual-region topology. The remote hub tunnel ID is 10.0.2.101.
Within ADVPN topologies, shortcut requests and responses traverse spokes and hubs. Fortinet documentation states:
"When a spoke receives a shortcut query from another spoke, it may forward the response to its hub for validation or to facilitate dynamic shortcut tunnel setup. This mechanism allows direct spoke-to-spoke communication for optimized routing and performance, reducing latency and offloading the hub after initial control-plane mediation." This is a core benefit of ADVPN's dynamic shortcut feature.
NEW QUESTION # 48
Refer to the exhibits. You use FortiManager to configure SD-WAN on three branch devices.
When you install the device settings. FortiManager prompts you with the error "Copy Failed" for the device branch1_fat When you click the log button. FortiManager displays the message shown in the exhibit.
Based on the exhibits, which statement best describes the issue and how you can resolve it?
  • A. Check the connection between branch1_fgt and FortiManager
  • B. Remove the installation target for the SD-WAN member port4. You cannot combine metadata variable and installation targets.
  • C. Gateways for all members in a zone must be defined the same way. Specify the gateway of the SD- WAN member port! without metadata variables.
  • D. Check the metadata variable definitions, and review the per-device mapping configuration.
NEW QUESTION # 49
An SD-WAN member is no longer used to steer SD-WAN traffic. The administrator updated the SD-WAN configuration and deleted the unused member. After the configuration update, users report that some destinations are unreachable. You confirm that the affected flow does not match an SD-WAN rule.
What could be a possible cause of the traffic interruption?
  • A. FortiGate administratively brings down interfaces when they are removed from the SD-WAN configuration.
  • B. FortiGate removes the layer 3 settings for interfaces that are removed from the SD-WAN configuration.
  • C. FortiGate can remove some static routes associated with an interface when the member is removed from SD-WAN.
  • D. FortiGate, with SD-WAN enabled, cannot route traffic through interfaces that are not SD-WAN members.
When an SD-WAN member is deleted, FortiGate can also remove static routes that were tied to that interface. If those routes are needed for destinations not covered by SD-WAN rules, traffic to those networks becomes unreachable. This explains why flows not matching SD-WAN rules are interrupted after the member was removed.
NEW QUESTION # 50
The TestBraindump Fortinet FCSS_SDW_AR-7.4 PDF questions file, desktop practice test software, and web-based practice test software, all these three Fortinet FCSS_SDW_AR-7.4 practice test questions formats are ready for instant download. Just download any Fortinet FCSS_SDW_AR-7.4 Exam Questions format and start this journey with confidence. Best of luck with exams and your career!!!
Reliable FCSS_SDW_AR-7.4 Exam Sims: https://www.testbraindump.com/FCSS_SDW_AR-7.4-exam-prep.html
