Top NSE6_FSR-7.3 Dumps | NSE6_FSR-7.3 Reliable Test Pattern
30
Posted at 4/19/2026 12:33:46      View45 | Replies0        Print      Only Author   [Copy Link] 1#
What's more, part of that Exams-boost NSE6_FSR-7.3 dumps now are free: https://drive.google.com/open?id=1JdNDSvs1Rj245nB_-kmk8MxzTtW1BwfH
Buying our NSE6_FSR-7.3 study materials can help you pass the test easily and successfully. We provide the NSE6_FSR-7.3 learning braindumps which are easy to be mastered, professional expert team and first-rate service to make you get an easy and efficient learning and preparation for the NSE6_FSR-7.3 test. If you study with our NSE6_FSR-7.3 exam questions for 20 to 30 hours, you will be bound to pass the exam smoothly. So what are you waiting for? Just come and buy our NSE6_FSR-7.3 practice guide!
Fortinet NSE6_FSR-7.3 Exam Syllabus Topics:
  • System Configuration: FortiSOAR requires careful setup of applications for FortiSoar System Administrators. It covers system fixtures, and proxy settings to function optimally.
  • System Monitoring and Maintenance: For FortiSOAR Administrators, this domain covers using various tools for system monitoring to ensure consistent performance. This includes how to regularly oversee FortiSOAR processes, along with other critical functions.
  • System Operation: For System Engineers, this section covers Elasticsearch data management that may need to be externalized or migrated to accommodate system needs. Additionally, this section covers configuring the recommendation engine and utilizing the war room functionality.
  • SOC and SOAR Overview: Security Engineers can gain an understanding of SOC and SOAR deployment requirements, including licensing management for FortiSOAR.
Topic 5
  • Security Management: This section covers how Security Engineers implement role-based access control (RBAC) and set up team structures within FortiSOAR to streamline security management.
Free PDF Quiz Efficient NSE6_FSR-7.3 - Top Fortinet NSE 6 - FortiSOAR 7.3 Administrator DumpsIn order to meet the upcoming NSE6_FSR-7.3 exam, we believe you must be anxiously searching for relevant test materials. After all, it may be difficult to pass the exam just on your own, so we're honored you can see this message today because our NSE6_FSR-7.3 Guide quiz can solve your problems. Since inception, our company has devoted itself to studying the proposition outlines of various examinations so as to design materials closely to the contents of these NSE6_FSR-7.3 exams.
Fortinet NSE 6 - FortiSOAR 7.3 Administrator Sample Questions (Q37-Q42):NEW QUESTION # 37
The former primary node was relegated to the secondary rote but is stuck in the Faulted state.
Which two steps must you take to restore operation in the high availability (HA) cluster? (Choose two.)
  • A. Restart the node that is in the Faulted state to trigger another election.
  • B. On the node that is in the Faulted state, enter the csadm ha leave-cluster command.
  • C. Enter the csadm ha join-cluster command to have the node that is in the Faulted state rejoin the HA cluster as a secondary node.
  • D. Perform a fire drill to test the database integrity of the node that is in the Faulted state.
In a FortiSOAR HA cluster, if the former primary node is relegated to a secondary role but is stuck in a Faulted state, it indicates that the node has lost sync or faced a failure during a role change. To restore its functionality, first, you should remove it from the cluster using the csadm ha leave-cluster command. Once it has left the cluster, you can use the csadm ha join-cluster command to re-add the node as a secondary node. This process will allow it to sync back up with the cluster and resume its role as intended.
NEW QUESTION # 38
Which three activities can be achieved using the FortiSOAR queue and shift management feature? (Choose three)
  • A. Generate shift leads and shift members
  • B. Create queue rules based on matching conditions
  • C. Set up queue meeting rooms
  • D. Designate a coordinator to monitor queues and shifts
  • E. Initiate shift handovers
Answer: A,B,E
The FortiSOAR queue and shift management feature enables several key activities for managing shifts and queues. Administrators can initiate shift handovers, allowing for smooth transitions between shift leads and members. They can also designate specific roles within shifts, including shift leads and members, to define responsibilities. Additionally, queue rules can be established based on certain conditions, ensuring that incidents and tasks are assigned according to predefined criteria, which helps streamline operations and improve response times.
NEW QUESTION # 39
View the exhibit:
What does the command output mean?
  • A. There is no connectivity between the PostgreSQL databases of the primary and secondary FortiSOAR instances.
  • B. The configuration to enable database externalization has not been completed.
  • C. The local PostgreSQL database is configured on the FortiSOAR instance.
  • D. The local PostgreSQL database is disabled on the FortiSOAR instance.
NEW QUESTION # 40
Which two ports must be open between FortiSOAR HA nodes'* (Choose two.)
  • A. Port 9200
  • B. Port 5432
  • C. Port 6380
  • D. Port 25
In a FortiSOAR HA configuration, certain ports must be open for communication between nodes. Port 5432 is required for PostgreSQL database communication, which is essential for data replication between HA nodes.
Port 9200 is used by Elasticsearch, which FortiSOAR leverages for indexing and search functions across the nodes. These ports must be accessible between nodes to ensure seamless operation and data consistency within the cluster.
NEW QUESTION # 41
NEW QUESTION # 42
As this new frontier of personalizing the online experience advances, our NSE6_FSR-7.3 exam guide is equipped with comprehensive after-sale online services. And we have customer service people 24 hours online to deal with your difficulties on our NSE6_FSR-7.3 exam questions. If you have any question or request for further assistance about the NSE6_FSR-7.3 study braindumps, you can leave us a message on the web page or email us. All in all, we take an approach to this market by prioritizing the customers first, and we believe the customer-focused vision will help our NSE6_FSR-7.3 test guide growth.
NSE6_FSR-7.3 Reliable Test Pattern: https://www.exams-boost.com/NSE6_FSR-7.3-valid-materials.html
BTW, DOWNLOAD part of Exams-boost NSE6_FSR-7.3 dumps from Cloud Storage: https://drive.google.com/open?id=1JdNDSvs1Rj245nB_-kmk8MxzTtW1BwfH
