Oracle 1z0-1054-25 PDF Questions - Most Effective Exam Preparation Method
Posted at 4/19/2026 15:17:32
View174
Replies0
P.S. Free & New 1z0-1054-25 dumps are available on Google Drive shared by UpdateDumps: https://drive.google.com/open?id=1mYAQ0RTy4zFbmpYXagPWKfIi7ZLsouVd
PassitCertify works hard to provide the most recent version of Oracle 1z0-1054-25 Exams through the efforts of a team of knowledgeable and certified Oracle Financials Cloud: General Ledger 2025 Implementation Professional 1z0-1054-25 Exams experts. Actual Dumps Our professionals update Oracle Financials Cloud: General Ledger 2025 Implementation Professional 1z0-1054-25 on a regular basis. You must answer all Oracle Financials Cloud: General Ledger 2025 Implementation Professional 1z0-1054-25 questions in order to pass the Oracle Financials Cloud: General Ledger 2025 Implementation Professional 1z0-1054-25 exam.
To further strengthen your preparation for the Oracle 1z0-1054-25 exam, UpdateDumps provides an online Oracle Practice Test engine. With this interactive tool, you can practice the 1z0-1054-25 Exam questions in a simulated exam environment. The 1z0-1054-25 online practice test engine is designed based on the real Oracle 1z0-1054-25 Exam patterns, allowing you to familiarize yourself with the format and gain confidence for the actual Oracle 1z0-1054-25 exam. Practicing with the Oracle 1z0-1054-25 exam questions will not only increase your understanding but also boost your overall performance.
1z0-1054-25 Latest Test Simulator | 1z0-1054-25 Valid Test AnswersGet the Oracle certification to validate your IT expertise and broaden your network to get more improvement in your career. UpdateDumps will help you with its valid and high quality 1z0-1054-25 prep torrent. 1z0-1054-25 questions & answers are compiled by our senior experts who with rich experience. Besides, we check the update about 1z0-1054-25 Training Pdf every day. If there is any update, the newest and latest information will be added into the 1z0-1054-25 complete dumps, while the old and useless questions will be removed of the 1z0-1054-25 torrent. The hiogh quality and high pass rate can ensure you get high scores in the 1z0-1054-25 actual test.
Oracle Financials Cloud: General Ledger 2025 Implementation Professional Sample Questions (Q54-Q59):NEW QUESTION # 54
You are implementing amultipillarimplementation of bothHCM CloudandERP Cloud. You are implementingERP first, followed byHCM Cloud. You want to ensure yourledgers and chart of accounts are correctly defined.
What should you do? (Choose three.)
- A. Create your chart of accounts in the following order: value sets, COA structure, and instance before assigning values to the value sets.
- B. Use file-based spreadsheet loaders using UCM to mass load and maintain chart of accounts segment values and hierarchies.
- C. Deploy your chart of accounts.
- D. Use the Rapid Implementation spreadsheet when creating your enterprise structure.
- E. Use HCM's Enterprise Structure Configurator (ESC) first.
Answer: A,D,E
NEW QUESTION # 55
Manage Chart of Accounts Structure and Instance
Scenario
Your client is implementing Oracle Fusion Cloud Financials. The decision is to have a 5-segment Chart of Accounts: Company, Cost Center, Account, Product, and Intercompany. You are working in the General Ledger team and will be responsible for creating the Chart of Accounts Structure and Instance for the Chart of Accounts.
Task 1
Create a Chart of Accounts Structure and Instance for the following Chart of Accounts:
Note:
Prefix all your setups with 07, where 07 is your candidate ID
There is one balancing segment.
Choose the appropriate segment labels.
. For the purpose of this test there is no need to deploy the flexfield.
. Valid code combinations should be added to the Code Combination table automatically.
Shorthand aliases will not be implemented.
. Accept the defaults for the instance segments.
See the Explanation for the complete Solution.
Here are the steps you need to follow:
* Navigate to the Setup and Maintenance work area and search for the task Manage Chart of Accounts Structures.
* Click on the Create icon to create a new Chart of Accounts Structure. Enter the following information:
* Structure Code: 07COA
* Structure Name: 07 Chart of Accounts
* Description: Chart of Accounts for candidate 07
* Number of Segments: 5
* Click on the Next button to define the segments. Enter the following information for each segment:
* Segment Number: 1
* Segment Name: Company
* Value Set Code: 07Corporate Company
* Value Set Name: 07 Corporate Company
* Maximum Size: 3
* Balancing: Yes
* Segment Label: Company
* Segment Number: 2
* Segment Name: Cost Center
* Value Set Code: 07Corporate Cost Center
* Value Set Name: 07 Corporate Cost Center
* Maximum Size: 4
* Balancing: No
* Segment Label: Cost Center
* Segment Number: 3
* Segment Name: Account
* Value Set Code: 07Corporate Account
* Value Set Name: 07 Corporate Account
* Maximum Size: 8
* Balancing: No
* Segment Label: Natural Account
* Segment Number: 4
* Segment Name: Product
* Value Set Code: 07Corporate Product
* Value Set Name: 07 Corporate Product
* Maximum Size: 3
* Balancing: No
* Segment Label: Product
* Segment Number: 5
* Segment Name: Intercompany
* Maximum Size: 3
* Balancing: No
* Segment Label: Intercompany
* Click on the Next button to review the summary and click on the Save and Close button to save the Chart of Accounts Structure.
* Navigate to the Setup and Maintenance work area and search for the task Manage Chart of Accounts Structure Instances.
* Click on the Create icon to create a new Chart of Accounts Structure Instance. Enter the following information:
* Chart of Accounts Structure: 07COA
* Enabled: Yes
* Allow Dynamic Inserts: Yes
* Click on the Next button to review the summary and click on the Save and Close button to save the Chart of Accounts Structure Instance.
You have successfully created a Chart of Accounts Structure and Instance for the given scenario. For more information, you can refer to the following resources:
* Chart of Accounts Structures and Instances
* Chart of Accounts Components
* Minimum Steps For Financial Enterprise Structures Configuration
* Overview of Creating and Configuring Chart of Accounts Structure and Instances
NEW QUESTION # 56
Your new accountants have been making mistakes in reconciling accounts assigned to them. Your account balances have either spiked or dropped 30-40% every period due to human error. This causes delays in reconciliation.
Which feature can be used to proactively notify you of account anomalies in a more timely manner?
- A. Account Inspector and its charts
- B. Account Monitor
- C. Smart View
- D. Financial reports with embedded charts
NEW QUESTION # 57
Your Oracle Fusion Cloud client needs to store balances such as floor space, number of employees, quantities purchased for use in journal allocations, and financial reporting.
Currently, in their test environment, they are unable to record statistical amounts.
What is the reason?
- A. The currency STAT does not have the statistical unit type enabled.
- B. The currency STAT does not have the ISO currency flag enabled.
- C. The ledger currency does not have the derivation flag enabled.
NEW QUESTION # 58
You have created several account groups with the Display in option as Expenses.
Which setting determines the account group that will be displayed in the General Accounting infolets on your home page?
- A. Set in Expenses
- B. Access is Public
- C. Set as Default
- D. Access is Shared
NEW QUESTION # 59
UpdateDumps is famous for its high-quality in this field especially for Oracle 1z0-1054-25 certification exams. It has been accepted by thousands of candidates who practice our 1z0-1054-25 study materials for their exam. In this major environment, people are facing more job pressure. So they want to get a Oracle Financials Cloud: General Ledger 2025 Implementation Professional 1z0-1054-25 Certification rise above the common herd.
1z0-1054-25 Latest Test Simulator: https://www.updatedumps.com/Oracle/1z0-1054-25-updated-exam-dumps.html
1z0-1054-25 test online materials will help users take it easy while taking part in the real test, Oracle 1z0-1054-25 Actual Test Pdf Every trade is quick-changed in today's society, let alone the IT industry, Oracle 1z0-1054-25 Actual Test Pdf We, a world-class certification dumps leader, have been sparing no efforts to provide the most useful study material and the most effective instruction for our subscribers, If you are tired of the digital screen study and want to study with your pens, 1z0-1054-25 Latest Test Simulator - Oracle Financials Cloud: General Ledger 2025 Implementation Professional pdf version is suitable for you.
It then delves into essential text processing subject areas, 1z0-1054-25 including string operations, regular expressions, parsers and state machines, and Internet tools and techniques.
Configure Full Duplex Mode in the Network Card in Windows, 1z0-1054-25 Test Online materials will help users take it easy while taking part in the real test, Every trade is quick-changed in today's society, let alone the IT industry.
Save Time and Money with Our Oracle 1z0-1054-25 Exam QuestionsWe, a world-class certification dumps leader, have been sparing 1z0-1054-25 Valid Test Answers no efforts to provide the most useful study material and the most effective instruction for our subscribers.
If you are tired of the digital screen study and want to study with your pens, 1z0-1054-25 Actual Test Pdf Oracle Financials Cloud: General Ledger 2025 Implementation Professional pdf version is suitable for you, If you are not sure about how to choose, you can download our free actual test dumps pdf for your reference.
- 1z0-1054-25 Latest Test Pdf 🔮 1z0-1054-25 Test Quiz 👻 1z0-1054-25 Test Lab Questions 🔎 Search for 1z0-1054-25 and download it for free immediately on ⇛ [url]www.prepawayexam.com ⇚ 💷1z0-1054-25 Flexible Learning Mode[/url]
- Updated Oracle 1z0-1054-25 Practice Questions In Three Formats 🌳 Simply search for ✔ 1z0-1054-25 ️✔️ for free download on ☀ [url]www.pdfvce.com ️☀️ 📴Latest 1z0-1054-25 Dumps[/url]
- 100% Pass Quiz 2026 Oracle 1z0-1054-25: Oracle Financials Cloud: General Ledger 2025 Implementation Professional C High-quality Actual Test Pdf 📉 Search for ⏩ 1z0-1054-25 ⏪ and download exam materials for free through { [url]www.exam4labs.com } 🦪Reliable 1z0-1054-25 Test Sims[/url]
- Latest 1z0-1054-25 Test Prep 👄 Reliable 1z0-1054-25 Exam Test 🥂 Reliable 1z0-1054-25 Test Sims 🧟 Easily obtain free download of ➽ 1z0-1054-25 🢪 by searching on { [url]www.pdfvce.com } ❔Latest 1z0-1054-25 Test Prep[/url]
- 1z0-1054-25 Related Exams ⬛ Latest 1z0-1054-25 Test Prep 🧃 New 1z0-1054-25 Dumps Ebook 🚕 Go to website ✔ [url]www.dumpsmaterials.com ️✔️ open and search for 1z0-1054-25 to download for free 💧1z0-1054-25 Official Practice Test[/url]
- 1z0-1054-25 Latest Test Discount 👳 1z0-1054-25 Test Lab Questions 🔍 Reliable 1z0-1054-25 Test Sims 🐜 Open ▷ [url]www.pdfvce.com ◁ enter 1z0-1054-25 and obtain a free download 🕺Latest 1z0-1054-25 Test Prep[/url]
- 1z0-1054-25 Valid Test Practice 👊 Latest 1z0-1054-25 Dumps 🌵 1z0-1054-25 Valid Real Exam 🛩 Open website ⮆ [url]www.practicevce.com ⮄ and search for [ 1z0-1054-25 ] for free download 🚹Latest 1z0-1054-25 Dumps[/url]
- [url=https://www.rmprioleau.com/?s=1z0-1054-25%20Valid%20Dump%20%f0%9f%a4%8e%20Reliable%201z0-1054-25%20Test%20Vce%20%f0%9f%9f%a2%201z0-1054-25%20Flexible%20Learning%20Mode%20%f0%9f%a5%8c%20Search%20for%20%e3%80%90%201z0-1054-25%20%e3%80%91%20and%20download%20it%20for%20free%20on%20[%20www.pdfvce.com%20]%20website%20%f0%9f%94%b7Latest%201z0-1054-25%20Test%20Prep]1z0-1054-25 Valid Dump 🤎 Reliable 1z0-1054-25 Test Vce 🟢 1z0-1054-25 Flexible Learning Mode 🥌 Search for 1z0-1054-25 and download it for free on [ www.pdfvce.com ] website 🔷Latest 1z0-1054-25 Test Prep[/url]
- 1z0-1054-25 Valid Dump 🦙 Latest 1z0-1054-25 Dumps 😾 1z0-1054-25 Test Lab Questions 🥴 ▷ [url]www.exam4labs.com ◁ is best website to obtain { 1z0-1054-25 } for free download 🕟Reliable 1z0-1054-25 Test Sims[/url]
- Pass Guaranteed 2026 Oracle 1z0-1054-25: Professional Oracle Financials Cloud: General Ledger 2025 Implementation Professional Actual Test Pdf 🥂 Download 1z0-1054-25 for free by simply entering { [url]www.pdfvce.com } website 🎥1z0-1054-25 Official Practice Test[/url]
- New 1z0-1054-25 Dumps Ebook 🟨 Reliable 1z0-1054-25 Exam Test ⛳ 1z0-1054-25 Official Practice Test 🔥 Search for ☀ 1z0-1054-25 ️☀️ and download it for free immediately on [url]www.vceengine.com 🙋1z0-1054-25 Valid Test Practice[/url]
- dl.instructure.com, www.jcdqzdh.com, yu856.com, tooter.in, www.abitur-und-studium.de, www.stes.tyc.edu.tw, divisionmidway.org, www.jzskj.cn, fixfliphispano.com, www.stes.tyc.edu.tw, Disposable vapes
What's more, part of that UpdateDumps 1z0-1054-25 dumps now are free: https://drive.google.com/open?id=1mYAQ0RTy4zFbmpYXagPWKfIi7ZLsouVd
