[Hardware] Nutanix NCP-MCA Reliable Practice Materials, NCP-MCA Latest Dumps
28
Hardware Nutanix NCP-MCA Reliable Practice Materials, NCP-MCA Latest Dumps
Posted at 4/19/2026 17:06:45      View107 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free & New NCP-MCA dumps are available on Google Drive shared by Actualtests4sure: https://drive.google.com/open?id=1DYOQ0htBaX4_9CBNXLYhxILp1yqmNl3Y
In the 21 Century, the NCP-MCA certification became more and more recognized in the society because it represented the certain ability of examinees. However, in order to obtain NCP-MCA certification, you have to spend a lot of time preparing for the NCP-MCA Exam. Many people gave up because of all kinds of difficulties before the examination, and finally lost the opportunity to enhance their self-worth. But our NCP-MCA exam questions will help you pass the exam for sure.
Nutanix NCP-MCA Certification Exam is divided into two parts: a written exam and a practical exam. The written exam tests the candidates' knowledge of Nutanix technologies, while the practical exam tests their ability to apply these technologies to real-world scenarios. Candidates who pass both exams are awarded the Nutanix NCP-MCA certification.
The NCP-MCA certification exam covers a wide range of topics, including automation and orchestration, virtualization, networking, security, and cloud computing. NCP-MCA exam is designed to test the candidate's understanding of core concepts and techniques related to managing and automating complex multicloud environments.
Nutanix Certified Professional - Multicloud Automation (NCP-MCA) Certification Exam is a rigorous test of an individual's knowledge and skills in managing and automating IT operations across multiple clouds. Passing the exam demonstrates a high level of proficiency in multicloud automation and provides a valuable credential for IT professionals who work with Nutanix technology. If you are an IT professional looking to advance your career in multicloud automation, the NCP-MCA Certification is a valuable credential to consider.
NCP-MCA Latest Dumps, NCP-MCA Relevant AnswersThe Nutanix NCP-MCA certification is one of the top-rated career advancement certifications in the market. This Nutanix Certified Professional - Multicloud Automation (NCP-MCA 6.10) (NCP-MCA) certification exam has been inspiring candidates since its beginning. Over this long time period, thousands of NCP-MCA Exam candidates have passed their Nutanix Certified Professional - Multicloud Automation (NCP-MCA 6.10) (NCP-MCA) certification exam and now they are doing jobs in the world's top brands. You can also be a part of this wonderful community.
Nutanix Certified Professional - Multicloud Automation (NCP-MCA 6.10) Sample Questions (Q84-Q89):NEW QUESTION # 84
When using Prism Central Disaster Recovery in an Organization, which statement is true for Playbooks on a recovered Prism Central?
  • A. Credentials should be re-entered into enabled Playbooks since a credential provider is used.
  • B. No changes need to be made to credentials in enabled Playbooks; they will continue to work successfully.
  • C. Credentials should be re-entered into enabled Playbooks so they will continue to work successfully.
  • D. No changes need to be made to credentials in enabled Playbooks since a credential provider is used.
In Nutanix Prism Central Disaster Recovery, when a Prism Central instance fails over to a recovered site, several automation components-including Playbooks-must be revalidated. Nutanix documentation clearly states:
* Playbooks store encrypted credentials locally in the Prism Central database.
* When Prism Central is recovered on a DR site, the credential encryption keys donottransfer.
* As a result,any credentials previously stored in Playbooks become invalidand must be manually re- entered.
This requirement ensures that the scripts, tasks, remediation sequences, and integrations invoked by the Playbook can authenticate properly after recovery.
Therefore:
* Playbookscannot automatically use previously stored credentialsafter a DR failover.
* Administrators mustre-enter all credentialsin enabled Playbooks so the automation continues functioning.
Hence, OptionCis correct.
Options A and D are incorrect because Playbooks donotautomatically retain functional credentials after DR recovery.
Option B is incorrect because the presence or absence of a credential provider does not change the need to re- enter credentials.
NEW QUESTION # 85
An administrator receives the following error while running a script through Calm on VM:
Which two conditions could cause this issue? (Choose two.)
  • A. The VM is still in the boot process.
  • B. There is an error in the script.
  • C. The credentials have insufficient permissions.
  • D. The VM port is not allowed by the firewall.
The error "Connection refused" can occur due to several reasons but in the context of running a script through Calm on VM, it is most likely caused by firewall restrictions or insufficient permissions. Option A suggests that the VM port is not allowed by the firewall, meaning that the firewall settings are preventing the connection. This could be because specific ports needed for the script to run are being blocked. Option B indicates that the credentials have insufficient permissions, meaning that the user or system trying to execute the script does not have the necessary permissions to establish a connection. Option C is unlikely because the VM should be ready before the script is executed. Option D is possible but not specific enough to explain the connection issue. References: You can find more information about this topic in the following sources:
* Nutanix Certified Professional - Multicloud Automation (NCP-MCA) Exam Blueprint Guide, Section 3
- Validate Blueprints, Runbooks, Playbooks, and Automation Settings, page 9
* Nutanix Multicloud Automation Administration (NMCAA), Module 5 - Troubleshooting, Lesson 1 - Troubleshooting Calm, page 5-4
NEW QUESTION # 86
An administrator needs to notify the on-call pager after hours using their PagerDuty incident management platform.
How should the administrator integrate notifications via PagerDuty in a Playbook using the least number of configurations possible?
  • A. Send Alert to Nutanix v3 API which will use APIs to send notification to PagerDuty.
  • B. Create an action to notify PagerDuty via IP address.
  • C. Create an action to send an alert to PagerDuty'.
  • D. Send Alert to Webhook which will use APIs to send notification to PagerDuty.
The Send Alert to Webhook action allows the administrator to send an HTTP request to a specified URL, which can be used to trigger a PagerDuty incident via its REST API1. This action requires the least number of configurations compared to the other options, as it only needs the webhook URL, the HTTP method, and the payload. The other options would require additional steps, such as creating a custom action, configuring the IP address, or using the Nutanix v3 API, which is not designed for integrating with third-party services.
Nutanix Certified Professional - Multicloud Automation (NCP-MCA) v6.5, Section 3, Objective 3.3 Nutanix Multicloud Automation Administration (NMCAA), Module 5, Lesson 5.2 Training Spotlight: Nutanix Multicloud Automation Administration (NMCAA), Video 5.2 Process Automation | PagerDuty
NEW QUESTION # 87
In which tab would a configured Credential Provider be added to a Self-Service-enabled Project?
  • A. Infrastructure
  • B. Tunnels
  • C. Users & Groups
  • D. Policies
In Nutanix Self-Service (formerly Calm), the Infrastructure tab within a Project is the designated location for configuring and assigning provider accounts.
When an administrator navigates toProjects>[Project Name]>Infrastructure, they can click"Add Infrastructure". This workflow presents the option to select:
* Account:Cloud provider accounts (e.g., Nutanix AHV, AWS, Azure, VMware) that the project is allowed to use.
* Credential Provider:External credential stores (if configured) or specific credential provider accounts that the project users can access for authenticating workloads.
The other tabs serve different purposes: "Users & Groups" handles RBAC, "Policies" handles Quotas and Approvals, and "Tunnels" handles VPC network connectivity.
NEW QUESTION # 88
An administrator is trying to save new settings for an Azure integration. but is having issues applying the changes.
What log should the administrator check?
  • A. / home/espilon/log/durga.log
  • B. / home/calm/log/sytx.log
  • C. / home/calm/log/hercules.log
  • D. / home/espilon/log/arjun.log
The hercules.log file is the log file for the Calm service, which is responsible for managing the integration with various cloud providers, including Azure. The administrator can check this log file to troubleshoot any issues related to the Azure integration, such as authentication, configuration, or communication errors. The other log files are not relevant for the Azure integration. The sytx.log file is the log file for the Sytx service, which is responsible for managing the Calm UI and API. The durga.log file is the log file for the Durga service, which is responsible for managing the Calm Marketplace and blueprints. The arjun.log file is the log file for the Arjun service, which is responsible for managing the Calm runbooks and playbooks.
* Nutanix Certified Professional - Multicloud Automation (NCP-MCA) v6.5, Section 2 - Deploy and Configure Nutanix Calm and Related Components, Objective 2.4 - Identify required configuration settings for a Nutanix Calm deployment
* [Troubleshooting Calm | Nutanix Community]
NEW QUESTION # 89
It is impossible to overstate the significance of valid NCP-MCA exam questions. The latest and actual NCP-MCA exam questions are essential to clear the NCP-MCA exam in one go. Applicants are better prepared to succeed when they prepare with the updated Nutanix NCP-MCA Questions. These NCP-MCA exam questions give applicants the knowledge they need to quickly ace the NCP-MCA examination.
NCP-MCA Latest Dumps: https://www.actualtests4sure.com/NCP-MCA-test-questions.html
