[General] CT-AI Valid Exam Topics, New CT-AI Test Practice
24
General CT-AI Valid Exam Topics, New CT-AI Test Practice
Posted at 4/19/2026 17:12:13      View147 | Replies0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest RealVCE CT-AI PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1G3so_kxnMmouqh5648m9NXAWm3Jei-wL
RealVCE helps you in doing self-assessment so that you reduce your chances of failure in the examination of Certified Tester AI Testing Exam (CT-AI) certification. Similarly, this desktop CT-AI practice exam software of RealVCE is compatible with all Windows-based computers. You need no internet connection for it to function. The Internet is only required at the time of product license validation.
Getting the Certified Tester AI Testing Exam (CT-AI) certification will highly expand your expertise. To achieve the CT-AI certification you need to prepare well. CT-AI exam dumps are a great way to assess your skills and abilities. CT-AI Questions can help you identify your strengths and weaknesses and better understand what you're good at. You should take a CT-AI Practice Exam to prepare for the Certified Tester AI Testing Exam (CT-AI) certification exam. With CT-AI exam preparation software, you can practice your skills and improve your performance.
Get Latest ISTQB CT-AI Exam Dumps [2026]Nowadays, the development of technology is quickly. Also, our CT-AI exam guide will keep advancing. A lot of reforms have applied to the content and formats of our CT-AI learning guide according to our professional experts constantly efforts. We just hope that you will have a better experience when you study on our CT-AI Actual Exam. Act from now if you are still hesitating, our CT-AI study materials will enable you embrace a bright future.
ISTQB CT-AI Exam Syllabus Topics:
  • ML: Data: This section of the exam covers explaining the activities and challenges related to data preparation. It also covers how to test datasets create an ML model and recognize how poor data quality can cause problems with the resultant ML model.
  • Machine Learning ML: This section includes the classification and regression as part of supervised learning, explaining the factors involved in the selection of ML algorithms, and demonstrating underfitting and overfitting.
  • Quality Characteristics for AI-Based Systems: This section covers topics covered how to explain the importance of flexibility and adaptability as characteristics of AI-based systems and describes the vitality of managing evolution for AI-based systems. It also covers how to recall the characteristics that make it difficult to use AI-based systems in safety-related applications.
  • Introduction to AI: This exam section covers topics such as the AI effect and how it influences the definition of AI. It covers how to distinguish between narrow AI, general AI, and super AI; moreover, the topics covered include describing how standards apply to AI-based systems.
Topic 5
  • Testing AI-Based Systems Overview: In this section, focus is given to how system specifications for AI-based systems can create challenges in testing and explain automation bias and how this affects testing.
Topic 6
  • Using AI for Testing: In this section, the exam topics cover categorizing the AI technologies used in software testing.
Topic 7
  • systems from those required for conventional systems.
Topic 8
  • Methods and Techniques for the Testing of AI-Based Systems: In this section, the focus is on explaining how the testing of ML systems can help prevent adversarial attacks and data poisoning.
Topic 9
  • Test Environments for AI-Based Systems: This section is about factors that differentiate the test environments for AI-based
Topic 10
  • Neural Networks and Testing: This section of the exam covers defining the structure and function of a neural network including a DNN and the different coverage measures for neural networks.
ISTQB Certified Tester AI Testing Exam Sample Questions (Q68-Q73):NEW QUESTION # 68
Which of the following is a problem with AI-generated test cases that are generated from the requirements?
  • A. They are defect prone because they are unable to detect nuances in the requirements.
  • B. They make debugging more complicated because the number of steps is usually high in order to induce the target failure.
  • C. They are slow and will usually not be able to execute in the time allowed.
  • D. They are usually missing the expected results, so verification is difficult or must resort to only detecting significant failures.
AI-generated test cases are often created using machine learning (ML) models or heuristic algorithms. While these can be effective in generating large numbers of test cases quickly, they oftensuffer from the "test oracle problem."
* Test Oracle Problem:A test oracle is the mechanism used to determine the expected output of a test case. AI-generated test cases oftenlack expected resultsbecause AI-based tools do not inherently understand what the correct output should be.
* Difficulty in Verification:Without expected results, verifying test cases becomes challenging. Testers mustrely on heuristics, anomaly detection, or significant failures, rather than traditional pass/fail conditions.
* A (Slow Execution Time):AI-generated tests are typically automated and designed for efficiency. They are not inherently slow and often executefasterthan manually written tests.
* B (Defect-Prone Due to Nuance Issues):While AI-generated tests may struggle with some complexities in requirements, they primarilylack expected results, rather than failing due to an inability to detect nuances.
* C (Complicated Debugging Due to Many Steps):AI-generated testsreducedebugging complexity by limiting the number of steps required to reproduce failures.
* ISTQB CT-AI Syllabus (Section 11.3: Using AI for Test Case Generation)
* "AI-generated test cases often lack expected results, making it difficult to verify correctness without a test oracle.".
* "Verification often relies on detecting significant failures rather than having predefined expected results.".
Why Other Options Are Incorrect:Supporting References from ISTQB Certified Tester AI Testing Study Guide:Conclusion:Since AI-generated test cases frequentlylack expected results, verification becomes difficult, requiring testers tofocus on major failuresrather than precise pass/fail conditions. Thus, thecorrect answer is D.
NEW QUESTION # 69
Which ONE of the following options does NOT describe an Al technology related characteristic which differentiates Al test environments from other test environments?
SELECT ONE OPTION
  • A. The challenge of providing explainability to the decisions made by the system.
  • B. The challenge of mimicking undefined scenarios generated due to self-learning
  • C. Challenges in the creation of scenarios of human handover for autonomous systems.
  • D. Challenges resulting from low accuracy of the models.
AI test environments have several unique characteristics that differentiate them from traditional test environments. Let's evaluate each option:
A . Challenges resulting from low accuracy of the models.
Low accuracy is a common challenge in AI systems, especially during initial development and training phases. Ensuring the model performs accurately in varied and unpredictable scenarios is a critical aspect of AI testing.
B . The challenge of mimicking undefined scenarios generated due to self-learning.
AI systems, particularly those that involve machine learning, can generate undefined or unexpected scenarios due to their self-learning capabilities. Mimicking and testing these scenarios is a unique challenge in AI environments.
C . The challenge of providing explainability to the decisions made by the system.
Explainability, or the ability to understand and articulate how an AI system arrives at its decisions, is a significant and unique challenge in AI testing. This is crucial for trust and transparency in AI systems.
D . Challenges in the creation of scenarios of human handover for autonomous systems.
While important, the creation of scenarios for human handover in autonomous systems is not a characteristic unique to AI test environments. It is more related to the operational and deployment challenges of autonomous systems rather than the intrinsic technology-related characteristics of AI .
Given the above points, option D is the correct answer because it describes a challenge related to operational deployment rather than a technology-related characteristic unique to AI test environments.
NEW QUESTION # 70
Which of the following options is an example of the concept of overfitting?
  • A. A model for predicting IT system failures delivers too many false-negative predictions because the failures cannot be adequately explained via the log files used for training.
  • B. A previously trained model for recognizing cars is adapted and extended so that it can also identify the make of the car beyond its original function.
  • C. A model for the recognition of dogs was trained predominantly with pictures of dogs in parks. On pictures with other animals in parks, dogs are also falsely recognized.
  • D. A model for predicting academic performance was trained with data from students at one university. The model shows low predictive accuracy when applied to other universities.
The ISTQB CT-AI syllabus defines overfitting in Section3.2 - ML Model Evaluationas a condition where an ML model learns the training data too precisely--including noise and irrelevant detail-- resulting in poor performance on unseen data. Overfitting is characterized byhigh accuracy on training data but low accuracy on validation or real-world data. Option A perfectly matches this definition: a model trained only on one university's student data generalizes poorly to students from other universities.
This is a textbook example of overfitting because the model has essentially memorized patterns unique to a narrow dataset, instead of learning generalizable relationships applicable across environments .
NEW QUESTION # 71
In a conference on artificial intelligence (Al), a speaker made the statement, "The current implementation of Al using models which do NOT change by themselves is NOT true Al*. Based on your understanding of Al, is this above statement CORRECT or INCORRECT and why?
SELECT ONE OPTION
  • A. This statement is correct. In general, today the term Al is utilized incorrectly.
  • B. This statement is incorrect. What is considered Al today will continue to be Al even as technology evolves and changes.
  • C. This statement is incorrect. Current Al is true Al and there is no reason to believe that this fact will change over time.
  • D. This statement is correct. In general, what is considered Al today may change over time.
* A. This statement is incorrect. Current AI is true AI and there is no reason to believe that this fact will change over time.
AI is an evolving field, and the definition of what constitutes AI can change as technology advances.
* B. This statement is correct. In general, what is considered AI today may change over time.
The term AI is dynamic and has evolved over the years. What is considered AI today might be viewed as standard computing in the future. Historically, as technologies become mainstream, they often cease to be considered "AI".
* C. This statement is incorrect. What is considered AI today will continue to be AI even as technology evolves and changes.
This perspective does not account for the historical evolution of the definition of AI . As new technologies emerge, the boundaries of AI shift.
* D. This statement is correct. In general, today the term AI is utilized incorrectly.
While some may argue this, it is not a universal truth. The term AI encompasses a broad range of technologies and applications, and its usage is generally consistent with current technological capabilities.
NEW QUESTION # 72
A wildlife conservation group would like to use a neural network to classify images of different animals. The algorithm is going to be used on a social media platform to automatically pick out pictures of the chosen animal of the month. This month's animal is set to be a wolf. The test teamhas already observed that the algorithm could classify a picture of a dog as being a wolf because of the similar characteristics between dogs and wolves. To handle such instances, the team is planning to train the model with additional images of wolves and dogs so that the model is able to better differentiate between the two.
What test method should you use to verify that the model has improved after the additional training?
  • A. Adversarial testing to verify that no incorrect images have been used in the training.
  • B. Pairwise testing using combinatorics to look at a long list of photo parameters.
  • C. Metamorphic testing because the application domain is not clearly understood at this point.
  • D. Back-to-back testing using the version of the model before training and the new version of the model after being trained with additional images.
Back-to-back testing isused to compare two different versions of an ML model, which is precisely what is needed in this scenario.
* The model initiallymisclassified dogs as wolvesdue to feature similarities.
* Thetest team retrains the modelwith additional images of dogs and wolves.
* The best way to verify whether this additional trainingimproved classification accuracyis to compare theoriginal model's output with the newly trained model's output using the same test dataset.
* A (Metamorphic Testing):Metamorphic testing is useful forgenerating new test casesbased on existing ones but does not directly compare different model versions.
* B (Adversarial Testing):Adversarial testing is used to check how robust a model is againstmaliciously perturbed inputs, not to verify training effectiveness.
* C (Pairwise Testing)airwise testing is a combinatorial technique for reducing the number of test casesby focusing on key variable interactions, not for validating model improvements.
* ISTQB CT-AI Syllabus (Section 9.3: Back-to-Back Testing)
* "Back-to-back testing is used when an updated ML model needs to be compared against a previous version to confirm that it performs better or as expected".
* "The results of the newly trained model are compared with those of the prior version to ensure that changes did not negatively impact performance".
Why Other Options Are Incorrect:Supporting References from ISTQB Certified Tester AI Testing Study Guide:Conclusion:To verify that the model's performance improved after retraining,back-to-back testing is the most appropriate methodas it compares both model versions. Hence, thecorrect answer is D.
NEW QUESTION # 73
The world is rapidly moving forward due to the prosperous development of information. Our company is also making progress in every side. The first manifestation is downloading efficiency. A lot of exam candidates these days are facing problems like lacking of time, or lacking of accessible ways to get acquainted with high efficient CT-AI guide question like ours. We emphasize on customers satisfaction, which benefits both exam candidates and our company equally. By developing and nurturing superior customers value, our company has been getting and growing more and more customers. To satisfy the goals of exam candidates, we created the high quality and high accuracy CT-AI real materials for you. By experts who diligently work to improve our practice materials over ten years, all content are precise and useful and we make necessary alternations at intervals.
New CT-AI Test Practice: https://www.realvce.com/CT-AI_free-dumps.html
P.S. Free & New CT-AI dumps are available on Google Drive shared by RealVCE: https://drive.google.com/open?id=1G3so_kxnMmouqh5648m9NXAWm3Jei-wL
