[General] Reliable 2V0-15.25 Exam Cram | 2V0-15.25 Exam Book
18
General Reliable 2V0-15.25 Exam Cram | 2V0-15.25 Exam Book
Posted at 4/19/2026 18:32:01      View101 | Replies0        Print      Only Author   [Copy Link] 1#
We promise that using 2V0-15.25 certification training materials of VCEEngine, you will pass 2V0-15.25 exam in your first try. If not or any problems in 2V0-15.25 certification training materials, we will refund fully. What's more, after you purchase our 2V0-15.25 Certification Training materials, VCEEngine will offer update service in one year.
Are you ready to gain all these 2V0-15.25 certification benefits? Looking for a simple, smart, and quick way to pass the challenging 2V0-15.25 exam? If your answer is yes then you need to enroll in the 2V0-15.25 exam and prepare well to crack this 2V0-15.25 exam with good scores. In this career advancement journey, you can get help from VCEEngine. The VCEEngine will provide you with real, updated, and error-free VMware 2V0-15.25 Exam Dumps that will enable you to pass the final 2V0-15.25 exam easily.
2V0-15.25 Test Braindumps: VMware Cloud Foundation 9.0 Support & 2V0-15.25 VCE DumpsVCEEngine VMware 2V0-15.25 Practice Test give you the opportunity to practice for the VMware 2V0-15.25 new exam questions. By using VMware Practice Test, you can get the ideal possibility to know the actual VMware Cloud Foundation 9.0 Support exam, as they follow the same interface as the real exam. This way, you can become more confident and comfortable while taking the actual exam.
VMware Cloud Foundation 9.0 Support Sample Questions (Q44-Q49):NEW QUESTION # 44
An administrator is asked to create a second provider gateway (provider gateway 02) in VMware Cloud Foundation (VCF) Automation Region-A.
After launching the Create Provider Gateway workflow in the VCF Automation Provider Management Portal, no Tier-0 Gateway is available for assignment.
How would you resolve this issue?
  • A. Create a new Region.
  • B. Log into the NSX Manager, create a new Tier-1 Gateway.
  • C. Log into the NSX Manager, create a new TO Gateway.
  • D. Retry the Create Provider Gateway workflow.
In VMware Cloud Foundation 9.0, aProvider Gatewayin VCF Automation is always backed by anexisting Tier-0 or Tier-0 VRF gatewayin NSX. When the administrator launches theCreate Provider Gateway workflow and no Tier-0 gateways appear for assignment, this indicates that VCF Automation cannot discover any valid Tier-0 gateways in the associated region.
The VMware Cloud Foundation 9.0 documentation explicitly states thatbefore adding a Provider Gateway, an administratormust first create an Active-Standby Tier-0 Gateway in NSX Manager. The Provider Gateway workflow only lists Tier-0 gateways that already exist and are properly configured in NSX. If none are present, the list will be empty.
From the documentation:"To add a provider gateway, first you must create an Active Standby tier-0 gateway in the NSX Manager associated with the region to back it.". Provider gateways in VCF Automationare discovered from these preexisting Tier-0 gatewaysand cannot be created until they exist.
Creating a Tier-1 gateway (Option B) does not satisfy the requirement because Provider Gateways must map specifically toTier-0, not Tier-1. Retrying the workflow (Option D) will not resolve the issue because the Tier-
0 backing resource is missing. Creating a new region (Option A) is unnecessary unless required for other organizational reasons, and it still would not produce a Tier-0 gateway.
Therefore, the correct and verified solution is tolog in to NSX Manager and create the required Tier-0 gateway, after which it will appear in the Provider Gateway creation workflow.
NEW QUESTION # 45
An administrator logs into the vSphere client to check the health of a cluster. An alert appears on the cluster stating, "vSphere HA host status".
The administrator toggles vSphere HA off and on and the following error appears on the host "A general system error occurred: Failed to start fdm service on host".
What is the cause of this issue?
  • A. The vmware-fdm vib is missing from the ESX host.
  • B. vSphere HA startup policy is not configured correctly.
  • C. vSphere HA Admission Control settings are not configured correctly.
  • D. The vmware-fdm service is disabled on the ESX host.
vSphere High Availability (HA) depends on theFDM agent(Fault Domain Manager) that runs on every ESXi host in the cluster. When an administrator enables HA on a cluster, vCenter automatically installs or updates thevmware-fdm VIBon each participating ESXi host. This VIB contains the HA agent binaries and is mandatory for HA services to start.
The error encountered:
is a classic and well-documented symptom of amissing or corrupted vmware-fdm VIB. When vSphere HA is toggled off and on, vCenter attempts to reinstall or restart the FDM agent; if the VIB is not present, HA cannot deploy successfully, and the FDM service fails to start.
Why the other answers are incorrect:
* A. The vmware-fdm service is disabledESXi does not allow manual disabling of this system service in normal operations. If the service fails to start, the root cause is usually the absence or corruption of the VIB-not a disabled service.
* C. Admission Control settings not configured correctlyAdmission Control errors affectVM failover capacity, not the ability to start FDM services.
* D. HA startup policy not configured correctlyThere isno per-host HA startup policythat prevents FDM from starting.
NEW QUESTION # 46
An administrator has created an alarm for an object in VMware Cloud Foundation (VCF) Operations. The alert does not show up In the alert pane despite being configured on the object.
Parameters:
* Symptom definition: Read Latency (ms) is higher than 1 ms.
* Alert definition: Alert is triggered as soon as the latency is higher than the 1 ms defined in the symptom definition.
* Object type: Virtual Machine.
What is the reason the alert does not show up in the alert view?
  • A. The administrator is missing the privileges to view alerts for this object.
  • B. The metric used in the symptom definition does not apply to this object type.
  • C. This type of alert must be forwarded from VMware Cloud Foundation Operations for Logs.
  • D. The alert is not enabled in the policy.
In VMware Cloud Foundation 9.0, VCF Operations (vROps-based) usespoliciesto control which alerts, symptoms, and metrics are evaluated for a given object. Creating an alert definition and symptom alone is not sufficient; the alert must beassociated with and enabled in a policythat is actively applied to the target object (in this case, a Virtual Machine). The documentation shows that when you create an alert definition, there is an explicitPolicies step, where you select the policy (for example, the default policy) so that the alert becomes active for objects governed by that policy.
The metric "Read Latency (ms)" is valid for virtual-machine-related objects: VCF Operations documents Read Latency metrics at the VM disk and VM-datastore link level (for Disk and Datastore metrics on Virtual Machines). Therefore, option B (metric not applicable) is incorrect. No requirement exists that such a performance alert must be forwarded from VCF Operations for Logs (D); log-based alerts are a separate alert type.
If the alert definition is not enabled in the effective policy for that VM, VCF Operations will not evaluate the symptom or generate the alert, and it will not appear in the alert pane-even though the definition technically exists. This matches optionCexactly.
NEW QUESTION # 47
An administrator is managing a VMware Cloud Foundation (VCF) environment. They receive a request from the developers to enable vDefend - Distributed Firewall. However, they noticed It cannot be enabled due to a missing license.
Where must the new license be applied?
  • A. SDDC Manager.
  • B. NSX Manager.
  • C. VCF Operations.
  • D. VCF Automation.
vDefend - Distributed Firewall is a security capability delivered byNSXwithin VMware Cloud Foundation.
Although VCF components such as SDDC Manager, VCF Operations, and VCF Automation rely on licensing frameworks, the enforcement and activation ofNSX features-including Distributed Firewall-occur entirely withinNSX Manager.
To enablevDefend (Distributed Firewall), NSX Manager must detect a valid NSX license that includes security features. Without applying the correct license directly to NSX Manager:
* The Distributed Firewall feature remains locked
* vDefend cannot be enabled in workload domains
* Security rules and micro-segmentation capability remain unavailable
VCF does not apply NSX security licensing at the SDDC Manager, VCF Automation, or VCF Operations layers. Instead, NSX Manager handles all feature entitlement checks internally.
Therefore, the new license must be installeddirectly in NSX Manager, under:
System # Licensing # NSX # Add License
Options A, C, and D are incorrect because none of those components control NSX feature activation.
NEW QUESTION # 48
An administrator is creating an additional Organization for All Apps within VMware Cloud Foundation (VCF) Automation.
After logging into the VCF Automation Provider Management Portal UI, the administrator is only able to create new Organizations for All Apps.
What action can the administrator take to resolve the issue and complete the task?
  • A. Enable the creation of new Organization for VM Apps feature in the Provider Management Portal UI.
  • B. Create the new Organization for VM Apps using the VCF Automation API.
  • C. Delete the existing Organization for VM Apps using the VCF Automation API.
  • D. Delete any existing Organizations for All Apps from the Provider Management Portal UI.
In VMware Cloud Foundation (VCF) 9.0 Automation,Provider Administratorsmanage which types of Organizations can be created:
* VM Apps Organizations
* All Apps Organizations
These capabilities are controlled byFeature Flagswithin theVCF Automation Provider Management Portal
. If the administrator logs in and only sees the ability to createAll Apps Organizations, it means that the feature flag enablingVM Apps Organization creationhas not been turned on.
VCF Automation requires the Provider Admin to explicitly enable creation ofVM Apps Organizations, because doing so exposes VM-centric consumption models and allows the environment to differentiate between VM-only and hybrid (VM + Kubernetes) application deployments.
Therefore, the administrator simply needs to navigate to:
Provider Management Portal # Administration # Feature Flags # Enable "Create VM Apps Organizations" Option A (creating via API) is unnecessary-the UI will support it once the feature is enabled.
Option B (deleting existing VM Apps orgs) has no effect on feature availability.
Option C (deleting All Apps orgs) is unrelated and would not unlock VM Apps org creation.
NEW QUESTION # 49
2V0-15.25 certifications establish your professional worth beyond your estimation. Procuring 2V0-15.25 certification is to make sure an extensive range of opportunities in the industry and doubling your present earning prospects. VCEEngine 2V0-15.25 Practice Test dumps provide you the best practical pathway to obtain the most career-enhancing, 2V0-15.25 certification.
2V0-15.25 Exam Book: https://www.vceengine.com/2V0-15.25-vce-test-engine.html
After the clients pay successfully for the 2V0-15.25 exam dump they can immediately receive our products in the form of mails in 5-10 minutes and then click on the links to use our software to learn, Many people choose to sign up for the VMware 2V0-15.25 certification examinations in order to advance their knowledge and abilities, If you want to have a try before you pay for the 2V0-15.25 exam braindumps, you can free download the demos which contain a small part of questions from the 2V0-15.25 practice materials.
Both had been involved in enterprise architecture efforts that 2V0-15.25 had faltered and failed, Learn the steps of creating a functional website called iFriends, After the clients pay successfully for the 2V0-15.25 Exam Dump they can immediately receive our products in the form of mails in 5-10 minutes and then click on the links to use our software to learn.
Reliable 2V0-15.25 Exam Cram - Your Sharpest Sword to Pass VMware Cloud Foundation 9.0 SupportMany people choose to sign up for the VMware 2V0-15.25 certification examinations in order to advance their knowledge and abilities, If you want to have a try before you pay for the 2V0-15.25 exam braindumps, you can free download the demos which contain a small part of questions from the 2V0-15.25 practice materials.
No one wants to own insipid life, Reliable 2V0-15.25 Exam Cram Our top-notched services are always here to back our promises.
