[General] Valid Exam SAP-C02 Blueprint | Certification SAP-C02 Test Answers
18
General Valid Exam SAP-C02 Blueprint | Certification SAP-C02 Test Answers
Posted at 4/19/2026 18:41:49      View104 | Replies0        Print      Only Author   [Copy Link] 1#
What's more, part of that ValidVCE SAP-C02 dumps now are free: https://drive.google.com/open?id=1BhSVMlgedB3GacOkZbDV6dLnKYylPNV7
Computer brings more convenience, online access to information, published an article, watch movies, online remote virtual learning and other benefits. IT workers are becoming high-salary field in all over the world. ValidVCE releases latest and valid SAP-C02 Exam preparations to help candidates clear exams certainly as Amazon certifications are outstanding and attractive. If you determine to take part in exams, our SAP-C02 exam preparations will be a good helper.
Our SAP-C02 learn materials include all the qualification tests in recent years, as well as corresponding supporting materials. Such a huge amount of database can greatly satisfy users' learning needs. Not enough valid SAP-C02 test preparation materials, will bring many inconvenience to the user, such as delay learning progress, these are not conducive to the user pass exam, therefore, in order to solve these problems, our SAP-C02 Certification material will do a complete summarize and precision of summary analysis to help you pass the SAP-C02 exam with ease.
Certification SAP-C02 Test Answers | SAP-C02 Valid Test FormatOur SAP-C02 study materials are compiled and tested by our expert. SAP-C02 try hard to makes SAP-C02 exam preparation easy with its several quality features. We send learning information in the form of questions and answers, and our SAP-C02 study materials are highly relevant to what you need to pass SAP-C02 certification exam. Our free demo will show you the actual SAP-C02 Certification Exam. You can learn about real exams in advance by studying our SAP-C02 study materials and improve your confidence in the exam so that you can pass SAP-C02 exams with ease. This is also the reason that has been popular by the majority of candidates.
Amazon AWS Certified Solutions Architect - Professional (SAP-C02) Sample Questions (Q354-Q359):NEW QUESTION # 354
Question:
How should EC2 instances in AWS synchronize their clocks with an on-premisesatomic clock NTP server, with theleast administrative overhead?
  • A. Create an IPsec VPN tunnel to sync over Direct Connect.
  • B. Deploy a 3rd-party NTP server from Marketplace.
  • C. Configure a DHCP options set with the on-prem NTP server.
  • D. Use a custom AMI with Amazon Time Sync.
Option Ais the most lightweight and scalable approach. By updating the VPC'sDHCP options set, you automatically configure all EC2 instances to use your on-premises NTP server. No extra software or infrastructure is required.
#VPC DHCP Options Docs
NEW QUESTION # 355
A company runs a microservice as an AWS Lambda function. The microservice writes data to an on-premises SQL database that supports a limited number of concurrent connections. When the number of Lambda function invocations is too high, the database crashes and causes application downtime. The company has an AWS Direct Connect connection between the company's VPC and the on-premises data center. The company wants to protect the database from crashes.
Which solution will meet these requirements?
  • A. Create a new Amazon Aurora Serverless DB cluster. Use AWS DataSync to migrate the data from the existing database to Aurora Serverless. Reconfigure the Lambda function to write to Aurora.
  • B. Create an Amazon RDS Proxy DB instance. Attach the RDS Proxy DB instance to the Amazon RDS DB instance. Reconfigure the Lambda function to write to the RDS Proxy DB instance.
  • C. Write the data to an Amazon Simple Queue Service (Amazon SQS) queue. Configure the Lambda function to read from the queue and write to the existing database. Set a reserved concurrency limit on the Lambda function that is less than the number of connections that the database supports.
  • D. Write the data to an Amazon Simple Notification Service (Amazon SNS) topic. Invoke the Lambda function to write to the existing database when the topic receives new messages. Configure provisioned concurrency for the Lambda function to be equal to the number of connections that the database supports.
Apparently, we need to make the lambda "not to rush that much" and keep the connection within the limit of the on-pre DB. So if we want not to lose data while waiting we implement SQS before the lambda so it keeps the requests in the queue.
NEW QUESTION # 356
A company recently completed the migration from an on-premises data center to the AWS Cloud by using a replatforming strategy. One of the migrated servers is running a legacy Simple Mail Transfer Protocol (SMTP) service that a critical application relies upon. The application sends outbound email messages to the company's customers. The legacy SMTP server does not support TLS encryption and uses TCP port 25. The application can use SMTP only. The company decides to use Amazon Simple Email Service (Amazon SES) and to decommission the legacy SMTP server. The company has created and validated the SES domain. The company has lifted the SES limits.
What should the company do to modify the application to send email messages from Amazon SES?
  • A. Configure the application to connect to Amazon SES by using TLS Wrapper. Create an IAM role that has ses:SendEmail and ses:SendRawEmail permissions. Attach the IAM role to an Amazon EC2 instance.
  • B. Configure the application to use AWS SDKs to send email messages. Create an IAM user for Amazon SES. Generate API access keys. Use the access keys to authenticate with Amazon SES.
  • C. Configure the application to use the SES API to send email messages. Create an IAM role that has ses:SendEmail and ses:SendRawEmail permissions. Use the IAM role as a service role for Amazon SES.
  • D. Configure the application to connect to Amazon SES by using STARTTLS. Obtain Amazon SES SMTP credentials. Use the credentials to authenticate with Amazon SES.
In this scenario, you should use Amazon SES SMTP interface to send emails because the application can use SMTP only.
https://docs.aws.amazon.com/ses/latest/dg/send-email-smtp.html
https://docs.aws.amazon.com/ses/latest/dg/smtp-credentials.html
https://docs.aws.amazon.com/ses/latest/dg/smtp-connect.html
NEW QUESTION # 357
A digital marketing company has multiple AWS accounts that belong to various teams. The creative team uses an Amazon S3 bucket in its AWS account to securely store images and media files that are used as content for the company's marketing campaigns. The creative team wants to share the S3 bucket with the strategy team so that the strategy team can view the objects.
A solutions architect has created an IAM role that is named strategy_reviewer in the Strategy account. The solutions architect also has set up a custom AWS Key Management Service (AWS KMS) key in the Creative account and has associated the key with the S3 bucket. However, when users from the Strategy account assume the IAM role and try to access objects in the S3 bucket, they receive an Account. The solutions architect must ensure that users in the Strategy account can access the S3 bucket. The solution must provide these users with only the minimum permissions that they need.
Which combination of steps should the solutions architect take to meet these requirements?
(Choose three.)
  • A. Create a bucket policy that includes read permissions for the S3 bucket.
    Set the principal of the bucket policy to the account ID of the Strategy account
  • B. Update the custom KMS key policy in the Creative account to grant decrypt permissions to the strategy_reviewer IAM role.
  • C. Update the strategy_reviewer IAM role to grant full permissions for the S3 bucket and to grant decrypt permissions for the custom KMS key.
  • D. Create a bucket policy that includes read permissions for the S3 bucket.
    Set the principal of the bucket policy to an anonymous user.
  • E. Update the custom KMS key policy in the Creative account to grant encrypt permissions to the strategy_reviewer IAM role.
  • F. Update the strategy_reviewer IAM role to grant read permissions for the S3 bucket and to grant decrypt permissions for the custom KMS key
Answer: A,B,F
https://aws.amazon.com/premiumsu ... ccess-denied-error- s3/ In addition to the url above, you can eliminate the 3 of the answers easily:
B- wrong becuase of the "full access"
D- wrong because of the "anonymous user"
E- wrong because of the "encrypt" - u need decrypt permission
NEW QUESTION # 358
A company has an Amazon VPC that is divided into a public subnet and a pnvate subnet. A web application runs in Amazon VPC. and each subnet has its own NACL The public subnet has a CIDR of 10.0.0 0/24 An Application Load Balancer is deployed to the public subnet The private subnet has a CIDR of 10.0.1.0/24. Amazon EC2 instances that run a web server on port 80 are launched into the private subnet Onty network traffic that is required for the Application Load Balancer to access the web application can be allowed to travel between the public and private subnets What collection of rules should be written to ensure that the private subnet's NACL meets the requirement? (Select TWO.)
  • A. An outbound rule for port 80 to destination 10.0.0.0/24
  • B. An outbound rule for ports 1024 through 65535 to destination 10.0.0.0/24
  • C. An inbound rule for port 80 from source 10.0 0 0/24
  • D. An outbound rule for port 80 to destination 0.0.0.0/0
  • E. An inbound rule for port 80 from source 0.0 0.0/0
Ephemeral ports are not covered in the syllabus so be careful that you don't confuse day to day best practise with what is required for the exam. Link to an explanation on Ephemeral ports here. https://acloud.guru/forums/aws-c ... cls-ephemeral-ports
NEW QUESTION # 359
When we choose to find a good job, there is important to get the SAP-C02 certification as you can. There is a fabulous product to prompt the efficiency--the SAP-C02 exam prep, as far as concerned, it can bring you high quality learning platform to pass the variety of exams. Our product is elaborately composed with major questions and answers. It only takes you 20 hours to 30 hours to do the practice. After your effective practice, you can master the examination point from the SAP-C02 Test Question. Then, you will have enough confidence to pass it.
Certification SAP-C02 Test Answers: https://www.validvce.com/SAP-C02-exam-collection.html
Amazon Valid Exam SAP-C02 Blueprint Instead, purchase Unlimited Access Megapack, and get unlimited access to ALL Questions and Answers, As job seekers looking for the turning point of their lives, it is widely known that the workers of recruitment is like choosing apples---viewing resumes is liking picking up apples, employers can decide whether candidates are qualified by the SAP-C02 appearances, or in other words, candidates educational background and relating SAP-C02 professional skills, ValidVCE Certification SAP-C02 Test Answers Real Career Booster!
A visitor should never have to figure out how to use your navigation Latest Braindumps SAP-C02 Book system, where they are in the site, or whether they are still in your web site or have jumped somewhere else.
When you use it on a spotlight, the light has three manipulators instead SAP-C02 Valid Test Format of oneone to move the light, Instead, purchase Unlimited Access Megapack, and get unlimited access to ALL Questions and Answers!
Reliable Valid Exam SAP-C02 Blueprint & Passing SAP-C02 Exam is No More a Challenging TaskAs job seekers looking for the turning point of their lives, it SAP-C02 is widely known that the workers of recruitment is like choosing apples---viewing resumes is liking picking up apples,employers can decide whether candidates are qualified by the SAP-C02 appearances, or in other words, candidates educational background and relating SAP-C02 professional skills.
ValidVCE Real Career Booster, I believe every candidate wants to buy SAP-C02 exam materials that with a high pass rate, because the data show at least two parts of the SAP-C02 exam guide, the quality and the validity.
However, proper planning, firm commitment, and complete real Amazon SAP-C02 Exam QUESTIONS preparation can enable you to crack the final SAP-C02 exam easily.
P.S. Free & New SAP-C02 dumps are available on Google Drive shared by ValidVCE: https://drive.google.com/open?id=1BhSVMlgedB3GacOkZbDV6dLnKYylPNV7
