Free PDF F5 - F5CAB2¨CReliable Latest Braindumps Book
24
Posted at 4/19/2026 19:24:03      View£º112 | Replies£º0        Print      Only Author   [Copy Link] 1#
P.S. Free & New F5CAB2 dumps are available on Google Drive shared by DumpsTests: https://drive.google.com/open?id=1I_ryWanMQ-F9P7Pv1yEolsyebB37ngyI
It is a truth universally acknowledged that the exam is not easy but the related F5CAB2 certification is of great significance for workers in this field so that many workers have to meet the challenge, I am glad to tell you that our company aims to help you to pass the examination as well as gaining the related certification in a more efficient and simpler way. During recent 10 years, our F5CAB2 Exam Questions have met with warm reception and quick sale in the international market. Our F5CAB2 study materials are not only as reasonable priced as other makers, but also they are distinctly superior in the following respects.
F5 F5CAB2 Exam Syllabus Topics:
  • Explain the relationship between interfaces, trunks, VLANs, self-IPs, routes and
  • their status
  • statistics: This domain covers BIG-IP networking components including interfaces, trunks, VLANs, self-IPs, and routes, their dependencies and status, plus predicting traffic paths and egress IPs.
  • Determine expected traffic behavior based on configuration: This domain focuses on predicting traffic behavior based on persistence, processing order, object status, egress IPs, and connection
  • rate limits.
  • Define ADC application objects: This domain covers ADC basics including application objects, load balancing methods, server selection, and key ADC features and benefits.
Topic 5
  • Explain high availability (HA) concepts: This domain addresses HA concepts including integrity methods, implementation approaches, and advantages of high availability configurations.
F5CAB2 Latest Braindumps Files | Latest F5CAB2 Exam ReviewUsing DumpsTests's F5CAB2 test certification training materials to pass F5CAB2 certification exam is easy. Our F5CAB2 test certification training materials is made up of senior IT specialist team through their own exploration and continuous practice and research. Our DumpsTests's F5CAB2 test certification training materials can help you in your first attempt to pass F5CAB2 exam easily.
F5 BIG-IP Administration Data Plane Concepts (F5CAB2) Sample Questions (Q65-Q70):NEW QUESTION # 65
A BIG-IP Administrator makes a configuration change to a Virtual Server on the Standby device of an HA pair. The HA pair is currently configured with Auto-Sync enabled. What effect will the change have on the HA pair configuration? (Choose one answer)
  • A. The change will be propagated next time a configuration change is made on the Active device.
  • B. The change will take effect when Auto-Sync propagates the config to the HA pair.
  • C. The change will be undone next time a configuration change is made on the Active device.
  • D. The change will be undone when Auto-Sync propagates the config to the Standby device.
Comprehensive and Detailed Explanation From BIG-IP Administration Data Plane Concepts documents:
In a BIG-IP high availability (HA) configuration, Auto-Sync is a device trust feature that automatically synchronizes configuration changes from the Active device to the Standby device within a Sync-Failover device group.
Key principles from BIG-IP Administration Data Plane Concepts:
The Active device is always the authoritative source of configuration
Configuration changes are intended to be made only on the Active device With Auto-Sync enabled, any time the Active device configuration changes, the system automatically pushes the configuration to all Standby members of the device group Configuration changes made directly on a Standby device are not preserved In this scenario:
The administrator modifies a Virtual Server on the Standby device
That change is local only and does not alter the device group's synchronized configuration When Auto-Sync next runs (triggered by a change on the Active device or an internal sync event), the Active device configuration overwrites the Standby configuration As a result, the configuration change made on the Standby device is undone.
Why the Other Options Are Incorrect:
A - The change is not undone only when another change is made; it is undone during the next Auto-Sync operation B - Changes made on the Standby device are never propagated to the Active device D - Auto-Sync does not merge or promote Standby changes into the HA pair configuration Best Practice Reinforced:
Always perform configuration changes on the Active BIG-IP device when Auto-Sync is enabled to ensure consistent and predictable HA behavior.
NEW QUESTION # 66
During a planned upgrade to a BIG-IP HA pair running Active/Standby, an outage to application traffic is reported shortly after the Active unit is forced to Standby. Reverting the failover resolves the outage. What should the BIG-IP Administrator modify to avoid an outage during the next failover event? (Choose one answer)
  • A. The Tag value on the Active device
  • B. The Tag value on the Standby device
  • C. The interface on the Active device to 1.1
  • D. The Interface on the Standby device to 1.1
Comprehensive and Detailed Explanation (BIG-IP Administration - Data Plane Concepts):
In an Active/Standby BIG-IP design, application availability during failover depends on both units having equivalent data-plane connectivity for the networks that carry application traffic. Specifically:
VLANs are bound to specific interfaces (and optionally VLAN tags).
Floating self IPs / traffic groups move to the new Active device during failover.
For traffic to continue flowing after failover, the new Active device must have the same VLANs available on the correct interfaces that connect to the upstream/downstream networks.
What the symptom tells you:
Traffic works when Device A is Active
Traffic fails when Device B becomes Active
Failback immediately restores traffic
This pattern strongly indicates the Standby unit does not have the VLAN connected the same way (wrong physical interface assignment), so when it becomes Active, it owns the floating addresses but cannot actually pass traffic on the correct network segment.
Why Interface mismatch is the best match:
If the Active unit is already working, its interface mapping is correct.
The fix is to make the Standby unit's VLAN/interface assignment match the Active unit.
That corresponds to changing the Standby device interface to 1.1.
Why the Tag options are less likely here (given the choices and the exhibit intent):
Tag issues can also break failover traffic, but the question/options are clearly driving toward the classic HA requirement: consistent VLAN-to-interface mapping on both devices so the data plane remains functional after the traffic group moves.
Conclusion: To avoid an outage on the next failover, the BIG-IP Administrator must ensure the Standby device uses the same interface (1.1) for the relevant VLAN(s) that carry the application traffic, so when it becomes Active it can forward/receive traffic normally.
NEW QUESTION # 67
The BIG-IP Administrator needs to ensure that if a pool member is marked down by the monitor, the BIG-IP system sends existing connections to another available pool member. Which task should the BIG-IP Administrator perform to meet this goal?
  • A. Set Action on Service Down setting under the Virtual Server configuration to reselect
  • B. Reconfigure the pool monitor to mark the member as UP
  • C. Set Action on Service Down setting under the pool configuration to reselect
  • D. Enable mirroring within the persistence profile
By default, when a pool member is marked "down" by a monitor, the BIG-IP system stops sendingnew connections to that member, but it typically allows existing connections to time out naturally (or resets them depending on profile settings).
* Action on Service Down:This setting is configured at thePoollevel.
* Reselect:When set toReselect, if a pool member is marked down, the BIG-IP system will immediately attempt to pick a different available pool member for any existing, active connections associated with the failed member.
* Client Experience:This is used to maintain the user session by transparently moving the traffic to a healthy server without the client needing to re-establish the connection to the Virtual Server.
NEW QUESTION # 68
Which statement is true concerning the default communication between a redundant pair of BIG-IP devices?
  • A. Connection mirroring data is shared through the serial fail over cable unless network failover is enabled.
  • B. Data for both connection and persistence mirroring are shared through the same TCP connection.
  • C. Communication between the systems cannot be effected by port lockdown settings.
  • D. Regardless of the configuration, some data is communicated between the systems at regular intervals.
NEW QUESTION # 69
What type of virtual server should be used to load balance UDP traffic without considering previous connections?
  • A. Reject
  • B. Forwarding
  • C. Stateless
  • D. Standard
NEW QUESTION # 70
The privacy protection of users is an eternal issue in the internet age. Many illegal websites will sell users' privacy to third parties, resulting in many buyers are reluctant to believe strange websites. But you don't need to worry about it at all when buying our F5CAB2 study materials. We assure you that we will never sell users¡¯ information because it is damaging our own reputation. In addition, when you buy our F5CAB2 Study Materials, our website will use professional technology to encrypt the privacy of every user to prevent hackers from stealing.
F5CAB2 Latest Braindumps Files: https://www.dumpstests.com/F5CAB2-latest-test-dumps.html
