C_ADBTP_2601 Exam Price | C_ADBTP_2601 Latest Study Plan
Posted at 4/19/2026 23:38:27
View174
Replies0
SAP C_ADBTP_2601 practice test software is compatible with windows and the web-based software will work on these operating systems: Android, IOS, Windows, and Linux. Chrome, Opera, Internet Explorer, Microsoft Edge, and Firefox also support the web-based C_ADBTP_2601 Practice Test software.
The SAP C_ADBTP_2601 certification exam is one of the top-rated and valuable credentials in the SAP world. This SAP C_ADBTP_2601 certification exam is designed to validate a candidate's skills and knowledge. With SAP C_ADBTP_2601 Certification Exam everyone can upgrade their expertise and knowledge level.
C_ADBTP_2601 Exam Price, SAP C_ADBTP_2601 Latest Study Plan: Administrating SAP Business Technology Platform(C_ADBTP_2601) Pass CertifyDumpExam is a wonderful study platform that contains our hearty wish for you to pass the exam by our C_ADBTP_2601 exam materials. So our responsible behaviors are our instinct aim and tenet. By devoting in this area so many years, we are omnipotent to solve the problems about the C_ADBTP_2601 learning questions with stalwart confidence. we can claim that only studing our C_ADBTP_2601 study guide for 20 to 30 hours, then you will pass the exam for sure.
SAP Administrating SAP Business Technology Platform(C_ADBTP_2601) Sample Questions (Q10-Q15):NEW QUESTION # 10
SIMULATION
Enable a Cloud Foundry Environment
Add a service plan for Cloud Foundry environment and enable it in a subaccount.
Task 1: Add a Service Plan for Cloud Foundry Environment
In your SAP BTP cockpit, in your EU HCM Dev subaccount, entitle one MEMORY service plan for the Cloud Foundry Runtime.
See the Explanation below for complete solution.
Before you start
Log in to SAP BTP Cockpit.
Open your correct Global Account.
Go to the Human Resources directory.
Open the EU HCM Dev subaccount.
This matters because the runtime memory quota must be assigned to the EU HCM Dev subaccount specifically. SAP documents that the MEMORY plan is the quota-bearing plan for Cloud Foundry Runtime.
Step 1 - Open the EU HCM Dev subaccount
In the cockpit, choose Directories.
Open Human Resources.
Select EU HCM Dev.
You should now be on the EU HCM Dev subaccount page.
Step 2 - Open Entitlements
In EU HCM Dev, choose Entitlements.
SAP Help confirms that service plans and quota assignments for a subaccount are configured in the Entitlements area.
Step 3 - Configure entitlements
Click Configure Entitlements or Add Service Plans.
Search for:
In SAP Help, this appears as Cloud Foundry Runtime (APPLICATION_RUNTIME), and the relevant plan for assigning runtime memory is MEMORY.
Step 4 - Select the MEMORY plan
Under Cloud Foundry Runtime, select:
MEMORY
Set the quantity to 1 if the cockpit shows an amount/quota field.
Add the plan to the subaccount.
Save the entitlement changes.
SAP documents that the MEMORY plan is specifically used to assign runtime memory quota to the subaccount, and that 1 unit corresponds to 1 GB of runtime memory when quota is adjusted or assigned.
Step 5 - Verify the result
After saving, check the Entitlements page of EU HCM Dev.
You should see:
plan: MEMORY
quantity: 1 if shown
Final expected result
Inside EU HCM Dev:
Cloud Foundry Runtime is entitled
the service plan is MEMORY
the assigned amount is 1 if the cockpit displays quantity/quota units
Common mistakes to avoid
Doing this in the wrong subaccount; it must be EU HCM Dev
Choosing the wrong Cloud Foundry plan; the task asks for MEMORY
Forgetting to save the entitlement change after adding the plan
Confusing the runtime memory entitlement with the later step of actually enabling the Cloud Foundry environment; SAP distinguishes the MEMORY runtime quota from enabling the Cloud Foundry org itself.
NEW QUESTION # 11
SIMULATION
Create Directories and Subaccounts
In a global account for SAP Business Technology Platform (BTP), create a hierarchy of subaccounts using directories.
Task 1: Create Directories
In your SAP BTP cockpit, create the directory Americas (Description: Americas Accounts) with your global account as the parent.
Create the directory Eurasia (Description: Eurasia Accounts) with your global account as the parent.
Create the directory Partner (Description: Partner Accounts) with the Americas directory as the parent. Add the label access with value external.
Create the directory Human Resources (Description: Human Resources Accounts) with the Eurasia directory as the parent. Add the label access with value internal.
You need to create these directories:
Americas
Eurasia
Partner under Americas with label access=external
Human Resources under Eurasia with label access=internal
Before You Start
Log in to the SAP BTP Cockpit.
Make sure you are inside the correct Global Account.
Open the left-side navigation menu.
Why this is important:
All directories in this task must be created inside the correct global account hierarchy. If you create them in the wrong location, the simulation result will be incorrect.
Step 1 - Create Directory Americas
What to do
In the SAP BTP Cockpit, select your Global Account.
In the left navigation menu, click Directories.
Click Create or Create Directory.
Fill the fields as follows:
Parent: your Global Account
Click Create.
This creates a top-level directory directly under the global account.
It will later be used as the parent for the Partner directory.
What to verify
After creation, you should see:
Americas
listed under the directories of the global account.
Step 2 - Create Directory Eurasia
What to do
Stay in Directories.
Click Create Directory again.
Fill the fields:
Click Create.
This creates another top-level directory, parallel to Americas.
What to verify
You should now see both:
Americas
Eurasia
Step 3 - Create Directory Partner under Americas
What to do
In the Directories area, select Americas.
Click Create Directory.
Enter:
Parent: Americas
Locate the Labels section.
Add a new label:
Key: access
Value: external
Click Create.
This creates Partner as a child directory under Americas.
The label is required and must be entered exactly:
access = external
This label helps classify the directory.
What to verify
Under Americas, you should now see:
Partner
and the directory should contain the label:
access=external
Step 4 - Create Directory Human Resources under Eurasia
What to do
Go back to the Directories list.
Select Eurasia.
Enter:
Name: Human Resources
Parent: Eurasia
In the Labels section, add:
Key: access
Value: internal
Click Create.
This creates Human Resources as a child directory under Eurasia.
The required label is:
access = internal
What to verify
Under Eurasia, you should now see:
Human Resources
and the label should be:
access=internal
Final Expected Directory Structure
After completing Task 1, your structure must be exactly like this:
Global Account
Americas
Partner
Label: access=external
Eurasia
Human Resources
Label: access=internal
Important Checks Before Moving On
Verify all of the following:
Americas exists
Eurasia exists
Partner is under Americas
Human Resources is under Eurasia
Partner has label access=external
Human Resources has label access=internal
All names and descriptions are entered exactly as required
Common Mistakes to Avoid
1. Wrong parent
Partner must be created under Americas
Human Resources must be created under Eurasia
2. Wrong label key or value
Use exactly:
access external
access internal
3. Spelling errors
Be careful with:
Americas
Eurasia
Partner
Human Resources
4. Creating all directories directly under the global account
Only Americas and Eurasia are direct children of the global account.
Partner and Human Resources must be child directories.
NEW QUESTION # 12
SIMULATION
Task 3: Create Subaccounts with Default Provider and Region
In the Human Resources directory, create the subaccount EU HCM Dev (Description: Human Resources Development) with subdomain btpops####-eu-hcm-dev in the region Amazon Web Services (AWS) Europe (Frankfurt) cf-eu10.2.
In the Human Resources directory, create the subaccount EU HCM Test (Description: Human Resources Testing) with subdomain btpops####-eu-hcm-test using EU HCM Dev as source subaccount.3.
In the Human Resources directory, create the subaccount EU HCM Prod (Description: Human Resources Production) with subdomain btpops####-eu-hcm-prod using EU HCM Dev as source subaccount. Set the subaccount as used in production.
You must create these 3 subaccounts inside the Human Resources directory:
EU HCM Dev
EU HCM Test
EU HCM Prod
Important:
Replace #### with your global account number
Enter names, descriptions, and subdomains exactly
EU HCM Prod must be marked as used in production
Task 3 - Create Subaccounts with Default Provider and Region
Before You Start
Open the correct Global Account.
Go to Directories.
Open the Human Resources directory.
Why this matters:
All 3 subaccounts in this task must be created inside Human Resources. If you create them anywhere else, the result will be incorrect.
Step 1 - Open the Human Resources Directory
What to do
In the left menu, choose Directories.
In the list, select Human Resources.
This is the parent directory where the required HR subaccounts must be created.
What to verify
You should now be inside the Human Resources directory.
Step 2 - Start Creating EU HCM Dev
What to do
Inside Human Resources, open Subaccounts.
Click Create Subaccount.
This opens the form to create the first HR subaccount.
Step 3 - Enter Values for EU HCM Dev
What to do
Enter the following:
Display Name / Name: EU HCM Dev
Subdomain: btpops####-eu-hcm-dev
Set the region as:
Cloud Provider: Amazon Web Services (AWS)
Region: Europe (Frankfurt)
Technical Region / Environment: cf-eu10
Then click Create.
This creates the development subaccount for HR and defines the required provider and region.
This first subaccount is important because it will be used as the source subaccount for the next two subaccounts.
What to verify
EU HCM Dev
under the Human Resources directory.
Step 4 - Confirm EU HCM Dev Exists
What to do
Check the subaccounts list in Human Resources.
You must make sure EU HCM Dev is available before you create the next subaccounts, because both EU HCM Test and EU HCM Prod must use it as the source subaccount.
What to verify
You should see:
EU HCM Dev
If it is missing, create it correctly before moving on.
Step 5 - Start Creating EU HCM Test
What to do
Still in the Human Resources directory, click Create Subaccount again.
This opens the form for the test subaccount.
Step 6 - Enter Values for EU HCM Test
What to do
Enter:
Display Name / Name: EU HCM Test
Subdomain: btpops####-eu-hcm-test
Then select:
Source Subaccount: EU HCM Dev
Then click Create.
This creates the testing subaccount by using EU HCM Dev as the source subaccount.
This helps keep the configuration aligned with the development subaccount.
What to verify
EU HCM Test
under Human Resources.
Step 7 - Start Creating EU HCM Prod
What to do
In Human Resources, click Create Subaccount once more.
This opens the form for the production subaccount.
Step 8 - Enter Values for EU HCM Prod
What to do
Enter:
Display Name / Name: EU HCM Prod
Subdomain: btpops####-eu-hcm-prod
Then select:
Enable:
Used in Production: Yes
Then click Create.
This creates the production HR subaccount based on EU HCM Dev and marks it as a production system.
The production setting is mandatory here.
What to verify
EU HCM Prod
under Human Resources, and it should be marked as used in production.
Final Expected Result for Task 3
Inside the Human Resources directory, you must have these 3 subaccounts:
1. EU HCM Dev
Region: Amazon Web Services (AWS) Europe (Frankfurt) cf-eu10
2. EU HCM Test
3. EU HCM Prod
1. Creating the subaccounts in the wrong directory
All 3 must be created inside:
Human Resources
Not under:
Global Account
Americas
Eurasia
Partner
2. Wrong subdomain values
Use exactly:
Only replace #### with your global account number.
3. Wrong region for EU HCM Dev
It must be:
Europe (Frankfurt)
cf-eu10
4. Wrong source subaccount
For both:
EU HCM Test
EU HCM Prod
you must select:
EU HCM Dev
5. Forgetting the production flag
For EU HCM Prod, make sure:
Used in Production is enabled
NEW QUESTION # 13
SIMULATION
Task 2: Create Subaccounts in a Directory
In the Partner directory, create the subaccount AM PA Dev Test (Description: Partner Development and Testing) with subdomain btpops####-am-pa-dev-test in the region Microsoft Azure US West (WA) cf-us20.
In the Partner directory, create the subaccount AM PA Prod (Description: Partner Production) with subdomain btpops####-am-pa-prod using AM PA Dev Test as source subaccount. Set the subaccount as used in production.
Task 2 - Create Subaccounts in a Directory
You must create these two subaccounts inside the Partner directory:
AM PA Dev Test
AM PA Prod
Important:
Enter all names and subdomains exactly
Be careful with hyphens and spaces
AM PA Prod must be marked as used in production
Before You Start
Go to Directories.
Open the Partner directory.
Why this matters:
Both subaccounts in this task must be created inside the Partner directory. If you create them under the global account or another directory, the task will be wrong.
Step 1 - Open the Partner Directory
What to do
In the left menu, click Directories.
In the directory list, select Partner.
The Partner directory is the container where both required subaccounts must be created.
What to verify
You should now be inside the Partner directory page.
Step 2 - Start Creating the First Subaccount
What to do
Inside the Partner directory, go to Subaccounts.
This opens the subaccount creation screen.
What to verify
You should now see the form for creating a new subaccount.
Step 3 - Enter Data for AM PA Dev Test
What to do
Enter the following values:
Display Name / Name: AM PA Dev Test
Subdomain: btpops####-am-pa-dev-test
Then choose the region:
Cloud Provider: Microsoft Azure
Region: US West (WA)
Environment / Technical Region: cf-us20
After checking all values, click Create.
This creates the development and testing subaccount for the Partner directory.
The important points are:
the subaccount name must match exactly
the subdomain must include your account number in place of ####
the region must be Microsoft Azure US West (WA) cf-us20
What to verify
After creation, you should see the new subaccount:
AM PA Dev Test
Step 4 - Confirm the First Subaccount Exists
What to do
Check the subaccounts list under Partner.
Before creating the production subaccount, confirm that AM PA Dev Test was created successfully, because it will be used as the source subaccount for the next step.
What to verify
You should see:
AM PA Dev Test
If it is not there, do not continue until it is created correctly.
Step 5 - Start Creating the Second Subaccount
What to do
Still inside the Partner directory, click Create Subaccount again.
This opens a new subaccount creation form for the production subaccount.
Step 6 - Enter Data for AM PA Prod
What to do
Display Name / Name: AM PA Prod
Subdomain: btpops####-am-pa-prod
Then set:
Source Subaccount: AM PA Dev Test
Enable the production setting:
Then click Create.
This creates the production subaccount by using AM PA Dev Test as the source subaccount.
Using a source subaccount means SAP BTP copies base settings from the selected source, which helps keep configuration aligned.
The production indicator is mandatory here because this is the production subaccount.
What to verify
AM PA Prod
inside the Partner directory, and it should be marked as a production subaccount.
Final Expected Result for Task 2
Inside the Partner directory, you must have these two subaccounts:
1. AM PA Dev Test
Region: Microsoft Azure US West (WA) cf-us20
2. AM PA Prod
1. Creating the subaccounts in the wrong place
Both subaccounts must be created in:
Partner directory
Not in:
Global Account
Americas
Eurasia
Human Resources
2. Wrong subdomain format
Use exactly:
Replace only #### with your global account number.
Do not:
remove hyphens
add spaces
misspell dev-test or pa-prod
3. Wrong region for AM PA Dev Test
It must be:
Microsoft Azure
US West (WA)
cf-us20
4. Forgetting the source subaccount for AM PA Prod
You must select:
AM PA Dev Test
For AM PA Prod, make sure:
NEW QUESTION # 14
All the C_ADBTP_2601 training files of our company are designed by the experts and professors in the field. The quality of our study materials is guaranteed. According to the actual situation of all customers, we will make the suitable study plan for all customers. If you buy the C_ADBTP_2601 Learning Materials from our company, we can promise that you will get the professional training to help you pass your C_ADBTP_2601 exam easily. By our professional training, you will pass your C_ADBTP_2601 exam and get the related certification in the shortest time.
C_ADBTP_2601 Latest Study Plan: https://www.dumpexam.com/C_ADBTP_2601-valid-torrent.html
SAP C_ADBTP_2601 Exam Price Our total average passing rate for all exams is high up to 98.33%, SAP C_ADBTP_2601 Exam Price Just imagine that when you have the certification, you will have a lot of opportunities to come to the bigger companies and get a higher salary, Believe in our C_ADBTP_2601 study guide, and you will have a brighter future, We provide these C_ADBTP_2601 questions in all three formats since each has useful features of its own.
If the attack is attempted on an internal network, physical access to Certification C_ADBTP_2601 Cost the network will be required, If you'd like to show off your artwork and get feedback, you can share it on the Behance creative network.
Pass Guaranteed Quiz 2026 SAP C_ADBTP_2601 C The Best Exam PriceOur total average passing rate for all exams is high up to 98.33%, Just C_ADBTP_2601 imagine that when you have the certification, you will have a lot of opportunities to come to the bigger companies and get a higher salary.
Secure Payments With 24/7 Support.
- C_ADBTP_2601 Valid Exam Dumps 🍘 C_ADBTP_2601 Latest Dump 🖕 C_ADBTP_2601 Valid Exam Dumps 👬 Open [ [url]www.practicevce.com ] enter C_ADBTP_2601 and obtain a free download 🪕Valid C_ADBTP_2601 Exam Pdf[/url]
- The Best C_ADBTP_2601 Exam Price and First-Grade C_ADBTP_2601 Latest Study Plan - Trusted Certification Administrating SAP Business Technology Platform(C_ADBTP_2601) Book Torrent 💁 Go to website ⮆ [url]www.pdfvce.com ⮄ open and search for ▛ C_ADBTP_2601 ▟ to download for free 🐯C_ADBTP_2601 Latest Dump[/url]
- C_ADBTP_2601 exam torrent pdf - C_ADBTP_2601 latest vce - C_ADBTP_2601 training vce 🟡 Enter ⇛ [url]www.prepawayete.com ⇚ and search for [ C_ADBTP_2601 ] to download for free 🕷New Soft C_ADBTP_2601 Simulations[/url]
- High-quality C_ADBTP_2601 Exam Price, Ensure to pass the C_ADBTP_2601 Exam 🍀 Search for ➥ C_ADBTP_2601 🡄 on [url]www.pdfvce.com immediately to obtain a free download 🤭Exam C_ADBTP_2601 Answers[/url]
- C_ADBTP_2601 Valid Exam Experience 🙁 Latest C_ADBTP_2601 Learning Materials 🏓 C_ADBTP_2601 Certificate Exam 🚾 Open ➡ [url]www.exam4labs.com ️⬅️ enter C_ADBTP_2601 and obtain a free download 💏C_ADBTP_2601 Valid Exam Experience[/url]
- C_ADBTP_2601 Test Papers 🦈 Valid C_ADBTP_2601 Exam Pdf 🧴 Dumps C_ADBTP_2601 Download 🧦 Search for C_ADBTP_2601 and download it for free on [url]www.pdfvce.com website ⚛C_ADBTP_2601 Test Dumps Free[/url]
- The Best C_ADBTP_2601 Exam Price and First-Grade C_ADBTP_2601 Latest Study Plan - Trusted Certification Administrating SAP Business Technology Platform(C_ADBTP_2601) Book Torrent 👛 [url]www.testkingpass.com is best website to obtain ⇛ C_ADBTP_2601 ⇚ for free download 😁C_ADBTP_2601 Test Papers[/url]
- [url=https://mahero.net/?s=New%20Soft%20C_ADBTP_2601%20Simulations%20%f0%9f%98%b4%20C_ADBTP_2601%20Exam%20Duration%20%f0%9f%92%b8%20C_ADBTP_2601%20Exam%20Duration%20%f0%9f%93%9e%20The%20page%20for%20free%20download%20of%20[%20C_ADBTP_2601%20]%20on%20%e2%9e%a4%20www.pdfvce.com%20%e2%ae%98%20will%20open%20immediately%20%f0%9f%a7%98C_ADBTP_2601%20Test%20Dumps%20Free]New Soft C_ADBTP_2601 Simulations 😴 C_ADBTP_2601 Exam Duration 💸 C_ADBTP_2601 Exam Duration 📞 The page for free download of [ C_ADBTP_2601 ] on ➤ www.pdfvce.com ⮘ will open immediately 🧘C_ADBTP_2601 Test Dumps Free[/url]
- Exam C_ADBTP_2601 Answers 🗓 C_ADBTP_2601 Test Papers 🐠 C_ADBTP_2601 Test Papers 👐 Search on ▶ [url]www.validtorrent.com ◀ for C_ADBTP_2601 to obtain exam materials for free download 📯Latest C_ADBTP_2601 Learning Materials[/url]
- C_ADBTP_2601 Exam Price Exam Pass Certify | C_ADBTP_2601 Latest Study Plan 💞 Easily obtain free download of C_ADBTP_2601 by searching on ▶ [url]www.pdfvce.com ◀ 🤟C_ADBTP_2601 Valid Exam Dumps[/url]
- Administrating SAP Business Technology Platform(C_ADBTP_2601) reliable practice torrent - C_ADBTP_2601 exam guide dumps - Administrating SAP Business Technology Platform(C_ADBTP_2601) test training vce 📤 ⏩ [url]www.practicevce.com ⏪ is best website to obtain ➥ C_ADBTP_2601 🡄 for free download 📘Latest C_ADBTP_2601 Learning Materials[/url]
- www.stes.tyc.edu.tw, songtr.ee, www.stes.tyc.edu.tw, github.com, www.thingstogetme.com, lms.bongoonline.xyz, portfolium.com, myskilluniversity.com, learningskill.site, pixabay.com, Disposable vapes
