¡¾Hardware¡¿
JN0-650 - Enterprise Routing and Switching, Professional (JNCIP-ENT)¨CThe Best Pr
Posted at 4/20/2026 00:18:00
View£º131
Replies£º0
DOWNLOAD the newest PassCollection JN0-650 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1BqdOPTlZ5dXCAekUB245LtOZTgRJmlLf
JN0-650 Exam is just a piece of cake if you have prepared for the exam with the helpful of PassCollection's exceptional study material. If you are a novice, begin from JN0-650 study guide and revise your learning with the help of testing engine. JN0-650 Exam brain dumps are another superb offer of PassCollection that is particularly helpful for those who want to the point and the most relevant content to Pass JN0-650 Exam. With all these products, your success is assured with 100% money back guarantee.
Our JN0-650 Exam Braindumps are the hard-won fruit of our experts with their unswerving efforts in designing products and choosing test questions. Pass rate is what we care for preparing for an examination, which is the final goal of our JN0-650 certification guide. According to the feedback of our users, we have the pass rate of 99%, which is equal to 100% in some sense. The high quality of our products also embodies in its short-time learning. You are only supposed to practice Enterprise Routing and Switching, Professional (JNCIP-ENT) guide torrent for about 20 to 30 hours before you are fully equipped to take part in the examination.
Practice JN0-650 Tests - JN0-650 Practice Exam OnlineAs a member of the people working in the JN0-650 industry, do you have a headache for passing some Juniper certification exams? Generally, JN0-650 certification exams are used to test the examinee's related JN0-650 professional knowledge and experience and it is not easy pass these exams. For the examinees who are the first time to participate JN0-650 certification exam, choosing a good pertinent training program is very necessary. PassCollection can offer a specific training program for many examinees participating in Juniper certification exams. Our training program includes simulation test before the formal examination, specific training course and the current exam which has 95% similarity with the real exam. Please add PassCollection to you shopping car quickly.
Juniper Enterprise Routing and Switching, Professional (JNCIP-ENT) Sample Questions (Q25-Q30):NEW QUESTION # 25
When configuring Q-in-Q tunneling, which type of tunneling involves the swapping of S-VLANs with C- VLANs?
- A. L2PT
- B. VLAN rewrites
- C. all-in-one
- D. many-to-many
In a Juniper Q-in-Q (Layer 2 tunneling) environment, VLAN rewrites (specifically the swap operation) provide the most granular control over how customer traffic (C-VLANs) is mapped to service provider traffic (S-VLANs).
* VLAN Rewrites (The Swap Operation): This method involves replacing the incoming customer VLAN tag with a service provider tag as the frame enters the tunnel. This is technically a " swap " because the original C-VLAN tag is removed and the S-VLAN tag is written in its place. At the egress of the tunnel, the S-VLAN tag is swapped back for the original C-VLAN tag. This is often used when different customers use the same C-VLAN IDs and the provider needs to keep them unique within their core.
* Many-to-Many: This is a mapping style where multiple customer VLANs are mapped to multiple service provider VLANs, but it typically relies on the " push " (stacking) operation rather than a literal " swap " of the tag itself.
* All-in-One: This is the simplest form of Q-in-Q where all traffic entering an interface is " pushed " into a single S-VLAN tag, regardless of any existing C-VLAN tags. No swapping occurs; the original tags are simply buried under the new provider tag.
* L2PT (Layer 2 Protocol Tunneling): This is a feature used to tunnel Layer 2 control protocols (like STP, CDP, or LLDP) across a provider network by encapsulating them or changing their destination MAC addresses. It does not involve the swapping of VLAN tags.
NEW QUESTION # 26
Exhibit
You are asked to configure VLAN load balancing on your network using MSTP. Referring to the exhibit, which two statements are correct? (Choose two.)
- A. Switch1 will be the root bridge for msti 2.
- B. Switch1 will assume the role of root bridge for both mstil and msti2 if Switch2 goes down.
- C. Switch 1 will not assume the role of root bridge for both mstil and msti2 if Switch2 goes down.
- D. Switch1 will be the root bridge for msti 1.
The exhibit shows the MSTP configuration for two switches, switch1 and switch2. MSTP allows you to group multiple VLANs into a single Multiple Spanning Tree Instance (MSTI), enabling different root bridges and topologies for different sets of VLANs.
* Root Bridge Election (Option B): For any Spanning Tree instance, the switch with the lowest bridge priority is elected as the root bridge.
* For msti 2, switch1 has a priority of 4k (4096), while switch2 has a priority of 8k (8192).
* Since 4096 < 8192, switch1 is elected the root bridge for msti 2.
* Failover Behavior (Option D): Spanning Tree is designed for redundancy. If a primary root bridge fails, the remaining switches in the network re-elect a new root based on the next lowest priority.
* If switch2 goes down, switch1 becomes the only switch in the region.
* Regardless of its original priority (4k or 8k), switch1 will take over as the root bridge for both msti 1 and msti 2 because there are no other contenders with a better (lower) priority.
* Incorrect Statements: Option A is incorrect because for msti 1, switch2 has the lower priority (4k vs.
8k), making switch2 the root bridge. Option C is incorrect because it contradicts the fundamental high- availability nature of Spanning Tree.
NEW QUESTION # 27
Exhibit.
Referring to the exhibit, which statement is correct?
- A. The OSPF state will be stuck in the 2Nay state
- B. The OSPF state will be stuck in the Exstart state
- C. The device with the highest IP address is elected as the DR.
- D. The device with the lowest IP address is elected as the DR.
In OSPF, the election of aDesignated Router (DR)and aBackup Designated Router (BDR)is mandatory on broadcast and non-broadcast multi-access (NBMA) network types to manage link-state database synchronization efficiently.
The exhibit shows that bothdevice1anddevice2have their OSPF interface priority explicitly set to0. According to the Junos OS 24.4 OSPF implementation:
* Ineligibility (Priority 0):A router with a priority of 0 is strictlyineligibleto be elected as a DR or BDR for that segment.
* No Election Possible:When every router on a broadcast segment has a priority of 0, the election process cannot complete because there are no eligible candidates to fill the required roles.
* State Behavior (Stuck in 2-Way):In OSPF adjacency formation, the2-Way stateindicates that bidirectional communication has been established (each router has seen itself in the other's Hello packets). However, to progress to theExstartandExchangestates on a multi-access network, routers must first identify a DR and BDR.
* Result:Since neither router can become the DR, they both wait indefinitely for a third party (with priority > 0) to take the lead. Consequently, the OSPF adjacency will bestuck in the 2-Way state.
Adjacencies only reach theFullstate with the DR and BDR; routers in a "DROther" role remain in 2- Way with each other.
Option A and Dare incorrect because the router ID (IP address) only acts as a tiebreaker if priorities are equal andgreater than 0.Option Bis incorrect because routers cannot reach the Exstart state (where they negotiate master/slave for database exchange) without first having a DR/BDR elected.
NEW QUESTION # 28
You are implementing an EVPN-VXLAN edge-routed bridging design using Layer 3 gateway operations. In this scenario, which statement is correct?
- A. Each distribution switch has unique IP addresses for IRB interfaces; routing protocols run on IRB interfaces
- B. Distribution switches share the same anycast IP addresses for IRB interfaces; routing occurs at the distribution layer.
- C. Only core switches have IRB interfaces; all Layer 3 routing happens in the core.
- D. IRB interfaces are disabled; all routing happens through external routers only.
In an EVPN-VXLAN Edge-Routed Bridging (ERB) architecture, also known as a collapsed fabric, the Layer
3 default gateway functionality is moved from the core/spine layer down to the edge (the leaf or distribution layer).
Anycast Gateways: To support seamless host mobility and redundancy, multiple distribution/leaf switches are configured with the same anycast IP address and MAC address on their IRB interfaces for a given VLAN.
This allows a host to move between different switches without needing to update its default gateway configuration or ARP cache.
Distributed Routing: Routing occurs locally at the edge (distribution layer). Traffic destined for a different subnet is routed by the first switch it hits (the ingress leaf), rather than being backhauled to a central core router.
Symmetric vs. Asymmetric IRB: Junos OS 24.4 supports both models, but the ERB design typically utilizes symmetric routing for better scalability, where each leaf only needs to know the routes for its locally connected VNIs and uses a transit VNI for inter-subnet communication.
Option A is incorrect because while unique IPs can be used (Method 1 in some docs), the defining characteristic of an efficient ERB design is the use of shared Anycast IPs for the gateway. Option C describes a Centrally-Routed Bridging (CRB) design, not ERB.
NEW QUESTION # 29
According to IETF standards, which two statements are correct about EVPN/VXLAN deployments? (Choose two.)
- A. Up to 16 million EVPN broadcast domains can exist.
- B. Up to 16 million VXLAN broadcast domains can exist.
- C. Layer 2 frames within the same broadcast domain are forwarded unchanged.
- D. IP packets within the same broadcast domain are forwarded unchanged.
The IETF standards for EVPN-VXLAN define the scalability and forwarding behavior of the architecture.
* VXLAN Scale (Statement B):The Virtual Network Identifier (VNI) is a24-bit fieldin the VXLAN header. This allows for up to $2
BTW, DOWNLOAD part of PassCollection JN0-650 dumps from Cloud Storage: https://drive.google.com/open?id=1BqdOPTlZ5dXCAekUB245LtOZTgRJmlLf
