[Hardware] Track Progress With Desktop-Based Nutanix NCP-BC-7.5 Practice Exam Software
17
Hardware Track Progress With Desktop-Based Nutanix NCP-BC-7.5 Practice Exam Software
Posted at 4/20/2026 00:42:32      View140 | Replies0        Print      Only Author   [Copy Link] 1#
We have three versions of NCP-BC-7.5 guide materials available on our test platform, including PDF, Software and APP online. The most popular one is PDF version of our NCP-BC-7.5 exam questions and you can totally enjoy the convenience of this version, and this is mainly because there is a demo in it, therefore help you choose what kind of NCP-BC-7.5 Practice Test are suitable to you and make the right choice. Besides PDF version of NCP-BC-7.5 study materials can be printed into papers so that you are able to write some notes or highlight the emphasis.
We provide online customer service on the NCP-BC-7.5 practice questions to the customers for 24 hours per day and we provide professional personnel to assist the client in the long distance online. If you have any questions and doubts about the NCP-BC-7.5 guide torrent we provide before or after the sale, you can contact us and we will send the customer service and the professional personnel to help you solve your issue about using NCP-BC-7.5 Exam Materials. The client can contact us by sending mails or contact us online. We will solve your problem on NCP-BC-7.5 exam questions until you pass the exam.
NCP-BC-7.5 Training Materials: Nutanix Certified Professional - Business Continuity (NCP-BC) 7.5 & NCP-BC-7.5 Exam PreparatoryIf you want to finish it with minimum efforts, Prep4away Nutanix NCP-BC-7.5 test questions and answers is your best choice. Prep4away Nutanix NCP-BC-7.5 test contains high quality exam dumps. Like the actual test, Prep4away test questions and test answers is of the same standard. Now, the best choice is to choose Prep4away Nutanix NCP-BC-7.5 Certification Training for exam preparation. You must pass at 100%. If you fail, FULL REFUND is allowed.
Nutanix Certified Professional - Business Continuity (NCP-BC) 7.5 Sample Questions (Q111-Q116):NEW QUESTION # 111
A sudden and unrecoverable hardware failure occurs at the primary site, making the Prism Element console for that cluster inaccessible. The secondary site is healthy and contains the latest replicated snapshots. Which action must the administrator take on the secondary cluster to restore the VMs?
  • A. Select the Protection Domain and click Activate.
  • B. Restart the local Cerebro service and wait for the VMs to power on.
  • C. Select the Protection Domain and click Migrate.
  • D. Create a new Protection Domain and import the snapshots.
When a primary Nutanix site suffers a catastrophic failure, the disaster recovery plan must be executed from the recovery (secondary) site . In a legacy Protection Domain-based environment, the secondary site is in a " passive " or " standby " mode, receiving snapshots but not actively running the workloads. The traditional method to failover is using the " Activate " command (Option A), which promotes the PD and registers the VMs. However, in certain specific failure scenarios or older software versions, the secondary cluster may require a service-level reset to recognize its new role as the active master for those specific workloads.
The Cerebro service is the core component responsible for managing Protection Domains and replication metadata. If the primary site is completely inaccessible and the secondary site ' s metadata state needs refreshing to initiate recovery, restarting the Cerebro service on the secondary cluster CVMs can force a re- evaluation of all local snapshots and protection domain states. This action triggers the recovery logic, allowing the administrator to then see and activate the recovery points. While " Activate " is the goal, the first technical step in a situation where the cluster management plane is unstable or the primary is gone is ensuring the data protection services are aware of the current state. This allows the VMs to be restored from the latest snapshots, fulfilling the Recovery Time Objective (RTO) despite the complete loss of the source infrastructure.
NEW QUESTION # 112
An administrator at a retail company is preparing to apply a critical OS security patch to a production SQL Server VM. Before starting, the administrator ensures the VM is part of a Protection Domain and manually creates a local snapshot (Recovery Point). Ten minutes after the patch is applied, the SQL service fails to start, and the database logs indicate corruption in the system registry. The administrator needs to return the VM to its functional state from ten minutes ago as quickly as possible. The administrator decides to perform a Restore from the local snapshot. Under which condition would an In-place Restore (Revert) fail, forcing the administrator to use the Clone (Out-of-place) option instead?
  • A. The VM ' s memory was increased from 16GB to 32GB to accommodate the patch installation.
  • B. NGT (Nutanix Guest Tools) version was updated immediately after the snapshot.
  • C. A new 50GB data disk was added to the VM configuration after the snapshot was taken.
  • D. The VM is currently powered on and cannot be shut down.
An In-place Restore (Revert) is the fastest way to roll back a VM because it overwrites the current vDisks with the data from the snapshot. However, this operation has strict requirements regarding the consistency of the VM ' s hardware configuration. The most common technical blocker for an in-place revert is a change in the disk topology between the time the snapshot was taken and the time of the restore.
If the administrator added a new 50GB data disk (Option D) after taking the snapshot, the VM ' s current configuration now includes a vDisk that does not exist in the snapshot ' s metadata. Nutanix AOS cannot " revert " a disk that has no point-in-time reference in the recovery point. In this situation, the " In-place Restore
" button is typically disabled or will throw an error, forcing the administrator to use the " Clone " (Out-of- place) option. Cloning creates a new VM based exactly on the snapshot ' s metadata, effectively ignoring the newly added disk. While changing memory (Option B) or NGT versions (Option A) might affect performance or guest features, they do not usually prevent the storage-level revert operation. Being forced into a " Clone " restore increases the RTO slightly, as the administrator must then delete the corrupted VM and ensure the new clone has the correct network settings.
NEW QUESTION # 113
An administrator is concerned about the operational overhead of manually creating and managing categories across both the primary and recovery sites to ensure Recovery Plans function correctly during failover and failback. What Nutanix Disaster Recovery behavior minimizes this concern?
  • A. Recovery Plans replicate categories only during an active failover event to minimize replication traffic.
  • B. Categories must be manually replicated using the Prism Central API between sites to ensure consistency.
  • C. Categories are automatically synchronized to the recovery site AZ when they are specified in a Recovery Plan.
  • D. Categories only need to be configured at the recovery site since that is where failover operations are executed.
Nutanix Disaster Recovery (formerly known as Leap) utilizes Prism Central-based " Categories " to group virtual machines for protection. These categories are used within Protection Policies to determine replication schedules and within Recovery Plans to determine power-on sequences and network mappings. A common operational concern is the need to manually replicate these category definitions across different availability zones (AZs).
To reduce this operational overhead, Nutanix has implemented an automatic synchronization mechanism.
When an administrator creates a Recovery Plan in Prism Central and specifies certain categories for failover, the system automatically synchronizes the definition and metadata of those categories to the paired recovery AZ. This ensures that if the primary Prism Central instance becomes unavailable, the recovery site already possesses the necessary grouping logic to identify and recover the correct virtual machines . This " policy- driven " approach ensures consistency across sites and eliminates the risk of human error associated with manual configuration (Option B). By automating the lifecycle of categories between paired sites, Nutanix ensures that the disaster recovery environment is always aligned with the production environment, allowing for seamless failover and failback operations without the need for repetitive administrative tasks.
NEW QUESTION # 114
An administrator performed an unplanned failover from AZ1 (primary) to AZ2 (recovery). Later, AZ1 is restored and the administrator wants to fail back the entities to AZ1. Which two statements are correct?
(Choose two.)
  • A. After unplanned failover, replication begins in the reverse direction, and failback success depends on recovery points being replicated back from AZ2 to AZ1 after failover.
  • B. Failback uses the same recovery plan, but the failover operations for failback must be performed at the primary AZ.
  • C. After unplanned failover, failback success depends on recovery points being created locally on AZ1 before outage.
  • D. Unplanned failover to AZ1 can use recovery points that were created locally in the past at AZ1, even if no recovery points replicate back from AZ2.
Nutanix Disaster Recovery is designed to be bi-directional, supporting both failover and failback . In an unplanned failover, the primary site (AZ1) is assumed to have crashed. Once AZ1 is brought back online, the system must synchronize any data changes that occurred while the VMs were running at AZ2.
Statement C is correct because once the VMs are powered on at AZ2, the Nutanix Cerebro service automatically reverses the protection policy. New recovery points are created at AZ2 and replicated back to AZ1. For a successful, modern failback with zero data loss from the cloud session, the administrator must wait for these recovery points to replicate back to AZ1 before initiating the failback.
Statement B is also correct and describes a specific " recovery of last resort " scenario. If AZ1 is restored but connectivity to AZ2 is permanently lost (e.g., the cloud provider has an issue), an administrator can still " Unplanned Failover " back to AZ1 using the historical snapshots that existed locally on AZ1 before the original outage. This would result in data loss equal to the time the VMs were running at AZ2, but it allows for service restoration when the recovery site itself fails. These two statements highlight the flexibility of the Nutanix DR architecture in handling both controlled failback and emergency local restoration.
NEW QUESTION # 115
An administrator plans to configure Cross Hypervisor Disaster Recovery (CHDR) to replicate VMs from an ESXi cluster to an AHV cluster using an Asynchronous replication schedule. Which component must be installed on the VMs to ensure successful migration and driver configuration during recovery?
  • A. Nutanix Guest Tools (NGT)
  • B. VirtIO Drivers manually installed
  • C. VMware Tools only
  • D. Pre-freeze scripts
Cross-Hypervisor Disaster Recovery (CHDR) allows for the seamless replication and failover of workloads between different hypervisor platforms, such as moving from VMware ESXi to Nutanix AHV. The primary technical challenge in CHDR is ensuring that the virtual machine has the correct storage and network drivers to boot on the new hypervisor. For instance, a VM running on ESXi uses VMware-specific drivers, while AHV requires Nutanix VirtIO drivers.
Nutanix Guest Tools (NGT) is the mandatory component that handles this translation process automatically.
When NGT is installed on a VM running on ESXi, it includes the necessary Nutanix drivers in a dormant state. During a failover to an AHV cluster, the Nutanix orchestration engine uses the NGT hooks to inject and activate these drivers, ensuring the VM can successfully recognize its virtual disks and network adapters upon power-on at the recovery site. Without NGT, the VM would likely suffer a " Blue Screen of Death " (BSOD) on Windows or a kernel panic on Linux due to the missing boot drivers. While manual VirtIO installation (Option A) is possible, NGT provides the integrated orchestration required for a reliable, automated BCDR workflow, making it the essential component for CHDR success.
NEW QUESTION # 116
Everybody wants success, but not everyone has a strong mind to persevere in study. If you feel unsatisfied with your present status, our NCP-BC-7.5 actual exam can help you out. Our products always boast a pass rate as high as 99%. Using our NCP-BC-7.5 study materials can also save your time in the exam preparation. If you choose our NCP-BC-7.5 Practice Engine, you are going to get the certification easily. Just make your choice and purchase our NCP-BC-7.5 training quiz and start your study now!
Accurate NCP-BC-7.5 Study Material: https://www.prep4away.com/Nutanix-certification/braindumps.NCP-BC-7.5.ete.file.html
Here, NCP-BC-7.5 study dumps are really worthwhile for your preparation, In order to keep your job, choose our NCP-BC-7.5 exam questions and let yourself become an irreplaceable figure, Our NCP-BC-7.5 study braindumps are designed in the aim of making the study experience more interesting and joyful, I believe that no one can know the NCP-BC-7.5 exam questions better than them.
Cloud computing represents a major change in how we store information and run applications, If you select a forward lookup zone, the Zone Name page appears, Here, NCP-BC-7.5 Study Dumps are really worthwhile for your preparation.
Why Prep4away Is One Of The Best Platform To Prepare For Nutanix NCP-BC-7.5 Exam?In order to keep your job, choose our NCP-BC-7.5 exam questions and let yourself become an irreplaceable figure, Our NCP-BC-7.5 study braindumps are designed in the aim of making the study experience more interesting and joyful.
I believe that no one can know the NCP-BC-7.5 exam questions better than them, It's not that we take money, give you the product and it ends there.
