[General] Fortinet FCP_FMG_AD-7.6 Valid Test Sims | New FCP_FMG_AD-7.6 Braindumps Question
22
General Fortinet FCP_FMG_AD-7.6 Valid Test Sims | New FCP_FMG_AD-7.6 Braindumps Question
Posted at 4/20/2026 03:12:34      View162 | Replies0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Real4test FCP_FMG_AD-7.6 dumps for free: https://drive.google.com/open?id=1FK1lGxH22j349G9pWffNj0kN4GqlhS7r
You may feel astonished and doubtful about this figure; but we do make our FCP_FMG_AD-7.6 exam dumps well received by most customers. Better still, the 98-99% pass rate of FCP_FMG_AD-7.6 exam questions has helped most of the candidates get the certification successfully, which is far beyond that of others in this field. In recent years, supported by our professional expert team, our FCP_FMG_AD-7.6 Test Braindumps have grown up and have made huge progress. You can totally rely on our FCP_FMG_AD-7.6 learning material for your future learning path.
This is the online version of the FCP - FortiManager 7.6 Administrator (FCP_FMG_AD-7.6) practice test software. It is also very useful for situations where you have free time to access the internet and study. Our web-based FCP - FortiManager 7.6 Administrator (FCP_FMG_AD-7.6) practice exam is your best option to evaluate yourself, overcome mistakes, and pass the Fortinet FCP_FMG_AD-7.6 Exam on the first try. You will see the difference in your preparation after going through FCP_FMG_AD-7.6 practice exams.
New FCP_FMG_AD-7.6 Braindumps Questions | FCP_FMG_AD-7.6 Test QuestionWhen you prepare for Fortinet FCP_FMG_AD-7.6 certification exam, it is unfavorable to blindly study exam-related knowledge. There is a knack to pass the exam. If you make use of good tools to help you, it not only can save your much more time and also can make you sail through FCP_FMG_AD-7.6 test with ease. If you want to ask what tool it is, that is, of course Real4test Fortinet FCP_FMG_AD-7.6 exam dumps.
Fortinet FCP - FortiManager 7.6 Administrator Sample Questions (Q47-Q52):NEW QUESTION # 47
What allows FortiManager to run CLI scripts on FortiGate devices without prompting for SSH authentication each time?
  • A. The script using the Remote FortiGate Directly via CLI option.
  • B. The script on the FortiManager device database.
  • C. The secure management tunnel between FortiManager and FortiGate devices.
  • D. FortiGate devices using the legacy login method.
The correct answer is B . The FortiManager 7.6 Administrator Study Guide explicitly states: "CLI scripts use the FGFM tunnel and the FGFM tunnel is authenticated using the FortiManager and FortiGate serial numbers." It also states: "Tcl scripts do not run through the FGFM tunnel like CLI scripts do. Tcl scripts use SSH to tunnel through FGFM and they require SSH authentication to do so." This is the exact reason CLI scripts can run without prompting for SSH authentication every time: they use the existing secure FGFM management tunnel , not a separate interactive SSH login. The FGFM section of the study guide also confirms that this is a secure communication tunnel established between FortiManager and managed FortiGate devices.
So the enabler is not legacy login, script location, or the "Remote FortiGate Directly" option by itself. It is the FGFM secure management tunnel .
NEW QUESTION # 48
FortiManager is operating behind a network address translation (NAT) device, and the administrator configured the FortiManager NATed IP address under the FortiManager system administration settings.
What is the expected result during discovery?
  • A. FortiManager sets both the 100.65.0.120 IP address and 100.65.0.101 IP address on FortiGate.
  • B. FortiManager sets the 100.65.0.101 IP address on FortiGate.
  • C. FortiManager sets the 100.65.0.120 IP address on FortiGate.
  • D. FortiManager sets both the 100.65.0.120 IP address and 10.0.13.120 IP address on FortiGate.
When FortiManager is behind a NAT device, setting the NATed IP address (100.65.0.120) in the system admin settings causes FortiManager to use that NATed IP address for communication and configuration with FortiGate during discovery and management operations.
NEW QUESTION # 49
Refer to the exhibits. Which IP/netmask will be present in the LAN firewall address object on the Remote-Firewall?
  • A. 172.16.0.0/255.255.255.0
  • B. 172.16.10.0/255.255.255.0
  • C. 10.0.0.0/255.255.255.0
  • D. 192.168.1.0/255.255.255.0
In FortiManager, the "Per-Device Mapping" section allows for overriding the default object value for specific devices. The Remote-Firewall is not listed in the Per-Device Mapping table.
Therefore, it will use the default value defined in the top portion of the address object, which is
10.0.0.0/255.255.255.0.
NEW QUESTION # 50
What can you conclude from the failed installation log shown in the exhibit?
  • A. Policy ID 2 is installed without a source address.
  • B. Policy ID 2 is installed in the disabled state.
  • C. Policy ID 2 will not be installed.
  • D. Policy ID 2 is installed without the remote user student.
The correct answer is D . The lab guide explains that when an installation fails, the installation log shows the commands that the managed device received and accepted, as well as the commands that the managed device did not accept .
From the exhibit, FortiGate accepted the policy creation commands for policy ID 2 such as set srcintf port3, set dstintf port1, set srcaddr all, set dstaddr all, set action accept, and set schedule always. However, the line set users student failed with "entry not found in datasource" and "value parse error before ' student ' " .
That shows the user reference was not accepted, while the rest of the policy commands were processed.
Therefore, policy ID 2 is still created, but without the remote user student . This rules out A , B , and C .
NEW QUESTION # 51
A service provider administrator has assigned a global policy package to a managed customer ADOM named My_ADOM. The customer administrator has access only to My_ADOM.
How can the customer administrator edit the global header policy of the global policy package?
  • A. The customer administrator can edit the header policy by using workspace mode on the global ADOM.
  • B. The service provider administrator can unlock the global policy from the global ADOM to authorize changes to the customer administrator.
  • C. The customer administrator cannot edit the global header policy; only the service provider administrator can make changes from the global ADOM.
  • D. The customer administrator can edit the header policy by using workflow mode on the global ADOM and My_ADOM.
The global policy package is managed only from the global ADOM by the service provider administrator.
Customer administrators with access solely to their ADOM (My_ADOM) cannot edit the global header policy; such changes must be made by the service provider administrator in the global ADOM.
NEW QUESTION # 52
For the challenging Fortinet FCP_FMG_AD-7.6 exam, they make an effort to locate reputable and recent Fortinet FCP_FMG_AD-7.6 practice questions. The high anxiety and demanding workload the candidate must face being qualified for the Fortinet FCP_FMG_AD-7.6 Certification are more difficult than only passing the Fortinet FCP_FMG_AD-7.6 exam.
New FCP_FMG_AD-7.6 Braindumps Questions: https://www.real4test.com/FCP_FMG_AD-7.6_real-exam.html
We have one year service warranty after you purchase our FCP_FMG_AD-7.6 Exam Collection, The updated pattern of Fortinet FCP_FMG_AD-7.6 practice test ensures that customers don't face any real issues while preparing for the test, Real4test FCP_FMG_AD-7.6 practice test questions answers are the best option to secure your success in just one go, So far, the FCP_FMG_AD-7.6 practice materials have almost covered all the official test of useful materials, before our products on the Internet, all the study materials are subject to rigorous expert review, so you do not have to worry about quality problems of our latest FCP_FMG_AD-7.6 exam dump, focus on the review pass the qualification exam.
On the surface, use cases appear to be a straightforward FCP_FMG_AD-7.6 and simple concept, I have worked for three software startups that were considered Software Engineering firms.
We have one year service warranty after you purchase our FCP_FMG_AD-7.6 Exam Collection, The updated pattern of Fortinet FCP_FMG_AD-7.6 practice test ensures that customers don't face any real issues while preparing for the test.
2026 Fortinet Realistic FCP_FMG_AD-7.6 Valid Test Sims Free PDF QuizReal4test FCP_FMG_AD-7.6 practice test questions answers are the best option to secure your success in just one go, So far, the FCP_FMG_AD-7.6 practice materials have almost covered all the official test of useful materials, before our products on the Internet, all the study materials are subject to rigorous expert review, so you do not have to worry about quality problems of our latest FCP_FMG_AD-7.6 exam dump, focus on the review pass the qualification exam.
The best service will be waiting for you.
P.S. Free & New FCP_FMG_AD-7.6 dumps are available on Google Drive shared by Real4test: https://drive.google.com/open?id=1FK1lGxH22j349G9pWffNj0kN4GqlhS7r
