[General] Valid SC-401 Test Objectives & Exam SC-401 Questions Pdf
30
General Valid SC-401 Test Objectives & Exam SC-401 Questions Pdf
Posted at 4/20/2026 03:50:51      View144 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free & New SC-401 dumps are available on Google Drive shared by PracticeDump: https://drive.google.com/open?id=11t5szghd4p0MezFup1iglDKHwVxuTlRQ
The SC-401 learning materials are of high quality, mainly reflected in the adoption rate. As for our SC-401 exam question, we guaranteed a higher passing rate than that of other agency. More importantly, we will promptly update our SC-401 quiz torrent based on the progress of the letter and send it to you. 99% of people who use our SC-401 Quiz torrent has passed the exam and successfully obtained their certificates, which undoubtedly show that the passing rate of our SC-401 exam question is 99%. So our SC-401 study guide is a good choice for you.
PracticeDump delivers up to date SC-401 exam products and modify them time to time. Latest SC-401 exam questions are assembled in our practice test modernizes your way of learning and replaces the burdensome preparation techniques with flexible learning. We accord you an actual exam environment simulated through our practice test sessions that proves beneficial for SC-401 Exams preparation. Our SC-401 practice tests provide you knowledge and confidence simultaneously. Candidates who run across the extensive search, PracticeDump products are the remedy for their worries. Once you have chosen for our SC-401 practice test products, no more resources are required for exam preparation.
Exam SC-401 Questions Pdf - SC-401 Test Pass4sureOur Administering Information Security in Microsoft 365 test torrent boost 99% passing rate and high hit rate so you can have a high probability to pass the exam. Our SC-401 study torrent is compiled by experts and approved by the experienced professionals and the questions and answers are chosen elaborately according to the syllabus and the latest development conditions in the theory and the practice and based on the real exam. If you buy our Administering Information Security in Microsoft 365 test torrent you only need 1-2 hours to learn and prepare the exam and focus your main attention on your most important thing.
Microsoft Administering Information Security in Microsoft 365 Sample Questions (Q172-Q177):NEW QUESTION # 172
You have a Microsoft 365 subscription that contains a sensitivity label named Contoso Confidential.
You publish Contoso Confidential to all users.
Contoso Confidential is configured as shown in the Configuration exhibit. (Click the Configuration tab.)
The Access control settings of Contoso Confidential are configured as shown in the Access control exhibit.
(Click the Access control tab.)
Step 1 - Review the configuration
Sensitivity label name: Contoso Confidential
Scope: Files and emails
Access control:
Encrypts documents/emails.
Permissions assigned to AuthenticatedUsers with Co-Author rights.
Offline access allowed only for 7 days.
Auto-labeling = None (not configured).
Content marking: Footer applied.
Step 2 - Analyze each statement
Statement 1: If a user account is disabled, the user will be immediately prevented from opening a file protected by Contoso Confidential.
Sensitivity labels with encryption enforce Azure AD authentication every time a user tries to access a file.
If the account is disabled in Azure AD, access is blocked immediately.
Statement 2: Guest users will be able to open documents protected by Contoso Confidential.
Access control was configured only for AuthenticatedUsers (internal users).
Guest or external users are not included in this group.
Therefore, guest users cannot open the protected documents.
Statement 3: Contoso Confidential will be applied automatically to the files stored in Microsoft SharePoint Online.
Auto-labeling for files and emails = None.
That means labeling must be applied manually by users, not automatically.
The  answer:  No
Final Verified Answers
If a user account is disabled, the user will be immediately prevented from opening a file protected by Contoso Confidential # Yes Guest users will be able to open documents protected by Contoso Confidential # No Contoso Confidential will be applied automatically to the files stored in Microsoft SharePoint Online # No
NEW QUESTION # 173
You have a Microsoft 365 E5 subscription that contains the adaptive scopes shown in the following table.
You create the retention policies shown in the following table.
Which retention policies support a preservation lock?
  • A. RPolicy1, RPolicy2, and RPolicy3
  • B. RPolicy2only
  • C. RPolicy1 and RPolicy3 only
  • D. RPolicy1 and RPolicy2 only
  • E. RPolicy3on1y
Answer: E
Step 1 - Review of Preservation Lock
* Preservation Lock in Microsoft 365 retention policies ensures that once a policy is locked, no one (including administrators) can turn it off, delete it, or make it less restrictive.
* Preservation Lock is only available for static retention policies and not supported for adaptive scopes.
# Reference: Preservation Lock in Microsoft 365 retention policies
From Microsoft docs:
"Preservation Lock can only be applied to retention policies configured with static scopes. Adaptive scopes do not currently support Preservation Lock." Step 2 - Analyzing the Case Data
* RPolicy1 # Adaptive scope (Scope1: Users). # Not eligible for Preservation Lock.
* RPolicy2 # Adaptive scope (Scope2: SharePoint Online sites). # Not eligible for Preservation Lock.
* RPolicy3 # Static scope (Microsoft 365 groups). # Eligible for Preservation Lock.
Step 3 - Conclusion
Only RPolicy3 qualifies for Preservation Lock.
NEW QUESTION # 174
You have a Microsoft 365 E5 subscription that uses Microsoft Purview.
You need to deploy a compliance solution that will detect the accidental oversharing of information outside of an organization.
The solution must minimize administrative effort.
What should you use? To answer, select the appropriate options in the answer area.
NEW QUESTION # 175
Hotspot Question
You need to perform a content search for email messages that meet the following requirements:
- Are delivered to both user1@contoso.com and user2@contoso.com
- Are sent from a user account that has a name that starts with the
word Compliance
How should you complete the query in the KQL editor? To answer, select the appropriate options in the answer area.
Box 1: "User1@contoso.com AND User2@contoso.com"
Delivered to both, so we must use AND.
Note:
A space between two keywords or two property:value expressions is the same as using OR. For example, from:"Sara Davis" subject:reorganization returns all messages sent by Sara Davis or messages that contain the word reorganization in the subject line.
Box 2: "Compliance*"
https://learn.microsoft.com/en-u ... d-search-conditions
NEW QUESTION # 176
You implement Microsoft 36S Endpoint data loss pi event ion (Endpoint DIP).
You have computers that run Windows 11 and have Microsoft 365 Apps instated The computers are joined to a Microsoft Entra tenant.
You need to ensure that Endpoint DIP policies can protect content on the computers.
Solution: You onboard the computers to Microsoft Defender for Endpoint Does this meet the goal?
  • A. No
  • B. Yes
NEW QUESTION # 177
Long time learning might makes your attention wondering but our effective SC-401 study materials help you learn more in limited time with concentrated mind. Just visualize the feeling of achieving success by using our SC-401 exam guide,so you can easily understand the importance of choosing a high quality and accuracy SC-401 training engine. You will have handsome salary get higher chance of winning and separate the average from a long distance and so on.
Exam SC-401 Questions Pdf: https://www.practicedump.com/SC-401_actualtests.html
In the future, our SC-401 Exam Answers study materials will become the top selling products, Purchase our SC-401 book torrent, PracticeDump SC-401 exam cram is acceptable for some candidates who are ready to attend exams but have no confidence in passing SC-401 exams, If you buy our SC-401 training quiz, you will find three different versions are available on our test platform, Since it is the web-based SC-401 practice exam, you can take it from Opera, Chrome, Safari, Firefox, or any other popular browser.
How do I purchase the products, Expanding the Databases tree displays the tables, views, and stored procedures of each data source, In the future, our SC-401 Exam Answers study materials will become the top selling products.
Pass Guaranteed 2026 Microsoft Useful SC-401: Valid Administering Information Security in Microsoft 365 Test ObjectivesPurchase our SC-401 book torrent, PracticeDump SC-401 exam cram is acceptable for some candidates who are ready to attend exams but have no confidence in passing SC-401 exams.
P.S. Free 2026 Microsoft SC-401 dumps are available on Google Drive shared by PracticeDump: https://drive.google.com/open?id=11t5szghd4p0MezFup1iglDKHwVxuTlRQ
