Hardware
Three User-Friendly Formats of Dumpcollection Pegasystems PEGACPRSA22V1 Updated
Posted at 4/20/2026 04:29:35
View129
Replies0
BONUS!!! Download part of Dumpcollection PEGACPRSA22V1 dumps for free: https://drive.google.com/open?id=1hpomoz5eq5i-jgOqL4N47WNy5AYPDQvK
How to get a good job? If you are a freshman, a good educational background and some useful qualifications certification will make you outstanding. If you are dreaming for obtaining a IT certificate, our PEGACPRSA22V1 test dumps pdf will help you clear exam easily. If you are a working man, a valid certification will make you obtain an advantage over others while facing job promotion competition. Our PEGACPRSA22V1 Test Dumps Pdf can help you clear exam and obtain exam at the first attempt.
Candidates who want to take the PEGACPRSA22V1 Certification Exam must meet certain prerequisites. They must have completed the Pega Robotics System Architect Essentials course and have at least six months of experience working with Pega Robotics. They must also have a good understanding of RPA concepts and be familiar with the Pega platform.
Pegasystems Realistic PEGACPRSA22V1 Exams Torrent - Certified Pega Robotics System Architect 22 Training Solutions 100% Pass QuizThese Pegasystems PEGACPRSA22V1 exam questions have a high chance of coming in the actual PEGACPRSA22V1 test. You have to memorize these PEGACPRSA22V1 questions and you will pass the Pegasystems PEGACPRSA22V1 test with brilliant results. The price of Pegasystems PEGACPRSA22V1 updated exam dumps is affordable.
Pegasystems PEGACPRSA22V1: Certified Pega Robotics System Architect 22 exam is the certification exam for individuals who want to become Certified Pega Robotics System Architects. Certified Pega Robotics System Architect 22 certification exam will test a candidate's knowledge, skills, and abilities in the use of Pega Robotics System Architect to design and develop intelligent automation solutions.
Pegasystems Certified Pega Robotics System Architect 22 Sample Questions (Q89-Q94):NEW QUESTION # 89
When interrogating a single-page web application, you need to create a container for the logical page view.
You decide to use the Select Element in the Interrogation Steps list, move the options to the Ordered Interrogation Steps column and place them in the correct order.
When interrogating a single-page web application (SPA), controls often reside within dynamic DOM regions or logical page views that reload content without changing the page URL.
To effectively interrogate such controls, developers must create containers that define a logical grouping for the dynamic content-allowing Pega Robot Studio to maintain proper context when referencing those controls.
According to the Pega Robotics System Design and Implementation Guide, section "Interrogating Single- Page Web Applications":
"When interrogating single-page web applications (SPA), developers must first create a container that represents the logical view within which controls exist.
* Navigate to the page or view where the target control appears.
* In the Interrogation Form, select Select Element to enable control selection mode.
* Use the Bullseye tool to highlight and select the control or parent HTML element.
* From the list of detected controls, choose the desired control to bind.
* Click Create Container to define the logical page grouping for the interrogated control.
* Click Close to exit the dialog once the container has been successfully created." Detailed Step Reasoning:
* Navigate to the view that contains the control.
* Ensures that the desired control is visible within the web application's dynamic content area.
* On the Interrogation Form, select the Select Element interrogation option.
* Activates the Select Element mode, allowing you to interrogate web-based elements precisely.
* Drag and drop the bullseye icon to the control.
* Highlights the specific control in the web application that you want to interrogate.
* Select the control from the list.
* Confirms which element to bind from the list of detected elements in the DOM.
* Click Create Container.
* Creates a container object in the automation hierarchy that represents the logical view of the web application (essential for SPAs).
* Click Close to close the dialog box.
* Completes the interrogation process and finalizes the container creation.
Final Ordered Steps:
Order
Interrogation Step
1
2
3
4
5
6
Reference:Extracted and verified from Pega Robotics System Design and Implementation Guide, Interrogating Single-Page Applications and Creating Logical Containers section (Pega Robotics 19.1 and later).
NEW QUESTION # 90
In a Java application, you click a button to load a grid. The grid loads as a separate process under the Java application.
Which property allows you to interrogate the grid?
- A. TargetPath
- B. HookChildProcesses
- C. EnableMatchInProcess
- D. IgnoreMainBrowser
Comprehensive and Detailed Explanation From Pega Robotics System Exact Extract:
In Pega Robot Studio, when interrogating Java applications, sometimes a child process is created separately from the main application process. In such cases, controls in the child process cannot be detected unless the adapter is configured to attach to child processes as well.
According to the Pega Robotics System Design and Implementation Guide, in the section "Java Application Integration and Child Processes":
"For Java applications that spawn additional processes, set the HookChildProcesses property of the adapter to True.
This enables the adapter to attach to both the main process and any child processes created by the parent application, allowing interrogation and automation of controls within those secondary windows." Detailed Reasoning:
* HookChildProcesses ensures that when a Java application spawns a new process (such as a popup or a grid), Pega Robotics attaches to and monitors that process.
* Without enabling this property, the adapter would only recognize the primary Java process, leaving controls in secondary processes unrecognized.
Option Analysis:
* A. HookChildProcesses: Correct. Allows interrogation of child processes.
* B. EnableMatchInProcess: Incorrect. Used for controlling object matching within the same process context.
* C. TargetPath: Incorrect. Defines executable location for adapters.
* D. IgnoreMainBrowser: Incorrect. Related to web adapters, not Java applications.
Reference:Extracted and verified from Pega Robotics System Design and Implementation Guide, Java Adapter Configuration and HookChildProcesses Property section (Pega Robotics 19.1 and later).
NEW QUESTION # 91
Which three of the following characterize automatic step creation? (Choose Three)
- A. Displays a blue Gear icon.
- B. Automatically available for applications that X-ray Vision supports.
- C. Automatically used for applications that X-ray Vision does not support.
- D. Usable at any time by clicking the Gear icon.
- E. Available for previously interrogated application controls.
Answer: A,B,E
Automatic Step Creation is a Pega Robot Studio feature that allows developers to automatically generate automation steps based on actions performed in an interrogated application. It leverages X-ray Vision for supported applications to intelligently detect UI elements and generate corresponding steps without requiring manual drag-and-drop logic creation.
According to the Pega Robotics System Design and Implementation Guide, section "Using Automatic Step Creation and X-ray Vision":
"Automatic Step Creation simplifies automation building by detecting user interactions in X-ray Vision- supported applications and automatically adding the equivalent automation steps to the design surface.
* A blue gear icon indicates that automatic step creation is active and available.
* Automatic step creation works with previously interrogated application controls.
* The feature is automatically available for applications that X-ray Vision supports.
* For applications not supported by X-ray Vision, developers must manually create steps using traditional interrogation." Detailed Reasoning:
* B. Displays a blue Gear icon.
* Correct. When automatic step creation is active, the blue gear icon indicates the feature is enabled and ready to record actions.
* D. Available for previously interrogated application controls.
* Correct. Automatic step creation can only generate steps for controls that have already been interrogated, ensuring proper mapping between actions and UI elements.
* E. Automatically available for applications that X-ray Vision supports.
* Correct. The feature activates automatically in X-ray Vision-supported applications, which include modern UI frameworks like HTML5 and WPF.
Incorrect Options:
* A. Automatically used for applications that X-ray Vision does not support.
* Incorrect. It only works for applications supported by X-ray Vision.
* C. Usable at any time by clicking the Gear icon.
* Incorrect. The gear icon appears only when automatic step creation is available, not universally across all projects.
Final Correct answer: B, D, E
Reference:Extracted and verified from Pega Robotics System Design and Implementation Guide, Automatic Step Creation and X-ray Vision Integration section (Pega Robotics 19.1 and later).
NEW QUESTION # 92
Runtime produces an error when debugging a solution. The error message references that a control does not have the necessary value to complete an activity. The control depends upon the completion of a second activity in another project to provide its value.
Which two debugging options provide a benefit when referencing threads for issue resolution? (Choose two.)
- A. Dissert a log file for propagating data
- B. Use the Automation Playback
- C. Add studio execution log entries
- D. Insert Try and Catch components to an automation
NEW QUESTION # 93
You are deploying a robotic project to Pega Robot Manager. Which file stores the Pega Robot Manager server settings?
- A. PegaStudioConfig.xml
- B. PegaRuntimeConfig.xml
- C. PegaConfig.xml
- D. CommonConfig.xml
When deploying robotic solutions to Pega Robot Manager, the connection and authentication details - such as Robot Manager server URL, authentication mode, and registration configuration - are stored in the file CommonConfig.xml.
This configuration file is shared between both Pega Robot Studio and Pega Robot Runtime, ensuring that both use consistent connectivity settings.
According to the Pega Robotics System Design and Implementation Guide, section " ega Robot Manager Integration and Configuration Files":
"The CommonConfig.xml file contains shared configuration information that is used by both Pega Robot Studio and Pega Robot Runtime.
It includes global settings such as:
* Connection information for Pega Robot Manager (URL, ports, authentication)
* Deployment configuration values
* Environment registration and runtime connectivity settings.
PegaRuntimeConfig.xml and PegaStudioConfig.xml are used for local settings only, while CommonConfig.xml stores the Robot Manager connection configuration used during deployment." Detailed Reasoning:
* A. PegaStudioConfig.xml - Used for developer-specific configuration within Robot Studio, not for deployment or server settings.
* B. CommonConfig.xml - Correct. This file contains the Robot Manager connectivity configuration and shared settings.
* C. PegaRuntimeConfig.xml - Controls runtime behavior on client machines, not Robot Manager connections.
* D. PegaConfig.xml - Not a valid configuration file in Pega Robotics.
Reference:Extracted and verified from Pega Robotics System Design and Implementation Guide, Pega Robot Manager Configuration and CommonConfig.xml Overview section (Pega Robotics 19.1 and later).
NEW QUESTION # 94
PEGACPRSA22V1 Training Solutions: https://www.dumpcollection.com/PEGACPRSA22V1_braindumps.html
- PEGACPRSA22V1 Exams Torrent - High Pass-Rate Pegasystems Certified Pega Robotics System Architect 22 - PEGACPRSA22V1 Training Solutions ☔ Search for ➽ PEGACPRSA22V1 🢪 on ➡ [url]www.examcollectionpass.com ️⬅️ immediately to obtain a free download ☀Valid PEGACPRSA22V1 Test Forum[/url]
- Free PDF 2026 PEGACPRSA22V1: Pass-Sure Certified Pega Robotics System Architect 22 Exams Torrent 🥋 Search for [ PEGACPRSA22V1 ] and easily obtain a free download on ⇛ [url]www.pdfvce.com ⇚ ⚫
EGACPRSA22V1 Exam PDF[/url] - Get Exam Ready with Real Pegasystems PEGACPRSA22V1 Questions 💧 Search for ▛ PEGACPRSA22V1 ▟ and download it for free immediately on [ [url]www.prepawayexam.com ] 🎌Exam PEGACPRSA22V1 Topics[/url]
- Pass The Exam On Your First Try With Pegasystems PEGACPRSA22V1 Exam Dumps 📒 Easily obtain ▛ PEGACPRSA22V1 ▟ for free download through ▶ [url]www.pdfvce.com ◀ 🏁
EGACPRSA22V1 Useful Dumps[/url] - Get Reliable PEGACPRSA22V1 Exams Torrent and Pass Exam in First Attempt 🚈 Go to website ➡ [url]www.troytecdumps.com ️⬅️ open and search for ▷ PEGACPRSA22V1 ◁ to download for free ⛷Reliable PEGACPRSA22V1 Exam Online[/url]
- Pass The Exam On Your First Try With Pegasystems PEGACPRSA22V1 Exam Dumps 👘 Search for ⮆ PEGACPRSA22V1 ⮄ and obtain a free download on ✔ [url]www.pdfvce.com ️✔️ 🎈New Braindumps PEGACPRSA22V1 Book[/url]
- Get Exam Ready with Real Pegasystems PEGACPRSA22V1 Questions 🦀 Easily obtain PEGACPRSA22V1 for free download through ➠ [url]www.pdfdumps.com 🠰 🍐
EGACPRSA22V1 Valid Exam Tips[/url] - Free PDF 2026 PEGACPRSA22V1: Pass-Sure Certified Pega Robotics System Architect 22 Exams Torrent 🚮 Search for ➠ PEGACPRSA22V1 🠰 and easily obtain a free download on ➥ [url]www.pdfvce.com 🡄 🦗
EGACPRSA22V1 Exam PDF[/url] - Get Reliable PEGACPRSA22V1 Exams Torrent and Pass Exam in First Attempt 🎬 The page for free download of ➽ PEGACPRSA22V1 🢪 on ✔ [url]www.examdiscuss.com ️✔️ will open immediately 🚙Reliable PEGACPRSA22V1 Exam Online[/url]
- PEGACPRSA22V1 Useful Dumps 📢 Pdf PEGACPRSA22V1 Braindumps 🧁 PEGACPRSA22V1 Practice Test Pdf 🌸 Search for ⮆ PEGACPRSA22V1 ⮄ and obtain a free download on ▶ [url]www.pdfvce.com ◀ ↩
EGACPRSA22V1 Learning Engine[/url] - Valid PEGACPRSA22V1 Test Book 📻 PEGACPRSA22V1 Test Duration 😲 Exam PEGACPRSA22V1 Topics 🔲 Download PEGACPRSA22V1 for free by simply entering [url]www.vceengine.com website 🚹
EGACPRSA22V1 Learning Engine[/url] - myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, ycs.instructure.com, github.com, www.notebook.ai, www.stes.tyc.edu.tw, paperboyclubacademy.com, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, Disposable vapes
P.S. Free 2026 Pegasystems PEGACPRSA22V1 dumps are available on Google Drive shared by Dumpcollection: https://drive.google.com/open?id=1hpomoz5eq5i-jgOqL4N47WNy5AYPDQvK
