[General] NSE6_SDW_AD-7.6 Training Materials Give You an Excellent Guide Dump to Master Mo
30
General NSE6_SDW_AD-7.6 Training Materials Give You an Excellent Guide Dump to Master Mo
Posted at 4/20/2026 04:44:16      View151 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Fortinet NSE6_SDW_AD-7.6 dumps are available on Google Drive shared by ActualVCE: https://drive.google.com/open?id=1ZrJiUwSxCwsCY0XTgDOuUviN6CYZku4s
The web-based Fortinet NSE 6 - SD-WAN 7.6 Enterprise Administrator (NSE6_SDW_AD-7.6) practice exam is accessible from any major OS. These Fortinet NSE6_SDW_AD-7.6 exam questions are browser-based, so there's no need to install anything on your computer. Chrome, IE, Firefox, and Opera all support this Fortinet NSE 6 - SD-WAN 7.6 Enterprise Administrator (NSE6_SDW_AD-7.6) web-based practice exam. You can take this Fortinet NSE 6 - SD-WAN 7.6 Enterprise Administrator (NSE6_SDW_AD-7.6) practice exam without plugins and software installation.
But there are question is that how you can pass the NSE6_SDW_AD-7.6 exam and get a certificate. The best answer is to download and learn our NSE6_SDW_AD-7.6 quiz torrent. Our products will help you get what you want in a short time. You just need little time to download and install it after you purchase, then you just need spend about 20~30 hours to learn it. We are glad that you are going to spare your precious time to have a look to our NSE6_SDW_AD-7.6 Exam Guide.
NSE6_SDW_AD-7.6 Best Practice | Valid NSE6_SDW_AD-7.6 Test PrepThe supremacy of ActualVCE in the tech sector solely relies on its competency to offer its users updated and real NSE6_SDW_AD-7.6 exam dumps. Our dedicated team takes feedback from experts all around the world to update its NSE6_SDW_AD-7.6 actual dumps. This practice material will make your preparation for the Fortinet NSE6_SDW_AD-7.6 examination super easy and effective.
Fortinet NSE 6 - SD-WAN 7.6 Enterprise Administrator Sample Questions (Q17-Q22):NEW QUESTION # 17
Which statement best describe the role of the ADVPN device in handling traffic?
  • A. This is a spoke that has received a shortcut query from a remote hub.
  • B. This is a spoke that has received a direct shortcut query from a remote spoke.
  • C. This is a hub, and two spokes, 192.2.0.1 and 10.0.3.101, establish a shortcut.
  • D. This is a hub that has received a shortcut query from a spoke and has forwarded it to another spoke.
The log shows messages on HUB1-VPN1 where the device processes a SHORTCUT_QUERY and performs NAT hole punching (peer at 192.2.0.1:4500). This indicates that the device is acting as a hub, helping two spokes (192.2.0.1 and 10.0.3.101) establish a direct ADVPN shortcut tunnel between each other, instead of routing their traffic through the hub.
NEW QUESTION # 18
(Refer to the exhibits.
You collected the output shown in the exhibits and want to know which interface HTTP traffic will flow through from the user device 10.0.1.101 to the corporate web server 10.0.0.126. All SD-WAN links are stable.
Which interface will FortiGate use to steer the traffic? Choose one answer.)
  • A. Only HUB1-VPN2
  • B. Either HUB1-VPN2 or HUB1-VPN3
  • C. Either HUB1-VPN1, HUB1-VPN2, or HUB1-VPN3
  • D. Only HUB1-VPN3
From the SD-WAN service configuration, rule edit 3 (name "Corp") is configured with:
* set mode sla
* set load-balance enable
* set dst "Corp-net"
* set src "LAN-net"
* SLA checks referenced under config sla
Traffic from 10.0.1.101 to 10.0.0.126 matches this rule because the destination is within the corporate network range (shown in the policy-route/proute output as destination 10.0.0.0-10.255.255.255 for the Corp service).
In the diagnose firewall proute list output for vwl_service=3 (Corp), FortiGate shows which SD-WAN members are eligible based on SLA pass results:
* oif=21 (HUB1-VPN3) num_pass=2
* oif=20 (HUB1-VPN2) num_pass=0
* oif=19 (HUB1-VPN1) num_pass=0
This indicates that, for the SLA-based rule, only HUB1-VPN3 is meeting the SLA requirements (it is the only member with num_pass=2). The other members have num_pass=0, so they are not eligible for forwarding under this SLA rule even though links are up.
The sniffer trace further corroborates the forwarding decision by showing the traffic egressing through HUB1-VPN3.
Therefore, FortiGate will steer the HTTP traffic through only HUB1-VPN3, which corresponds to Option A.
NEW QUESTION # 19
The FortiGate devices are managed by ForliManager, and are configured for direct internet access (DIA). You confirm that DIA is working as expected for each branch, and check the SD-WAN zone configuration and firewall policies shown in the exhibits.
Then, you use the SD-WAN overlay template to configure the IPsec overlay tunnels. You create the associated SD-WAN rules to connect existing branches to the company hub device and apply the changes on the branches.
After those changes, users complain that they lost internet access. DIA is no longer working.
Based on the exhibit, which statement best describes the possible root cause of this issue?
  • A. The SD-WAN overlay template redefines the interface gateway addresses if they are defined with metadata variables.
  • B. The SD-WAN overlay template updates the SD-WAN template and the rules.
  • C. The SD-WAN overlay template defines a zone for each underlay interface and moves the interfaces into those zones.
  • D. The SD-WAN overlay template didn't configure a firewall policy to allow traffic through the overlay.
The SD-WAN overlay template defines a zone for each underlay interface and moves the interfaces into those zones. This statement perfectly describes the likely sequence of events. The template, when applied, re- organizes the interfaces and zones, causing the existing firewall policy that relies on the old zone configuration to fail. This is the most plausible root cause.
NEW QUESTION # 20
The exhibits show an SD-WAN event log, the member status, and the SD-WAN rule configuration.
Which two conclusions can you draw from the information shown? (Choose two.)
  • A. The administrator configured the SD-WAN rule ID 1 with the default strategy mode.
  • B. Port2 has a lower latency than port1.
  • C. The administrator configured the service ID 1 with the highest priority member for port2.
  • D. FortiGate updated the outgoing interface list on the rule so it prefers port2.
The SD-WAN rule (config service edit 1) is configured with set mode priority. This means the rule selects the best interface based on a defined performance metric, as opposed to a simple static priority or SLA. The event log (image_41cfb5.png) shows Metric latency and Message Service prioritized by performance metric will be redirected in sequence order. This indicates that the rule is using latency to determine the preferred member.
Given that the log message is about a change, and the most logical reason for a change in a priority mode is that a different member is now the best performer, it implies that the latency on port2 has become lower than that on port1.
The log message Service prioritized by performance metric will be redirected in sequence order confirms that FortiGate is changing the member being used for this service. Because the mode is priority, FortiGate dynamically selects the member that currently meets the best performance criteria, which in this case is latency. The log implies a new member has been selected as the most optimal, and with the default configuration, the members are sorted based on their performance, so the outgoing interface list is effectively updated to prefer the new best-performing member (port2).
NEW QUESTION # 21
The exhibits show the SD-WAN zone configuration of an SD-WAN template prepared on FortiManager and the policy package configuration.
When the administrator tries to install the configuration changes, FortiManager fails to commit.
What should the administrator do to fix the issue?
  • A. Configure a normalized interface for the IPsec tunnel HUB1-VPN1.
  • B. Configure HUB1 as the destination of policy 3.
  • C. Configure both HUB1-VPN1 and HUB1-VPN2 as the destination of policy 3
  • D. Configure branch1_fgt as the installation target for policy 3.
Policy 3 points traffic To = HUB1-VPN1, which is an SD-WAN member interface. In SD-WAN you must reference the SD-WAN zone (the logical interface) in policies, not its member tunnels. Change the policy's To interface to the zone HUB1, and the install will succeed.
NEW QUESTION # 22
The users can instantly access the product after purchasing it from ActualVCE NSE6_SDW_AD-7.6, so they don't have to wait to prepare for the Fortinet NSE6_SDW_AD-7.6 Exams. The 24/7 support system is available for the customers, so they can contact the support whenever they face any issue, and it will provide them with the solution. Furthermore, ActualVCE offers up to 1 year of free updates and free demos of the product.
NSE6_SDW_AD-7.6 Best Practice: https://www.actualvce.com/Fortinet/NSE6_SDW_AD-7.6-valid-vce-dumps.html
NSE6_SDW_AD-7.6 exam prep look forward to meeting you, It is well acknowledged that people who have been qualified by the NSE6_SDW_AD-7.6 exam certification, they must have a fantastic advantage over other people to get good grade in the exam, By getting this NSE6_SDW_AD-7.6 dumps for Fortinet certification exam guide you will get Fortinet NSE 6 - SD-WAN 7.6 Enterprise Administrator test study material, By exploring the easiest way of passing the NSE6_SDW_AD-7.6 quiz torrent, we determined to figure out how to help customers master the knowledge in limited time, there are a group of specialists have been researched the most useful knowledge of NSE6_SDW_AD-7.6 pass-sure materials all the time, and they have been dedicated in this area for over ten years.
Joseph Muniz is an architect at Cisco Systems and security researcher, NSE6_SDW_AD-7.6 Alongside this is the concept of influence, which is the ability to get other people to perform tasks on your behalf.
Fortinet NSE6_SDW_AD-7.6 Test Torrent: Fortinet NSE 6 - SD-WAN 7.6 Enterprise Administrator - ActualVCE Try Free and Buy EasilyNSE6_SDW_AD-7.6 Exam Prep look forward to meeting you, It is well acknowledged that people who have been qualified by the NSE6_SDW_AD-7.6 exam certification, they must have a fantastic advantage over other people to get good grade in the exam.
When you face the NSE6_SDW_AD-7.6 actual exam, you must be no-mind and don't know what to do next.
P.S. Free & New NSE6_SDW_AD-7.6 dumps are available on Google Drive shared by ActualVCE: https://drive.google.com/open?id=1ZrJiUwSxCwsCY0XTgDOuUviN6CYZku4s
