[Hardware] Simulated PT-AM-CPE Test & Latest PT-AM-CPE Dumps Ppt
26
Hardware Simulated PT-AM-CPE Test & Latest PT-AM-CPE Dumps Ppt
Posted at 4/20/2026 05:46:27      View158 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Ping Identity PT-AM-CPE dumps are available on Google Drive shared by Itcertking: https://drive.google.com/open?id=1dCAMPJG5sA56ZhSWsJ-JW-3wBn_jansr
Many people dream about occupying a prominent position in the society and being successful in their career and social circle. Thus owning a valuable certificate is of paramount importance to them and passing the test PT-AM-CPE certification can help them realize their goals. If you are one of them buying our PT-AM-CPE Exam Prep will help you pass the PT-AM-CPE exam successfully and easily. Our PT-AM-CPE guide torrent provides free download and tryout before the purchase and our purchase procedures are safe.
Ping Identity PT-AM-CPE Exam Syllabus Topics:
  • Federating Across Entities Using SAML2: This domain covers implementing single sign-on using SAML v2.0 and delegating authentication responsibilities between SAML2 entities.
  • Enhancing Intelligent Access: This domain covers implementing authentication mechanisms, using PingGateway to protect websites, and establishing access control policies for resources.
  • Improving Access Management Security: This domain focuses on strengthening authentication security, implementing context-aware authentication experiences, and establishing continuous risk monitoring throughout user sessions.
  • Extending Services Using OAuth2-Based Protocols: This domain addresses integrating applications with OAuth 2.0 and OpenID Connect, securing OAuth2 clients with mutual TLS and proof-of-possession, transforming OAuth2 tokens, and implementing social authentication.
Topic 5
  • Installing and Deploying AM: This domain encompasses installing and upgrading PingAM, hardening security configurations, setting up clustered environments, and deploying PingOne Advanced Identity Platform to the cloud.
2026 PT-AM-CPE C 100% Free Simulated Test | Excellent Latest Certified Professional - PingAM Exam Dumps PptOur PT-AM-CPE preparation exam is compiled specially for it with all contents like exam questions and answers from the real PT-AM-CPE exam. If you make up your mind of our PT-AM-CPE exam prep, we will serve many benefits like failing the first time attached with full refund service, protecting your interests against any kinds of loss. In a word, you have nothing to worry about with our PT-AM-CPE Study Guide.
Ping Identity Certified Professional - PingAM Exam Sample Questions (Q56-Q61):NEW QUESTION # 56
Which authentication node can you use in PingAM to add a key:value property to the user's session after successful authentication?
  • A. The Get Session Data node
  • B. You have to use a webhook, not a node
  • C. The Provision Dynamic Account node
  • D. The Set Session Properties node
In PingAM 8.0.2 Intelligent Access, the Set Session Properties node is a specialized utility node designed to modify the session object once it is created.
According to the "Authentication Node Reference":
During an authentication journey, data is typically stored in the sharedState. However, sharedState is transient and is destroyed once the tree finishes. If an administrator wants to take a piece of information (e.g., a "Risk Score" calculated during the tree, or a "Branch ID" retrieved from a legacy system) and make it a permanent part of the user's session, they must use the Set Session Properties node.
Functionality: This node allows you to map a value from the sharedState or transientState to a session property name. After the tree reaches a Success node, these properties are persisted in the session (either in the CTS for server-side sessions or the JWT for client-side sessions).
Usage: Once set, these properties can be retrieved later for Response Attributes in policies, or by applications using the /json/sessions endpoint.
Option A (Get Session Data node) is used to retrieve existing properties from an active session, not set them. Option B is incorrect because while webhooks can trigger external logic, the native way to modify the session within a tree is a node. Option C (Provision Dynamic Account node) is for creating user entries in the Identity Store (LDAP), not for managing session-level properties. Therefore, Set Session Properties (Option D) is the correct technical tool for this requirement in version 8.0.2.
NEW QUESTION # 57
In a default PingAM configuration, what type of keystore stores the secret ID named storepass, which contains the encrypted password of the default-keystore secret store?
  • A. Environment and system property secret store
  • B. Keystore secret store
  • C. Filesystem secret store
  • D. Hardware Security Module secret store
In PingAM 8.0.2, the management of sensitive data such as passwords and cryptographic keys is handled through a unified Secret Store framework. This framework abstracts the source of the secret from the component that consumes it using Secret IDs. One of the most critical secret IDs in a standard installation is storepass.
The storepass secret ID is specifically used by the default-keystore (which is typically a "Keystore secret store" pointing to keystore.jks or keystore.p12). Before AM can access the keys within the default-keystore to sign tokens or encrypt data, it must first unlock the keystore itself using the password mapped to the storepass secret ID.
According to the PingAM "Secrets, certificates, and keys" documentation, in a default file-based configuration, PingAM initializes a Filesystem secret store as its primary global store. This store is configured to look into a specific directory within the AM configuration path (usually .../openam/secrets/). Inside this directory, AM expects to find files named after the secret IDs they contain. For the storepass ID, there is typically a corresponding file (such as storepass or .storepass) containing the cleartext or encrypted password required to open the primary keystore.
While AM can be configured to use an Environment and system property secret store (Option B) for high-portability cloud deployments, the "out-of-the-box" default behavior during a standard installation relies on the filesystem. Option A is incorrect because the storepass is the key to the keystore, not a secret inside it, and Option D refers to specialized hardware integrations not used in a default software-only setup. Therefore, the Filesystem secret store is the correct technical answer for the default location of the storepass.
NEW QUESTION # 58
When defining a policy and specifying a resource pattern, which of the following statements is true concerning the difference between the wildcards * and -*-?
  • A. The wildcard * will match query parameters, whereas -*- will not match query parameters.
  • B. The wildcard * will match multiple levels in a path, whereas -*- will match only a single level
  • C. Neither the * wildcard nor the -*- wildcard can be used to match the port number
  • D. The wildcard * and the wildcard -*- can be mixed liberally within the same pattern
When configuring Authorization Policies in PingAM 8.0.2, defining the Resource Pattern is critical for determining which URLs the policy applies to. PingAM uses specific wildcard symbols to represent dynamic parts of a URI, but they behave differently regarding directory depth.
According to the PingAM documentation on "olicies and Resource Types":
The * Wildcard (One-Level Wildcard): This wildcard matches characters within a single path level. It does not match forward slashes (/). For example, http://example.com/* will match http://example.com/page1 but will not match http://example.com/folder/page1.
The -*- Wildcard (Multi-Level Wildcard): This wildcard is designed to match any number of characters, including forward slashes (/), effectively spanning multiple levels of a directory hierarchy. For example, http://example.com/-*- will match http://example.com/page1, http://example.com/folder/page1, and even http://example.com/deeply/nested/resource.
Statement B is the correct technical distinction. Statement A is incorrect because query parameters are typically handled by specifically enabling "Query Parameter Matching" in the Resource Type configuration, rather than being a primary distinction between these two wildcards. Statement C is technically discouraged because mixing them can lead to unpredictable or overly broad matches that are difficult to debug. Statement D is incorrect because wildcards can be used in the host/port portion of the URL if the resource type is configured to support it. Understanding the difference between single-level (*) and multi-level (-*-) matching is a fundamental skill for AM policy administrators to prevent security gaps.
NEW QUESTION # 59
Which authentication node checks and validates a recovery code used during a multi-factor authentication challenge sequence?
  • A. Recovery Code Display node
  • B. Recovery Code Verifier node
  • C. Recovery Code Collector Decision node
  • D. Recovery Code Comparator node
NEW QUESTION # 60
Which of the following are existing script types in PingAM?
A) Decision node script for authentication trees
B) End User user interface theme script
C) OpenID Connect claims script
D) Policy condition script
  • A. A, B and D
  • B. A, C and D
  • C. B, C and D
  • D. A, B and C
PingAM 8.0.2 is highly extensible through its Scripting Engine, which supports Groovy and JavaScript. However, scripts can only be applied to specific "hooks" or "extension points" defined by the platform.
According to the "Scripting" and "Script Types" reference in the PingAM 8.0.2 documentation, the standard supported script types are:
Decision node script (A): Used within Authentication Trees via the "Scripted Decision Node." These scripts allow for complex logic, such as checking user attributes, calling external APIs, or evaluating risk before deciding which path a user should take in their journey.
OpenID Connect claims script (C): This script type is used to customize the claims returned in OIDC ID Tokens or at the UserInfo endpoint. It allows administrators to transform internal LDAP attributes into the specific JSON format required by OIDC clients.
Policy condition script (D): Used within Authorization Policies. These scripts define custom logic for granting or denying access (e.g., "Allow access only if the user is connecting from a specific IP range and it is between 9 AM and 5 PM").
Why Statement B is incorrect: There is no such thing as an "End User user interface theme script" in the PingAM scripting engine. UI customization (Themeing) in PingAM 8.0.2 is handled through the XUI framework using CSS, HTML templates, and configuration JSON files, or by building a custom UI using the Ping SDKs. It does not use the server-side Groovy/JavaScript scripting engine that governs authentication and authorization logic. Therefore, the valid script types are A, C, and D, making Option D the correct choice.
NEW QUESTION # 61
The Certified Professional - PingAM Exam (PT-AM-CPE) PDF format, desktop practice test software, and web-based practice test software, all three formats of actual exam questions are ready for quick download. You just need to pay the affordable Ping Identity PT-AM-CPE Exam Questions charges and click on the download button. Get them now and start Certified Professional - PingAM Exam (PT-AM-CPE) exam preparation today.
Latest PT-AM-CPE Dumps Ppt: https://www.itcertking.com/PT-AM-CPE_exam.html
BONUS!!! Download part of Itcertking PT-AM-CPE dumps for free: https://drive.google.com/open?id=1dCAMPJG5sA56ZhSWsJ-JW-3wBn_jansr
